Results 1 to 8 of 8
Thread: New user copy of my autoscan
    Dec 2019
    Scotland
    Hi all, first of all nice to meet you all so i took the plunge and bought my own hex net professional was sick of the costs at the garage for them to find my faults haha.
    Here is a copy of my autoscan if anyone can help me with any of it
    Friday,06,December,2019,12:25:14:40804
    VIN: WUAZZZ8HX4K901613   License Plate: MA54BVR
    Mileage: 191540km-119017mi   Repair Order:
    Chassis Type: 8H (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
              67 69 75 76 77
    VIN: WUAZZZ8HX4K901613   Mileage: 191540km-119017miles
    Address 01: Engine        Labels: 079-910-560-BBK.lbl
       Part No SW: 8H0 910 560 A    HW: 8E0 907 560
       Component: 4.2L V8/5V          0010
       Coding: 0011774
       Shop #: WSC 00672 785 00200
       VCID: 2600EFBF9078697FFD-5160
    7 Faults Found:
    16524 - Oxygen (Lambda) Sensor B1 S2
                P0140 - 004 - No Activity
                P0300 - 001 -  - Intermittent
    16686 - Cylinder 2
                P0302 - 001 - Misfire Detected - Intermittent
    17985 - Right Engine Mount Solenoid Valve (N145)
                P1577 - 004 - Open Circuit - Intermittent
    18080 - Coolant Fan Control 1
                P1672 - 004 - Open or Short to Ground - Intermittent
    18308 - Coolant Fan Control 2
                P1900 - 004 - Open or Short to Ground - Intermittent
    Readiness: 0110 1001
       Part No SW: 8E0 910 156     HW: 09L 927 156
       Component: AG6 09L 4.2L5V RdW  0040
       Revision: 00000001    Serial number:        0009249
       Coding: 0000001
       VCID: 6386B6ABA3CADC57DA-5160
    16946 - System Voltage
                P0562 - 000 - Too Low - Intermittent
                        RPM: 1440 /min
                        RPM: 800 /min
                        (no units): 30.0
                        (no units): 0.0
                        Temperature: 12.0°C
                        T.B. Angle: 0.0°
                        Voltage: 6.64 V
       VCID: 55E29873AD9E32E7A4-51A8
    No Faults Found
       Part No: 8E0 820 043 AD
       Component:   A4 Klimaautomat   1324
       Coding: 00100
       Shop #: WSC 00672
       VCID: 6386B6ABF3CADC57DA-513C
                07-00 - Signal too Low
    00532 - Supply Voltage B+
       Part No: 8E0 907 279 F
       Component: int. Lastmodul  RDW 0617
       Coding: 01001
       Shop #: WSC 00672
       VCID: 352238F30DDE12E744-4B00
    Address 15: Airbags        Labels: 8H0-959-655-84.lbl
       Part No: 8H0 959 655 B
       Component: Airbag 8.4EC        2015
       Coding: 0010104
       VCID: 393A34C371C6F687A0-5160
       Part No: 8E0 953 549 N
       Component: Lenksáulenmodul     0611
       Coding: 01111
       Shop #: WSC 00672
       VCID: 3E3027DF38E8D1BF95-4B00
       Part No: 8H0 920 980 L
       Component: KOMBI+WEGFAHRS. RB4 D22
       Coding: 01401
       Shop #: WSC 19411
       VCID: 383C31C71ACCEF8F5F-5160
       WUAZZZ8HX4K901613     AUZ6Z0D0118946
    01304 - Radio
                49-00 - No Communications
                00-00 - -
       Part No: 8H0 959 760
       Component: Sitzmemory EE H05   X014
       Coding: 00002
       Shop #: WSC 00065
       VCID: 74A4C5F745244BEFB3-4B00
    02010 - Left Entry Assistance Control Module (J572)
       Part No: 8H0 951 178
       Component: Innenraumueberw.   0411
       Coding: 00001
       VCID: 6FAECA9B2F0268374E-50F4
    01349 - Alarm via Theft Warning System; Front
                43-00 - Closed
                81-00 - Open
       Part No: 8H0 959 433 F
       Component: Komfortgerát T3B    3220
       Coding: 32767
       VCID: 373E32FB17D2E0F756-4B00
       Subsystem 1 - Part No: 8H2959802
       Component: Tőrsteuer.FS BRM 3020
       Component: Tőrsteuer.BF BRM 0003
    12 Faults Found:
    01134 - Alarm Horn (H12)
                29-10 - Short to Ground - Intermittent
    01370 - Alarm triggered by Interior Monitoring
                35-00 - -
                35-00 - -
                35-00 - -
    00955 - Key 1
                35-10 - - - Intermittent
    00957 - Key 3
       Part No: 4Z7 907 357
       Coding: 00070
       Shop #: WSC 00672
       VCID: 0444953715847B6F83-4AE0
    01539 - Headlights Not Adjusted
                35-00 - -
                30-00 - Open or Short to Plus
    Address 76: Park Assist        Labels: 8Z0-919-283.lbl
       Part No: 8Z0 919 283 A
       Component: Parkingsyst. A4 RDW D09
       Coding: 01105
       Shop #: WSC 00672
       VCID: 43C6562B500ABC57FA-513C
    End----------(Elapsed Time: 05:13, VBatt start/end: 13.9V/13.9V)-----------
    Just thought i better add its a Audi s4 b6 cabriolet 4.2 v8
  2. Likes Uwe liked this post
  3. #2
    Near Philadelphia, PA, USA
    Welcome to the forum. On a quick review of your scan, it appears you have had a low battery. Anything you want to share about that?
