Results 1 to 6 of 6
Thread: 2013 Touareg Brake Replacement Challenges
    Mar 2018
    US
    Replaced my brake pads and rotors on my 2013 Touareg recently. Good news is they work and I can stop my car, bad news is I am dealing with 2 indicator lights. The "Brake Pad Ware" light is on as well as the "Brake" indicator light. Was hoping a scan would shed some light on why the "Brake" light is on, but I am not seeing anything helpful (visually check fluid level and seems to be in range, but VW makes it very difficult to tell on this model).
    Second issue is I know I damaged one of the wires when installing the pad ware sensors, so I would like to turn off that light if possible. Not seeing anything in 17 Instruments that point to that feature, any help on how to turn that off?
    Monday,26,August,2019,15:11:23:50497
    VIN: WVGEP9BP6DD003589   License Plate: A
    Mileage: 182866km-113627mi   Repair Order:
    Chassis Type: BP-VW52 (7P6)
    Scan: 01 02 03 05 08 09 15 16 17 19 36 42 46 52 53 55 56 5F 62 65
              69 6C 6D 72
    VIN: WVGEP9BP6DD003589   Mileage: 182866km-113627miles
    Address 01: Engine (J623-CNRB)       Labels:. 059-907-401-V2.clb
       Part No SW: 7P0 907 401 K    HW: 7P0 907 401 K
       Component: 3.0TDI FSA    H17 0011
       Revision: 56H17---
       Coding: 292A4012233600050000
       Shop #: WSC 23342 444 00000
       ASAM Dataset: EV_ECM30TDI0117P0907401K 001012
       ROD: EV_ECM30TDI0117P0907401K.rod
       VCID: 372BD6085FC1D0AF3B3-8062
    8863 - Diesel Particulate Filter
              P2459 00 [096] - Regeneration Frequency
    17277 - SCR NOx Catalyst Bank 1
              P20EE 00 [096] - Efficiency too Low
       Part No SW: 0C8 927 750 AK    HW: 0C8 927 750 AK
       Component: AL1000 AISIN  001 3398
       Coding: 001368
       Shop #: WSC 41331 001 1048576
       ASAM Dataset: EV_TCMAL991031 002115
       ROD: EV_TCMAL991031_002.rod
       VCID: 75B71C00054D62BFE9F-8020
    Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
       Part No SW: 7P0 907 379 M    HW: 7P0 907 379 A
       Component: MK25A         H36 0436
       Revision: --------    Serial number: 418920010EC815
       Coding: 5B7613C349242556DAF9C89B92DBA4407300
       Shop #: WSC 31414 790 00001
       ASAM Dataset: EV_MK25AXT 008001
       ROD: EV_ESPMK25A00800.rod
       VCID: 47CBA6C82F21A02F4B3-8012
       Part No SW: 4H0 907 064 CK    HW: 4H0 907 064 CK
       Component: BCM2 2.0      H32 0421
       Coding: 09860010000000000000
       VCID: 74B121040EB77BB7DE1-8020
       Subsystem 1 - Part No SW: 7P6 959 754 AD    HW: 7P6 959 754 AD
       Component: FBSTOUAREGIDG  H04 0051
       Serial number: 0512000041786012
       Serial number: 2312000147086002
       Part No SW: 7P6 907 040 BK    HW: 7P6 907 040 BK
       Component: Klima 2 Zonen H20 1305
       Coding: B686200A80
       VCID: 7EA5032C307B21E7B85-802A
    15360256 - Component Protection
              U1101 00 [008] - Active
                        Reset counter: 28
                        Mileage: 182117 km
                        Date: 2019.08.10
                        Time: 22:11:17
    0243 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
                        Reset counter: 252
                        Mileage: 180832 km
                        Date: 2019.07.24
                        Time: 06:21:09
       Part No SW: 4H0 907 063 BL    HW: 4H0 907 063 D
