Results 1 to 5 of 5
Thread: GTI 2019 - DRL not dimming while front fogs ON?
    Verified VCDS User VagImports's Avatar
    Mar 2019
    Argentina
    Hi guys! This is my first thread in the forum, I hope to participate and be usefull for any of you.
    I would like to know if theare is any possibility of setting the DRL´s to not dim when the front fogs are on. In Argentina, driving just with DRL´s at night is allowed, so many people here are interested in this setup.
    And another general question about the functioning of Leutche cannals. If we found the way to do this in my GTI MK7.5, it can be done on any MQB vehicle using the same procedure? Or each model uses it´s own Leutche setup? Of course the headlights are completely different between models, but the way they function is the same (at least regarding DRL dimming).
    Saturday,06,July,2019,11:44:52:43894
    VCDS Version: 18.9.1.0 (x64)
    Workshop Code: 123 12345 000001
    VIN: 3VW4E6AU2JM283388   License Plate: CODING GTI 7.5 AD 063 EY
    Mileage: 11558km   Repair Order:
    Chassis Type  AU-VW37 (3Q0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 2B 42 44 4B 52 5F A9
    VIN: 3VW4E6AU2JM283388   Mileage: 11558km-7181miles
    4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
    Address 01: Engine (J623-CXDB)       Labels:. 06K-907-425-V1.clb
       Part No SW: 5G0 906 259 P    HW: 06K 907 425 B
       Component: 2.0l R4 TFSI  H13 0001
       Revision: --H13---
       Coding: 091D00124424012B1000
       Shop #: WSC 00066 790 00235
       ASAM Dataset: EV_ECM20TFS0205G0906259P 001001
       ROD: EV_ECM20TFS0205G0906259P.rod
       VCID: 3B75FCE9B2CED692C8-806E
       Part No SW: 0D9 300 043 F    HW: 02E 927 770 AS
       Component: DQ250-6F MQB  H54 5204
       Revision: 06454104    Serial number: TFK01802152159
       ROD: EV_TCMDQ250021.rod
       VCID: 1D3112710C1AB8A2D6-8048
    Address 03: ABS Brakes (J104)       Labels:* 5Q0-907-379-ESP-V1.clb
       Part No SW: 5Q0 614 517 CS    HW: 5Q0 614 517 AF
       Component: ESC           H62 0973
       Revision: 00000000    Serial number: 50848000000789
       Coding: 01FA6BA13428216F407A0608E0CB2980D62C84026007947620415030C009430B00000012121212B835351919323200
       Shop #: WSC 01383 790 50316
       ASAM Dataset: EV_Brake1UDSContiMK100ESP 037009
       ROD: EV_Brake1UDSContiMK100ESP_037_VW37.rod
       VCID: 040747158FB0696AF9-8050
       Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
       Component: VWKESSYMQB    021 0803
       Revision: 00021000    Serial number: 0470595341
       Coding: 032C0C
       ASAM Dataset: EV_KessyHellaMQBAB 002020
       VCID: 3C77FFF5B7C0D1AAC1-8068
       Part No SW: 5GM 907 044 G    HW: 5GM 907 044 G
       Component: Climatronic   H04 2001
       Revision: 00001K05
       Coding: 00020014200108011004000000101402
       ASAM Dataset: EV_ACClimaBHBVW37X 006146
       VCID: 489F9325F3188D0A55-801C
       Part No SW: 5Q0 937 086 BL    HW: 5Q0 937 086 BG
       Component: BCM PQ37BOSCH 034 0246
       Revision: --------    Serial number: C86423031801G8
       Shop #: WSC 00066 790 00248
       ROD: EV_BCMBOSCH_018.rod
       VCID: 05015A11848A5062EE-8050
       Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS    180106  043 0551
       Serial number: 97022066180120152833
       Component: RLHS  047 0105
       Serial number: S9Y18M04D09H16M53S01
       Coding: 00A8DD
       Serial number: 000000000ZY180111HLZ
       Serial number: 00000000000099770728
       Sun Roof:
       Subsystem 5 - Part No SW: 5GD 959 591 A    HW: 5GD 959 591 A
       Component: J245 PS60.006  H07 0170
       Serial number: 03690818401607171745
       Coding: 181803
    263442 - Siren / Alarm Horn for Anti-Theft Alarm System
              B131D F7 [008] - No Release by Immobilizer
                        Reset counter: 29
                        Mileage: 11145 km
                        Date: 2019.06.23
                        Time: 23:05:51
    204546 - Remote key 2
                        Reset counter: 116
                        Mileage: 8804 km
                        Date: 2019.04.12
                        Time: 23:16:14
    262936 - Sensor for anti-theft alarm system
              B1330 29 [008] - Signal Implausible
       Serial number: 000116643R18104
       Coding: 0471151011
       VCID: 4B95AC29E26E661278-801E
       Part No SW: 5Q0 959 655 BH    HW: 5Q0 959 655 BH
       Serial number: 003VVM05TE06
       Coding: 98CCC000000000005C0000CF000800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 071D5019BE8642729C-8052
       Subsystem 1 - Part No SW: -----------    HW: 480 000 804 18
       Serial number: 35700000000AAAB8CE26
       Subsystem 2 - Part No SW: -----------    HW: 480 000 804 18
       Serial number: 358000000006B77D6F2/
       Subsystem 3 - Part No SW: -----------    HW: 480 402 803 18
       Serial number: 3510001AB29B7D41E46G
       Subsystem 4 - Part No SW: -----------    HW: 480 402 803 18
       Serial number: 3520001AF29B7D4373DM
       Subsystem 5 - Part No SW: -----------    HW: 480 400 804 18
       Serial number: 3550001B5297CD523704
       Part No SW: 5Q0 953 507 HL    HW: 5Q0 953 549 E
       Revision: --------    Serial number: 25021820240413
       Coding: 0410
       ROD: EV_SMLSKLOMQB_VW37.rod
       Part No SW: 5G1 920 756 C    HW: 5G1 920 756 C
       Component: KOMBI         342 0310
       Coding: 07AD0918A980000801086A001001000080000000
       VCID: 2D51C2B17CBA482246-8078
       Component: GW MQB High   518 5323
       Serial number: 19031800840041
       Coding: 030100047F085900FA0002681C0F00010001070000000000000000000000
       Shop #: WSC 00066 790 00204
       ROD: EV_GatewNF_VW37.rod
       VCID: 387FE3E583F8FD8A25-806C
       Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H11 0103
       Serial number: 29170001826350047361
       Coding: 31FFFF
       Serial number: 0533435700
       Revision: 00000000    Serial number: 18000041302006
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 3467D7D59F9019EA09-8060
       Serial number: 5038810700203
       Coding: 003E12208000020000001000
       VCID: 479D9019FE0682725C-8012
       Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F
       Component: Fond FHSG DRV  010 0004
       Serial number: 00000000000000316014
    65649 - Lamp for Ambient Illumination
              B1325 13 [008] - Open Circuit
                        Reset counter: 55
                        Mileage: 11558 km
                        Date: 2019.07.06
                        Time: 10:38:45
       Part No SW: 5QN 909 144 A    HW: 5QN 909 144 A
       Component: EPS_MQB_ZFLS  507 5081
       Coding: 011F0000
       ROD: EV_SteerAssisMQB_015.rod
       VCID: 50AFBB450B4845CA0D-8004
    Address 4B: Multifunc. Module
    Interface not compatible.
