Results 1 to 10 of 20
Thread: 2016 GOLF R DQ500 BASIC SETTING ABORT ISSUE
    Jul 2019
    NJ, USA
    Good Afternoon all.
    I have a 2016 Golf R that I have swapped a DQ500 into. I have been fighting with issues for a long time on this car. finally was able to install a new mechtronics unit which leads me to my new issue.
    When I try to perform basic setting for the transmission I get abort code 10. Anyone know what that is?
    ign on
    engine at idle
    dsg fluid 65 deg c
    parking brake on
    vehicle level
    start the adaptation and i get aborted safety reasons.
    no fault codes.
    attached is the auto scan and controller map. let me know if anyone could shed some light on this for me.
    Wednesday,28,August,2019,00:02:49:11506
    VCDS Version: 19.6.1.0 (x64)
    Dealer/Shop Name: 3
    VIN: WVWVF7AU0HW142856   License Plate:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 3C 42 44 47 52
              55 5F 75 A5 A9
    VIN: WVWVF7AU0HW142856   Mileage: 25462km-15821miles
    Address 01: Engine (J623-CYFB)       Labels:. 06K-907-425-V1.clb
       Part No SW: 8V0 906 259 H    HW: 06K 907 425 E
       Component: 2.0l R4 TFSI  H13 I718
       Revision: --H13---
       Coding: 091D00122466000E3004
       ASAM Dataset: EV_ECM20TFS0208V0906259H 001003
       ROD: EV_ECM20TFS0208V0906259H.rod
       VCID: 45818740C48D1467EA-8010
    Readiness: 1010 0101
       Part No SW: 0DL 300 043 T    HW: 0DE 927 711
       Component: TVS DQ500     H12 9999
       Revision: 00H12V32
       VCID: 3E73E8ACA15B47BFAB-806A
       Part No SW: 5Q0 614 517 CH    HW: 5Q0 614 517 AH
       Component: ESC           H62 0743
       Revision: 00000000    Serial number: 63206000000865
       Coding: 01FA6BA15424096E457F030540C96980D62A90A2C0029637184050D8C2A8430000000012121212B835351919323200
       VCID: 79F93BB0F8F5A087DE-802C
    0128 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
                        Reset counter: 223
                        Mileage: 25462 km
                        Date: 2018.12.12
                        Time: 00:40:27
    0297 - Steering Angle Sensor
              B1168 F2 [008] - Not Initialized
                        Reset counter: 222
                        Mileage: 25462 km
                        Date: 2018.12.12
                        Time: 01:02:23
    4202 - Rear Right ABS Wheel Speed Sensor
              C101D F1 [008] - Magnetic Field too Low
                        Reset counter: 182
                        Mileage: 25462 km
                        Date: 2018.12.12
                        Time: 01:16:47
    32928 - Function Restricted due to Insufficient Voltage
              U1400 00 [009] - -
                        Reset counter: 223
                        Mileage: 25462 km
                        Date: 2019.01.17
                        Time: 01:45:40
       Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
       Revision: 00021000    Serial number: 0423411988
       Coding: 032C0C
       VCID: 3B75E1B8B24952978C-806E
       Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
       Revision: 00001K08
       Coding: 0002000420010000010500001251140A
       Shop #: WSC 12345 123 61029
       VCID: 6DD11FE0BCBD0C2742-8038
    262914 - Refrigerant Pressure
              B10AB F0 [009] - Too Low
                        Reset counter: 181
                        Mileage: 25462 km
                        Date: 2018.12.12
                        Time: 01:02:27
                        Outside air temperature: 28.5 °C
                        Engine speed: 0 /min
                        Temperature after evaporator: 32.7 °C
                        System run time-Terminal 15 on: 5 s
              B10CD 00 [008] - -
                        Reset counter: 223
                        Mileage: 25462 km
                        Date: 2018.12.14
                        Time: 18:06:58
                        Voltage terminal 30: 7.9 V
                        CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 3
       Part No SW: 5Q0 937 085 BL    HW: 5Q0 937 085 AF
       Component: BCM MQBAB HNA H24 0175
       Serial number: 01061631400540
       Coding: 00011B46C041A2E169E44000091407201800000000000000000000000000
       ROD: EV_BCMBOSCH_015.rod
       VCID: 04075A448F37ED6FBD-8050
       Component: WWS    161024  043 0551
       Serial number:         161107073447
       Component: RLHS  042 0105
       Serial number: S3Y16M11D21H10M36S25
       Coding: 00A8DD
    131330 - Supply voltage
                        Reset counter: 223
                        Time: 00:00:00
