Results 1 to 10 of 11
Thread: Audi SQ7 2017 - "Active roll stabilisation: fault. Restricted Stability."
    Feb 2018
    New Zealand
    HI can anyone help explain the most likely cause. I can not find any of these fault codes in the list of fault codes on the website.
    Saturday,31,August,2019,11:25:04:03057
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(Parallels)
    VCDS Version 19.6.1.0 (x64)  HEX-NET CB: 0.4508.4
    VIN: WAUZZZ4M6HD011780   License Plate: M1DW1F
    Mileage: 73906km-45923mi   Repair Order:
    Chassis Type: 4M-AU73 (8W7)
    Scan: 01 02 03 06 08 09 13 15 16 17 19 28 29 2B 32 36 39 3C 42 44
              46 47 50 52 5F 61 69 6C 6D 74 81 82 8B A5 A9 AC BA BB BC C0
              C4 CA CB CF D4 D5 D6 D7
    VIN: WAUZZZ4M6HD011780   Mileage: 73906km-45923miles
    50-Seat Adj. 3rd row -- Status: OK 0000
    74-Chassis Control -- Status: Malfunction 0010
    BB-Door Rear Drv -- Status: Malfunction 0010
    C4-DC/DC Converter -- Status: OK 0000
    CA-Sunroof -- Status: OK 0000
    CB-Rear Axle Steering -- Status: OK 0000
    D4-Roll Control 1 -- Status: Malfunction 0010
    D5-Roll Control 2 -- Status: Malfunction 0010
    Address 01: Engine (J623-CZAC)       Labels: Redir Fail!
       Part No SW: 4M0 907 409     HW: 057 907 309
       Component: 4.0l V8 TDI   H43 0004
       Revision: D1H43---
       Coding: 2A2A4032057E050335380400000000000000000000000000
       Shop #: WSC 31414 790 00001
       ASAM Dataset: EV_ECM40TDI0114M0907409 001008
       ROD: EV_ECM40TDI0114M0907409_AU73.rod
       VCID: 6E902801B19CF43F7B-803B
       Electrical Charger:
       Subsystem 1 - Part No SW: 057 145 601 D    HW: 057 145 601 D
       Component: J1123 - EAV  H06 0003
       Serial number:  EOL_PASSED
    32017 - Electric Compressor
              P15B7 00 [039] - Electrical Malfunction
                        Mileage: 73863 km
                        Date: 2019.08.30
                        Time: 16:50:02
                        Engine speed: 755.50 /min
                        Normed load value: 20.0 %
                        Coolant temperature: 89 °C
                        Intake air temperature: 32 °C
                        Voltage terminal 30: 12.480 V
                        Electrically driven compressor: reference speed: 5000 /min
                        Electrically driven compressor: speed: 0 /min
                        Electrically driven compressor: supply voltage: 49.3 V
                        Electrically driven compressor: current: 0 A
                        Electrically driven compressor: component temperature: 53 °C
                        Bypass valve of the el. driven compressor: reference value: 95.00 %
                        Elec Cmpr Byp r Ps: 90.00 %
    Address 02: Auto Trans        Labels:* None
       Part No SW: 4M0 927 158 AD    HW: 0D6 927 156 F
       Component: 0D6  40TDIRdW H03 1004
       Revision: --H03---
       Coding: 100000
       ASAM Dataset: EV_TCMALX52011 002010
       ROD: EV_TCMALX52011.rod
       VCID: 76A00061C9CCCCFFB3-8023
    Address 03: ABS Brakes (J104)       Labels: 4M0-907-379-PRE-V1.clb
       Part No SW: 4M0 907 379 Q    HW: 4M0 907 379 N
       Component: ESP9 Premium  H09 0657
       Coding: 2C983AB230A30A97D1A558995C7D56AAE6A6DA345C0C508B1A3A6A5567655B
       ASAM Dataset: EV_ESP9BOSCHAU536K 012013
       ROD: EV_ESP9BOSCHAU536K_AU73.rod
       VCID: 45C2B7ADC4AA1767EA-8011
    0075 - Databus
              U1122 00 [047] - Implausible Message
              [Signal_AFR_Fehler_faulty_(1.2:3]
                        Mileage: 73862 km
                        Date: 2019.08.30
                        Time: 16:43:44
                        7B C0 80 00 C2 24 00 00 00 00
    Address 06: Seat Mem. Pass (J521)       Labels:* None
       Part No SW: 4M1 959 760 B    HW: 4M1 959 760 B
       Component: MEM-BFS       008 0031
       Serial number: 00000211737800
       Coding: 00383A000001B2810060010101010000110000171700171700000000000000
       ROD: EV_SCMPasseSideCONTIAU736_AU49.rod
       VCID: 383CCE5983587A8F61-806D
       Valve Block 1 In Passenger Side Front Seat:
       Subsystem 1 - Part No SW: 4M0 907 182     HW: 4M0 907 182
       Component: N477 VB1 BFSv  H06 0030
       Serial number: SJ8001200716011000BB
       Coding: BF2F00
       Part No SW: 4M0 820 043 AD    HW: 4M0 820 043 AD
       Component: Klima Zone 4  H52 0093
       Coding: 6818083D5544451102220280800000000000000000000000000000000000
       ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
       ROD: EV_AirCondiFrontBHTCAU736.rod
       VCID: 679E5D259E66257738-8033
       Subsystem 1 - Part No SW: 4M2 820 021     HW: 4M2 820 021
       Component: J216 FLuftV  H05 0001
       Serial number: 00000000000000976875