       Serial number: 6038810401397
       Coding: 003E12208E00020000001000
       VCID: 46839D1DF90C9B7AA7-8012
       Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F
       Component: Fond FHSG PSG  010 0004
       Serial number: 00000000000000312964
       Coding: 090000
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH2.clb
       Part No SW: 5NA 035 045 B    HW: 5NA 035 045
       Component: MU-H-N-RW     H54 1161
       Serial number: A868D0J9101113
       Coding: 02731003FF00000051220001001828001F0103D401200500DF
       VCID: 377DE0D98EE6F2F22C-8062
       Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
       Component: ABT_High-2  H51 9130
       Serial number: VWZ6ZJV0661546
       Subsystem 2 - Part No SW: V03 959 801 ED    HW: -----------
       Component: ROW 2017/2018  --- 0065
       Component: Gracenote2  --- 4012
       Part No SW: 5G0 907 159 G    HW: 4H0 907 159 A
       Serial number: 180216204691
       VCID: 326BD1CD658417DA1B-8066
    End-------------------------(Elapsed Time: 04:40)--------------------------
    VAG Imports Argentina (Juan García)
    VAG Imports: "This is my first thread in the forum"? Really - didn't we have a chat about starting vibration channel not so long ago?
    Doesn't matter - The Leuchte-command that you are looking-for is Blinken links/rechts aktiv (beide Phasen). But where this command is placed can vary. Please post-up a adaptation channel map for the BCM (the module @ address hex09) - please
  3. Likes Uwe, VagImports liked this post
    Mar 2019
    Argentina
    Hey Don! I think we talked before in the GolfMK7 forum, it´s posibble? I´m a verified user here since yesterday!
    I´m sure this isn´t what you are asking me for, but I have a complete adaptation channel map saved from my car.
     IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,2 sekunden verzoegerung ,8
    IDE05143-MAS02985-Writing parameter-Value,130 ,5
    IDE05143-MAS04381-Writing parameter-Parameter address,FE 00 00 ,5
    IDE05144-Read parameter address,FE 00 00 ,3
    IDE05145-Light configuration,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 36 00 1A 0B 10 7F 00 00 00 00 00 00 00 00 00 05 40 00 1B 0C 10 7F 00 00 00 00 00 00 00 00 00 05 44 00 4B 46 00 7F 08 0A 7F 00 00 00 00 00 00 05 3A 00 49 46 00 7F 08 09 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 38 00 22 12 00 7F 00 00 00 00 00 00 00 00 00 06 42 00 23 13 00 7F 00 00 00 00 00 00 00 00 00 ,224
    IDE05822-DWA Vehicle inclination sensor,100 %,1
    IDE05823-DWA Interior monitoring parameter set,01 0A 08 00 43 53 0A C8 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 45 42 57 9B 25 44 3F 3A 69 58 95 2D 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 42 87 1B 05 34 3F 3A 69 58 93 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 05 24 3F 3A 69 47 93 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 05 24 3F 3A 69 58 92 05 09 A3 05 34 26 19 15 0C 12 18 86 09 26 33 67 23 45 42 57 9B 25 24 0C FA 0A 34 95 2D 09 A3 21 03 00 02 02 02 02 02 02 B1 10 23 29 66 ,172
    IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN,Heizmatten am BCM ,30
    IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,30
    IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 °C,30
    IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,22.50 °C,30
    IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,21.50 °C,30
    IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,22.50 °C,30
    IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,21.50 °C,30
    IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,38.00 °C,30
    IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,36.00 °C,30
    IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,38.00 °C,30
    IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,36.00 °C,30
    IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,56.00 °C,30
    IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,54.00 °C,30
    IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,56.00 °C,30
    IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,54.00 °C,30
    IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI,Keine_Spannungsanforderung ,30
    IDE06089-ENG154775-Seat heater level current consumption allocation-Sitzheizung.Regelbetrieb LO,Keine_Spannungsanforderung ,30
    IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75,15.0 V,30
    IDE06507-MAS13132-Button in center console-Function of button 3,NOT-DEFINED ,8
    IDE06507-ENG140243-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED,LED installed ,8
    IDE07007-ENG142253-A/C heater function via remote control-Abbruch_d_Warnblinker_moeglich,active ,8
    IDE07007-ENG142255-A/C heater function via remote control-Aktivierung_Drehzahlanzeige,active ,8
    IDE07007-ENG142254-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Akustik,active ,8
    IDE07007-ENG128461-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt,active ,8
    IDE07007-ENG115720-A/C heater function via remote control-Remote Start,not installed ,8
    IDE07007-ENG128460-A/C heater function via remote control-Rueckmeldung_bei_Aktivierung,active ,8
    IDE07356-Position during interval mode,31.494474 °,2
    IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten ueber Abschaltstufen des Energiemanagements oder nach der Nachlaufzeit ,6
    IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min,6
    IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein,active ,6
    IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,active ,9
    IDE08786-ENG141985-Assistance light functions-Regen_Lichtsensor,LIN_REGEN_LICHT_SENSOR ,9
    IDE08786-ENG124476-Assistance light functions-Sunlight Sensor,not installed ,9
    IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual,7 ,19
    IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation,not active ,19
    IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung,not active ,19
    IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default,active ,19
    IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.10 s,19
    IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,2 ,19
    IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,3 ,19
    IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,1 ,19
    IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,80 %,19
    IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,0 ,19
    IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum,50 %,19
    IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,80 %,19
    IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer,50 %,19
    IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn,50 %,19
    IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,active ,19
    IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,active ,19
    IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,active ,19
    IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,active ,19
    IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,active ,19
    IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,active ,19
    IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen,not active ,19
    IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten,active ,19
    IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig,not active ,19
    IDE09731-ENG98648-Int. light: 2nd generation-Interior light,Keine_Spannungsanforderung ,19
    IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWM,not active ,19
    IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,not active ,19
    IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G,installed ,19
    IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,not active ,19
    IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default,0 ,5
    IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI,not active ,5
    IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,not installed ,5
    IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,installed ,5
    IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,not active ,5
    IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,not active ,5
    IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung,not installed ,5
    IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,installed ,5
    IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,30 %,17
    IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,25 %,17
    IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30 %,17
    IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,25 %,17
    IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,58 %,17
    IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,53 %,17
    IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,58 %,17
    IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,53 %,17
    IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,85 %,17
    IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,80 %,17
    IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,85 %,17
    IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,80 %,17
    IDE09761-ENG142024-Seat fan charac. curve-Sitzlueftung,not installed ,17
    IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar,installed ,17
    IDE10298-Alternating park position 1,7.494498 °,2
    IDE10299-Alternating park position 2,29.494476 °,2
    IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit,1.00 ,256
    IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach,1.00 ,256
    IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum,0.20 ,256
    IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel,1.00 ,256
    IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher,1.00 ,256
    IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko,1.00 ,256
    IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd,1.00 ,256
    IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer,0.60 ,256
    IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI,00000000  ,256
    IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2,00000000  ,256
    IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3,00000000  ,256
    IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI,00000000  ,256
    IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2,00000000  ,256
    IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3,00000000  ,256
    IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4,00000000  ,256
    IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI,00000000  ,256
    IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit,100 %,256
    IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach,100 %,256
    IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum,70 %,256
    IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel,100 %,256
    IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher,100 %,256
    IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko,100 %,256
    IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd,100 %,256
    IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren,96 %,256
    IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit,100 %,256
    IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach,100 %,256
    IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum,70 %,256
    IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel,100 %,256
    IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher,100 %,256
    IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko,100 %,256
    IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd,100 %,256
    IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren,96 %,256
    IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit,100 %,256
    IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach,100 %,256
    IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum,70 %,256
    IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel,100 %,256
    IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher,100 %,256
    IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko,100 %,256
    IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd,100 %,256
    IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren,96 %,256
    IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit,100 %,256
    IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach,100 %,256
    IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum,70 %,256
    IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel,100 %,256
    IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher,100 %,256
    IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko,100 %,256
    IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd,100 %,256
    IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren,96 %,256
    IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit,100 %,256
    IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach,100 %,256
    IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum,70 %,256
    IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel,100 %,256
    IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher,100 %,256
    IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko,100 %,256
    IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd,100 %,256
    IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren,96 %,256
    IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit,100 %,256
    IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach,100 %,256
    IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum,0 %,256
    IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel,100 %,256
    IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher,100 %,256
    IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko,100 %,256
    IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd,100 %,256
    IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren,0 %,256
    IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit,100 %,256
    IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach,100 %,256
    IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,70 %,256
    IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht,100 %,256
    IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel,100 %,256
    IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher,100 %,256
    IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko,100 %,256
    IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd,100 %,256
    IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,96 %,256
    IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit,100 %,256
    IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach,100 %,256
    IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum,127 %,256
    IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht,100 %,256
    IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel,100 %,256
    IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher,100 %,256
    IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko,100 %,256
    IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd,100 %,256
    IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren,127 %,256
    IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit,126 %,256
    IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach,126 %,256
    IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum,126 %,256
    IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel,126 %,256
    IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher,126 %,256
    IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko,126 %,256
    IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd,126 %,256
    IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren,126 %,256
    IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit,100 %,256
    IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach,100 %,256
    IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum,127 %,256
    IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht,100 %,256
    IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel,100 %,256
    IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher,100 %,256
    IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko,100 %,256
    IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd,100 %,256
    IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren,127 %,256
    IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit,100 %,256
    IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach,100 %,256
    IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,126 %,256
    IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht,100 %,256
    IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel,100 %,256
    IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher,100 %,256
    IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko,100 %,256
    IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd,100 %,256
    IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,126 %,256
    IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit,100 %,256
    IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach,100 %,256
    IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum,70 %,256
    IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel,100 %,256
    IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher,100 %,256
    IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko,100 %,256
    IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd,100 %,256
    IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren,96 %,256
    IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit,100 %,256
    IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach,100 %,256
    IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,70 %,256
    IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht,100 %,256
    IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel,100 %,256
    IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher,100 %,256
    IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko,100 %,256
    IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd,100 %,256
    IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,96 %,256
    IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit,100 %,256
    IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach,100 %,256
    IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,70 %,256
    IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht,100 %,256
    IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel,100 %,256
    IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher,100 %,256
    IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko,100 %,256
    IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd,100 %,256
    IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,96 %,256
    IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit,100 %,256
    IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach,100 %,256
    IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,70 %,256
    IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht,100 %,256
    IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel,100 %,256
    IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher,100 %,256
    IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko,100 %,256
    IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd,100 %,256
    IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,96 %,256
    IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte,200 ms,256
    IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum,2.0 s,256
    IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren,0.5 s,256
    IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1,0 ,30
    IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10,0 ,30
    IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2,0 ,30
    IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3,0 ,30
    IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4,0 ,30
    IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5,0 ,30
    IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6,0 ,30
    IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7,0 ,30
    IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8,0 ,30
    IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9,0 ,30
    IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1,0 ,30
    IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10,0 ,30
    IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2,0 ,30
    IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3,0 ,30
    IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4,0 ,30
    IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5,0 ,30
    IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6,0 ,30
    IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7,0 ,30
    IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8,0 ,30
    IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9,0 ,30
    IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1,0 ,30
    IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10,0 ,30
    IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2,0 ,30
    IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3,0 ,30
    IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4,0 ,30
    IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5,0 ,30
    IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6,0 ,30
    IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7,0 ,30
    IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8,0 ,30
    IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9,0 ,30
    IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung,installed ,3
    IDE11944-ENG141948-Keyless access and start authorization-Kessy,installed ,3
    IDE11944-ENG116654-Keyless access and start authorization-Kessy Komfort schliessen,active ,3
    IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung,not active ,3
    IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,3
    IDE12412-ENG154526-LIN Ambient light color list-Blauwert_Farbe_1_lin,0 ,30
    IDE12412-ENG154537-LIN Ambient light color list-Blauwert_Farbe_2_lin,0 ,30
    IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin,0 ,30
    IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin,0 ,30
    IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin,0 ,30
    IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin,0 ,30
    IDE12412-ENG154563-LIN Ambient light color list-Blauwert_Farbe_7_lin,0 ,30
    IDE12412-ENG154564-LIN Ambient light color list-Blauwert_Farbe_8_lin,0 ,30
    IDE12412-ENG154565-LIN Ambient light color list-Blauwert_Farbe_9_lin,0 ,30
    IDE12412-ENG154645-LIN Ambient light color list-Gruenwert_Farbe_1_lin,0 ,30
    IDE12412-ENG154646-LIN Ambient light color list-Gruenwert_Farbe_10_lin,0 ,30
    IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin,0 ,30
    IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin,0 ,30
    IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin,0 ,30
    IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin,0 ,30
    IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin,0 ,30
    IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin,0 ,30
    IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin,0 ,30
    IDE12412-ENG154684-LIN Ambient light color list-Gruenwert_Farbe_9_lin,0 ,30
    IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin,0 ,30
    IDE12412-ENG154734-LIN Ambient light color list-Rotwert_Farbe_10_lin,0 ,30
    IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin,0 ,30
    IDE12412-ENG154764-LIN Ambient light color list-Rotwert_Farbe_3_lin,0 ,30
    IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin,0 ,30
    IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin,0 ,30
    IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin,0 ,30
    IDE12412-ENG154770-LIN Ambient light color list-Rotwert_Farbe_7_lin,0 ,30
    IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin,0 ,30
    IDE12412-ENG154772-LIN Ambient light color list-Rotwert_Farbe_9_lin,0 ,30
    MAS05055-lower turn position,31.494474 °,2
    MAS05056-upper turn position,170.494336 °,2
    MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,0 lx,24
    MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,00 00 ,24
    MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,2000 lx,24
    MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,0 mV,24
    MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke,0 lx,24
    MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,0 mV,24
    ENG153709-ENG154696-Aktivierung_Entwicklungsdiagnose-log_dtc_status,not active ,9
    ENG153709-ENG154697-Aktivierung_Entwicklungsdiagnose-log-dtc_DFCC,00 00 00 ,9
    ENG153709-ENG154714-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG-DTC,First_dtc ,9
    ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active ,4
    ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active ,4
    ENG153710-ENG154516-Ambience_lightning_color_list_2-Blauwert Farbe 11,0 ,60
    ENG153710-ENG154517-Ambience_lightning_color_list_2-Blauwert Farbe 12,0 ,60
    ENG153710-ENG154518-Ambience_lightning_color_list_2-Blauwert Farbe 13,0 ,60
    ENG153710-ENG154519-Ambience_lightning_color_list_2-Blauwert Farbe 14,0 ,60
    ENG153710-ENG154520-Ambience_lightning_color_list_2-Blauwert Farbe 15,0 ,60
    ENG153710-ENG154521-Ambience_lightning_color_list_2-Blauwert Farbe 16,0 ,60
    ENG153710-ENG154522-Ambience_lightning_color_list_2-Blauwert Farbe 17,0 ,60
    ENG153710-ENG154523-Ambience_lightning_color_list_2-Blauwert Farbe 18,0 ,60
    ENG153710-ENG154524-Ambience_lightning_color_list_2-Blauwert Farbe 19,0 ,60
    ENG153710-ENG154525-Ambience_lightning_color_list_2-Blauwert Farbe 20,0 ,60
    ENG153710-ENG154539-Ambience_lightning_color_list_2-Blauwert_Farbe_21,0 ,60
    ENG153710-ENG154541-Ambience_lightning_color_list_2-Blauwert_Farbe_22,0 ,60
    ENG153710-ENG154543-Ambience_lightning_color_list_2-Blauwert_Farbe_23,0 ,60
    ENG153710-ENG154545-Ambience_lightning_color_list_2-Blauwert_Farbe_24,0 ,60
    ENG153710-ENG154547-Ambience_lightning_color_list_2-Blauwert_Farbe_25,0 ,60
    ENG153710-ENG154549-Ambience_lightning_color_list_2-Blauwert_Farbe_26,0 ,60
    ENG153710-ENG154551-Ambience_lightning_color_list_2-Blauwert_Farbe_27,0 ,60
    ENG153710-ENG154553-Ambience_lightning_color_list_2-Blauwert_Farbe_28,0 ,60
    ENG153710-ENG154555-Ambience_lightning_color_list_2-Blauwert_Farbe_29,0 ,60
    ENG153710-ENG154558-Ambience_lightning_color_list_2-Blauwert_Farbe_30,0 ,60
    ENG153710-ENG154635-Ambience_lightning_color_list_2-Gruenwert Farbe 11,0 ,60
    ENG153710-ENG154636-Ambience_lightning_color_list_2-Gruenwert Farbe 12,0 ,60
    ENG153710-ENG154637-Ambience_lightning_color_list_2-Gruenwert Farbe 13,0 ,60
    ENG153710-ENG154638-Ambience_lightning_color_list_2-Gruenwert Farbe 14,0 ,60
    ENG153710-ENG154639-Ambience_lightning_color_list_2-Gruenwert Farbe 15,0 ,60
    ENG153710-ENG154640-Ambience_lightning_color_list_2-Gruenwert Farbe 16,0 ,60
    ENG153710-ENG154641-Ambience_lightning_color_list_2-Gruenwert Farbe 17,0 ,60
    ENG153710-ENG154642-Ambience_lightning_color_list_2-Gruenwert Farbe 18,0 ,60
    ENG153710-ENG154643-Ambience_lightning_color_list_2-Gruenwert Farbe 19,0 ,60
    ENG153710-ENG154644-Ambience_lightning_color_list_2-Gruenwert Farbe 20,0 ,60
    ENG153710-ENG154658-Ambience_lightning_color_list_2-Gruenwert_Farbe_21,0 ,60
    ENG153710-ENG154660-Ambience_lightning_color_list_2-Gruenwert_Farbe_22,0 ,60
    ENG153710-ENG154662-Ambience_lightning_color_list_2-Gruenwert_Farbe_23,0 ,60
    ENG153710-ENG154664-Ambience_lightning_color_list_2-Gruenwert_Farbe_24,0 ,60
    ENG153710-ENG154666-Ambience_lightning_color_list_2-Gruenwert_Farbe_25,0 ,60
    ENG153710-ENG154668-Ambience_lightning_color_list_2-Gruenwert_Farbe_26,0 ,60
    ENG153710-ENG154670-Ambience_lightning_color_list_2-Gruenwert_Farbe_27,0 ,60
    ENG153710-ENG154672-Ambience_lightning_color_list_2-Gruenwert_Farbe_28,0 ,60
    ENG153710-ENG154674-Ambience_lightning_color_list_2-Gruenwert_Farbe_29,0 ,60
    ENG153710-ENG154677-Ambience_lightning_color_list_2-Gruenwert_Farbe_30,0 ,60
    ENG153710-ENG154723-Ambience_lightning_color_list_2-Rotwert Farbe 11,0 ,60
    ENG153710-ENG154724-Ambience_lightning_color_list_2-Rotwert Farbe 12,0 ,60
    ENG153710-ENG154725-Ambience_lightning_color_list_2-Rotwert Farbe 13,0 ,60
    ENG153710-ENG154726-Ambience_lightning_color_list_2-Rotwert Farbe 14,0 ,60
    ENG153710-ENG154727-Ambience_lightning_color_list_2-Rotwert Farbe 15,0 ,60
    ENG153710-ENG154728-Ambience_lightning_color_list_2-Rotwert Farbe 16,0 ,60
    ENG153710-ENG154729-Ambience_lightning_color_list_2-Rotwert Farbe 17,0 ,60
    ENG153710-ENG154730-Ambience_lightning_color_list_2-Rotwert Farbe 18,0 ,60
    ENG153710-ENG154731-Ambience_lightning_color_list_2-Rotwert Farbe 19,0 ,60
    ENG153710-ENG154732-Ambience_lightning_color_list_2-Rotwert Farbe 20,0 ,60
    ENG153710-ENG154746-Ambience_lightning_color_list_2-Rotwert_Farbe_21,0 ,60
    ENG153710-ENG154748-Ambience_lightning_color_list_2-Rotwert_Farbe_22,0 ,60
    ENG153710-ENG154750-Ambience_lightning_color_list_2-Rotwert_Farbe_23,0 ,60
    ENG153710-ENG154752-Ambience_lightning_color_list_2-Rotwert_Farbe_24,0 ,60
    ENG153710-ENG154754-Ambience_lightning_color_list_2-Rotwert_Farbe_25,0 ,60
    ENG153710-ENG154756-Ambience_lightning_color_list_2-Rotwert_Farbe_26,0 ,60
    ENG153710-ENG154758-Ambience_lightning_color_list_2-Rotwert_Farbe_27,0 ,60
    ENG153710-ENG154760-Ambience_lightning_color_list_2-Rotwert_Farbe_28,0 ,60
    ENG153710-ENG154762-Ambience_lightning_color_list_2-Rotwert_Farbe_29,0 ,60
    ENG153710-ENG154765-Ambience_lightning_color_list_2-Rotwert_Farbe_30,0 ,60
    ENG153711-ENG154528-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_11_lin,0 ,60
    ENG153711-ENG154529-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_12_lin,0 ,60
    ENG153711-ENG154530-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_13_lin,0 ,60
    ENG153711-ENG154531-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_14_lin,0 ,60
    ENG153711-ENG154532-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_15_lin,0 ,60
    ENG153711-ENG154533-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_16_lin,0 ,60
    ENG153711-ENG154534-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_17_lin,0 ,60
    ENG153711-ENG154535-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_18_lin,0 ,60
    ENG153711-ENG154536-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_19_lin,0 ,60
    ENG153711-ENG154538-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_20_lin,0 ,60
    ENG153711-ENG154540-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_21_lin,0 ,60
    ENG153711-ENG154542-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_22_lin,0 ,60
    ENG153711-ENG154544-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_23_lin,0 ,60
    ENG153711-ENG154546-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_24_lin,0 ,60
    ENG153711-ENG154548-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_25_lin,0 ,60
    ENG153711-ENG154550-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_26_lin,0 ,60
    ENG153711-ENG154552-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_27_lin,0 ,60
    ENG153711-ENG154554-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_28_lin,0 ,60
    ENG153711-ENG154556-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_29_lin,0 ,60
    ENG153711-ENG154559-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_30_lin,0 ,60
    ENG153711-ENG154647-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_11_lin,0 ,60
    ENG153711-ENG154648-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_12_lin,0 ,60
    ENG153711-ENG154649-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_13_lin,0 ,60
    ENG153711-ENG154650-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_14_lin,0 ,60
    ENG153711-ENG154651-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_15_lin,0 ,60
    ENG153711-ENG154652-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_16_lin,0 ,60
    ENG153711-ENG154653-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_17_lin,0 ,60
    ENG153711-ENG154654-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_18_lin,0 ,60
    ENG153711-ENG154655-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_19_lin,0 ,60
    ENG153711-ENG154657-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_20_lin,0 ,60
    ENG153711-ENG154659-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_21_lin,0 ,60
    ENG153711-ENG154661-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_22_lin,0 ,60
    ENG153711-ENG154663-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_23_lin,0 ,60
    ENG153711-ENG154665-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_24_lin,0 ,60
    ENG153711-ENG154667-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_25_lin,0 ,60
    ENG153711-ENG154669-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_26_lin,0 ,60
    ENG153711-ENG154671-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_27_lin,0 ,60
    ENG153711-ENG154673-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_28_lin,0 ,60
    ENG153711-ENG154675-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_29_lin,0 ,60
    ENG153711-ENG154678-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_30_lin,0 ,60
    ENG153711-ENG154735-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_11_lin,0 ,60
    ENG153711-ENG154736-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_12_lin,0 ,60
    ENG153711-ENG154737-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_13_lin,0 ,60
    ENG153711-ENG154738-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_14_lin,0 ,60
    ENG153711-ENG154739-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_15_lin,0 ,60
    ENG153711-ENG154740-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_16_lin,0 ,60
    ENG153711-ENG154741-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_17_lin,0 ,60
    ENG153711-ENG154742-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_18_lin,0 ,60
    ENG153711-ENG154743-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_19_lin,0 ,60
    ENG153711-ENG154745-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_20_lin,0 ,60