    131586 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
                        Reset counter: 223
    136458 - Terminal 15
              B1148 15 [008] - Open or Short to Plus
                        Reset counter: 223
                        Mileage: 25462 km
                        Date: 2019.01.17
                        Time: 01:45:35
       Revision: --------    Serial number: 39331631710835
       Coding: 0071155011
       VCID: 43859958CAB92A57C4-8016
    1113107 - Front Parking Aid Sensor(s)
              B10FC 13 [008] - Open Circuit
                        Reset counter: 180
                        Mileage: 25462 km
                        Date: 2018.11.27
                        Time: 05:19:05
              U1400 00 [008] - -
                        Reset counter: 223
    13637120 - Databus
                        Reset counter: 223
                        Mileage: 25462 km
                        Date: 2018.12.15
                        Time: 01:36:06
    13637426 - Databus
                        Reset counter: 222
                        Mileage: 25462 km
                        Date: 2018.12.12
                        Time: 01:02:23
       Part No SW: 5Q0 907 572 H    HW: 5Q0 907 572 H
       Component: ACC BOSCH MQB H10 0620
       Coding: 350000C151FFC428949C810530301600000000000000000000
       ASAM Dataset: EV_ACCBOSCHVW416 002005
       VCID: 3C77E2A4B74755AF85-8068
    7 Faults Found:
    2055 - Databus
                        Reset counter: 222
                        Mileage: 25462 km
                        Date: 2018.12.12
                        Time: 01:02:25
                        Control Module temperature: 33 °C
                        Voltage terminal 15: 13.0 V
                        Status_ACC_System: ACC_irreversible error
    0803 - Databus
                        Reset counter: 222
                        Mileage: 25462 km
                        Date: 2018.12.12
                        Time: 01:02:24
                        Voltage terminal 15: 13.3 V
    2086 - Databus
                        Reset counter: 223
                        Mileage: 25462 km
                        Date: 2018.12.15
                        Time: 01:36:06
                        Control Module temperature: 32 °C
                        Voltage terminal 15: 12.2 V
    2101 - Databus
                        Reset counter: 222
                        Mileage: 25462 km
                        Date: 2018.12.12
                        Time: 01:02:23
                        Voltage terminal 15: 12.9 V
    2067 - Databus
                        Fault Frequency: 26
                        Reset counter: 222
                        Mileage: 25462 km
                        Date: 2018.11.27
                        Time: 05:45:55
                        Control Module temperature: 44 °C
                        Voltage terminal 15: 14.4 V
    2068 - Databus
                        Reset counter: 222
                        Mileage: 25462 km
                        Date: 2018.11.26
                        Time: 06:16:00
                        Control Module temperature: 29 °C
                        Voltage terminal 15: 14.6 V
    1389 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
                        Reset counter: 223
                        Mileage: 25462 km
                        Date: 2018.12.15
                        Time: 01:28:27
                        Control Module temperature: 31 °C
                        Voltage terminal 15: 7.0 V
                        Status_ACC_System: ACC_Init
       Serial number: 09101641350795
       ROD: EV_DRCONTITEMIC_VW37.rod
       VCID: 387FFEB4837F798F61-806C
       Serial number: 003GCR06HVJ2
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 479D8D48FE81067718-8012
       Occupant Detection:
       Serial number: IBH00000000000602TKH
       Coding: 30324E
       Subsystem 2 - Part No SW: -----------    HW: 480 001 711 16
       Serial number: 35700000000060414F13
       Subsystem 3 - Part No SW: -----------    HW: 480 001 211 16
       Serial number: 358000000006E1819F1S
       Subsystem 4 - Part No SW: -----------    HW: 480 400 911 16
       Serial number: 3510001A72303C8133CV
       Subsystem 5 - Part No SW: -----------    HW: 480 401 211 16
       Serial number: 3520001C123B3B51653V
       Subsystem 6 - Part No SW: -----------    HW: 480 401 411 16
       Serial number: 3550001B52303C82058U
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 401 411 16
       Component: FrontSensor_P  000 6149
       Serial number: 3560001B52303C83C35$
    9483264 - Seat Occupied Recognition
