Results 1 to 6 of 6
Thread: Case Study: 15202 - Actuator Module for Turbocharger 1 P00AF 00 [109] - Stuck
    Tartu, Estonia
    14846 - Turbocharger Boost Control Position Sensor Circuit
              P2563 00 [096] - Implausible Signal
    Issue here was, that customer went to dealer as warranty has just ran out. Dealer suggested new turbocharger to be fitted.
    He then came to us by hearing we might have other solution.
    At initial diagnostic we confirmed the same thing that waste gate doesn't move. My thought was that it must have similar issue to 1.2-1.4 engines waste gate rod getting seized.
    Read here: https://forums.ross-tech.com/showthr...l=1#post106771 and here: https://www.golfmk7.com/forums/showthread.php?t=28690
    It was not possible to remove circlip just from underneath the car and we suggested removing the turbocharger to have better access.
    While starting the removal process it became clear that circlip can be easily accessed if right driveshaft and catalytic converter are removed.
    Circlip removal was easy, removing spindle wasn't, as it was seized pretty good. Using heat and lot of patience it gave up and was finally removed.
    Left to do here was only to clean spindle really good, reinstall it with good grease and assemble everything else.
    Using output test of VCDS showed good movement of spindle and rod with no resistance what-so-ever.
    Most of the credit goes to my good co-worker Roland who didn't gave up and fixed this issue for customer.
    I believe this issue might be happening on all EA888 engines... .
    And autoscan for reference.
    Friday,16,August,2019,08:59:03:39429
    VCDS Version: 19.6.1.0 (x64)  HEX-NET CB: 0.4508.4
    Dealer/Shop Name: Tarfor OÜ
    VIN: TMBJE9NE8E0   License Plate:
    Mileage: 101350km-62975mi   Repair Order:
    Chassis Type: NE-SK37 (5Q0)
    Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F 69 A9
    VIN: TMBJE9NE8E0   Mileage: 101350km-62975miles
    Address 01: Engine (J623-CHHB)       Labels:. 06K-907-425-V1.clb
       Part No SW: 5G0 906 259     HW: 06K 907 425 B
       Component: 2.0l R4 TFSI  H13 0007
       Revision: --H13---
       Coding: 0C1900322434010B0000
       Shop #: WSC 73430 031 00133
       ASAM Dataset: EV_ECM20TFS0215G0906259 001011
       ROD: EV_ECM20TFS0215G0906259.rod
       VCID: EB96BF86021F7517DC-80BE
                        Mileage: 101069 km
                        Date: 2019.08.09
                        Time: 11:09:33
                        Vehicle speed: 2 km/h
                        Coolant temperature: 45 °C
                        Intake air temperature: 27 °C
                        Voltage terminal 30: 10.000 V
                        Unlearning counter according OBD: 28
                        Status of charge air pressure control valve basic setting-LV_BPA_AD_REQ[0]: 00000001
                        Charge air pressure control valve uncond voltage sensor: 2.5342 V
                        Charge air pressure control valve position: target value: 0.00 %
                        Charge air pressure control valve position: actual value: 23.84 %
                        Charge air pressure control valve activation pulse duty factor: -35.94 %
                        Charge air pressure control valve voltage: position closed: 3.2474 V
                        STATE_BPA[0]: AD
                        Fault Frequency: 8
                        Mileage: 101069 km
                        Date: 2019.08.09
                        Time: 11:09:00
                        Engine speed: 2571.00 /min
                        Vehicle speed: 23 km/h
                        Coolant temperature: 36 °C
                        Intake air temperature: 25 °C
