Hi there - newbie here to the forums.
Picked up a hex-v2 VCDS scanner in an attempt to diagnose my son's 2009 A4 2.0T quattro.
We've had a recurring issue with a p2404 problem, and finally punted to the dealer to fix. The dealer was convinced it was the wiring for the leak detection pump (corroded) and the leak detection pump itself.
Dealer repaired the wiring and replaced the LDP. About 3 days later the p2404 came back, this time the dealer diagnosed and replaced the charcoal canister, said it was full of fuel.
About 3 days later, the p2404 came back. When I called to complain, the service manager assured me there were many components that could go wrong in the EVAP system on this car, and they'd be happy to continue to work on it, just more money and time! So here I am.
Unfortunately, after reading the code with my simple reader, I cleared it out and it hasn't come back yet (3 days ago). I got the VCDS in the mail the other day, so had a change to pull a complete auto scan from the car 2 days ago (attached).
This auto-scan doesn't have the issue showing up yet because the EVAP readiness flag hasn't been set in the ECU yet, it seems.
I've been searching the forums to get an idea of what's next to check - seems there is quite a lot of info on different models, but I suspect many of the diagnostic steps are similar.
I ordered a 3-day subscription to erwin, really only needed 1 day (30 minutes would have been fine probably). I also ordered an online manual on CD from Bentley publishing, but it only runs under WindowsXP (needed to fire up a virtual machine for that).
Found this info on the p2404 code:
http://wiki.ross-tech.com/wiki/index.php/18836/P2404/009220
Anything else I need to look at at this point, before I can run another full auto-scan for this problem? Worth testing the N80? It looks like a major PITA to replace this without taking off the intake manifold.
Thank you!
-Matt
Full auto-scan here (not showing p2404 issue yet):
Thank you!
-Matt
Saturday,31,August,2019,18:29:28:64242
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WAULF78K39N062404 License Plate:
Mileage: 182240km-113238mi Repair Order:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 02 03 05 08 09 15 16 17 19 42 46 47 52 53 56 62 65 72
VIN: WAULF78K39N062404 Mileage: 182240km-113238miles
Address 01: Engine (DL0MA-CAEB) Labels:| 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 AL HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H14 0001
Revision: E1H14---
Coding: 0104010A190F0160
Shop #: WSC 06133 444 122352
ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001
ROD: EV_ECM20TFS0118K2907115AL.rod
VCID: 79AFED4BF956FDEF8D7-802C
Readiness: 0000 0101
Address 02: Auto Trans (J217) Labels:| 0B6-927-156.clb
Part No SW: 8K0 927 158 C HW: 0B6 927 156
Component: 0B6 20TFSIUSA H04 0050
Revision: --H04---
Coding: 001002
Shop #: WSC 02145 785 00200
ASAM Dataset: EV_TCMAL651 A01004
ROD: EV_TCMAL651.rod
VCID: 3635267788C8D297205-8062
Part No SW: 8K0 907 379 AF HW: 8K0 907 379 AF
Component: ESP8 quattro H04 0210
Coding: 150500
Shop #: WSC 02391 823 56573
VCID: 7DA7F95BEDFEC1CFA1F-8028
Part No SW: 8K0 907 064 F HW: 8K0 907 064 F
Component: BCM2 1.1 H80 0145
Coding: 090100
Shop #: WSC 02399 823 56573
VCID: 33331F639B3AC7BF07B-8066
Subsystem 1 - Part No SW: 8T0 959 754 A HW: 8T0 959 754 A
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0509000004863008
Component: ELVAUDIB8 H36 0041
Serial number: 0208000113912014
Part No SW: 8T1 820 043 AA HW: 8T1 820 043 AA
Component: KLIMA 1 ZONE H06 0150
Revision: A1000000 Serial number: 01090220090941
Coding: 64002000
VCID: 70B9D06FAAACBCA73A9-8024
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Component: BCM1 1.0 H22 0253