    ENG153711-ENG154747-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_21_lin,0 ,60
    ENG153711-ENG154749-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_22_lin,0 ,60
    ENG153711-ENG154751-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_23_lin,0 ,60
    ENG153711-ENG154753-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_24_lin,0 ,60
    ENG153711-ENG154755-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_25_lin,0 ,60
    ENG153711-ENG154757-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_26_lin,0 ,60
    ENG153711-ENG154759-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_27_lin,0 ,60
    ENG153711-ENG154761-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_28_lin,0 ,60
    ENG153711-ENG154763-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_29_lin,0 ,60
    ENG153711-ENG154766-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_30_lin,0 ,60
    ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1,1.00 ,30
    ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10,1.00 ,30
    ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11,1.00 ,30
    ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12,1.00 ,30
    ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13,1.00 ,30
    ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14,1.00 ,30
    ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15,1.00 ,30
    ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2,1.00 ,30
    ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3,1.00 ,30
    ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4,1.00 ,30
    ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5,1.00 ,30
    ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6,1.00 ,30
    ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7,1.00 ,30
    ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8,1.00 ,30
    ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9,1.00 ,30
    ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1,door ,30
    ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10,door ,30
    ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11,door ,30
    ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12,door ,30
    ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13,door ,30
    ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14,door ,30
    ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15,door ,30
    ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2,door ,30
    ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3,door ,30
    ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4,door ,30
    ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5,door ,30
    ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6,door ,30
    ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7,door ,30
    ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8,door ,30
    ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9,door ,30
    ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2,not installed ,30
    ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1,0 ,60
    ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2,0 ,60
    ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3,0 ,60
    ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4,0 ,60
    ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,00 ,60
    ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2,0 ,60
    ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3,0 ,60
    ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4,0 ,60
    ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1,not installed ,60
    ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2,not installed ,60
    ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3,not installed ,60
    ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4,not installed ,60
    ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente,Keine_Spannungsanforderung ,23
    ENG153712-ENG154602-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_0,1 ,23
    ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1,1 ,23
    ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10,1 ,23
    ENG153712-ENG154605-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_11,1 ,23
    ENG153712-ENG154606-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_12,1 ,23
    ENG153712-ENG154607-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_13,1 ,23
    ENG153712-ENG154608-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_14,1 ,23
    ENG153712-ENG154609-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_15,1 ,23
    ENG153712-ENG154610-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_2,1 ,23
    ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3,1 ,23
    ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4,1 ,23
    ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5,1 ,23
    ENG153712-ENG154614-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_6,1 ,23
    ENG153712-ENG154615-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_7,1 ,23
    ENG153712-ENG154616-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_8,1 ,23
    ENG153712-ENG154617-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_9,1 ,23
    ENG141649-ENG122212-Außenlicht_Blinker-ABBA_Blinken,not active ,10
    ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken,not active ,10
    ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung,not active ,10
    ENG141649-ENG154601-Außenlicht_Blinker-Fahrerassistenz_Blinkenfunktionen,Warnblinke_zulaessig ,10
    ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing,not active ,10
    ENG141649-ENG154711-Außenlicht_Blinker-PreCrash_RECAS,PreCrash_passiv ,10
    ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links,active ,10
    ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts,active ,10
    ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken,not active ,10
    ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing,not active ,10
    ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,not active ,10
    ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken,not active ,10
    ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz,not active ,10
    ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS,active ,10
    ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN,active ,10
    ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf,not active ,10
    ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu,not active ,10
    ENG141647-ENG141986-Außenlicht_Front-Abblendlicht_Leuchtentyp,H7 ,9
    ENG141647-ENG116705-Außenlicht_Front-Allwetterlicht Ausschaltgrenze,350 km/h,9
    ENG141647-ENG116704-Außenlicht_Front-Allwetterlicht Einschaltgrenze,350 km/h,9
    ENG141647-ENG142193-Außenlicht_Front-Geschwindigkeitsabhaengiges TFL,5 km/h,9
    ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich,not active ,9
    ENG141647-ENG115832-Außenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,9
    ENG141647-ENG142191-Außenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument,not active ,9
    ENG141647-ENG142190-Außenlicht_Front-Signaturlicht_verbaut,not installed ,9
    ENG141647-ENG116592-Außenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht,active ,9
    ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,not active ,9
    ENG141647-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active ,9
    ENG141647-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO,not active ,9
    ENG141647-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,9
    ENG141647-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen ,9
    ENG141648-ENG141987-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht,No ,5
    ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit,0 km/h,5
    ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA,active ,5
    ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather lights,not installed ,18
    ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung,abschaltbar über Energiemanagement ,18
    ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung,abschaltbar über Energiemanagement ,18
    ENG141656-ENG115656-Außenlicht_uebergreifend-Coming Home Leuchten,Low beam ,18
    ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus,manual ,18
    ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach,active ,18
    ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig,Hinweis_in_LDS-Stellung_Null_und_SL ,18
    ENG141656-ENG137034-Außenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer,Faktor fuer x5 Minuten ,18
    ENG141656-ENG154619-Außenlicht_uebergreifend-Fernlicht_LH,Sollspannungsanforderung 13.5 ,18
    ENG141656-ENG154177-Außenlicht_uebergreifend-Fog light,Sollspannungsanforderung 13.5 ,18
    ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung,46400 lx,18
    ENG141656-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung,12 lx,18
    ENG141656-ENG115858-Außenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung ,18
    ENG141656-ENG142185-Außenlicht_uebergreifend-LCM_blinker,false ,18
    ENG141656-ENG141991-Außenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht,Yes ,18
    ENG141656-ENG141990-Außenlicht_uebergreifend-LDS_mit_Nebellicht,Yes ,18
    ENG141656-ENG141989-Außenlicht_uebergreifend-Lichtdrehschalter (LDS),discrete ,18
    ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module,installed ,18
    ENG141656-ENG98354-Außenlicht_uebergreifend-Low beam,Sollspannungsanforderung 13.5 ,18
    ENG141656-ENG115863-Außenlicht_uebergreifend-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,18
    ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome,10 seconds ,18
    ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP,10 seconds ,18
    ENG141656-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert,One-sided ,18
    ENG141656-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht,active ,18
    ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit,24 s,18
    ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal,Sollspannungsanforderung 13.5 ,18
    ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung,AFS: Fernlicht ueber AFS ,6
    ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset,not active ,6
    ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent,Not Present ,6
    ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung,present ,6
    ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA,not active ,6
    ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung,800 ms,6
    ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlauf,active ,6
    ENG141682-ENG154620-Front_wiper-Frontwischer Spannungsanforderung_konfig,Keine_Spannungsanforderung ,6
    ENG141682-ENG154706-Front_wiper-Mindestwaschzeit_Frontwischer,0 ms,6
    ENG141682-ENG115771-Front_wiper-Regensensor aktivieren,Deactivating ,6
    ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay,300 ms,6
    ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status,not active ,6
    ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung,not active ,6
    ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus,not active ,6
    ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube,active ,6
    ENG99457-ENG98971-Head area heater-Temperature,-2 ,2
    ENG141645-MAS00212-HW_Verbau-Insufficient washer fluid,installed ,8
    ENG141645-MAS00214-HW_Verbau-Brake pad wear,installed ,8
    ENG141645-ENG142026-HW_Verbau-Druckklappe,not installed ,8
    ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelung,not installed ,8
    ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15,active ,8
    ENG141645-ENG142003-HW_Verbau-Status_Tankdeckelverriegelung,not active ,8
    ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0,100.00 %,30
    ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1,100.00 %,30
    ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2,100.00 %,30
    ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3,100.00 %,30
    ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4,83.00 %,30
    ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5,67.00 %,30
    ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6,50.00 %,30
    ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7,33.00 ,30
    ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8,17.00 %,30
    ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9,-0.00 %,30
    ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0,58.5 %,30
    ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1,58.5 %,30
    ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2,58.5 %,30
    ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3,58.5 %,30
    ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4,54.5 %,30
    ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5,49.5 %,30
    ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6,46.5 %,30
    ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7,35.5 %,30
    ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8,31.5 %,30
    ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9,20.0 %,30
    ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,0 ,16
    ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,00 ,16
    ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,00 ,16
    ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,not active ,16
    ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,not active ,16
    ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15,63 ,16
    ENG141657-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15,41 - LED Kleinleistung ,16
    ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15,Unknown (76),16
    ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10,0 ,16
    ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,00 ,16
    ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,00 ,16
    ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10,not active ,16
    ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10,not active ,16
    ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,127 ,16
    ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,22 ,16
    ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,38 ,16
    ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,6 - LED Lichtmodul ,16
    ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,Nebellicht links ,16
    ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,not active ,16
    ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,127 ,16
    ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,23 ,16
    ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,42 ,16
    ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,6 - LED Lichtmodul ,16
    ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,Nebellicht rechts ,16
    ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,not active ,16
    ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,127 ,16
    ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,36 ,16
    ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,00 ,16
    ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,43 - allgemeine LED ,16
    ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,only_if_closed ,16
    ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16,Parking light right ,16
    ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,not active ,16
    ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,127 ,16
    ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,35 ,16
    ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,00 ,16
    ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,43 - allgemeine LED ,16
    ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,only_if_closed ,16
    ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
    ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,not active ,16
    ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,127 ,16
    ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,38 - LED Blinkleuchten ,16
    ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,not active ,16
    ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,127 ,16
    ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,38 - LED Blinkleuchten ,16
    ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,not active ,16
    ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,0 ,16
    ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,00 ,16
    ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,00 ,16
    ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,not active ,16
    ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,not active ,16
    ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,127 ,16
    ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,0 ,16
    ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,2B ,16
    ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,09 ,16
    ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,43 - allgemeine LED ,16
    ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,not active ,16
    ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,not active ,16
    ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,127 ,16
    ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,0 ,16
    ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,2D ,16
    ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,19 ,16
    ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,43 - allgemeine LED ,16
    ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,not active ,16
    ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,not active ,16
    ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,127 ,16
    ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22,42 - LED dritte Bremsleuchte ,16
    ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,Quittierungsfunktion 1 ,16
    ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,127 ,16
    ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,0 ,16
    ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,43 - allgemeine LED ,16
    ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
    ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,not active ,16
    ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,not active ,16
    ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,127 ,16
    ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,0 ,16
    ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,43 - allgemeine LED ,16
    ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,Parking light right ,16
    ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,not active ,16
    ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,not active ,16
    ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25,127 ,16
    ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25,not active ,16
    ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,127 ,16
    ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,2E ,16
    ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,0C ,16
    ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,43 - allgemeine LED ,16
    ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,only_if_closed ,16
    ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr ,16
    ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,0 ,16
    ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,00 ,16
    ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,00 ,16
    ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,not active ,16
    ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,not active ,16
    ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,127 ,16
    ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,43 - allgemeine LED ,16
    ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,only_if_closed ,16
    ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,127 ,16
    ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,43 - allgemeine LED ,16
    ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,only_if_closed ,16
    ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2,maximize ,16
    ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,0 ,16
    ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,0 ,16
    ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,0 ,16
    ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,00 ,16
    ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,00 ,16
    ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,not active ,16
    ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,not active ,16
    ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,not active ,16
    ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2,not active ,16
    ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,not active ,16
    ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2,not active ,16
    ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,89 ,16
    ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,36 - LED Kleinleistung ,16
    ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31,0 ,16
    ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31,00 ,16
    ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31,not active ,16
    ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32,0 ,16
    ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32,00 ,16
    ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,not active ,16
    ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33,0 ,16
    ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33,00 ,16
    ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,not active ,16
    ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34,0 ,16
    ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34,00 ,16
    ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,not active ,16
    ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3,maximize ,16
    ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,0 ,16
    ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,0 ,16
    ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,0 ,16
    ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,00 ,16
    ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,00 ,16
    ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,not active ,16
    ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,not active ,16
    ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,not active ,16
    ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3,not active ,16
    ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,not active ,16
    ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3,not active ,16
    ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4,maximize ,16
    ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,0 ,16
    ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,0 ,16
    ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,00 ,16
    ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,00 ,16
    ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,not active ,16
    ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,not active ,16
    ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,not active ,16
    ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,not active ,16
    ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4,not active ,16
    ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5,maximize ,16
    ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,0 ,16
    ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,0 ,16
    ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,00 ,16
    ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,00 ,16
    ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,not active ,16
    ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,not active ,16
    ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,not active ,16
    ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,not active ,16
    ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5,not active ,16
    ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6,127 ,16
    ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,0 ,16
    ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,5 - LED Abblendlicht ,16
    ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,Lichthupe bei bereits aktivem Abblendlicht oder bereits aktivem Dauerfahrlicht ,16
    ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,not active ,16
    ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7,127 ,16
    ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,0 ,16
    ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,5 - LED Abblendlicht ,16
    ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,Lichthupe bei bereits aktivem Abblendlicht oder bereits aktivem Dauerfahrlicht ,16
    ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,not active ,16
    ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,127 ,16
    ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,127 ,16
    ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,4B ,16
    ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,44 ,16
    ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,5 - LED Abblendlicht ,16
    ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Versorgungsbedarf der LCM Module ,16
    ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,not active ,16
    ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,Parking light right ,16
    ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,127 ,16
    ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,127 ,16
    ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,49 ,16
    ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,3A ,16
    ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,5 - LED Abblendlicht ,16
    ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Versorgungsbedarf der LCM Module ,16
    ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,not active ,16
    ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
    ENG141661-Leuchtenkonfiguration_Aussenlich_Heck,26 08 00 16 02 00 7F 00 00 00 00 00 00 00 00 00 26 18 00 18 04 00 7F 00 00 00 00 00 00 00 00 00 2B 09 00 2B 18 00 7F 00 00 00 00 00 00 00 00 00 2B 19 00 2D 18 00 7F 00 00 00 00 00 00 00 00 00 2A 29 00 2C 18 24 7F 00 00 00 00 00 00 00 00 00 2B 0A 00 29 08 09 7F 00 00 00 00 00 00 00 00 00 2B 1A 00 2A 08 0A 7F 00 00 00 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 2B 0C 00 2E 1B 00 FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2B 0B 00 31 19 00 FF 00 00 00 00 00 00 00 00 00 2B 1B 00 32 19 00 FF 00 00 00 00 00 00 00 00 00 ,192
    ENG141662-Leuchtenkonfiguration_Sonstiges,2B 00 00 36 08 0A FF 00 00 00 00 00 00 00 00 00 2B 00 00 35 08 09 FF 00 00 00 00 00 00 00 00 00 24 00 00 02 2B 00 59 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00 ,128
    ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges,0 mm,62
    ENG141658-ENG142201-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe,not active ,62
    ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze,90.0 %,62
    ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze,10.0 %,62
    ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung,-114.3 ms,62
    ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1,-8.00 mm/%,62
    ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2,-8.00 mm/%,62
    ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3,-8.00 mm/%,62
    ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1,-8.00 mm/%,62
    ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2,-8.00 mm/%,62
    ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3,-8.00 mm/%,62
    ENG141658-ENG142198-Leuchtweitenregulierung-Fahrwerk_Variante,Variante_1 ,62
    ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR,0.0 %,62
    ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf,0.00 Hz,62
    ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung,normal ,62
    ENG141658-ENG142202-Leuchtweitenregulierung-Logik_PWM_Signal,Negative ,62
    ENG141658-ENG154702-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_1,0 mm,62
    ENG141658-ENG154703-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_2,0 mm,62
    ENG141658-ENG154704-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_3,0 mm,62
    ENG141658-ENG154705-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_4,0 mm,62
    ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand,0 mm,62
    ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe,0 mm,62
    ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle,2.5 %,62
    ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr,0 km/h,62
    ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung,0.00 Hz,62
    ENG141658-ENG142200-Leuchtweitenregulierung-Quelle_Hoehenwerte,BCM ,62
    ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed,Rear ,62
    ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht,active ,62
    ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese,20.0 %,62
    ENG141658-ENG154776-Leuchtweitenregulierung-sLWR_nach_Motorstart,not active ,62
    ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad,0.0 %/s,62
    ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht,-100.0 %,62
    ENG141658-ENG142196-Leuchtweitenregulierung-sLWR_verbaut,not installed ,62
    ENG141658-ENG142205-Leuchtweitenregulierung-Zyklus_sLWR,0.00 s,62
    ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,5.0 %,12
    ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,50.0 %,12
    ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,75.0 %,12
    ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,110.0 ,12
    ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,126.5 ,12
    ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0,-5.00 %,20
    ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1,-5.00 %,20
    ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2,-5.00 %,20
    ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3,-5.00 %,20
    ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4,-5.00 %,20
    ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0,-5.00 ,20
    ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1,-5.00 ,20
    ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2,-5.00 ,20
    ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3,-5.00 ,20
    ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4,-5.00 ,20
    ENG122979-ENG141954-Networking-A/C electronics,installed ,8
    ENG122979-ENG141968-Networking-Anhaengeranschlussgeraet,not installed ,8
    ENG122979-ENG141974-Networking-Bremsen_Steuergeraet,installed ,8
    ENG122979-ENG141953-Networking-Getriebesteuergeraet,installed ,8
    ENG122979-ENG99457-Networking-Head area heater,not installed ,8
    ENG122979-ENG142040-Networking-Kunden_spezifisches_Funktions_SG,not installed ,8
    ENG122979-ENG141969-Networking-UGDO,not installed ,8
    ENG124714-ENG142044-OCU-DWA_push,not active ,8
    ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare,not active ,8
    ENG124714-OCU-,not installed ,8
    ENG124714-ENG142261-OCU-Remote HuF Abbruch,20 km/h,8
    ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz,3 Hz,8
    ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1,80 s,8
    ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3,2000 ms,8
    ENG124714-ENG125657-OCU-Remote_Unlock_Lock,not_active ,8
    ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar,active ,16
    ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten,4 ,16
    ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,active ,16
    ENG98831-ENG126848-Personalization-Personalisierung_aktiv,not active ,16
    ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion,profiles_inactive ,16
    ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,active ,16
    ENG98831-ENG142030-Personalization-Profil_Variante,Schluessel ,16
    ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1,active ,16
    ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2,active ,16
    ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3,not active ,16
    ENG141646-MAS01065-Querschnitts_funktionen-Brand,VW ,5
    ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung,active ,5
    ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21,active ,5
    ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus,Pin A31 ,5
    ENG141646-ENG154685-Querschnitts_funktionen-Hupe,Sollspannungsanforderung 13.5 ,5
    ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme,not_installed ,5
    ENG141646-ENG141964-Querschnitts_funktionen-Steering alignment,Left ,5
    ENG141646-ENG141965-Querschnitts_funktionen-Traffic side,Right ,5
    ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,0 ,10
    ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system,not installed ,10
    ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel,not active ,10
    ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit,0 ms,10
    ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit,0 ms,10
    ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit,0 ms,10
    ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit,0 ms,10
    ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit,0 ms,10
    ENG115729-ENG154424-Scheinwerferreinigung-Waschen,Keine_Spannungsanforderung ,10
    ENG141684-SFT271873-Slave_systems_identification-Control Unit For Wiper Motor,Not available ,6
    ENG141684-SFT271874-Slave_systems_identification-Rain Light Recognition Sensor,Not available ,6
    ENG141684-SFT271875-Slave_systems_identification-Light switch,Not available ,6
    ENG141684-SFT271876-Slave_systems_identification-Garage door opener control module,Not available ,6
    ENG141684-SFT271877-Slave_systems_identification-Garage Door Opener Operating Unit,Not available ,6
    ENG141684-SFT271894-Slave_systems_identification-Sensor For Anti Theft Alarm System,Not available ,6
    ENG141684-SFT271896-Slave_systems_identification-Alarm horn,Not available ,6
    ENG141684-SFT271904-Slave_systems_identification-Sun Roof,Not available ,6
    ENG141684-SFT271910-Slave_systems_identification-Ceiling Light Module,Not available ,6
    ENG141684-SFT271928-Slave_systems_identification-Roof Blind,Not available ,6
    ENG141684-SFT271947-Slave_systems_identification-Relative Air Humidity Interior Sender,Not available ,6