       Serial number: 20788D3800PAG0MUFU02
    262914 - High Pressure Sensor
              B10AE 21 [008] - Signal Amplitude Too Low
                        Fault Frequency: 109
                        Reset counter: 197
                        Mileage: 63964 km
                        Date: 2019.06.14
                        Time: 14:28:35
                        Outside air temperature: 10.50 °C
                        Engine speed: 693 /min
                        Compressor current: actual value: 0.00 A
                        Temperature after evaporator: 17.40 °C
       Part No SW: 8W0 907 063 BG    HW: 8W0 907 063 BG
       Component: BCM1 MLBevo   H13 0248
       Coding: 07501943C13900CD010D57195BBF8CF9130331019000000000000000E20016810A4502AB32B70A
       ASAM Dataset: EV_BCM1BOSCHAU736 016006
       ROD: EV_BCM1BOSCHAU736_016.rod
       VCID: 014A63BD9002FB4796-8055
       Subsystem 1 - Part No SW: 4M2 955 119 A    HW: 4H1 955 119 C  Labels: 1KX-955-119.CLB
       Component: WWS536 160506  043 0893
       Serial number: 895653?0401612701345
       Coding: 1BC7F7
       Serial number: 62111738
       Coding: 02006E
       Subsystem 3 - Part No SW: 4M0 941 531 AB    HW: 4M0 941 531 AB
       Component: E1 - LDS  H06 0008
       Serial number: 06 06 2016  00400820
       Subsystem 4 - Part No SW: 8W0 857 511     HW: 8W0 857 511
       Serial number: GX1CE109051612010297
       Coding: 230000
       Interior Light Module:
       Subsystem 5 - Part No SW: 4M0 947 135 CK    HW: 4M0 947 135
       Component: J528-Dachele  H14 0130
       Serial number: Q00169561
       Electrically Adjustable Steering Column:
       Subsystem 6 - Part No SW: 4M0 907 705 A    HW: 4M0 907 705 A
       Component: J866-EVLS-SG  H03 0060
       Serial number: WA124457000022814000
       Coding: 020100
       Subsystem 7 - Part No SW: 4M0 925 301 B    HW: 4M0 925 301 B
       Component: SL-Q7NF/AU736  H10 0013
       Serial number: 00000000000000035246
       Part No SW: 4M0 907 561 E    HW: 4M0 907 561
       Component: LRR4          H09 0220
       Coding: 3477FFFB78FFEC06747860A0
       ASAM Dataset: EV_ACCBOSCHAU736 002018
       ROD: EV_ACCBOSCHAU49X_002.rod
       VCID: 3228FC71652490DF5F-8067
       Part No SW: 4M0 959 655 B    HW: 4M0 959 655 B
       Component: Airbag10.44   H75 0086
       Serial number: 003SB0000PWD
       Coding: AAFCF0D80CA0000098F650F3C0CC00000000
       ASAM Dataset: EV_AirbaAU10BPAAU736 005012
       ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
       VCID: 3A38D451BD54689F97-806F
       Belt Pretensioner left:
       Subsystem 1 - Part No SW: 4M0 980 945     HW: 4M0 980 945
       Component: BeltPretRevFL  205 2033
       Serial number: 4M0857705J0215Q00471
       Coding: 88001B
       Belt Pretensioner right:
       Subsystem 2 - Part No SW: 4M0 980 946     HW: 4M0 980 946
       Component: BeltPretRevFR  205 2033
       Serial number: 4M0857706D0217Q00224
       Coding: 88001B
       Subsystem 3 - Part No SW: -----------    HW: 442 061 307 16
       Component: SideSensor_Df  1E2 0887
       Serial number: 3577Y00A91F5EA33D1EP
       Subsystem 4 - Part No SW: -----------    HW: 442 061 307 16
       Component: SideSensor_Pf  1E2 0887
       Serial number: 3587Y00A91F5EA32C24F
       Subsystem 5 - Part No SW: -----------    HW: 442 0B1 306 16
       Component: SideSensor_Dr  1C7 0148
       Serial number: 3517700AF20D817342FH
       Subsystem 6 - Part No SW: -----------    HW: 442 0B1 306 16
       Component: SideSensor_Pr  1C7 0148
       Serial number: 3527700B120D8172A351
       Subsystem 7 - Part No SW: -----------    HW: 442 0C2 005 16
       Component: FrontSensor_D  1C5 014A
       Serial number: 3557500AD208F3A35019
       Front Sensor Passenger:
       Subsystem 8 - Part No SW: -----------    HW: 442 0C2 005 16
       Component: FrontSensor_P  1C5 014A
       Serial number: 3567500AD20BEEE0632T
       Pedestrian Protection Center:
       Subsystem 9 - Part No SW: -----------    HW: 442 0C2 107 16
       Component: PedP_Sensor_C  1C5 014A
       Serial number: 2307500C920DD1F0C19I
       Subsystem 10 - Part No SW: -----------    HW: 442 421 807 16
       Component: PedPSensor_D2  21E 0887
       Serial number: I0M8U00B72027083D4FL
       Subsystem 11 - Part No SW: -----------    HW: 442 421 807 16
       Component: PedPSensor_P2  21E 0887
       Serial number: I0N8U00C31F5EA3533BZ
       Central Sensor XY:
       Subsystem 12 - Part No SW: -----------    HW: 410 200 107 16
       Component: CentrSensorXY  1C8 0108
       Serial number: I0O7800B72042360C20K
       Part No SW: 4M0 907 129 HL    HW: 4M0 907 129 HL
       Component: Lenks.Modul   H11 0009
       ROD: EV_SMLSKLOAU736_006.rod
    Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI2
