I've installed the trailer control module in my Highline Tiguan. I've got every option including ACC, 360 area view. I believe the trim line would be similar to an SEL Premium Plus. I was wondering if anyone has a similar Trimline with a hitch module installed that could kindly provide an auto scan of all modules. I am having a few issues with several of them. Kindly appreciated.
Thursday,29,August,2019,10:36:12:52563
VCDS Version: 19.6.1.0 (x64)
Chassis Type AX-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 2B 36 3C 42 44 47 4B
52 5F 69 6C 6D A5 BB BC CA
VIN: 3VV4B7AX5JM195*** Mileage: 20977km-13034miles
4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
CA-Sunroof -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-DGUA) Labels:. 06L-907-115-V1.clb
Part No SW: 5NA 907 115 A HW: 06L 907 309 B
Component: R4 2.0l TFSI H31 0004
Revision: 1DH31000
Coding: 012A00122476010FB4000000000000000000000000000000
Shop #: WSC 00066 790 00455
ASAM Dataset: EV_ECM20TFS0115NA907115A 001005
ROD: EV_ECM20TFS0115NA907115A.rod
VCID: 3C7CC8A4B7A6F4AF85-8068
Readiness: 0000 0100
Address 02: Auto Trans (J217) Labels: 09G-927-749-V2.clb
Part No SW: 09G 927 158 Q HW: 09G 927 158
Component: AISIN AQ8 206 3486
Coding: 0002000100000000000000000000000000000000
Shop #: WSC 00066 790 00240
ROD: EV_TCMAQ450031_VW37.rod
VCID: 4182B950D0449947D6-8014
Part No SW: 5Q0 614 517 CF HW: 5Q0 614 517 AD
Component: ESC H25 0513
Revision: 00000000 Serial number: 51668000000324
Coding: 0BFA6BA454291B71C57D0306A2C349D0D62AD8A3C045927C38415058C2AA4200002864121A1C230935351919323200
Shop #: WSC 01383 790 50316
VCID: 77F61788CE0017F7A8-8022
Part No SW: 3Q0 959 435 G HW: 3Q0 959 435 G
Component: VWKESSYMQB 037 0907
Revision: 00037000 Serial number: 0479643969
Coding: 132C2C0723
VCID: 3E78C2ACA1BAE6BFAB-806A
Subsystem 1 - Part No SW: 3G0 962 243 C HW: 3G0 962 243 C
Component: GEB.F.Heckoef H17 0906
Serial number: 11033943
Address 08: Auto HVAC (E87) Labels:| 3V0-907-044.clb
Part No SW: 5NN 907 044 K HW: 5NN 907 044 K
Component: AC Automat H35 4401
Revision: 20K03000 Serial number: 00000D00177998
Coding: 00020024200118001105010C1211140E
ASAM Dataset: EV_ACClimaPrehVW37X 002025
ROD: EV_ACClimaPrehVW37X.rod
VCID: 54AC80043F361CEF6D-8000
Part No SW: 5Q0 937 087 AS HW: 5Q0 937 087 AP
Component: BCM PQ37BOSCH 034 0246
Revision: -------- Serial number: C86428061802XF
ROD: EV_BCMBOSCH_018.rod
VCID: 0C1C5864A786042FF5-8058
Subsystem 1 - Part No SW: 5NN 955 119 HW: 5NN 955 119 Labels: 1KX-955-119.CLB
Component: 326 LL 180618 034 0373
Serial number: 18060522172460
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 050 0107
Serial number: S8Y18M05D17H12M46S35
Coding: 00A8DD
Part No SW: 5QA 919 294 E HW: 5QA 919 294
Component: PDC 8 KanalH07 0443
Serial number: 000145450R18191
Coding: 0471255911
VCID: 4E98926C111A763F5B-801A
Address 13: Auto Dist. Reg (J428) Labels:| 2Q0-907-572.clb
Part No SW: 2Q0 907 572 M HW: 2Q0 907 572 B
Component: ACCCONTIMQB H02 0233
Coding: 320000CA5CFF8728749C8145304097
Part No SW: 5Q0 959 655 AG HW: 5Q0 959 655 AG
Component: AirbagVW21 004 0336
Serial number: 003NUM09YCCG
Coding: 8CCCFC00000000005000001AC20800000065
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 050A6D4084EC7567AA-8050
Occupant Detection:
Component: BF-Gewichtss. H13 0022
Serial number: IBH000000000009NC4CK
Coding: 303352
Subsystem 2 - Part No SW: ----------- HW: 480 002 406 18
Serial number: 35700000000B04693038
Subsystem 3 - Part No SW: ----------- HW: 480 002 306 18
Serial number: 35800000000AE64D203P
Subsystem 4 - Part No SW: ----------- HW: 480 401 105 18
Serial number: 35100019B29E1EF3A6DV
Subsystem 5 - Part No SW: ----------- HW: 480 401 205 18
Serial number: 3520001A729E73234691
Subsystem 6 - Part No SW: ----------- HW: 480 400 206 18
Component: FrontSensor_D 003 6149
Serial number: 3550001A329F25F3E7BO
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 400 206 18
Component: FrontSensor_P 003 6149
Serial number: 3560001A329F25F4984F
Part No SW: 5Q0 953 507 JF HW: 5Q0 953 549 D
Component: Lenks. Modul 004 0140
Revision: -------- Serial number: 21051820241047
Coding: 0C10
VCID: 030E73588AD84B5784-8056
Part No SW: 5NA 920 791 B HW: 5NA 920 791 B
Component: KOMBI 409 3197
Coding: 0BAD041AEF88880902886B0B54010000A0000000
VCID: 4280B65CD542825FCF-8016
Part No SW: 3Q0 907 530 L HW: 3Q0 907 530 C
Component: GW MQB High 518 5323
Serial number: 09061800840792
Coding: 030500347F085900FB03225A1E0F00010001070000000000000000000000
ROD: EV_GatewNF.rod
VCID: 3874D4B4839ED88F61-806C