    ENG141684-SFT271966-Slave_systems_identification-Neck Heating Left,Not available ,6
    ENG141684-SFT271967-Slave_systems_identification-Neck Heating Right,Not available ,6
    ENG141684-SFT272065-Slave_systems_identification-Seat Backrest Fan 1 Front Left,Not available ,6
    ENG141684-SFT272067-Slave_systems_identification-Seat Cushion Fan 1 Front Left,Not available ,6
    ENG141684-SFT272069-Slave_systems_identification-Seat Backrest Fan 1 Front Right,Not available ,6
    ENG141684-SFT272071-Slave_systems_identification-Seat Cushion Fan 1 Front Right,Not available ,6
    ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker,MFG ,4
    ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen,active ,5
    ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus,by look command via remote control key ,5
    ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen,active ,5
    ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung,active ,5
    ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung,active ,5
    ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel,active ,5
    ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt,active ,5
    ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung,not active ,5
    ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron,active ,5
    ENG153700-ENG154515-Steering Column Switch-Anzahl_fehler_P-verriegelt,250 ,10
    ENG153700-ENG154621-Steering Column Switch-Geschwindigkeitesschwele_erkennung_fahrt_P_plausibel,10 km/h,10
    ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter,CAN ,10
    ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel,5.0 min,10
    ENG153700-ENG154829-Steering Column Switch-Zeit_t_P-verriegelt_entprellen,40 ms,10
    ENG141666-ENG101574-Suchbeleuchtung_Abdimmen-X1,200 ms,22
    ENG141666-ENG115664-Suchbeleuchtung_Abdimmen-x10,2000 ms,22
    ENG141666-ENG99557-Suchbeleuchtung_Abdimmen-X2,400 ms,22
    ENG141666-ENG102140-Suchbeleuchtung_Abdimmen-X3,600 ms,22
    ENG141666-ENG102936-Suchbeleuchtung_Abdimmen-X4,800 ms,22
    ENG141666-ENG103548-Suchbeleuchtung_Abdimmen-X5,1000 ms,22
    ENG141666-ENG113992-Suchbeleuchtung_Abdimmen-X6,1200 ms,22
    ENG141666-ENG115661-Suchbeleuchtung_Abdimmen-x7,1400 ms,22
    ENG141666-ENG115662-Suchbeleuchtung_Abdimmen-x8,1600 ms,22
    ENG141666-ENG115663-Suchbeleuchtung_Abdimmen-x9,1800 ms,22
    ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1,100.0 %,22
    ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2,95.0 %,22
    ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3,80.0 %,22
    ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4,40.0 %,22
    ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5,20.0 %,22
    ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6,10.0 %,22
    ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7,5.0 %,22
    ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8,3.0 %,22
    ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9,1.0 %,22
    ENG141663-ENG154582-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xs_PWM,0.00 s,21
    ENG141663-ENG154583-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xt_PWM,0.00 s,21
    ENG141663-ENG154584-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xd_PWM,0.00 s,21
    ENG141663-ENG154585-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xt_PWM,0.00 s,21
    ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung,HMI ,21
    ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,20.0 s,21
    ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen,3.0 s,21
    ENG141663-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten,not_active ,21
    ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,2 ,21
    ENG141663-ENG154712-Suchbeleuchtung_allgemein-PWM_Daempfung_Aufdimmen_KL58xs_PWM,0.00 s,21
    ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert,100 %,21
    ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor,0.100 ,21
    ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,10.0 %,21
    ENG141667-ENG99777-Suchbeleuchtung_Fotosensor-Y1,50 lx,22
    ENG141667-ENG100480-Suchbeleuchtung_Fotosensor-Y2,100 lx,22
    ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3,200 ,22
    ENG141665-ENG101574-Suchbeleuchtung_Hochdimmen-X1,200 ms,22
    ENG141665-ENG115664-Suchbeleuchtung_Hochdimmen-x10,2000 ms,22
    ENG141665-ENG99557-Suchbeleuchtung_Hochdimmen-X2,400 ms,22
    ENG141665-ENG102140-Suchbeleuchtung_Hochdimmen-X3,600 ms,22
    ENG141665-ENG102936-Suchbeleuchtung_Hochdimmen-X4,800 ms,22
    ENG141665-ENG103548-Suchbeleuchtung_Hochdimmen-X5,1000 ms,22
    ENG141665-ENG113992-Suchbeleuchtung_Hochdimmen-X6,1200 ms,22
    ENG141665-ENG115661-Suchbeleuchtung_Hochdimmen-x7,1400 ms,22
    ENG141665-ENG115662-Suchbeleuchtung_Hochdimmen-x8,1600 ms,22
    ENG141665-ENG115663-Suchbeleuchtung_Hochdimmen-x9,1800 ms,22
    ENG141665-ENG99777-Suchbeleuchtung_Hochdimmen-Y1,1.0 %,22
    ENG141665-ENG100480-Suchbeleuchtung_Hochdimmen-Y2,3.0 %,22
    ENG141665-ENG100773-Suchbeleuchtung_Hochdimmen-Y3,5.0 %,22
    ENG141665-ENG100631-Suchbeleuchtung_Hochdimmen-Y4,11.0 %,22
    ENG141665-ENG102174-Suchbeleuchtung_Hochdimmen-Y5,22.0 %,22
    ENG141665-ENG113993-Suchbeleuchtung_Hochdimmen-Y6,40.0 %,22
    ENG141665-ENG115665-Suchbeleuchtung_Hochdimmen-y7,80.0 %,22
    ENG141665-ENG115666-Suchbeleuchtung_Hochdimmen-y8,95.0 %,22
    ENG141665-ENG115667-Suchbeleuchtung_Hochdimmen-y9,100.0 %,22
    ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3,500 lx,8
    ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2,50 ,12
    ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3,100 ,12
    ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0,2.0 %,12
    ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1,2.0 %,12
    ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2,6.0 %,12
    ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3,10.0 %,12
    ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4,80.0 %,12
    ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1,10 lx,12
    ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2,100 lx,12
    ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3,500 lx,12
    ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1,20 ,12
    ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2,80 ,12
    ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3,180 ,12
    ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4,300 ,12
    ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen,active ,4
    ENG141632-ENG116646-Sunroof-SAD Komfort schliessen,active ,4
    ENG141632-ENG116645-Sunroof-SAD Richtung Komfortoeffnen,tilting ,4
    ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1,installed ,4
    ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rollo,not installed ,4
    ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule,LIN ,4
    ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck,not active ,9
    ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb,not active ,9
    ENG141634-ENG142259-Verdecksteuergeraet-Kick_and_close,not installed ,9
    ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global,not active ,9
    ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen,not active ,9
    ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließen,not active ,9
    ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf,not active ,9
    ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen,not active ,9
    ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung,Always ,9
    ENG141634-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden,Always ,9
    ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit,not installed ,9
    ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung,not active ,9
    ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy,not active ,9
    ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder,not active ,9
    ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung,not active ,9
    ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessy,not active ,9
    ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinder,not active ,9
    ENG141634-ENG115869-Verdecksteuergeraet-Virtuelles_Pedal,not active ,9
    ENG141634-ENG142258-Verdecksteuergeraet-Virtuelles_Pedal_HMI_einstellba,not active ,9
    ENG141634-ENG142257-Verdecksteuergeraet-Virtuelles_Pedal_Verbau,not installed ,9
    ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein,not active ,7
    ENG141651-ENG141981-ZV allgemein-Lock_Unlock_Taster_direkt,not installed ,7
    ENG141651-ENG142019-ZV allgemein-Lock_Unlock_Toggle_Taster,not installed ,7
    ENG141651-ENG115755-ZV allgemein-Notschließfunktion,active ,7
    ENG141651-ENG141957-ZV allgemein-Radio freq.,434.42MHz ,7
    ENG141651-ENG141958-ZV allgemein-Tankschloss,Bidirectional ,7
    ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung,Globale Entriegelung ,7
    ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion,not installed ,7
    ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit,not active ,3
    ENG141654-ENG116706-ZV Autolock-Autounlock NAR,not active ,3
    ENG141654-ENG116622-ZV Autolock-Geschwindigkeitsabhaengige Tankdeckelverriegelung,not active ,3
    ENG141654-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock,adjustable ,3
    ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen,not active ,4
    ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash,not active ,4
    ENG141653-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckels,active ,7
    ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster,not installed ,7
    ENG141653-ENG133386-ZV Heck-Heckfreigabe_Ohne_Verzoegerung,not active ,7
    ENG141653-ENG142245-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen,not active ,7
    ENG141653-ENG141998-ZV Heck-Heckschloss_mit_Vorraste,Yes ,7
    ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung,Contact control ,7
    ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster,0.0 s,7
    ENG141653-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active ,7
    ENG141681-IDE02022-ZV Komfort-Comfort opening,not active ,8
    ENG141681-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen,active ,8
    ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen,active ,8
    ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen,active ,8
    ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen,active ,8
    ENG141681-ENG122186-ZV Komfort-Menuesteuerung Regenschliessen,active ,8
    ENG141681-ENG125656-ZV Komfort-Regenschliessen_art,Permanent ,8
    ENG141681-ENG125655-ZV Komfort-Regenschliessen_ein_aus,active ,8
    ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen,not active ,8
    ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen,not active ,8
    ENG141652-ENG141999-ZV Türkonfiguration-Fond_Schloss,2-Motorenschloesser ,5
    ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR,No ,5
    VAG Imports Argentina (Juan García)
    Juan: thanks for posting the admap - but alas it's bad news!
    The BCM in your car doesn't use Leuchte-sets to control the lamps in the headlight assemblies. All of the normal Leutch-sets for these lamps are not active - which means that their operation can't be changed (alas).
  6. Likes Uwe, VagImports liked this post
    Aug 2019
    NW Florida
    This interests me as well. It looks like the same light sets used in the Atlas - Leuchte6ABL/Leuchte7ABL (low beam); Leuchte8FL/Leuchte9FL (high beam); Leuchte12NL/Leuchte13NL (fogs)
    TW