                        Voltage terminal 30: 14.531 V
                        Status of charge air pressure control valve basic setting-LV_BPA_AD_REQ[0]: 00000000
                        Charge air pressure control valve uncond voltage sensor: 1.7676 V
                        Charge air pressure control valve position: target value: 89.24 %
                        Charge air pressure control valve position: actual value: 49.32 %
                        Charge air pressure control valve activation pulse duty factor: 77.41 %
                        STATE_BPA[0]: OPM
       Part No SW: 5Q0 907 379 R    HW: 5Q0 907 379 F
       Component: EMB8 EHCB     H31 0356
       Revision: 00000000    Serial number: 61124000000A4A
       Coding: 1C076B915422296F007D060941CA2938D62A9400608294F600400070C009
       Shop #: WSC 73430 031 00063
       ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
       ROD: EV_Brake1UDSContiMK100ESP_033_VW37.rod
       VCID: CBD61F06625F9517BC-809E
       Part No SW: 5E0 907 044 N    HW: 5E0 907 044 N
       Component: Climatronic   H03 0907
       Revision: 00001K06
       Coding: 02010004000100011005000100100000
       ASAM Dataset: EV_ACClimaBHBVW37X 003017
       VCID: B02C68EAEBB9D6CFA9-80E4
       Air quality sensor:
       Part No SW: 5Q0 937 086 Q    HW: 5Q0 937 086 Q
       Component: BCM PQ37BOSCH 026 0097
       Revision: --------    Serial number: 86580205141019
       Coding: 0C020A66C24722FB07A04082B11C07280000000000000000000000000000
       Shop #: WSC 73430 790 00133
       ASAM Dataset: EV_BodyContrModul1UDSBosc 012003
       ROD: EV_BCMBOSCH_012.rod
       VCID: C8DC200A73297E0F91-809C
       Subsystem 1 - Part No SW: 5E1 955 119     HW: 5E1 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS371 140415  041 0570
       Serial number:         140424090521
       Coding: 065DDD
       Component: RLFS  024 0042
       Serial number: Y14M05D07H05M46S30S8
       Coding: 02805D
       Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
       Serial number: 000000000ZY140511W06
       Serial number: 00000000000059363646
    Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-283.clb
       Part No SW: 5Q0 919 283 B    HW: 5Q0 919 283
       Component: PARKHILFE 4K  H09 0033
       Revision: --------    Serial number: 60831411900727
       Coding: 0001050101
       ASAM Dataset: EV_EPHVA14AU3700000 002018
       VCID: B83C50CA03C90E8FE1-80EC
       Part No SW: 3Q0 959 655 AB    HW: 3Q0 959 655 AB
       Component: Airbag VW20   012 0189
       Revision: --------    Serial number: 003P3P2QMLNL
       Coding: 98FCC000000000005C5400CC000800000065
       ROD: EV_AirbaVW20TS6VW48X.rod
       VCID: FEB086D2616DF0BF6B-80AA
       Subsystem 1 - Part No SW: -----------    HW: 454 002 204 14
       Serial number: 3576U0000008C890AF0R
       Subsystem 2 - Part No SW: -----------    HW: 454 001 904 14
       Serial number: 3586U000000B6D796F0X
       Subsystem 3 - Part No SW: -----------    HW: 454 802 004 14
       Serial number: 3516RA5D863030000004
       Subsystem 4 - Part No SW: -----------    HW: 454 802 004 14
       Serial number: 3526RC3EA8503000000C
       Subsystem 5 - Part No SW: -----------    HW: 454 801 903 14
       Serial number: 3556VE57A2D03000000I
       Part No SW: 5Q0 953 507 AC    HW: 5Q0 953 549
       Revision: --------    Serial number: 30041404400743
       Coding: 1400
       VCID: F7BE93F64E57C1F728-80A2
       Part No SW: 5E0 920 871 C    HW: 5E0 920 871 C
       Component: KOMBI         333 2210
       Coding: 07A509002980000801082A00000000
       VCID: A81C808AD3699E0F71-80FC
       Part No SW: 5Q0 907 530 Q    HW: 5Q0 907 530 F
       Component: GW MQB High   125 1164