              B10B4 00 [008] - Function Restriction due to Undervoltage
                        Reset counter: 222
                        Mileage: 25462 km
                        Date: 2018.12.15
                        Time: 01:28:34
       Part No SW: 5Q0 953 507 HN    HW: 5Q0 953 549 E
       Revision: --------    Serial number: 16111604220439
       Coding: 0C10
       VCID: 09194B70A815B007CE-805C
       Part No SW: 5G1 920 858 B    HW: 5G1 920 858 B
       Component: KOMBI         304 8311
       Coding: 0BAD081A7F88CF0502886B0B5400000000000000
       VCID: 2F6DC5E87631BE3730-807A
    13635840 - Supply voltage
                        Reset counter: 223
                        Time: 00:00:00
       Revision: --------    Serial number: 0005593897
       Coding: 0101000838085900FB00023A9C0F00000001050000000000000000000000
       ROD: EV_GatewLear_013.rod
       VCID: 7CF722A4F7C795AFC5-8028
       Subsystem 2 - Part No SW: 5G0 959 442 S    HW: 5G0 959 442 S  Labels: 3C8-959-537.CLB
       Serial number: 29160002086150076425
       Coding: 35FFFF
    1282 - Supply voltage
                        Reset counter: 223
                        Mileage: 25462 km
                        Date: 2019.01.17
                        Time: 02:04:13
                        Supply voltage: Terminal 30: 8.4 V
                        Terminal 15: On
       Serial number: HA1-00018.10.16
       Coding: 0001
       VCID: 4A9BB47CED93FB1F07-801E
       Revision: 00000000    Serial number: 16000194265006
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 3467CA849F179DEF4D-8060
              U1400 00 [008] - -
                        Reset counter: 223
                        Time: 00:00:00
                        ELV State: 04
                        Information Clamps: 00 00
                        CoCo State: E0 00
                        WFS State: 00 06
                        Vehicle speed: 655.33 km/h
                        Voltage: 35
                        AD-Value H-bridge: 18
                        Clamp15 flip flop: SSTx: button contacts: 06
                        CAN signals: 05
       Component: HRE_Master    H12 0071
       Serial number: 0421291709
       Coding: 02011103
       ROD: EV_HREntryHella_VW37.rod
       Lane Change Assistant 2:
       Component: HRE_Slave  H12 0071
       Serial number: 0421356520
       Coding: 020111
       Serial number: 011116EK100027
       Coding: 003E13208000040000000000
       Serial number: 00000000000012353969
       Coding: 111000
    65548 - Supply voltage
                        Reset counter: 223
                        Time: 00:00:00
    65799 - Door Warning / Entry Lighting
              B1775 01 [008] - Electrical Failure
                        Reset counter: 222
                        Mileage: 25462 km
                        Date: 2018.12.15
                        Time: 01:36:04
    65649 - Lamp for Ambient Illumination
              B1325 13 [008] - Open Circuit
                        Reset counter: 223
                        Mileage: 25462 km
                        Date: 2018.12.15
                        Time: 01:36:04
    589829 - Window Regulator; Rear Driver side
              B131F F5 [008] - Supply Voltage too Low
                        Fault Frequency: 13
                        Reset counter: 223
                        Mileage: 25462 km
                        Date: 2018.12.12
                        Time: 00:00:19
       Coding: 9102
       ROD: EV_SteerAssisMQB_013.rod
       VCID: 3A7BE4BCBD736B9F97-806E
    16272 - Steering Angle Sensor
                        Reset counter: 187
                        Motor status: 00
                        System status: Reset
                        Supply voltage: 10.25 V
                        Temperature: 32.0 °C
                        KFC: 3F
                        KFA: 00 90
                        Environmental conditions: 21
                        uioUdNotFilt_xdu16: 10.13 V
                        uAdSensI_SwitchedKl30_xdu16: 10.10 V
                        NoInitCause_AsicSens: [0x12] ASC_CTRL_SAS_PERIOD_ERR - SASPERIOD content lost after last ignition off
                        NoInitCause_RackPos_Rohwert: 00 C0
                        RP_VALCNTSAV: not activated
                        RP_DIAGJOB: not activated
                        RP_RPS: not activated
                        RP_STARTUP: not activated
                        RP_L2PLAUSI: not activated
                        RP_INDEXPLAUSI: not activated
                        RP_RUKUCNTR: not activated
                        RP_UNDERVOLT: activated