       Part No SW: 4M0 920 790 B    HW: 4M0 920 790 B
       Component: FBenRDW       H15 0302
       Coding: 248D08F07CB8060001A3E9603100600000000000
       ASAM Dataset: EV_DashBoardAU736 001022
       ROD: EV_DashBoardAU736_AU49.rod
       VCID: 2E10E801711CB43F3B-807B
       Part No SW: 8W7 907 468 C    HW: 8W7 907 468 C
       Component: Gateway       H27 1298
       Revision: 4M090005    Serial number: 0584M035616721
       Coding: 0301000100088E407F00000000590032F4130007B40000000175078E00000000
       ASAM Dataset: EV_CGateCONTIAU491 002060
       ROD: EV_CGateCONTIAU491_002_AU49.rod
       VCID: 4BD68195E2CEE1173C-801F
       Subsystem 1 - Part No SW: 4M0 951 523     HW: 4M0 951 523
       Component: J453 MFL  H06 0002
       Serial number: 20160801060736 00675
       Serial number: 2224001104
    9502742 - Databus
              [eAWS_No_Component_Function]
                        Reset counter: 198
                        Mileage: 66209 km
                        Date: 2019.07.03
                        Time: 12:56:21
                        48V activation restriction-Airbag control module: not active
                        48V activation restriction-Engine Electronics: not active
                        48V activation restriction-Roll stabilization: not active
                        48V activation restriction-48 V activation restriction due to open circuit: not active
                        48V activation restriction-48 V activation restriction due to deactivation: not active
                        48V activation restriction-Battery Energy Control Module 2: not active
                        48V activation restriction-DC/DC Converter Control Module: not active
                        48V activation restriction-Control module for auxiliary air heater: not active
                        48V activation restriction-Electrical Charger: not active
    Address 28: HVAC, Rear (E265)       Labels:* None
       Part No SW: 4M0 919 158 C    HW: 4M0 919 158 C
       Component: Klima Zone 2  H52 0092
       Coding: 000000000000040100820080000000000000000000000000000000000000
       ASAM Dataset: EV_AirCondiFondBHTCAU736 001013
       ROD: EV_AirCondiFondBHTCAU736.rod
       VCID: 3522C76D944A87E77A-8061
    65544 - Button(s) or Switch(es) in Operating Device
              B1312 07 [008] - Mechanical Failure
                        Fault Frequency: 7
                        Reset counter: 221
                        Mileage: 71710 km
                        Date: 2019.08.12
                        Time: 17:07:54
                        Voltage terminal 30: 14.86 V
                        Pressing a button-Button for instrument panel vents: not activated
                        Pressing a button-Defrost: not activated
                        Pressing a button-Recirculating air: not activated
                        Pressing a button-Rear window defogger: not activated
                        Pressing a button-Left pressure knob: not activated
                        Pressing a button-Right pressure knob: not activated
                        Pressing a button-Left air distribution: not activated
                        Pressing a button-Right air distribution: not activated
                        Pressing a button-AUTO left: not activated
                        Pressing a button-AUTO right: not activated
                        Pressing a button-Air quantity left: not activated
                        Pressing a button-Air quantity right: not activated
                        Pressing a button-AC: not activated
                        Pressing a button-Left heated seat: not activated
                        Pressing a button-Left seat ventilation: not activated
                        Pressing a button-Right heated seat: not activated
                        Pressing a button-Right seat ventilation: not activated
                        Pressing a button-OFF: not activated
                        Pressing a button-AUTO: not activated
                        Pressing a button-Air quantity: not activated
                        Pressing a button-Footwell air distribution: not activated
                        Pressing a button-Upper body vent air distribution: not activated
                        Pressing a button-Air distribution up: not activated
                        Pressing a button-Left cabin heater: not activated
                        Pressing a button-Right cabin heater: not activated
                        Pressing a button-AC max/eco: not activated
                        Pressing a button-Input mode: not activated
                        Pressing a button-A/C mode: not activated
