- Joined
- Aug 24, 2019
- Messages
- 56
- Reaction score
- 30
- Location
- NW Florida
- VCDS Serial number
- C?ID=369048
Not sure this is the best thread for this…I’m just a novices here, but with help from this forum I’ve may some successful tweaks to the exterior lights on my 2019 Atlas SEL - that I'm very happy with. (1) Added inner Brake lights and (2) rear Daytime Running lights for better visibility from ‘rear-enders’. Also, as a matter of preference, (3) changed to Fogs only in the front and (4) Reverse lights only in the back during Coming Home/Leaving Home activation. I’d be happy to share some photos and the coding with anyone here who’s interested.
Now, I’m trying to learn how the Atlas headlights might be re-coded, specifically, the Daytime Running lights that go out completely when the turn signal is activated. I know all about the Federal regulations on DRLs – please, no lectures. Is it even possible with the Atlas’ light configuration? Can the DRLs be re-coded to stay on during signal activation; or what I would really like to see is, dimmed DRLs during the turn signal cycle?
I believe Leuchte8FL LB39 (left) and Leuchte9FL RB2 (right) function as High Beam, DRL, Parking light, Turn Signal and Side Marker all in one – this might be a unique configuration for the Atlas. The Dipped beam (or Low beam) function appears to be singularly assigned to Leuchte6ABL LC5 (Left) and Leuchte7ABL RB1 (Right) – please let me know if otherwise.
Shown below is the Factory coding for Leuchte8FL LB39 (left) and Leuchte9FL RB2 (right). Interestingly, these are the only lights on the Atlas coded with a Light function (Lichtfunktion) of “Versorgungsbedarf der LCM Module”. I’m sure this complicates things but I’m not sure how, or for that matter, what coding options to try regarding the LCM.
TW
Autoscan
TW
Autoscan
;SW:5Q0-937-085-BT HW:5Q0-937-085-BG --- Cent. Elect.
;Component:BCM MQBAB HNA H38 0273 Coding:000000000000000000000000000000000000000000000000000000000000
;EV_BCMMQB 19001
;Sunday 25
;VCDS Version: Release 19.6.1 (x64) Data version: 20190529 DS308.0
;VCID: 0C41A58456CD9757A61-8058
IDE00001-ENG99061-Production mode-Access control not active
IDE00001-ENG115730-Production mode-Exterior lighting not active
IDE00001-ENG112304-Production mode-Heckwischer not active
IDE00001-ENG98647-Production mode-Interior lighting not active
IDE00001-ENG115729-Production mode-Scheinwerferreinigung not active
IDE00001-ENG115731-Production mode-Virtuel_pedal not active
IDE00002-Transport mode active
IDE00820-Activating and deactivating all development messages not active
IDE02152-Characteristics in production mode 2000 ms
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking Decelerate
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln not active
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global active
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn not active
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln active
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn short
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung active
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte active
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen active
IDE02269-ENG133344-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehl not active
IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl active
IDE02269-ENG142248-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit 200 ms
IDE02269-ENG142247-Acknowledgement signals-ZV-Blinken_Dunkelzeit 200 ms
IDE02269-ENG142246-Acknowledgement signals-ZV-Blinken_Hellzeit 200 ms
IDE02332-Deactivate production mode 0
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen not active
IDE02711-ENG133397-Rear Window Wiper-Einzelansteuerung Heckintervallwischen not active
IDE02711-ENG133395-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1 8 s
IDE02711-ENG133396-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2 16 s
IDE02711-ENG112304-Rear Window Wiper-Heckwischer logikgesteuert
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf not active
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck active
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1 5 s
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2 3 s
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik 7 s
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall 7 s
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW active
IDE02711-ENG154784-Rear Window Wiper-Spannungsanforderung_konfig_Wischer Keine_Spannungsanforderung
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck active
IDE02711-ENG154831-Rear Window Wiper-Zeit_wasch_min_heck 0 ms
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset 0.3 °
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit 50.0 %/s
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt both sides
IDE03638-ENG116675-static AFS light-Lower speed threshold 0.0 km/h
IDE03638-ENG116682-static AFS light-Maximaltemperatur 100.0 °C
IDE03638-ENG116679-static AFS light-obere Grenztemperatur 95.0 °C
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel 120 °
IDE03638-ENG116680-static AFS light-untere Grenztemperatur 80.0 °C
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel 80 °
IDE03638-ENG116676-static AFS light-Upper speed threshold 40.0 km/h
IDE03638-ENG116674-static AFS light-Vorschrift ECE R119
IDE03638-ENG115830-static AFS light-Zeitwert Einschaltzeit Abbiegelicht 15 min
IDE03787-Activate left/right hand drive switch-over not active
IDE04927-IDE01446-Window heater-Running time of heated front window 240 s
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung 35.0 °C
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung 35.0 °C
IDE04927-ENG142251-Window heater-Frontscheibenheizung _maximale_Dauer 0 s
IDE04927-ENG142035-Window heater-Frontscheibenheizung_LED_direkt not installed
IDE04927-ENG142018-Window heater-Frontscheibenheizungsansteuerung direkt von externem Algorithmus not installed
IDE04927-ENG126845-Window heater-FSH Automatik active
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert 320 s
IDE04927-ENG141955-Window heater-heizbare Heckscheibe installed
IDE04927-ENG142021-Window heater-Heizbare_Frontscheibe not installed
IDE04927-ENG246969-Window heater-HZG_Wischer_Ablage not installed
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH active
