Results 1 to 9 of 9
Thread: ABS coding help please ? (MK60EC1)
    Jul 2014
    Yorkshire
    Can anyone assist in coding help after used module fitted to vehicle (not by me) please ?
    Saturday,31,August,2019,17:25:26:47217
    VCDS Version: 19.6.1.0
    VIN: WVWZZZ1KZ9W025962   License Plate: NB08KMO
    Mileage: 165140km-102613mi   Repair Order:
    Chassis Type: 1K (1K0)
    VIN: WVWZZZ1KZ9W025962   Mileage: 165140km-102613miles
    Address 01: Engine        Labels: 03G-906-016-BKD.clb
       Part No SW: 03G 906 021 PP    HW: 03G 906 021 AN
       Component: R4 2,0L EDC  000SG  4661
       Revision: --H08---    Serial number: VWX7Z0H53NB7TN
       Coding: 0000072
       Shop #: WSC 00464 210 88252
       VCID: 7CF38C0F3F5316AFC5-8028
    005660 - Glowplug for Cylinder 3 (Q12)
                   P161C - 000 - Open Circuit
                        Fault Status: 01110000
                        Mileage: 165143 km
                        Time: 00:32:49
                        RPM: 819 /min
                        Load: 0.0 %
                        Voltage: 14.29 V
                        Bin. Bits: 00000100
                        Temperature: 16.2°C
                        Bin. Bits: 10110000
       Part No SW: 1K0 907 379 AN    HW: 1K0 907 379 AN
       Component: ESP MK60EC1   H45 0107
       Revision: 00H45001
       Shop #: WSC 09550 758 180955
       VCID: 7EF78607E94F04BFEB-802A
                        Reset counter: 91
                        Count: 3
                        Count: 4608
                        Count: 195
                        Count: 51200
       Part No SW: 1K0 820 047 HN    HW: 1K0 820 047 HN
       Component: Climatic PQ35   142 1111
       Revision: 00142031    Serial number: 00000000000000
       VCID: 77F99323067535F7A8-8022
    00229 - Refrigerant Pressure
                002 - Lower Limit Exceeded
    01316 - ABS Control Module
       Revision: 00H54000    Serial number: 00000008510179
       Coding: E5898F2700041500471400001400000000087F075C000100000000000000
       Shop #: WSC 01367 785 00200
       VCID: 33616733528D19D754-8066
       Component: Wischer 300508 021  0501
       Coding: 00038805
       Shop #: WSC 01367
       Component: RLS     130608 054  0402
       Coding: 00209069
       Shop #: WSC 01367
       Component: 38 AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 0038PD22266O
       Coding: 0013112
       Shop #: WSC 01373 785 00200
       VCID: 3D75410B64C9DFA7B2-8068
       Subsystem 1 - Serial number: 6332MSME2D22624CE
       Subsystem 2 - Serial number: 6342MSME2C316675E
       Subsystem 3 - Serial number: 6352QSME736E4829U
       Subsystem 4 - Serial number: 6362QSME6F77184D$
       Part No SW: 1K0 953 549 CA    HW: 1K0 953 549 CA
       Component: J0527           051 0101
       Coding: 0000012
       Shop #: WSC 01392 785 00200
       VCID: 73E1A733120D59D794-8026
    00576 - Terminal 15
       Part No SW: 1K0 920 964 B    HW: 1K0 920 964 B
       Component: KOMBIINSTRUMENT VDD 1212
       Revision: V0002000    Serial number: VWX7Z0H53NB7TN
       Coding: 0003403
       Shop #: WSC 00464 067 57207
       VCID: 2C537C4F8FB3462F15-8078
                        Reset counter: 131
                        Mileage: 165139 km
                        Time: 00:10:04
       Component: J533  Gateway   H07 0062
       Revision:   H07 01    Serial number: 300508F2001341
       Coding: E9807F060002020003
       VCID: 3565592B5CF907E77A-8060
                        Fault Status: 00110100
                        Reset counter: 131
                        Mileage: 165139 km
                        Time: 00:01:06
       Component: IMMO            VDD 1212
       Shop #: WSC 00137 211 56823
       Component: Tuer-SG         005 0972
       Coding: 0000692
       Shop #: WSC 01279 785 00200
       VCID: 387B501F4BEBFA8F61-806C
       Part No: 1K0 909 144 C
       Component: EPS_ZFLS Kl. 69     2301
       Revision: 00H15000
       VCID: 2A5F7A578547581FE7-807E
                000 - - - MIL ON
                        Fault Status: 11100000
                        Mileage: 165143 km
                        Time: 00:48:08
                        Battery Volts: 14.2 V
                            DU
                        Temperature: 26.0°C
                        Count: 9
                        Steering Angle: 4.33°
                        Count: 1
                            SteerAng n.Init
       Coding: 819002005103087F2D04840570085FC690FCA0
       Shop #: WSC 19310 683 574528
       VCID: 0301F7F342AD695784-8056
       Subsystem 2 - Part No: 1K0 951 178 A
       Component: Neigungssensor  003 0203
       Subsystem 3 - Part No: 1K0 951 178 A
       Component: Innenraumueberw.003 0203
       Component: Tuer-SG         006 1220
       Coding: 0000692
       VCID: 397D551B70E1E3879E-806C
       Part No: 1K0 035 186 AF
       Component: Radio GR0       035 0034
       Revision: 0003505S    Serial number: VWZ2Z2H1131090
       Coding: 0040400
       VCID: 6ADFBA5745C7981F27-803E
       Part No SW: 1K0 959 703 K    HW: 1K0 959 703 K
       Component: Tuer-SG         006 1302
       Coding: 0000144
       Shop #: WSC 01392 785 1012552
       Part No SW: 1K0 959 704 K    HW: 1K0 959 704 K
       Coding: 0000144
    End-------------------------(Elapsed Time: 01:58)--------------------------
    Feb 2019
    France
    hi test 113B200D092400FF881404EA901B00403000 after coding effectue inizialization procedure
  3. Likes Robski liked this post
    Jul 2014
    Yorkshire
    hello, thanks for the quick response, the coding was accepted but now throws 01044- control module incorrectly coded DTC !
    Feb 2019
    France
    113b400d092400ff881402ea901b00423000 retry
  6. Likes Robski liked this post
    Jul 2014
    Yorkshire
    thanks again, same story mate !
    going by PL24 the module part number should be : 1K0 907 375 AN , so I'm going to have to see if the previous place have still got the old module to check/confirm ?
    That's just the superseded part number.
    Recheck attributes!
  9. Likes Robski liked this post
  10. #7
    Jul 2014
    Yorkshire
    Recheck attributes!
    so the module fitted now is acceptable ? the part number isn't listed at all under the VIN ??
    EDIT: this one's fixed now with an accepted string of :
    113B00D092400FF881402EA901B00823000
    Thanks for the contributions.
  11. Likes Jack@European_Parts, Uwe liked this post
  12. #8
    What does microfiche say?
  13. #9
    Jul 2014
    Yorkshire
    I don't have/use one, I went by PL24 & like I said the 1K0 907 379 AN wasn't listed in the remarks section as an older replaceable module.