    Address 29: Left Light (J1018)       Labels: 4M0-907-397.clb
       Part No SW: 4M0 907 397 AB    HW: 4M0 907 397 B
       Component: LCM_MLBevoH05 0023
       ROD: EV_LCMLeftHELLAAU736_VW48.rod
       VCID: 77BE0D65CEC6B5F7A8-8023
       Part No SW: 3Q0 905 861 A    HW: 3Q0 905 861 A
       Component: ELV-MLBevo    H05 0032
       Serial number: 16000086190012
       Coding: 8800000000000000
       ROD: EV_ELVMarquMQBB.rod
    Address 32: Differential Locks (J187)       Labels: None
       Part No SW: 8W0 907 163     HW: 8W0 907 163
       Component: QSP QCU Gen2  H07 0030
       Revision: 5WK12700    Serial number: 605628722250907
       Coding: 0300
       ASAM Dataset: EV_TVDCQSP22 001007
       ROD: EV_TVDCQSP22.rod
       VCID: 79BA0B5DF8D2A387DE-802D
       Component: MEM-FS        008 0031
       Serial number: 00000211748138
       Coding: 00383B000001B2810000010101010000110000171700171700000000000000
       ROD: EV_SCMDriveSideCONTIAU736_AU49.rod
       Valve Block 1 In Driver Side Front Seat:
       Component: N475 VB1 FSv  H06 0030
       Serial number: SJ80012007160110017B
       Coding: BF2F00
    Address 39: Right Light (J1023)       Labels: 4M0-907-397.clb
       Part No SW: 4M0 907 566 B    HW: 4M0 907 566
       Component: MRR1Rear      H13 0230
       Revision: --------
       Coding: 5EE002
       ASAM Dataset: EV_RearRadarS1BoschAU736 001015
       VCID: 3424FA699F309EEF4D-8061
       Part No SW: 4M0 959 793 G    HW: 4M0 959 793 C
       Component: TSG FS        009 0052
       Serial number: 0000210141060
       Coding: 005D9A005E010082000130B2
       ROD: EV_DCU2DriveSideMAXHCONT_AU49.rod
       VCID: 42C8ACB1D584205FCF-8017
       Part No SW: 4M0 909 144 G    HW: 4M0 909 144 B
       Component: EPS_MLBEVO1BS H20 0004
       Serial number: 0000027102
       Coding: B2150101000101
       ASAM Dataset: EV_EPSVWBSAU736 008020
       ROD: EV_EPSVWBSAU736_008.rod
       VCID: 3326F9759A3E99D754-8067
       Part No SW: 8W0 907 064 BD    HW: 8W0 907 064 D
       Component: BCM2 MLBevo   018 0328
       Coding: 01351E002F9100406309A0006E00580203004000004F06502F0400000504803F001F0001000000
       ASAM Dataset: EV_BCM2HellaAU736 011012
       ROD: EV_BCM2HellaAU736_011_AU49.rod
       VCID: 7F4EE545E6F68DB7E0-802B
       Ignition key:
       Subsystem 1 - Part No SW: 4M0 959 754 AF    HW: 4M0 959 754 AF
       Component: ID-Geber  H40 0105
       Serial number: 3616000109827013
       Subsystem 2 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
       Serial number: 000000000ZY1617333PA
       Subsystem 3 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
       Component: Sirene, DWA  005 0313
       Serial number: 00000000000066477095
       Subsystem 4 - Part No SW: 3AA 962 243 F    HW: 3AA 962 243 F
       Component: GEB.F.Heckoef  H16 0816
       Serial number: 94142507
    131120 - Remote key 1
              B1479 18 [008] - Current Too Low
                        Fault Frequency: 10
                        Reset counter: 231
                        Mileage: 35668 km
                        Date: 2018.09.18
                        Time: 09:25:00
                        Supply voltages-Supply voltage: Terminal 30: 12.120 V
                        Supply voltages-Supply voltage Terminal 30 - 2: 12.147 V
                        Supply voltages-Supply voltage Terminal 30 - 3: 12.093 V
                        general_additional_freeze_frame-Ambient_temperature_not_filtered: -50.0 °C
                        general_additional_freeze_frame-coprocessor_spi_status: 00000000
                        general_additional_freeze_frame-dataflash_status: 00000000
                        general_additional_freeze_frame-interior_temperature: -50.0 °C
                        general_additional_freeze_frame-Operating_Status: 00000000 00000000
                        general_additional_freeze_frame-production_mode: not active
                        general_additional_freeze_frame-reset_cause: 00000000
                        general_additional_freeze_frame-Reset_counter: 0
                        general_additional_freeze_frame-Stall_current_cutoff_level: Deactivation stage 0
                        general_additional_freeze_frame-Stall_Current_Measuring_Mode: not active
                        general_additional_freeze_frame-subnetwork_status: 00000000 00000000
                        general_additional_freeze_frame-terminal_control_intern_status: 40 04 5A 12 04 38
                        general_additional_freeze_frame-Transport_Mode: not active
                        general_additional_freeze_frame-Vehicle speed: 0.00 km/h
                        key_error_freeze_frame: 01001000 11111111 11111111 11111111
    131123 - Remote key 2
              B147A 18 [008] - Current Too Low