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH active
IDE04927-ENG246996-Window heater-WAH_Temp_Wischer_aktiv -2.0 °C
IDE04927-ENG141962-Window heater-Waschduesenheizung installed
IDE04927-ENG154810-Window heater-window heating front activation time pause 240 s
IDE04928-MAS01577-Anti-theft device-Parking heater not installed
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn not active
IDE04928-ENG115864-Anti-theft device-Alarmsignal frequency modulated
IDE04928-ENG141960-Anti-theft device-Anti-theft alarm system active
IDE04928-ENG154588-Anti-theft device-Deaktivierung DWA-Sensoren via Doppelklick activ
IDE04928-ENG154589-Anti-theft device-Deaktivierung_DWA_Sensoren_HMI not_active
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung not active
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus not active
IDE04928-ENG142007-Anti-theft device-DWA_Einfachhorn_oder_Sounder Horn_verbaut
IDE04928-ENG141961-Anti-theft device-Heckscheibenbruchsensor not installed
IDE04928-ENG142006-Anti-theft device-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet No
IDE04928-ENG142249-Anti-theft device-OBD Alarm not_active
IDE04928-ENG154722-Anti-theft device-RHF_Panikalarm activ
IDE04928-ENG142009-Anti-theft device-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv) No
IDE04928-ENG142010-Anti-theft device-Sensor_fuer_Innenraumueberwachung No
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl 10 Alarme
IDE04928-ENG142008-Anti-theft device-tilt_sensor No
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel not active
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm keine verzoegerung
IDE05143-MAS02985-Writing parameter-Value 130
IDE05143-MAS04381-Writing parameter-Parameter address FE 00 00
IDE05144-Read parameter address FE 00 00
IDE05145-Light configuration 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 36 00 1A 0B 0F 7F 00 00 00 00 00 00 00 00 00 05 40 00 1B 0C 0F 7F 00 00 00 00 00 00 00 00 00 05 3A 00 49 46 00 7F 08 09 7F 00 00 00 00 00 00 05 44 00 4A 46 00 7F 08 0A 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 38 00 22 12 16 64 00 00 00 1E 00 64 00 00 00 0A 42 00 23 13 17 64 00 00 00 1E 00 64 00 00 00
IDE06089-ENG246993-Seat heater level current consumption allocation-SIH_PWM_Teiler 0
IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN Heizmatten am BCM
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss 1 s
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss 0.00 °C
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle 18.50 °C
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle 18.00 °C
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle 18.50 °C
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle 18.00 °C
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle 26.00 °C
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle 25.50 °C
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle 26.00 °C
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle 25.50 °C
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle 43.00 °C
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle 42.50 °C
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle 43.00 °C
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle 42.50 °C
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI Keine_Spannungsanforderung
IDE06089-ENG154775-Seat heater level current consumption allocation-Sitzheizung.Regelbetrieb LO Keine_Spannungsanforderung
IDE06089-ENG141977-Seat heater level current consumption allocation-Sitzheizungsfreigabe not installed
IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75 15.7 V
IDE06425-Roller test bench mode: functional not active
IDE06507-MAS13125-Button in center console-Function of button 1 Start-stop
IDE06507-MAS13129-Button in center console-Function of button 2 not coded/not installed
IDE06507-MAS13132-Button in center console-Function of button 3 not coded/not installed
IDE06507-MAS13135-Button in center console-Function of button 4 Steering wheel heater
IDE06507-ENG140243-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED LED installed
IDE07007-ENG142253-A/C heater function via remote control-Abbruch_d_Warnblinker_moeglich active
IDE07007-ENG142252-A/C heater function via remote control-Abbruch_Hupen_RSt not active
IDE07007-ENG142255-A/C heater function via remote control-Aktivierung_Drehzahlanzeige active
IDE07007-ENG142254-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Akustik active
IDE07007-ENG128461-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt active
IDE07007-ENG115720-A/C heater function via remote control-Remote Start installed
IDE07007-ENG246992-A/C heater function via remote control-Remotestart_externe_FFB_verbaut not installed
IDE07007-ENG128460-A/C heater function via remote control-Rueckmeldung_bei_Aktivierung active
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs abschalten ueber Abschaltstufen des Energiemanagements oder nach der Nachlaufzeit
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit 30 min
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein active
IDE08577-Garage door opener: use of GPS data not active
IDE08578-Garage door opener: bi-directional communic. active
IDE08580-Garage door opener: increasing transm. power not active
IDE08583-Garage door opener: no. of channels 3 channels
IDE08584-MAS07165-Garage door opener: freq. selection-Frequency range A not active
IDE08584-MAS07166-Garage door opener: freq. selection-Frequency range B not active
IDE08584-MAS07167-Garage door opener: freq. selection-Frequency range C not active
IDE08584-MAS07168-Garage door opener: freq. selection-Frequency range D not active
IDE08584-MAS07169-Garage door opener: freq. selection-Frequency range E not active
IDE08584-MAS07170-Garage door opener: freq. selection-Frequency range F not active
IDE08584-MAS07171-Garage door opener: freq. selection-Frequency range G not active
IDE08584-MAS07172-Garage door opener: freq. selection-Frequency range H not active
IDE08584-MAS07173-Garage door opener: freq. selection-Frequency range I not active
IDE08584-MAS07174-Garage door opener: freq. selection-Frequency range J not active
IDE08584-MAS07175-Garage door opener: freq. selection-Frequency range K not active
IDE08584-MAS09302-Garage door opener: freq. selection-Frequency range US-I not active