Revision: 05022001 Serial number: 00000000310293
Coding: 690000B1063C00010000080300007F5F0F14520800000001000000
VCID: 3039106F6A2CFCA77A9-8064
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 230109 H06 0070
Serial number: SWF09010236757
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 941 531 T HW: 8K0 941 531 T
Component: E1 - LDS H07 0080
Serial number: 00000000002901091977
Address 15: Airbags (J234) Labels:* 8K0-959-655.clb
Part No SW: 8K0 959 655 F HW: 8K0 959 655 F
Component: AirbagVW-AU10 H27 0410
Serial number: 0039KD14UMGW
Coding: 303836354230303030304A55304C384B3053
Shop #: WSC 02135 785 00200
VCID: 40D940AFDA0C6C278A9-8014
Subsystem 1 - Part No SW: 8K0 959 339 B HW: 8K0 959 339 B
Component: BF-Gewichtss. H01 0030
Serial number: 5810000R0900003H3T
Serial number: 6334MSME457170052
Serial number: 6344MSME4572410A7
Serial number: 6352QSME762317069
Serial number: 6362QSME42170A226
Serial number: 63732SME1B221D22X
Serial number: 63832SME11162512J
Component: Lenks.Modul H15 0013
Revision: -------- Serial number: 90304IB60001U
Coding: 000014
VCID: 3D27395BAD7E01CFE1F-8068
Component: E221 - MFL H02 0003
Part No SW: 8K0 920 950 A HW: 8K0 920 950 A
Component: KOMBIINSTR. H18 0224
Revision: 00000000 Serial number: 9DR11T229
Coding: 831209000304D705020000
VCID: 2D07091B7D1E914F51F-8078
Part No SW: 8T0 907 468 M HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0095
Revision: GB300043 Serial number: 4300G0913000B5
Coding: 000303
VCID: 4BC36783E3CABF7F6FB-801E
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
Serial number: 190623E8150109
Part No SW: 8K0 959 793 D HW: 8K0 959 793 D
Component: TSG FA H11 0250
Revision: Serial number: 0000008399442
Coding: 011C03204000410001
VCID: 41DF45ABD186652F857-8014
Revision: 00002001 Serial number: 0116980748
Coding: 0106063A007A000400B001
Component: LIN BACKUP HO H03 1301
Subsystem 2 - Part No SW: 8K0 959 591 HW: 8K0 959 591
Component: J245 PS034 H06 0037
Address 47: Sound System (J525) Labels:. 8T0-035-223-ASC.clb
Part No SW: 8T0 035 223 AB HW: 8T0 035 223
Component: DSP STD H07 0220
Revision: S2100000
Coding: 0203010101
VCID: 6E85CE17B098AA57285-803A
00417 - Left Front DSP Mid-Bass Speaker (R101)
Reset counter: 87
Mileage: 181784 km
Date: 2019.08.13
Time: 16:47:55
Voltage: 12.50 V
Temperature: 39.0°C
Bin. Bits: 00000000
00418 - Front Right DSP Mid-Bass Speaker (R102)
Reset counter: 87
Mileage: 181784 km
Date: 2019.08.13
Time: 16:47:55
Voltage: 12.50 V
Temperature: 39.0°C
Bin. Bits: 00000000
Part No SW: 8K0 959 792 D HW: 8K0 959 792 D
Component: TSG BF H11 0250
Revision: Serial number: 0000008365904
VCID: 40D940AFDA8C6C278A9-8014
Part No SW: 8K0 907 801 G HW: 8K0 907 801 G
Component: EPB Audi B8 H08 0080
Revision: 00000003 Serial number: 00000000307010
Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 186 R HW: 8T1 035 186 R
Component: Con3 Sirius H01 0301
Revision: 00000003 Serial number: AUZ5Z6I1177073
Coding: 05020000010105004119070000
VCID: 46D556B7F8A84217B05-8012
Subsystem 1 - Part No SW: 8T0 919 603 A HW: 8T0 919 603 A
Component: Display
Reset counter: 33
Mileage: 181784 km
Date: 2019.08.13
Time: 16:36:28
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 N HW: 8K0 959 795 C
Component: TSG HL H10 0251
Revision: Serial number: 0000100697844
Coding: 010C03204000210001
VCID: 44D14CBFCE947007AE1-8010
Address 65: Tire Pressure (J502) Labels: 8K0-907-273.clb
Part No SW: 8K0 907 273 A HW: 8K0 907 273 A
Component: J502-RDK H03 0250
Revision: 00001001 Serial number: 13140790109164
Coding: 0CD154
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H10 0251
Revision: Serial number: 0000100697834
End----------(Elapsed Time: 01:22, VBatt start/end: 12.2V/12.2V)-----------