                        Fault Frequency: 6
                        Reset counter: 231
                        Mileage: 55600 km
                        Date: 2019.04.10
                        Time: 11:07:59
                        Supply voltages-Supply voltage: Terminal 30: 12.636 V
                        Supply voltages-Supply voltage Terminal 30 - 2: 12.649 V
                        Supply voltages-Supply voltage Terminal 30 - 3: 12.609 V
                        key_error_freeze_frame: 01000101 11111111 11111111 11111111
       Part No SW: 4M0 035 223 B    HW: 4M0 035 223
       Component: MIB2_amp_PD   H02 0430
       Serial number: 00000000008244
       Coding: 0135560A008AF53AAF0000010000
       ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
       ROD: EV_AMPMst16C4Gen2BOSE_AU73.rod
       VCID: 22080C3135C4005FAF-8077
    Address 50: Seat Adj. 3rd row (J857)       Labels:* None
       Part No SW: 4M0 959 760 G    HW: 4M0 959 760 G
       Component: MEM-SR3       008 0015
       Serial number: 00000212102428
       Coding: FF201020F1000000000F000000000900000021210900000000000000440000
       ASAM Dataset: EV_SCM3rdRowCONTIAU736 005007
       ROD: EV_SCM3rdRowCONTIAU736.rod
       VCID: 3C34D249B76056AF85-8069
       Part No SW: 4M0 959 792 G    HW: 4M0 959 792 C
       Component: TSG BFS       009 0052
       Serial number: 0000209946625
       Coding: 005D9A005E010082000130B0
       ROD: EV_DCU2PasseSideMAXHCONT_AU49.rod
       VCID: 41CAA3BDD0823B47D6-8015
    Address 5F: Information Electr. (J794)       Labels:* 4M0-035-MIB-HGH2.clb
       Part No SW: 4M0 035 035 D    HW: 4M0 035 035 A
       Component: MU-P-LND-EU   052 0678
       Serial number: A787G0G7503628
       Coding: 013756080000000053111102000A00332F001CE7017001009E
       VCID: 2502172D24EAF767CA-8071
       Subsystem 1 - Part No SW: V03 959 801 FP    HW: -----------
       Component: ROW 2016/2017  --- 0058
       Subsystem 2 - Part No SW: 4M0 919 605     HW: 4M0 919 605
       Component: AU536_DU_HIGH  H43 0008
       Serial number: AUZ8Z9GJ402L9M
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 4M0 919 615 H    HW: 4M0 919 615 H
       Component: ControlUnit_P  H15 0209
       Serial number: 29071600000000000241
       Component: Gracenote2---  --- 1013
              B201A 00 [009] - -
              [Check software version management]
                        Reset counter: 198
                        Mileage: 8230 km
                        Date: 2017.06.27
                        Time: 14:49:15
                        Voltage terminal 30: 14.3 V
                        Status_Software_Version_Management-module_name: MDUA303/Front
    2571 - Navigation system
              B126C F2 [009] - Navigation database not enabled
                        Reset counter: 159
                        Mileage: 8230 km
                        Date: 2017.06.27
                        Time: 14:49:10
    7223 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [ENI (0x37) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 209
                        Mileage: 71644 km
                        Date: 2019.08.11
                        Time: 11:35:54
                        Voltage terminal 30: 13.0 V
                        BAP-BAP_Function_ID: 15
    Address 61: Battery Regul. (J1120)       Labels: None
       Part No SW: 4M0 915 105 B    HW: 4M0 915 105 B
       Component: BMS_48V_LiIon H06 0102
       ASAM Dataset: EV_BMS48VLiIonLGAU536 001001
       ROD: EV_BMS48VLiIonLGAU536_AU37.rod
       VCID: 281C1E1953F8EA0FF1-807D
       Part No SW: 4M0 907 383 D    HW: 4M0 907 383 B
       Component: Anhaenger     H20 0214
       Revision: 9A001003    Serial number: 0411968417
       Coding: 0110000202010000
       Trailer Articulation Angle Sensor:
       Subsystem 1 - Part No SW: 4M0 907 811     HW: 4M0 907 811
       Component: G820 KNWINSEN  H18 0019
       Serial number: 15897
       Part No SW: 4M0 907 428 D    HW: 4M0 907 428
       Component: Areaview 2    H12 0311
       Serial number: C854607JG001822
       Coding: 02350601BF0FA10008404480
       ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004015
       ROD: EV_CamSysRVAV2CE2MLBEv_004.rod
       Part No SW: 4M0 959 107 A    HW: 4M0 959 107 A
       Component: HDSG-Modul    H13 0155
       Revision: --------    Serial number: 30824929800000
       Coding: 00F0
       ROD: EV_DeckLidCONTIAU736_AU73.rod
       VCID: 312AF37D6022ABC726-8065
    Address 74: Chassis Control (J775)       Labels:* None
       Part No SW: 4M0 907 777 G    HW: 4M0 907 777 B
       Component: Fahrwerk-SG   H34 1213
       Serial number: 0807160018
       Coding: BE607060F8
       ASAM Dataset: EV_ChassContrContiAU426 001003
