Results 1 to 10 of 16
Thread: 2012 seat Ibiza 1.6TDI fuel rail pressure to low. 0087.
    Jul 2019
    Peebles, Scotland
    2012 seat Ibiza 1.6TDI fuel rail pressure to low. 0087 ?
    Please post an auto-scan and JPPSG the RTFB if seeking specifications and safety guidelines.
    A little more information would be helpful.........
  3. Likes Uwe liked this post
    Jul 2019
    Peebles, Scotland
    Tuesday,30,July,2019,08:16:28:26536
    VCDS Version: 19.6.0.2 (x64)  HEX-V2 CB: 0.4505.4
    VIN: VSSZZZ6JZCR122168   License Plate:
    Chassis Type: 6J-SE25 (6N0)
    Scan: 01 03 04 08 09 10 15 17 19 25 2E 44 4B 56 77
    VIN: VSSZZZ6JZCR122168   Mileage: 90830km-56439miles
    Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 LE    HW: 03L 906 023 Q
       Component: R4 1.6l TDI   H33 9978
       Revision: --H33---    Serial number:
       Coding: 00114016002500080000
       ASAM Dataset: EV_ECM16TDI02103L906023LE 003011
       ROD: EV_ECM16TDI02103L906023LL.rod
       VCID: 74B1DDCFEE3D5527DE9-8020
    10116 - Fuel Rail/System Pressure
              P0087 00 [096] - Too Low
                        Mileage: 90827 km
                        Date: 2019.07.29
                        Time: 22:23:14
                        Engine speed: 2748.25 /min
                        Normed load value: 100.0 %
                        Vehicle speed: 75 km/h
                        Coolant temperature: 91 C
                        Intake air temperature: 33 C
                        Voltage terminal 30: 14.118 V
                        Fuel high pressure: actual value-FUP_FIL: 109.546 MPa
                        Fuel pressure regulator valve: specified value rail pressure-LV_PCV_CTL: 00000000
                        Fuel level-FTL_CAN: 39 l
                        Fuel temperature-TFU: 27 C
                        Fuel Metering Valve-VCV: 32.184 %
                        Fuel Pressure Regulator Valve-PCV: 41.743 %
                        Fuel high pressure commanded value_1-FUP_SP_KPA_ENVD: 145922.852 kPa
    7476 - Fuel Pressure Regulation Valve 2 Control Difference
              P229A 00 [096] - Pressure too Low
                        Mileage: 90827 km
                        Date: 2019.07.29
                        Time: 22:23:14
    Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ABS82.clb
       Part No SW: 6R0 907 379 AD    HW: 6R0 907 379 AB
       Component: ABS8.2 front  H03 0001
       Revision: --------
       Coding: 100200DB006F00B4082600E800D900000000
       Shop #: WSC 04941 000 00000
       VCID: 0059811FAA457987CA1-8054
    Address 08: Auto HVAC (J255)       Labels: 6R0-907-044.clb
       Part No SW: 6J0 820 043 C    HW: 6J0 820 043 C
       Component: Climatronic   H07 0606
       Revision: S0000000
       VCID: 2411ED8F1EDD85A78E9-8070
       Part No SW: 7H0 937 089 F    HW: 7H0 937 089
       Component: BCM T5GP Li4  H50 0254
       Revision: BS050001    Serial number: 0465 016120173
       Coding: 24880BE88861250093300EF06ECB8EC80F80602F608C2009200000000000
       Shop #: WSC 64564 324 38760
       VCID: 392F2CFB895FE84FCDF-806C
       Component: RLS 010212 05  54  0403
       Coding: 02242D
       Subsystem 2 - Part No SW: 6R0 959 802 N    HW: 6R0 959 802 N  Labels: 6R0-959-802.CLB
       Component: J386__TSG_FT  003 3110
       Coding: 030000
       Subsystem 3 - Part No SW: 6R0 959 801 Q    HW: 6R0 959 801 Q  Labels: 6R0-959-801.CLB
       Component: J387__TSG_BT  003 3110
       Coding: 020000
       Subsystem 4 - Part No: 1K8 951 171 A
       Component: DWA-Sensor 00  001 0103
       Subsystem 5 - Part No: 1K8 951 605 B
       Component: LIN BACKUP HO  H11 9005
       Subsystem 6 - Part No: 1K8 951 171 A
       Subsystem 7 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
       Component: J388__TSG_HL  002 3121
       Subsystem 8 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
       Component: J389__TSG_HR  002 3121
    Address 10: Park/Steer Assist (J446)       Labels:| 6J0-919-475.clb
       Part No SW: 6J0 919 475 B    HW: 8P0 919 475 M
       Component: PARKHILFE 4K  H08 0008
       Revision: --------    Serial number: 36861132200647
       Coding: 000007
       Shop #: WSC 06402 785 00200
       ASAM Dataset: EV_SE250ParkiAssis2 S01006