                        RP_CNTERR: activated
    12289 - Supply voltage
                        Reset counter: 222
                        Time: 00:00:00
                        Motor status: 00
                        Supply voltage: 6.75 V
                        Temperature: 27.0 °C
                        KFC: 30
                        KFA: 00 01
                        uioUdNotFilt_xdu16: 5.08 V
                        uAdSensI_SwitchedKl30_xdu16: 5.09 V
                        RP_UNDERVOLT: not activated
                        RP_CNTERR: not activated
    11776 - Supply voltage
                        Reset counter: 222
                        Mileage: 25462 km
                        Date: 2018.12.15
                        Time: 01:29:46
                        Motor status: 00
                        Supply voltage: 8.50 V
                        Temperature: 34.0 °C
                        KFC: 2E
                        KFA: 00 00
                        uioUdNotFilt_xdu16: 8.81 V
                        uAdSensI_SwitchedKl30_xdu16: 8.82 V
    Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
       Part No SW: 5Q0 035 456     HW: 5Q0 035 456
       Component: MIB2_lite_amp H30 0150
       Revision: 00000001    Serial number: VWZ8Z1GBA02SJAN
       Coding: 2200000000AAAAAA000000000000
       ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003
       ROD: EV_AMPMst12C1Gen2ALPI.rod
    1539 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
                        Reset counter: 223
                        Mileage: 25462 km
                        Date: 2018.12.12
                        Time: 01:02:24
                        Voltage terminal 30: 7.6 V
       Serial number: 251016EJP23167
       Coding: 003E13208600040000800000
       VCID: 428B9C5CD5A3235FCF-8016
       Serial number: 00000000000012039118
       Coding: 091000
                        Reset counter: 223
                        Time: 00:00:00
                        Reset counter: 223
                        Mileage: 25462 km
                        Date: 2018.12.15
                        Time: 01:31:34
    589845 - Window Regulator; Front Passenger side
              B1320 F5 [008] - Supply Voltage too Low
                        Fault Frequency: 13
                        Reset counter: 223
                        Mileage: 25462 km
                        Date: 2018.12.12
                        Time: 00:00:29
       Coding: 022202010B000400
       VCID: 408F9654DBAF314FD9-8014
       Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
       Coding: 2E0000
       Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
       Coding: 2E0000
       Part No SW: 3Q0 035 876 A    HW: 3Q0 035 876 A
       Component: MU-S-NS-US    840 0751
       Coding: 027300020000000051220002001808009F0207F401200105C6
       ROD: EV_MUStd4CDELP_VW37.rod
       VCID: 326BCC9C650393DF5F-8066
       Subsystem 1 - Part No SW: 5GM 919 605     HW: 5GM 919 605
       Component: ABT_Std-2_Nav  H50 4065
       Serial number: VWZ6Z9S2501003
       Subsystem 2 - Part No SW: 3G0 919 866 BB    HW: -----------
       Component: NAR 2017  --- 0525
              U1400 00 [008] - -
                        Reset counter: 223
                        Mileage: 25462 km
                        Date: 2018.12.14
                        Time: 01:13:22
                        Voltage terminal 30: 7.5 V
              B11CF 53 [009] - Deactivated
                        Reset counter: 180
                        Mileage: 25462 km
                        Date: 2018.11.26
                        Time: 06:14:57
                        Voltage terminal 30: 14.6 V
                        SDARS_tuner_status_2-Audio Signal: Available
                        SDARS_tuner_status_2-Antenna current: 132 mA
                        SDARS_tuner_status_2-Reception quality: optimum_signal
                        SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 07
                        SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 07
       Component: OCULowMQBUS   007 0570
       Coding: 02730002C2821A017F1E06020000
       ROD: EV_OCULowMQB.rod
                        Reset counter: 223
                        Mileage: 25462 km
                        Date: 2019.01.17
                        Time: 02:02:12
              U1400 00 [008] - -
                        Fault Frequency: 11
                        Reset counter: 223
                        Mileage: 25462 km
                        Date: 2018.12.12
                        Time: 00:00:00
       Part No SW: 3Q0 980 654 G    HW: 3Q0 980 654