Subsystem 2 - Part No SW: 5NN 959 442 A HW: 5NN 959 442 A
Component: E221__MFL-TAT H06 0023
Serial number: 0861820143502352BO2B
Coding: 2E0000
Subsystem 3 - Part No SW: 5QA 915 181 D HW: 5QA 915 181 D
Serial number: 5021225900
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
Component: Haldex4Motion H52 7084
Serial number: HA1-00004.04.18
Coding: 0101
VCID: 4C9C9864E706442F35-8018
Part No SW: 3Q0 905 861 B HW: 3Q0 905 861 B
Component: ELV-MQBB H05 0020
Serial number: 18000168194007
Coding: 0800000000000000
ROD: EV_ELVMarqMQBA0_VW37.rod
VCID: 336EE3989AF83BD754-8066
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 5Q0 959 760 C HW: 5Q0 959 760 C
Component: Sitzmemory H09 0024
Serial number: Y0006RDP36442
Coding: 0010000000000500018280808080000000008101000000F400
ASAM Dataset: EV_SeatMemorDriveSide 002022
VCID: 3D7AC5A0ACBCFDA7B2-8068
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Component: HRE_Master H12 0081
Serial number: 0480586284
Coding: 02012103
ROD: EV_HREntryHella_VW37.rod
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C
Component: HRE_Slave H12 0081
Serial number: 0480682456
Coding: 020121
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 011 0032
Serial number: 5038819100017
Coding: 003F1B205200028000000000
VCID: 4796A748FE60A77718-8012
Address 44: Steering Assist (J500) Labels:| 5Q0-909-143.clb
Part No SW: 5Q0 909 143 P HW: 5Q0 909 143 E
Component: MQB_PP_APA 204 2051
Revision: 00000000 Serial number: 0002484535
Coding: 01010011004001
ROD: EV_SteerAssisVWBSMQBA_009_VW37.rod
VCID: 4084BC54DB4E904FD9-8014
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5Q0 035 456 A HW: 5Q0 035 456 A
Component: MIB2_lite_amp H40 0200
Revision: 00000001 Serial number: VWZ8Z1JMD02EL7P
Coding: 2200000000AAAAAA000000000000
ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003
ROD: EV_AMPMst12C1Gen2ALPI.rod
VCID: 2E58F2EC71DA163F3B-807A
Address 4B: Multifunc. Module
Interface not compatible.
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 011 0032
Serial number: 6038819200746
Coding: 003F13205E00028000000000
VCID: 4688AA4CF96ABE7FE3-8012
Part No SW: 3Q0 035 876 B HW: 3Q0 035 876 B
Component: MU-S-NS-US 851 0867
Coding: 027306020000000051220002001828001F0506E401200405C6
Shop #: WSC 00066 790 00317
ROD: EV_MUStd4CDELP_VW37.rod
Subsystem 1 - Part No SW: 5G6 919 605 D HW: 5G6 919 605 D
Component: ABT_Std-2_Nav H52 8130
Serial number: VWZ6ZJV1370512
Subsystem 2 - Part No SW: 3G0 919 866 BP HW: -----------
Component: NAR 2018 --- 0715
B11CF 53 [009] - Deactivated
Reset counter: 54
Mileage: 20977 km
Date: 2019.08.29
Time: 10:19:43
Voltage terminal 30: 12.0 V
SDARS_tuner_status_2-Antenna current: 103 mA
SDARS_tuner_status_2-Reception quality: weak_signal
SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 02
SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 02
Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
Part No SW: 5Q0 907 383 N HW: 5Q0 907 383 N
Component: Anhaenger H27 0264
Revision: 8A001003 Serial number: 0457569528
Coding: 0200000202000000
136203 - Supply Voltage
P1757 00 [009] - Open Circuit
Reset counter: 54
Mileage: 20794 km
Date: 2019.08.27
Time: 14:29:05
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 5Q0 907 556 C HW: 5Q0 907 556
Component: Areaview 2 H13 0608
Serial number: C854707JG030875
Coding: 01230601210020173000400C
ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
VCID: 3972D1B0B894C1879E-806C
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 5Q0 959 107 Q HW: 5Q0 959 107 C
Component: HDSG-Modul H12 0266
Revision: -------- Serial number: A2-C758-8700-2
Coding: 0AA8
ASAM Dataset: EV_DeckLidCONTIAU736 001016
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3QD 980 654 HW: 3Q0 980 654 A
Component: MQB_B_MFK H08 1272
Serial number: 03031841K20533
Coding: 0003070601020201002213578150490084000E200120
VCID: 08146474B3FE680FD1-805C
1122656 - Databus
Reset counter: 54
Mileage: 20977 km
Date: 2019.08.29
Time: 10:21:54
Control Module temperature: 30 °C
Outside air temperature: 18.5 °C
Vehicle speed: 0.00 km/h
System run time: 798.5 s
Voltage terminal 15: 11.8 V
mid: 02 10
Status of camera: operational
Engine_Running_Info: 0
Software_Info_4: 2
Software_Info_3: 7
Software_Info_2: 2
Software_Info_1: 1
Part No SW: 5Q4 959 595 E HW: 5Q4 959 595 B
Component: TSG HFS 012 0032
Serial number: 0000323250224
Coding: 002011200101028000000000
ASAM Dataset: EV_DCURearDriveMAXCONT 006001
VCID: 4992A170E87451070E-801C
Component: TSG HBFS 012 0032
Serial number: 0000321174635
ASAM Dataset: EV_DCURearPasseMAXCONT 006001