       ROD: EV_SE250ParkiAssis2.rod
       VCID: 353720CBA5C70C2F297-8060
       Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
       Component: VW10AirbagA0D H09 0020
       Revision: --------    Serial number: 003GX012VZ7%
       Coding: 003044
       Shop #: WSC 06401 785 00200
       ROD: EV_AirbaVW10BPAVW250.rod
       VCID: 4ACD6337DC3973D7545-801E
       Serial number: 3495RRB404R126SEC20E
       Serial number: 3505RRB404P126SEH0T-
       Part No SW: 6J0 920 903 H    HW: 6J0 920 903 H
       Component: KOMBI         H02 0504
       Coding: 410A00
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
       VCID: 2F3B12A3479B36FF63B-807A
       Part No SW: 6N0 909 901     HW: 7H0 937 089
       Component: GW-K-CAN TP20 H50 0254
       Revision: BS050001
       Coding: 322300
       VCID: 70B9D1DF9AA569073A1-8024
       Component: IMMO          H02 0504
       VCID: 6A8DC3B7BCF993D7745-803E
       Part No SW: 6J0 035 342 E    HW: 6J0 035 342 E
       Revision: A1001003    Serial number: 7661738846
       Coding: 020000
       VCID: 2615F78768E177B790D-8072
       Part No: 6R0 423 156 B
       Component: LenkhilfeTRW        V277
       Coding: 10121
       Shop #: WSC 06402
       VCID: 2F3B12A34E5B36FF63B-807A
    Address 4B: Multifunc. Module        Labels: 6J0-959-441.clb
       Part No: 6J0 959 441 A
       Component: MF-Modul       0007 0001
       Shop #: WSC 77005 000 00000
       VCID: 313F14DB5D2F200F75F-8064
    Address 56: Radio (J503)       Labels:. 6J0-035-153.clb
       Part No SW: 6J2 035 153 G    HW: 6J2 035 153 G
       Component: Radio         H15 0204
       Revision: R0000000    Serial number: SEZAZ2L1961825
       Coding: 0005020002
       VCID: 2A0D03B77CF953D7B45-807E
       Part No SW: 7P6 035 730 F    HW: 7P6 035 730 F
       Component: TELEFON       H13 2730
       Revision: 1B001001    Serial number: 00007661841208
       Coding: 0200000001010110
       ASAM Dataset: EV_UHVNA A01015
       ROD: UHVNA.rod
    13635840 - Supply voltage
              U1011 00 [000] - Voltage too Low
              [Klemme 30: unterer Grenzwert unterschritten]
              U1400 00 [000] - -
    End----------(Elapsed Time: 01:58, VBatt start/end: 12.4V/12.4V)-----------
    Tuesday,30,July,2019,08:12:40:26536
    VCDS Version: Release 19.6.0 (x64) Running on Windows 10 x64
                    Address 01: Engine       Labels: 03L-906-023-CAY.clb
    Control Module Part Number: 03L 906 023 LE    HW: 03L 906 023 Q
      Component and/or Version: R4 1.6l TDI   H33 9978
               Software Coding: 00114016002500080000
                Work Shop Code: WSC 131071 1023 2097151
                  ASAM Dataset: EV_ECM16TDI02103L906023LE 003011 (SE25)
                        Mileage: 90827 km
                        Date: 2081.14.23
                        Time: 22:23:14
                        Mileage: 90827 km
                        Date: 2081.14.23
                        Time: 22:23:14
    Did you do a volume and PSI test of the fuel system for lift, boost and HPP ?
    Ever JPPSG?
    https://forums.ross-tech.com/showthr...l=1#post125791
    Jul 2019
    Peebles, Scotland
    Sorry but I'm a novice when it comes to mechanics. Looking to see if there are any common failures a diyer can do?
    Jul 2019
    Peebles, Scotland
    VCDS Version: Release 19.6.1
    Mileage: 92973 km
    Date: 2083.14.11
    Time: 08:19:06
    Engine speed: 1418.75 /min
    Vehicle speed: 39 km/h
    Coolant temperature: 95 C
    Intake air temperature: 17 C
    Voltage terminal 30: 14.231 V
    Fuel high pressure: actual value-FUP_FIL: 112.439 MPa
    Fuel pressure regulator valve: specified value rail pressure-LV_PCV_CTL: 00000001
    Fuel level-FTL_CAN: 28 l
    Fuel temperature-TFU: 30 C
    Fuel Metering Valve-VCV: 21.228 %
    Fuel Pressure Regulator Valve-PCV: 50.626 %
    Fuel high pressure commanded value_1-FUP_SP_KPA_ENVD: 129931.641 kPa
    HQ
    Jef
  9. #8
    Jul 2019
    Peebles, Scotland
    please see auto scan in previous posts I've made
  10. #9
    Please see JPPSG
    Did you verify the mechanical components for fuel PSI?
  11. #10
    Jul 2019
    Peebles, Scotland
    Not sure how to test high pressure fuel pump?