       Component: BCM1 2.0      H12 0111
       Revision: 15012002    Serial number: 00000001554352
       Coding: 26001012973C5D010020180300005D0C431C660882010261000000020000
       VCID: 73B322180BB97C8FC7B-8026
       Component: WWS    120626  31  0020
       Serial number: 90243400120706154751
       Coding: 004DBD
       Component: RLFS  H09 0011
       Serial number: 10413081
       Coding: 025223
       Component: E1 - LDS  H04 0031
       Serial number: 00000000001207120610
       Subsystem 4 - Part No SW: 4H0 907 410 A    HW: 4H0 907 410 A
       Component: USHL4.2  H30 0020
       Serial number: 0000001805569R15DG07
    01856 - Temperature Sensor for Heated Seat; Front Right (G345)
                        Fault Status: 00101100
                        Reset counter: 252
                        Mileage: 180832 km
                        Date: 2019.07.24
                        Time: 06:21:00
       Part No SW: 7P0 959 655 C    HW: 7P0 959 655 C
       Component: VW10Airbag025 H05 0025
       Revision: --------    Serial number: 003L00042U1I
       Coding: 000000000000000000000000000000003235
       VCID: 41DFB8D001059E1F857-8014
       Subsystem 1 - Part No SW: 7P6 959 339     HW: 7P6 959 339
       Component: BF-Gewichtss.  003 0005
       Serial number: 5850000R1243008U3U
       Serial number: 3575LRB405V1F0BA8O6M
       Serial number: 3585LRB405T1F0BA5H8D
       Serial number: 3515RRB404P1ADPC4GBW
       Serial number: 3525RRB40651ADPCHG8P
       Serial number: 3555NRB400M4UIV8R0S-
       Serial number: 3565NRB400K4UIV8713Y
       Component: Lenks.Modul   H05 0005
       Revision: --------    Serial number: 90372QGQ0001A
       Coding: 000415
       VCID: 3829D534525FDFD7329-806C
       Serial number: 0197198
       Part No SW: 7P6 920 981 F    HW: 7P6 920 981 F
       Component: Kombi         H13 0318
       Revision: 13240077    Serial number: 658260612592029
       Coding: 8B7733022B00CF05020004
       ASAM Dataset: EV_KombiUDSRBVW526 001017
       ROD: EV_KombiUDSRBVW526.rod
       VCID: 40D9BDD40A0F97178A9-8014
       Part No SW: 7P6 907 530 F    HW: 7P6 907 530 F
       Component: GW-CAN-L-MOST H11 6028
       Revision: --------    Serial number: 00000000602288
       Coding: 0001037500
       ASAM Dataset: EV_GatewVW526UDS 001007
       ROD: EV_GatewUDS_VW52.rod
       VCID: 3B23CA3863E9F4CFDFB-806E
       Serial number: 00000000005650778968
       Revision: AA000000    Serial number: 00000034314519
       Coding: 0058130000004001000001010101202020202121202020
       VCID: 3431E1044E373BB71E1-8060
       Part No SW: 4H0 959 793 N    HW: 4H0 959 793 F
       Component: TSG FA        H07 0166
       Revision: --------    Serial number: 0000129061681
       Coding: 011D07205E00453005080000
       VCID: 44D1B1C41E978B37AE1-8010
       Revision: 00002001    Serial number: 0180018216
       Coding: 0186123A28B9509480A00620210000000000000000000000000000000000
       Subsystem 1 - Part No SW: 7P6 959 719     HW: 7P6 959 719
       Component: GTO BT  H19 0059
       Serial number: 194124326
       Subsystem 3 - Part No SW: 7P0 959 591 B    HW: 7P0 959 591 B
       Component: J245 PS30.055  H01 0008
       Serial number:     WOO17385727
       Coding: 191100
       Subsystem 4 - Part No SW: 7P0 959 591 C    HW: 7P0 959 591 C
       Component: J394 PS30.055  H01 0008
       Serial number:     WOO1741322.
