Results 1 to 4 of 4
Thread: 2009 Vw Golf gti Mk5 ( no ignition lights, no start, no ecu comunication )
Hybrid View
    Ecuador
    Hi, I have a 2009 Vw golf gti year 2009, the car dont start, I make a key in on but I dont have ignition lights in the cluster, the lights, radio, etc working, I dont have comunicacion with the ecm, this is the auto scan
    Saturday,31,August,2019,15:53:40:14592
    VCDS Version: 19.6.1.0 (x64)
    VIN: WVWZZZ1KZ9W141278   License Plate:
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56
    VIN: WVWZZZ1KZ9W141278   Mileage: 62680km-38947miles
    Address 01: Engine
    Address 02: Auto Trans
    Address 03: ABS Brakes
       Part No SW: 1K0 907 044 DE    HW: 1K0 907 044 DE
       Component: ClimatronicPQ35 130 1213
       Revision: 00130023    Serial number: 00000000000000
       VCID: 6DD1F00D74A8FE2742-8038
    7 Faults Found:
    00538 - Reference Voltage
                002 - Lower Limit Exceeded
    01273 - Fresh Air Blower (V2)
                007 - Short to Ground
                009 - Open or Short to Ground
    01316 - ABS Control Module
       Revision: 00H54000    Serial number: 00000008950425
       Coding: E78F8F2700041500471400001400000000097F075C000100000000000000
       VCID: 33652675520C68D754-8066
       Component: Wischer 081008 021  0501
       Coding: 00038805
       Shop #: WSC 01357
       Component: RLS     131008 054  0402
       Coding: 00209069
       Shop #: WSC 01357
    00834 - Signal for Activation of Heated Rear Window
                        Fault Status: 00101001
                        Reset counter: 234
                        Mileage: 62683 km
                        Voltage: 12.80 V
    00924 - Relay for Headlamp Cleaning System (J39)
                        Reset counter: 234
                        Mileage: 62683 km
                        Voltage: 12.80 V
    02403 - Terminal 15 for Interior
                        Fault Status: 01101100
                        Reset counter: 194
                        Mileage: 62683 km
                        Voltage: 12.95 V
                        Reset counter: 194
                        Mileage: 62683 km
                        Voltage: 12.90 V
                        Reset counter: 194
                        Mileage: 62683 km
                        Voltage: 12.90 V
                        Reset counter: 194
                        Mileage: 62683 km
                        Voltage: 12.90 V
    Address 15: Airbags
       Part No SW: 1K0 953 549 BG    HW: 1K0 953 549 BG
       Component: J0527           057 0101
       Coding: 0012102
       VCID: 78FFD1590BEA4B8FA1-802C
    00576 - Terminal 15
    00002 - Transmission Control Unit
    01426 - Controls in Steering Wheel (E221)
       Part No SW: 1K6 920 874     HW: 1K6 920 874
       Component: KOMBIINSTRUMENT VDD 2416
       Revision: V0002000    Serial number: VWX7Z0H83NT8CD
       Coding: 0004103
       VCID: 70EFE979639A13CF69-8024
       Component: J533  Gateway   H07 5063
       Revision:   H07 01    Serial number: 021008F2000160
       Coding: ED811F060002020000
       VCID: 3561186D5C7876E77A-8060
       Component: IMMO            VDD 2416
       Component: Tuer-SG         006 1207
       Coding: 0000052
       VCID: 387F11594B6A8B8F61-806C
    Address 44: Steering Assist
       Coding: 819002085103087F2D04840570084A06F0BC00
       VCID: 0305B6B5422C185784-8056
                        Reset counter: 194
    00625 - Vehicle Speed Signal
                        Reset counter: 194
                        Mileage: 62683 km
                        Time: 22:27:24
       Coding: 0000052
       VCID: 3979145D706092879E-806C
    Address 55: Headlight Range
       Part No SW: 3C8 035 195     HW: 3C8 035 195
       Component: Radio RCD510  040 0166
       Revision: 00000001    Serial number: VWZ1Z3K6401310
       Coding: 0100040004
       Shop #: WSC 00020 790 00000
       VCID: 65C1882D6C58C6670A-8030
                        Reset counter: 194
                        Mileage: 62543 km
                        Time: 07:40:58
    End-------------------------(Elapsed Time: 01:50)--------------------------
    Looks like the everything on the powertrain CAN is not talking, but strangely enough, there's no fault for that bus in the Gateway, so I'm not sure what to make of this.
    Ecuador
    Thanks Uwe, I have one question,it is possible that the problem may be a BCM? or ignition switch?
