Can anyone assist in coding help after used module fitted to vehicle (not by me) please ?
Saturday,31,August,2019,17:25:26:47217
VCDS Version: 19.6.1.0
VIN: WVWZZZ1KZ9W025962 License Plate: NB08KMO
Mileage: 165140km-102613mi Repair Order:
Chassis Type: 1K (1K0)
VIN: WVWZZZ1KZ9W025962 Mileage: 165140km-102613miles
Address 01: Engine Labels: 03G-906-016-BKD.clb
Part No SW: 03G 906 021 PP HW: 03G 906 021 AN
Component: R4 2,0L EDC 000SG 4661
Revision: --H08--- Serial number: VWX7Z0H53NB7TN
Coding: 0000072
Shop #: WSC 00464 210 88252
VCID: 7CF38C0F3F5316AFC5-8028
005660 - Glowplug for Cylinder 3 (Q12)
P161C - 000 - Open Circuit
Fault Status: 01110000
Mileage: 165143 km
Time: 00:32:49
RPM: 819 /min
Load: 0.0 %
Voltage: 14.29 V
Bin. Bits: 00000100
Temperature: 16.2°C
Bin. Bits: 10110000
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AN HW: 1K0 907 379 AN
Component: ESP MK60EC1 H45 0107
Revision: 00H45001
Shop #: WSC 09550 758 180955
VCID: 7EF78607E94F04BFEB-802A
Reset counter: 91
Count: 3
Count: 4608
Count: 195
Count: 51200
Part No SW: 1K0 820 047 HN HW: 1K0 820 047 HN
Component: Climatic PQ35 142 1111
Revision: 00142031 Serial number: 00000000000000
VCID: 77F99323067535F7A8-8022
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
01316 - ABS Control Module
Revision: 00H54000 Serial number: 00000008510179
Coding: E5898F2700041500471400001400000000087F075C000100000000000000
Shop #: WSC 01367 785 00200
VCID: 33616733528D19D754-8066
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 300508 021 0501
Coding: 00038805
Shop #: WSC 01367
Component: RLS 130608 054 0402
Coding: 00209069
Shop #: WSC 01367
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 38 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD22266O
Coding: 0013112
Shop #: WSC 01373 785 00200
VCID: 3D75410B64C9DFA7B2-8068
Subsystem 1 - Serial number: 6332MSME2D22624CE
Subsystem 2 - Serial number: 6342MSME2C316675E
Subsystem 3 - Serial number: 6352QSME736E4829U
Subsystem 4 - Serial number: 6362QSME6F77184D$
Part No SW: 1K0 953 549 CA HW: 1K0 953 549 CA
Component: J0527 051 0101
Coding: 0000012
Shop #: WSC 01392 785 00200
VCID: 73E1A733120D59D794-8026
00576 - Terminal 15
Part No SW: 1K0 920 964 B HW: 1K0 920 964 B
Component: KOMBIINSTRUMENT VDD 1212
Revision: V0002000 Serial number: VWX7Z0H53NB7TN
Coding: 0003403
Shop #: WSC 00464 067 57207
VCID: 2C537C4F8FB3462F15-8078
Reset counter: 131
Mileage: 165139 km
Time: 00:10:04
Component: J533 Gateway H07 0062
Revision: H07 01 Serial number: 300508F2001341
Coding: E9807F060002020003
VCID: 3565592B5CF907E77A-8060
Fault Status: 00110100
Reset counter: 131
Mileage: 165139 km
Time: 00:01:06
Component: IMMO VDD 1212
Shop #: WSC 00137 211 56823
Component: Tuer-SG 005 0972
Coding: 0000692
Shop #: WSC 01279 785 00200
VCID: 387B501F4BEBFA8F61-806C
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 69 2301
Revision: 00H15000
VCID: 2A5F7A578547581FE7-807E
000 - - - MIL ON
Fault Status: 11100000
Mileage: 165143 km
Time: 00:48:08
Battery Volts: 14.2 V
DU
Temperature: 26.0°C
Count: 9
Steering Angle: 4.33°
Count: 1
SteerAng n.Init
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Coding: 819002005103087F2D04840570085FC690FCA0
Shop #: WSC 19310 683 574528
VCID: 0301F7F342AD695784-8056
Subsystem 2 - Part No: 1K0 951 178 A
Component: Neigungssensor 003 0203
Subsystem 3 - Part No: 1K0 951 178 A
Component: Innenraumueberw.003 0203
Component: Tuer-SG 006 1220
Coding: 0000692
VCID: 397D551B70E1E3879E-806C
Part No: 1K0 035 186 AF
Component: Radio GR0 035 0034
Revision: 0003505S Serial number: VWZ2Z2H1131090
Coding: 0040400
VCID: 6ADFBA5745C7981F27-803E
Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
Component: Tuer-SG 006 1302
Coding: 0000144
Shop #: WSC 01392 785 1012552
Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
Coding: 0000144
End-------------------------(Elapsed Time: 01:58)--------------------------