       Coding: 191100
       Part No SW: 4H0 959 792 F    HW: 4H0 959 792 F
       Component: TSG BF        H07 0166
       Revision: --------    Serial number: 0000128888513
       VCID: 3B23CA386369F4CFDFB-806E
       Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
       Component: EPB           H51 1201
       Revision: 00000000    Serial number: C1270201062
       Coding: 01040200
       ROD: EV_ParkbA7.rod
       VCID: 3635DB0C58CB29A7205-8062
       Slave 3:
       Part No SW: 7P6 907 357     HW: 7L6 907 357 C
       Component: AFS-ECU       H04 0110
       Coding: 010A00010F000400
       VCID: 7CA10924266733F7961-8028
       Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
       Coding: 130000
       Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
       Coding: 130000
       Part No SW: 4G0 035 082 D    HW: 4G0 035 082
       Component: Radio U SIRIU H60 0112
       Revision: AB001007    Serial number: 156F$0C7608462
       Coding: 020007020100000001
       VCID: 211F1850E1C5BE1FE57-8074
       Part No SW: 7P6 035 664 C    HW: 7P6 035 664
       Component: H-BN-NA       H45 0544
       Revision: --------    Serial number: 445G10C7537861
       Coding: 010200050040E1EE41022B0C00000003F0000100
       Subsystem 1 - Part No: 8R0 060 884 AM
       Component: NAR 2012  0605
       Subsystem 2 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
       Component: DU8 SV Touch  H26 0045
       Serial number: VWZ8Z9M7900CMT
       Subsystem 3 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
       Component: CD-Database  1886
       Part No SW: 4H0 959 795 B    HW: 4H0 959 795 B
       Component: TSG HL        H09 0167
       Revision: --------    Serial number: 0000129107491
       Coding: 011C07200000253005080000
       VCID: 3A2DCF3C6C53CDC7C4D-806E
    Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
       Part No SW: 7P6 907 273 F    HW: 7P6 907 273 F
       Component: RDKBERU25     H09 0008
       Serial number: 10000000086386
       ROD: EV_RDKBERU25_VW52.rod
       VCID: 3FDBBE2877F1E8EFF33-806A
    8397058 - Front Left TPMS Sensor
              C1050 31 [009] - No Signal
                        Reset counter: 244
                        Mileage: 182585 km
                        Date: 2019.08.22
                        Time: 17:48:43
                        Vehicle speed: 134 km/h
                        Outside air temperature: 22 °C
                        Reception level antenna 1: 670 mV
                        Offset level antenna 1: 630 mV
    Address 69: Trailer (J345)       Labels: Redir Fail!
       Part No SW: 7P0 907 383 F    HW: 7P0 907 383 B
       Component: Anhaenger     H09 0110
       Revision: 5A001001    Serial number: 00000179754306
       Coding: 020D000000000000
       Part No SW: 7P6 907 441 A    HW: 4H0 907 441
       Component: SG Rueckfahrkamera  0020
       Revision: 00H06000    Serial number: 525 PA8J261227
       Coding: 0110001
       VCID: 372BD6085341D0AF3B3-8062
       Part No SW: 7P6 959 107 A    HW: 7P6 959 107
       Component: HDSG-Modul    H10 0620
       Revision: 22010001    Serial number: 170200965
       Coding: 0533314003
       ASAM Dataset: EV_HeckkTouar 202137
       ROD: EV_HeckkTouar.rod
       VCID: 3D27C4207DFDFAFFE1F-8068
       Component: TSG HR        H09 0167
       Revision: --------    Serial number: 0000129107393
    End----------(Elapsed Time: 02:02, VBatt start/end: 14.4V/14.5V)-----------
    Did you do front and rear or just front?
    Your brake wear warning light is probably on due to the damaged wire. That's generally a dumb circuit straight to the instrument cluster; continuity in the circuit turns the light off. Where's the damage? On car's wiring or the pad's wiring?
    HQ
    So it is a simple circuit that goes from the J519 to ground. J519 to left front to right front to right rear to left rear to ground. Make sure the pigtail connectors of the sensors are secured. /1 of each sensor goes back towards the J519 and /2 of each sensor goes towards ground.
    You can unplug a sensor and short /1 to ground and see if that tricks the system. If so, then the point of failure is past that point, plug back up and go down stream towards ground. I guess you should also be able to ohm test /2 to ground and get 0 ohms, if not, go down stream towards ground.
    Jef
  4. Likes PetrolDave, Uwe liked this post
    Mar 2018
    US
    I did front and back rotors and pads.
    As for the damaged wire, it was the left front. When trying to remove the clip which is held in the metal bracket, I accidentally pulled the car side wires out of the plug. Thought I hard wired it together correctly, but may not have made a good enough connection. Will take the tire off later in the day and see if I can do a better job connecting to get the light to go off. Will be a few hours before I can do this but will report back later in the day.
    Mar 2018
    US
    Just a quick update. Took off the right front tire and removed the damaged pad sensor connectors to just wires then used a couple of butt connectors and heat shrink to connect the wires directly from the car to the pad sensors, not ideal but not many options given the damage to the connectors. This worked and both the "BRAKE" and "Pad Ware" indicator lights are off so all is now good. Hopefully I do not need to worry about this for another 100k miles (what I got out of the original pads). Thanks for the help.
  7. Likes Uwe liked this post
    HQ
    Quote Originally Posted by LWitty View Post
    Lulz, you are a VERY optimistic Touareg owner.
    Jef
