MK4 MFD - adjust fuel economy displayed
pkhoury
C?ID=123629
I retrofitted an MFD instrument cluster in my 2004 Golf TDI (BEW). I wanted to see if it's possible to adjust what the fuel economy shows on my display, as it's off by about 1-2mpg. I know this is possible for the Mk5/Mk6 (and I've done it on my other TDIs), but I'm not sure if it's possible to do this on a Mk4. Google doesn't yield a lot of results on this, since I know the MFD wasn't an option here in the US for a Golf TDI.
Thanks.
I think might be. Please post an Auto-Scan so we can see exactly what cluster you've got.
pkhoury
C?ID=123629
VCDS Version: 18.2.1.2 (x64)
VIN: 9BWGR21J244016339   License Plate: DSEL
Mileage: 479760km-298109mi   Repair Order:
Chassis Type: 1J (1J - VW Golf/Bora IV (1998 > 2006))
          76
VIN: 9BWGR21J244016339   Mileage: 479760km-298109miles
Address 01: Engine        Labels: 038-906-016-BEW.lbl
   Part No SW: 038 997 016 R    HW: 028 101 114 6
   Component: R4 1,9L EDC G000SG  0282
   Revision: 12345678    Serial number: VWZ7Z0C7100327
   Coding: 0150031
   Shop #: WSC 00002 512 00096
   VCID: 2D516209B789232CBC-5140
17911 - Load Signal from Alternator Term. DF
            P1503 - 000 - Implausible Signal
                    RPM: 1533 /min
                    Torque: 156.0 Nm
                    Speed: 24.0 km/h
                    Load: 48.6 %
                    Voltage: 14.29 V
                    Bin. Bits: 00101000
                    (no units): 0.0
16725 - Camshaft Position Sensor (G40)
            P0341 - 000 - Implausible Signal - Intermittent
                    RPM: 2814 /min
                    Torque: 188.0 Nm
                    Speed: 129.0 km/h
                    Load: 52.2 %
                    Voltage: 14.06 V
                    Bin. Bits: 00101000
                    Idle Stabilization: 0.0°KW
                    (no units): 48.0
Address 03: ABS Brakes        Labels: 1C0-907-37x-ABS.lbl
   Part No: 1C0 907 379 L
   Component: ABS FRONT MK60      0101
   Coding: 0004097
   Shop #: WSC 00000 785 00200
   VCID: 3365747151AD75DCEA-5140
   Part No: 1C0 909 605 A
   Component: 1M AIRBAG VW51 02   0008
   Coding: 12621
   VCID: 224B8135AE57EC5411-5122
   Part No: 1J0 920 926 C
   Component: KOMBI+WEGFAHRSP VDO V13
   Coding: 05234
   Shop #: WSC 00396
   VCID: 2A5B6915D667341459-5122
   9BWGR21J244016339     VWZ7Z0C7100327
            80-10 - Single-Wire Operation - Intermittent
01304 - Radio
            49-00 - No Communications
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 00028
   VCID: 70EFBB7D303B0EC4D7-5122
01304 - Radio
   Part No: 1C0 959 799 C
   Component: 8C Komfortgerát HLO 0003
   Coding: 00259
   VCID: 377D406115D599FCD6-4AE8
   Component: 8C Tõrsteuer.FS KLO 0202
   Component: 1H Tõrsteuer.BF KLO 0002
   Component: 8C Tõrsteuer.HL KLO 0202
   Component: 8C Tõrsteuer.HR KLO 0202
01359 - Internal Central Locking Switch; Passenger Side (E198)
End-------------------------(Elapsed Time: 05:12)--------------------------
Adaptation Channel 3. It likely has 100 in it. You should be able to change it to some value between 85 and 115.
Let's say you're getting an actual 40 but the cluster is indicating 42 mpg. That would be a 5% difference, so I'd try 105 as the New Value in that channel.
pkhoury
C?ID=123629
I'm not good with math, so I gotta think this through. So if the MFD reports say 40 and I'm getting 41-41.5, would I do 95 instead? I keep logs in Excel, and I'm finding that it's about 1-1.5mpg off. Oddly, when towing, fuel economy is more accurate, but still slightly off.
Mari
C?ID=150535
(MFD value/Real value)x100
(40/41)x100 = 97
(40/41.5)x100 = 96
I use an App called SpritMonitor... in the last 17.396 miles I did 58.8 MPG, MFD tells me another story...