       ROD: EV_ChassContrContiAU426.rod
       VCID: 3D32DF4DAC7A5FA7B2-8069
       Air Suspension Compressor:
       Subsystem 1 - Part No SW: 4M0 907 589 B    HW: 4M0 907 589 B
       Component: V66LFKompOLV  H06 0012
       Serial number: 00000000004130067246
       Coding: 303030
    10747906 - Function Limitation due to Malfunction in Roll Stabilization
              C1297 00 [137] - -
              [Function restriction due to functional error eAWS FA]
                        Fault Frequency: 60
                        Reset counter: 197
                        Mileage: 66208 km
                        Date: 2019.07.03
                        Time: 12:44:46
    10747907 - Function Limitation due to Malfunction in Roll Stabilization
              C1297 00 [008] - -
              [Function restriction due to functional error eAWS RA]
                        Reset counter: 238
                        Mileage: 66208 km
                        Date: 2019.07.03
                        Time: 12:44:46
    Address 81: Gear Shift (J587)       Labels: 4MX-713-041-81.clb
       Part No SW: 4M2 713 041 D    HW: 4M2 713 041 D
       Component: GSM-LL        H08 0068
       Revision: 0L0D5012    Serial number: 20160524000281
       ASAM Dataset: EV_GSMWaehlZFAU736 001013
       ROD: EV_GSMWaehlZFAU736.rod
       VCID: 271E1D255EE6E577F8-8073
    Address 82: Heads Up Display (J898)       Labels:* None
       Part No SW: 4M0 919 617 C    HW: 4M0 919 617 C
       Component: HeadUpDisplay H26 1603
       Coding: 4F01C0
       ASAM Dataset: EV_HudNSEIKAU736 001015
       ROD: EV_HudNSEIKAU736.rod
    Address 8B: Adaptive Cruise 2 (J850)       Labels: 4M0-907-541.clb
       Part No SW: 4M0 907 541 E    HW: 4M0 907 541
       ASAM Dataset: EV_ACC2BOSCHAU736 002018
       ROD: EV_ACC2BOSCHAU736_002_AU73.rod
       VCID: 302CF6796B28A2CF29-8065
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:* None
       Part No SW: 4M0 907 217 D    HW: 4M0 907 217 A
       Component: BVS           H13 0042
       Coding: 0407030600000404034023A7CD0000B4B0F0C020E280
       ROD: EV_BVSMLBevKOSTAAU736_AU73.rod
       VCID: 2F2EF5057616BD3730-807B
    1123591 - predictive route data
              B1630 02 [009] - Signal Failure
                        Reset counter: 198
                        Mileage: 8230 km
                        Date: 2017.06.27
                        Time: 14:49:07
                        Control Module temperature: 30 °C
                        Voltage terminal 15: 14.20 V
    Address A9: Struct. Borne Sound (J869)       Labels: None
       Part No SW: 4M0 907 159     HW: 4H0 907 159 A
       Component: SAS-GEN 2     H07 0001
       Serial number: 160613201091
       VCID: 70AC3679ABA8E2CF69-8025
    Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
       Part No SW: 4M0 907 355     HW: 4M0 907 355
       Component: SCR-Stg-G3H10 0003
       ASAM Dataset: EV_RDCMINERGAU736 005009
       ROD: EV_RDCMINERGAU736_AU49.rod
    Address BA: Motor Mounts (J931)       Labels: None
       Part No SW: 4M0 907 145 C    HW: 4M0 907 145 B
       Component: AEMevo        H08 0101
       ASAM Dataset: EV_AEMZFAU736 006011
       ROD: EV_AEMZFAU736_006.rod
       Part No SW: 4M0 959 795 G    HW: 4M0 959 795 C
       Component: TSG HFS       009 0052
       Serial number: 0000211784629
       Coding: 004D980000010082000030A0
       ROD: EV_DCU2RearDriveMAXHCONT_AU49.rod
       VCID: 44C4AAA9CF902E6FFD-8011
    196660 - Motor for Window Regulator
              B1487 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 197
                        Mileage: 73861 km
                        Date: 2019.08.30
                        Time: 16:06:41
       Component: TSG HBFS      009 0052
       Serial number: 0000211784626
       ROD: EV_DCU2RearPasseMAXHCONT_AU49.rod
    Address C0: Act. for Ext. Noise (J943)       Labels: None
       Part No SW: 4M0 907 160     HW: 4G0 907 160 B
       Component: SAS-GEN 2 AGA H10 0001
       Serial number: 160616200057
       VCID: 689C5E1993782A0F31-803D
    Address C4: DC/DC Converter (J519)       Labels: 4M0-959-663.clb
       Part No SW: 4M0 959 663 B    HW: 4M0 959 663 B
       Component: PCU10         022 0317
       ASAM Dataset: EV_DCDC48V210ABOSCHAU736 001008
       ROD: EV_DCDC48V210ABOSCHAU736.rod
       VCID: 393ACB5DB85263879E-806D
       Part No SW: 4M0 907 594 G    HW: 4M0 907 594
       Component: SAD_STG_1     013 0005
       Coding: 7A8000053602
    Address CB: Rear Axle Steering (J1019)       Labels:* None
       Part No SW: 4M0 909 145 G    HW: 4M0 909 145 D
       Component: HAL_MLBevoH07 0607
       Revision: --------    Serial number: CCC_007_D_07_03
       Coding: 00852C
       ASAM Dataset: EV_RearAxleSteerZFAU736 005010