    If not, and the battery is now fully charged and holding charge, then do the following:
    • clear the faults.
    • Drive it for a good drive - fully warmed and running for say a half hour minimum
    • Run a new autoscan after the drive.
    • Post that autoscan to this thread for us to have another look.
  4. Likes Uwe liked this post
  5. #3
    Dec 2019
    Scotland
    Hey bruce, thanks for taking the time to take a look at my autoscan, yes i went on holiday and left my car on my mums driveway only to come back to find water in front passenger footwell and my comfort control unit flooded out (which i have replaced with new one since) and yes battery was flat to. For how long i don't know, have been trying to get it to hold a full charge for last 3 months to no avail so have took the plunge yesterday and ordered a new one (S5 013 Bosch Car Battery 12V 100Ah Type 019 S5013) should get it monday, the one in the car just now is'nt even a year old only bought last year from ebay "yes i know probably a fakey which i have been told of a few people now" was a bosch s5 010.
    Did notice one the report:
    wondering if that has anything to do with the water leak i now have after garage done my valve cover gasket seals both side which they buggered up as i had to go back due to loads of smoke coming from engine due to them bending plastic clips when they put covers back on leaving loads of oil to spray out down back of engine ( think they have nicked a water hose or something else at the same time )???
    With the low battery voltage, you often get false readings which is why I do not at this point think one should be fussing about the intermittent Coolant Fan errors.
    Given what you have said about the shop, I do hope you have searched and found another. Hard to believe professionals could muck things up as you have described...
    Dec 2019
    Scotland
    HaHa yea sure have found a new garage, am booked in next thursday they going to try and find out why i'm leaking water and see if there is any other problems as well as try and clean oil from back of engine or bottom of it don't know were exactly as i have burning oil smell and smoke coming from engine sides when i first start engine till its heated up, garage that done job said it was nothing to worry about just to wait till it burned of and nothing could be done about it unless engine taken out as hard to clean bottom of engine where engine would be sitting from it leaking out from when they done the seal change's if you ask me i think they should be the ones cleaning the oil as they buggered up.
    Quote Originally Posted by DesertEales View Post
    First thing I would check is the heater plenum chamber drain, if that is blocked water builds up in the plenum chamber and comes out into the footwell.
  9. Likes Uwe, DV52, Dana liked this post
  10. #7
    Dec 2019
    Scotland
    So new battery fitted, codes cleared and took for a drive over half and hour.
    Here is new copy of autoscan
    Sunday,08,December,2019,12:08:06:40804
    Mileage: 191550km-119027mi   Repair Order: 2
              67 69 75 76 77
    VIN: WUAZZZ8HX4K901613   Mileage: 191550km-119023miles
       Coding: 0011774
    Readiness: 0110 1101
       Coding: 0000001
       Part No: 8E0 614 517 Q
       Component: ABS/ESP allrad      4533
       Coding: 04597
       Shop #: WSC 00672
       VCID: 36203FFF10D819FF4D-51A8
       Coding: 00100
       Shop #: WSC 00672
       Coding: 01001
       Shop #: WSC 00672
       Coding: 0010104
       Coding: 01111
       Shop #: WSC 00672
       Coding: 01401
       Shop #: WSC 19411
                00-00 - -
       Coding: 00002
       Shop #: WSC 00065
       Coding: 00001
       VCID: 6FAECA9B2F0268374E-5118
       Coding: 32767
       Subsystem 2 - Part No: 8H2959801
       Subsystem 3 - Part No: 8H0959801A
       Component: Tőrsteuer.HL BRM 0002
       Subsystem 4 - Part No: 8H0959802A
       Component: Tőrsteuer.HR BRM 0002
       Coding: 00070
       Shop #: WSC 00672
       VCID: 0444953715847B6F83-4B00
                35-00 - -
       Coding: 01105
       Shop #: WSC 00672
    End----------(Elapsed Time: 05:43, VBatt start/end: 14.1V/14.0V)-----------
  11. Likes Uwe, Dana liked this post
  12. #8
    Dec 2019
    Scotland
    Thanks for that suggestion PetrolDave, was one of the first things i done after reading up on it on various audi forums haha even took the plugs out.
    Having sat in car today doing my scan on the car and it pouring down outside i noticed where the leak was coming from as it was dripping from top of door down on to handle inside and on to the ground, think i need to get the seals done around the door and hopefully that will solve my problem there. Wish i had seen that in the first place as would have saved me going around all the drain holes front to back and clearing them out ach well least they jobs have been done as well.
    Thanks again anyway bud
  13. Likes Dana, PetrolDave liked this post