    What do you think
    thanks
    Ecuador
    Hi, I ahve news, I have ignition lights in the cluster, I found a problem in the BCM, , I start a engine, but the EPC light is on and the car dont work , I dont have Volt in electronic components, any idea abou that
    thanks
    Wednesday,04,September,2019,13:15:12:14592
    08-Auto HVAC -- Status: Malfunction 1010
    09-Cent. Elect. -- Status: Malfunction 1010
    15-Airbags -- Status: Malfunction 1010
       Part No SW: 1K0 907 115 R    HW: 8P0 907 115 B
       Revision: 5BH16---    Serial number: VWX7Z0H83NT8CD
       Coding: 040300101C070060
    7 Faults Found:
    008852 - Fuel Pressure Regulator Valve (N276)
                   P2294 - 004 - Open Circuit - Intermittent
                        Mileage: 62683 km
                        Time: 22:05:09
                        RPM: 760 /min
                        Load: 20.0 %
                        Temperature: 53.0C
                        Temperature: 34.0C
                        Absolute Pres.: 730.0 mbar
                        Voltage: 13.716 V
    012423 - Voltage Supply Relay for Engine Components
                   P3087 - 004 - Electrical Malfunction
                        Mileage: 62683 km
                        Time: 22:05:09
                        RPM: 760 /min
                        Load: 20.0 %
                        Temperature: 53.0C
                        Temperature: 34.0C
                        Voltage: 13.716 V
    001092 - EVAP Purge Control Valve (N80)
                   P0444 - 004 - Circuit Open
                        Mileage: 62683 km
                        Time: 22:05:09
                        RPM: 737 /min
                        Load: 20.0 %
                        Temperature: 53.0C
                        Temperature: 34.0C
                        Voltage: 13.589 V
    000051 - Turbocharger Bypass Valve Control Circuit
                   P0033 - 004 - Malfunction / Open Circuit
                        Mileage: 62683 km
                        Time: 22:05:09
                        RPM: 737 /min
                        Load: 20.0 %
                        Temperature: 53.0C
                        Temperature: 34.0C
                        Voltage: 13.589 V
    000579 - Solenoid Valve  for Boost Pressure Control (N75)
                   P0243 - 004 - Malfunction
                        Mileage: 62683 km
                        Time: 22:05:09
                        RPM: 737 /min
                        Load: 20.0 %
                        Temperature: 53.0C
                        Temperature: 34.0C
                        Voltage: 13.589 V
    009728 - Coolant Pump Control Circuit
                   P2600 - 004 - Open
                        Mileage: 62683 km
                        Time: 22:05:09
                        RPM: 737 /min
                        Load: 20.0 %
                        Temperature: 53.0C
                        Temperature: 34.0C
                        Voltage: 13.589 V
    000048 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
                   P0030 - 004 - Malfunction / Open Circuit
                        Mileage: 62683 km
                        Time: 22:05:19
                        RPM: 772 /min
                        Load: 20.0 %
                        Temperature: 53.0C
                        Temperature: 34.0C
                        Voltage: 13.843 V
    Readiness: 0000 0101
       Part No SW: 02E 300 051 C    HW: 02E 927 770 AJ
       Component: GSG DSG AG6     431 1817
       Revision: 04843012    Serial number: 00000807111279
       VCID: 132586F5324C88D734-8046
       Part No SW: 1K0 907 379 AP    HW: 1K0 907 379 AP
       Component: ESP MK60EC1   H45 0107
       Revision: 00H45001
       Coding: 143B600D092600FB280D06EB90210041B500
       Shop #: WSC 11149 003 1048576
       VCID: 000FB9B9933A034F99-8054
    7 Faults Found:
                013 - Check DTC Memory
       Coding: 00038805
       Shop #: WSC 01357
       Coding: 00209069
       Shop #: WSC 01357
    10 Faults Found:
    00156 - Control Circuit for Windshield Washer Pump
                        Reset counter: 234
                        Voltage: 5.00 V
    02398 - Control Circuit for Rear Windshield Washer Pump
                        Reset counter: 234
                        Voltage: 5.00 V
    00906 - Horn (H1)
                        Reset counter: 234
                        Voltage: 5.00 V
                        Reset counter: 234
                        Voltage: 5.00 V
    01800 - Light Switch (E1)
                008 - Implausible Signal
                        Fault Status: 01101000
                        Reset counter: 194
                        Mileage: 62683 km
                        Voltage: 12.20 V
    01516 - Terminal 30; Left
                        Fault Status: 00101011
                        Reset counter: 234
                        Voltage: 5.00 V
                        Fault Status: 00101100
                        Reset counter: 234
                        Voltage: 5.00 V
    02389 - Release Signal Transmission; Position P/N
                        Reset counter: 234
                        Mileage: 62683 km
                        Voltage: 12.25 V
    00926 - Terminal 30
                        Reset counter: 234
                        Voltage: 5.00 V
    00918 - Terminal 31
                        Reset counter: 234
                        Voltage: 5.00 V
       Component: 39 AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 0038PD28A4XK
       Coding: 0013113
       VCID: 3D71004D6448AEA7B2-8068
       Subsystem 1 - Serial number: 6332MSME41134432-
       Subsystem 2 - Serial number: 6342MSME4020391B2
       Subsystem 3 - Serial number: 6352QSME680B0D18O
       Subsystem 4 - Serial number: 6362QSME6007312EB
       Coding: 0012102
       Coding: 0004103
                        Reset counter: 234
                        Mileage: 62683 km
                        Time: 21:27:01
                        Reset counter: 234
                        Mileage: 62683 km
                        Time: 21:49:08
                        Fault Status: 00110100
                        Reset counter: 234
                        Mileage: 62683 km
                        Time: 21:27:02
                        Reset counter: 234
                        Mileage: 62683 km
                        Time: 21:49:09
                        Reset counter: 234
                        Mileage: 62683 km
                        Time: 21:26:17
       Coding: 0000052
       Part No: 1K1 909 144 M
       Component: EPS_ZFLS Kl.074 H08 1901
       Shop #: WSC 00000 028 00001
                        Fault Status: 01101101
                        Reset counter: 194
                        Reset counter: 234
                        Mileage: 62683 km
                        Time: 21:49:08
       Coding: 0000052
       Part No: 1T0 907 357
       Coding: 0000003
       VCID: 74E7E56917822FEF8D-8020
       Coding: 0100040004
                        Reset counter: 234
                        Mileage: 62683 km
                        Time: 21:49:12
    End-------------------------(Elapsed Time: 01:45)--------------------------