       ROD: EV_RearAxleSteerZFAU736_005_AU73.rod
    Address CF: Lane Chge Asst 2 (J770)       Labels: None
       Part No SW: 4M0 907 590 B    HW: 4M0 907 590
       Revision: --------
       Coding: 5EE002
       ASAM Dataset: EV_RearRadarS2BoschAU736 001015
       ROD: EV_RearRadarS2BoschAU736.rod
    Address D4: Roll Control 1 (----)       Labels: None
       Part No SW: 971 907 156 H    HW: 971 907 156 H
       Component: EAWSH16 0209
       Serial number: 00120160617022
       ASAM Dataset: EV_EAWSSchaeFront 008001
       ROD: EV_EAWSSchaeFront_AU73.rod
    12673029 - 48V System
              C124E 00 [137] - -
              [ShutOffPathCheck_ChargePumpTest]
                        Reset counter: 106
                        Mileage: 66209 km
                        Date: 2019.07.03
                        Time: 12:56:14
                        Spannung KL30: 9.4 V
                        Spannung KL40: 49.50 V
                        Micro Controller Temperatur: 16 °C
                        Endstufe-Temperatur: 16 °C
                        Aktor-Motor-Temperatur: 18 °C
                        Current: 0 A
                        Steller Position: 0 °
                        Steller Drehzahl: 0 rad/s
                        Transverse acceleration: 0.29 m/s²
                        Derating (Über-/Unterspannnung) niedere Bit (MSB): 00000000
                        Abstuetzkraft: -10 N
                        System status: Stoerung
                        Derating (Über-/Unterspannnung) höhere Bit (MSB): 00000000
                        Fahrzeuggeschwindigkeit Steller: 0.00 km/h
                        Fehlerpfad: 00
                        DTC: C1 60 05
                        Status HW-KL15: active
                        MVK_eAWS_Sollmodus: Release
                        Zeit Nach KL15-Wechsel: 0.6 s
                        Fahrprogram: Program 2
                        Batterieabriss: 00
    12689675 - Functional Limitation due to Energy Management
              B10CD 00 [008] - -
              [MVK - keine Freigabe]
                        Reset counter: 40
                        Mileage: 66208 km
                        Date: 2019.07.03
                        Time: 12:45:42
                        Spannung KL30: 13.0 V
                        Spannung KL40: 11.00 V
                        Micro Controller Temperatur: 19 °C
                        Endstufe-Temperatur: 17 °C
                        Current: 0 A
                        Steller Position: 128 °
                        Steller Drehzahl: -1 rad/s
                        Transverse acceleration: -0.27 m/s²
                        Derating (Über-/Unterspannnung) niedere Bit (MSB): 00000101
                        Fahrzeuggeschwindigkeit Steller: 30.01 km/h
                        Fehlerpfad: 00
                        DTC: C1 A1 0B
                        MVK_eAWS_Sollmodus: No enabling
                        Zeit Nach KL15-Wechsel: 51.0 s
                        Fahrprogram: no function
                        Batterieabriss: 00
                        Steller-Isttorsion: 1.9921875
                        Steller-Solltorsion: 1.9921875
                        StellerTorsion Init: 1.9843750
                        Externer Verdrehwinkel: 1.9296875
                        Externe Winkelgeschwindigkeit: 0.0000000
                        ElektroMotor Istmoment: 0.0000
                        EawsCrtlActiveStatus: active
                        LL-Statemachine (Commutation Task) State: State: Temp Safe Mode
    12665856 - Internal Fault
              B200F FE [008] - Unknown Error Elaboration
              [Störungsmeldung eAWS_HA]
                        Reset counter: 238
                        Mileage: 66208 km
                        Date: 2019.07.03
                        Time: 12:44:46
                        Spannung KL30: 11.2 V
                        Spannung KL40: 23.50 V
                        Micro Controller Temperatur: 17 °C
                        Current: 0 A
                        Transverse acceleration: 0.27 m/s²
                        Fehlerpfad: 00
                        DTC: C1 44 00
                        Zeit Nach KL15-Wechsel: 2.2 s
                        Batterieabriss: 00
                        Steller-Isttorsion: 0.0000000
                        Steller-Solltorsion: 0.0000000
                        Externer Verdrehwinkel: 0.0156250
    13635841 - 48V System
              C124E 00 [009] - -
              [Unterspannung 48V]
                        Reset counter: 106
                        Mileage: 66208 km
                        Date: 2019.07.03
                        Time: 12:44:46
                        Spannung KL30: 11.0 V