       Component: MQB_B_MFK     H06 0231
       Serial number: 16111612P21265
       Coding: 0003070000000201002213548050490084000E100020
    1123173 - Databus
                        Reset counter: 222
                        Mileage: 25462 km
                        Date: 2018.11.26
                        Time: 06:14:51
                        Control Module temperature: 17 °C
                        Outside air temperature: 5.0 °C
                        Vehicle speed: 0.00 km/h
                        System run time: 605.0 s
                        mid: 02 E0
                        Status of camera: operational
                        Engine_Running_Info: 1
                        Software_Info_4: 1
                        Software_Info_3: 3
                        Software_Info_2: 2
                        Software_Info_1: 0
    262144 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
                        Reset counter: 223
                        Mileage: 25462 km
                        Date: 2018.12.15
                        Time: 01:28:36
                        Outside air temperature: 25.5 °C
                        System run time: 5.8 s
                        Voltage terminal 15: 6.9 V
                        mid: 00 05
                        Engine_Running_Info: 0
                        Software_Info_4: 1
                        Software_Info_3: 3
                        Software_Info_2: 2
                        Software_Info_1: 0
       Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
       Serial number: 160930200242
    End---------------------(Elapsed Time: 05:41, udsna)-----------------------
    Wednesday,28,August,2019,00:06:42:11506
    Dealer/Shop Name: 3
    Mileage: 25462km-15821mi   Repair Order:
    Gateway Installation List:  5Q0 907 530 AM
    47-Sound System -- Status: Cannot be reached 0100
    Address 02: DTCs cleared
    Address 02,0DL 300 043 T,channel IDE00001-Production mode,adapted from,not activated ,to,activated ,
    Address 02,0DL 300 043 T,channel IDE02332-Deactivate production mode,adapted from,00 00 00 ,to,00 00 00 ,
    Address 02,0DL 300 043 T,channel IDE06425-Roller test bench mode: functional,adapted from,not activated ,to,activated ,
    Address 02,0DL 300 043 T,channel IDE06425-Roller test bench mode: functional,adapted from,activated ,to,not activated ,
    Apr 2018
    ITALY
    several modules are complaining about insufficient voltage. I would try to fix that first, then clear errors again and see what stays.
    my Golf came out of the factory with 13 ECUs. now she has 19. and counting
  3. Likes Uwe liked this post
    Jul 2019
    NJ, USA
    Yes that was because the battery was dead. installed a new battery. just didn't clear the faults on that Auto scan.
    All faults are now cleared.
    could the abort be due to the hood being opened?
    Mar 2015
    Australia
    ...thread hijack alert...
    I'm having trouble running basic settings on my DQ500 retrofit also...it aborts with main reason 0 and sub reason 91.
    Is anyone able to decode these status codes at all? For both OP and myself?
    Mine happens at the point of clutch 1 closure so it looks like a problem with K1 clutch somewhere.
    2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|THA475 Amp+active sub|Whiteline ALK|RVC|Discover Media
    2009 R36 wagon|Biscay Blue|RVC|Tailgate|ECU and DSG tune|LED DRL/Indicators|Full colour MFD|Quad LED tail rings| Climatronics upgrade| Dynaudio retrofit | B7 RLine Flat Steering Wheel|3AA CCM|B7 Adaptive Cruise with Front Assist|TPMS Direct|Discover Media retrofit|PLA 2.0|Lane Assist
    Jul 2019
    NJ, USA
    Quote Originally Posted by kamold View Post
    haha its all good.
    I made sure all codes are clear and have a clean auto scan now.
    closed the hood.
    still have the same issue with aborting
    main abort 0
    sub 10
  7. Likes kamold liked this post
    You are looking at these Measurement values, while trying to do Basic Settings ?
    IDE02775
    IDE02824
    IDE02825
  9. Likes kamold liked this post
  10. #7
    Jul 2019
    NJ, USA
    IDE02775
    IDE02824
    IDE02825
    Sorry for my ignorance but how do you watch the MVB While doing the Basic settings?
  11. #8
    While in Basic Settings, press the button [Show Measuring Data], enter the numbers, one at a time, 2775 2824 2825, in search box and select them.
  12. Likes Boki Ar, Uwe liked this post
  13. #9
    Jul 2019
    NJ, USA
    I tried that and nothing shows up in the box after selecting any Chanel’s
  14. #10
    Start Basic Settings