Don't worry too much over fuel consumption report on MFD, worry about faultcodes in scan ;)
Yes, but that's in consumption (Liters / 100km). But if you're in the US and the MFD displays Miles / Gallon, then you have to flip the equation.
pkhoury
C?ID=123629
Bad news. Channel 3 is not available. Is that the only way it could be changed? It's a pull down option in adaptation, but it says it's not available when I select it, or choose that channel manually.
pkhoury
C?ID=123629
(40/41)x100 = 97
(40/41.5)x100 = 96
Regarding fault codes in the scan:
I cheated, and that was an old scan from 2018, but I haven't changed any hardware since then. I haven't used the car since May until recently, because I had a boost leak and an exhaust manifold leak (both since corrected). But I just thought to get the MFD issue fixed, as I had a pickup truck bed cover smack my 2010 JSW TDI, so this is now my primary car in the meantime. Which is fine; I love my Mk4 Golf!
Also, there were at least 2 codes concerning the databus - I'm not using a VW OEM radio (because they suck, and mine didn't work anyways). The only persistent code is the alternator DF code, but the car still works otherwise. I've had that since I bought the car.
If channel 3 is not available in your particular cluster then I'm not aware of any way to change this.
pkhoury
C?ID=123629
Well, it was worth a shot trying to check anyways. Thanks for your help, Uwe.
JonneH
C?ID=287892
Hello, i have Similar car, a seat leon 2004 1.9tdi
There is a login code that regarding to description, enables adaptation.
When i enter the login code in instrument cluster, i get a message "login Lost due to dropped session"
Is there some other code that gives me access to edit the adaptations?
Sunday,15,November,2020,11:18:40:43954
VCDS Version: 20.4.2.0
VIN: VSSZZZ1MZ4R072554   License Plate: ZOG-247
Mileage: 357090km-221885mi   Repair Order:
Chassis Type: 1M (1M - Seat Leon (2000 > 2005))
Scan: 01 02 03 08 15 17 19 22 35 36 37 46 56
VIN: VSSZZZ1MZ4R072554   Mileage: 357090km-221885miles
Address 01: Engine        Labels: 038-906-019-ARL.lbl
   Part No: 038 906 019 KG
   Component: 1,9l R4 EDC G000SG  5342
   Coding: 00002
   Shop #: WSC 06402
   VCID: 66C2336502CC7FB689-4AE4
   VSSZZZ1MZ4R072554     SEZ7Z0C2333506
Readiness: 0 0 1 1 1
Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-F.lbl
   Part No: 1C0 907 379 M
   Coding: 0019970
   Shop #: WSC 00001 001 00001
   VCID: 3466992D5490DD26C7-5140
Address 08: Auto HVAC        Labels: 1M0-820-043.lbl
   Part No: 1M0 820 043 E
   Component: 1M-CLIMATRONIC    X0702
   Coding: 00043
   Shop #: WSC 06402
   VCID: 2446696DB4704DA657-257E
   Component: 39 AIRBAG VW51 0A   0008
   Coding: 13113
   Shop #: WSC 06402
   VCID: 224A6F75AE64439625-5106
00532 - Supply Voltage B+
            07-00 - Signal too Low
Address 17: Instruments        Labels: 1M0-920-xx2-17.lbl
   Part No: 1M0 920 822 E
   Component: KOMBI+WEGFAHRSP VDO V05
   Coding: 05124
   VCID: 2A5A8755D6549BD66D-5106
   Coding: 00006
   Shop #: WSC 06402
   VCID: 70EE553D3008A106E3-5106
   Part No: 1C0 959 799 F
   Component: 9V Komfortgerát HLO 0003
   Coding: 00257
   Shop #: WSC 14400
   VCID: 3A7AB71526F42B561D-4AE4
   Component: 9V Tõrsteuer.FS KLO 0202
   Component: 9V Tõrsteuer.BF KLO 0202
   Component: 9V Tõrsteuer.HL KLO 0202
   Component: 9V Tõrsteuer.HR KLO 0202
End-------------------------(Elapsed Time: 02:59)--------------------------
Address 01: DTCs cleared
That Login is not applicable to the instrument cluster. A login should not be needed to adjust the channel that adjusts the fuel consumption calculation, assuming the cluster in question has such a channel.
JonneH
C?ID=287892
okay thank you, this means i cannot change the values, just like the original poster
Jonne