                        Current: 0 A
                        Fehlerpfad: 00
                        DTC: D0 11 01
                        Zeit Nach KL15-Wechsel: 2.0 s
                        Batterieabriss: 00
    Address D5: Roll Control 2 (----)       Labels: None
       Serial number: 00120161120031
       Shop #: WSC 08648 002 1048576
       ASAM Dataset: EV_EAWSSchaeRear 008001
    12664851 - Function Limitation due to Malfunction in Roll Stabilization
              C1297 00 [008] - -
              [Keine Fahrdynamikaktivierung]
                        Reset counter: 238
                        Mileage: 66213 km
                        Date: 2019.07.03
                        Time: 14:44:40
                        Spannung KL30: 14.6 V
                        Spannung KL40: 49.75 V
                        Micro Controller Temperatur: 20 °C
                        Endstufe-Temperatur: 15 °C
                        Aktor-Motor-Temperatur: 13 °C
                        Current: 0 A
                        Transverse acceleration: -0.05 m/s²
                        Fahrzeuggeschwindigkeit Steller: 60.05 km/h
                        Fehlerpfad: 00
                        DTC: C1 40 13
                        Batterieabriss: 00
                        StellerTorsion Init: 0.0000000
                        Externer Verdrehwinkel: 1.9609375
                        LL-Statemachine (Commutation Task) State: State: GDU off Running
              B10CD 00 [008] - -
                        Reset counter: 40
                        Mileage: 66208 km
                        Date: 2019.07.03
                        Time: 12:45:42
                        Micro Controller Temperatur: 15 °C
                        Endstufe-Temperatur: 13 °C
                        Current: 0 A
                        Fehlerpfad: 00
                        DTC: C1 A1 0B
                        Batterieabriss: 00
                        StellerTorsion Init: 1.9687500
                        Externer Verdrehwinkel: 1.9375000
    12665857 - Internal Fault
              B200F FE [009] - Unknown Error Elaboration
              [Störungsmeldung eAWS_VA]
                        Reset counter: 0
                        Mileage: 66208 km
                        Date: 2019.07.03
                        Time: 12:44:46
                        Micro Controller Temperatur: 13 °C
                        Current: 0 A
                        Steller Position: 1 °
                        Fehlerpfad: 00
                        DTC: C1 44 01
                        Batterieabriss: 00
                        Externer Verdrehwinkel: 0.0234375
    Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-592.clb
       Part No SW: 7PP 941 592 CB    HW: 7PP 941 592 C
       Component: LED1L         H10 2003
       VCID: 1A7834D11D94489F77-804F
    Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-592.clb
       Component: LED1R         H10 2003
    End----------(Elapsed Time: 03:00, VBatt start/end: 11.8V/12.0V)-----------
    That whole system with modules 74, D4, and D5 is rather rare. I'm not sure I've ever seen a scan of a vehicle with that stuff in it.
    Looking at the fault codes, I might speculate that the root cause of all those complaints, even the electrical charger fault in the engine might just be isn't the 48V battery being weak. Note that I'm by no means confident in this.
    Dec 2016
    Amsterdam
    Well module 61 doesn’t complain about anything and according to the subtext that module is the BMS for the 48V system. Any TSB’s?
    Current:
    Feb 2018
    New Zealand
    Thank you thats a good place for me to start..
    Feb 2018
    New Zealand
    Quote Originally Posted by MasterTommy View Post
    Please forgive me, what are TSB's???
  6. #6
    Quote Originally Posted by drlumsden View Post
    Technical Service Bulletins.
  7. #7
    Feb 2018
    New Zealand
    Hi Not that I am aware of
  8. #8
    Feb 2018
    New Zealand
    So it seems that Audi have a recall on this fault. Electrical supercharger.
  9. Likes Uwe liked this post
  10. #9
    Feb 2018
    New Zealand
    Finally got the vehicle to the dealers after 2 other automotive repairs said the could help BUT COULD NOT! so yes there was a recall on the 48V supercharger. BUT the air suspension still has an issue...
  11. #10
    Feb 2018
    New Zealand
    So latest update 4 weeks at Dealers
    1) TSB recall for the 48V supercharger - replaced by Audi - TSB 205 04 22-3
    2) Stability control units x2 (replaced in pairs) NZ$5400 cost :-( awaiting specific part numbers
    3) Stone damage to the Air conditioner condenser - covered under insurance, 2 holes punch into the condenser by stones
    4) New tires, Right hand front - slow leak