       Revision: --------    Serial number: 0001924458
       Coding: 030100342F085900EF00026A080F00010001050000000000000000000000
       ASAM Dataset: EV_GatewLear 010015
       ROD: EV_GatewLear_010.rod
       VCID: BFCE3BD626E739B720-80EA
       Subsystem 2 - Part No SW: 5E0 919 719 A    HW: 5E0 919 719 A
       Component: E221__MFL-PR6  H04 0130
       Serial number: 000000000B1229250414
       Subsystem 3 - Part No SW: 5Q0 915 181 E    HW: 5Q0 915 181 E
       Component: J367-BDMHella  H03 8043
       Serial number: 6463323203
       Part No SW: 5Q4 959 593 B    HW: 5Q4 959 593 B
       Component: TSG FS        009 0014
       Serial number: 0000101630324
       Coding: 001D0020D000040000001100
       VCID: C4C4343A4F015A6F7D-8090
       Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000002520980
       Coding: 010200
       Part No SW: 3Q0 909 144 F    HW: 3Q0 909 144 F
       Component: EPS_MQB_ZFLS  503 5043
       Coding: 8103
       ROD: EV_SteerAssisMQB_010.rod
       VCID: B52259FE14DBF3E7FA-80E0
       Part No SW: 5Q4 959 592 B    HW: 5Q4 959 592 B
       Component: TSG BFS       009 0014
       Serial number: 0000101598853
       VCID: C3C637264A0F5D5744-8096
       Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000002480637
       Coding: 190200
       Coding: 03DA02003F000000
       Shop #: WSC 73430 790 00063
       VCID: C0CC382A5B19464F59-8094
       Subsystem 1 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
       Component: LeiMo links  H06 0009
       Coding: 3E0000
       Subsystem 2 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H06 0009
       Coding: 3E0000
    Address 5F: Information Electr. (J794)       Labels:| 5E0-035-MIB-STD1.clb
       Part No SW: 5E0 035 840 A    HW: 5E0 035 840 A
       Component: MU-S--ER      040 0490
       Serial number: S3E00405140572
       Coding: 037352000000000011110002000100002F0001A40100010000
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: 9F0E9B56862759B700-80CA
       Subsystem 1 - Part No SW: 5E0 919 605 B    HW: 5E0 919 605 B
       Component: ABT_Std_Plus  H50 0022
       Serial number: SKZ8Z9PK60150S
       Part No SW: 5Q0 907 383     HW: 5Q0 907 383
       Component: Anhaenger     H11 0030
       Revision: 6A001003    Serial number: 00008200286511
       Coding: 0100000200000000
       ASAM Dataset: EV_TrailFunctDemouHella 001001
       ROD: EV_TrailFunctDemouHella.rod
       VCID: F4A4A4FA5F21AAEF0D-80A0
       Part No SW: 5E0 907 159     HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0001
       Serial number: 140331200219
       VCID: E99AC58E08E36707AE-80BC
    End----(Elapsed Time: 01:40, VBatt start/end: 11.8V/11.7V. VIgn 11.7V)-----
    The world is my oyster...
    HQ
    As per forum rules, #8:
    Jef
    Reaming hole and using a high heat never seize from Wurth & with copper might work better than grease.
  4. Likes Uwe liked this post
    Verified VCDS User Danners74's Avatar
    Jun 2016
    Hot bolt paste...….ive done a few.
    Apr 2020
    Yep, this has been happening on my 65' tts. Manually pulling the arm back and forth seems to fix the problem temporarily.
    Until i can get in there and give it a proper service anyway.
    Quote Originally Posted by Placeborick View Post
    NB - most people on here are not from the UK so don't understand UK number plates, so saying 65' won't mean anything to them, always best to quote the model year (note NOT year of registration, that's not the same thing).
    UK 65 plate = registered between September 2015 and February 2016, so probably (but not definitely as the dealer could have had it in stock) a 2016 MY vehicle.
  8. Likes Uwe, MartinsX liked this post