IDE08584-MAS09303-Garage door opener: freq. selection-Frequency range US-II not active
IDE08584-MAS09304-Garage door opener: freq. selection-Frequency range US-III not active
IDE08584-MAS09305-Garage door opener: freq. selection-Frequency range US-IV not active
IDE08584-MAS10461-Garage door opener: freq. selection-Frequency range AB not active
IDE08585-Garage door opener: activation via remote key not active
IDE08778-Garage door opener: surround. target area 30 m
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen active
IDE08786-ENG141956-Assistance light functions-Humidity sensor installed
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit normal
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe not active
IDE08786-ENG142228-Assistance light functions-Maskierung_Regenfunktion not active
IDE08786-ENG141985-Assistance light functions-Regen_Lichtsensor LIN_REGEN_LICHT_SENSOR
IDE08786-ENG124476-Assistance light functions-Sunlight Sensor installed
IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual 7
IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation not active
IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung not active
IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default not active
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit 0.10 s
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1 2
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2 3
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3 1
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig not active
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig not active
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach 50%
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe 2
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum 50%
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole 50%
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer 50%
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn 50%
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen active
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen active
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen active
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen active
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen active
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen active
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen active
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen active
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen active
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen active
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen active
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen active
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen active
IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen active
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten active
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig not active
IDE09731-ENG98648-Int. light: 2nd generation-Interior light Keine_Spannungsanforderung
IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWM not active
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig not active
IDE09731-ENG142031-Int. light: 2nd generation-LIN-Dachkonsole mit Flaechenlicht not installed
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig not active
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren not active
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig not active
IDE09731-ENG116687-Int. light: 2nd generation-Tuerinnengriff mit Tuertafel not installed
IDE09731-ENG116686-Int. light: 2nd generation-Tuerinnengriffbeleuchtung mit I-Tafel not installed
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig not active
IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G installed
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel not active
IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default 1
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI not active
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel not installed
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel not installed
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher not installed
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen not active
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus not active
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung not installed
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung not installed
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil not installed
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI not installed
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting installed
IDE09732-ENG133385-Interior light: light configuration-Frei_Farbwahl_ueber_HMI not active
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar not active
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung not installed
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung not installed
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne 30%
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz 30%
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne 30%
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz 30%
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne 50%
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz 50%
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne 50%
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz 50%
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne 75%
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz 75%
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne 80%
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz 80%
IDE09761-ENG142024-Seat fan charac. curve-Sitzlueftung not installed
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar installed
IDE09761-ENG142025-Seat fan charac. curve-Sitzpneumatik not installed
IDE10308-Garage door opener: support door name not active
IDE10349-MAS10436-Garage door opener: Default/Fix kit mode-Default mode not active
IDE10349-MAS10437-Garage door opener: Default/Fix kit mode-Fixkit mode: button 1 not active
IDE10349-MAS10438-Garage door opener: Default/Fix kit mode-Fixkit mode: button 2 not active
IDE10349-MAS10439-Garage door opener: Default/Fix kit mode-Fixkit mode: button 3 not active
IDE10350-Garage door opener: programming antenna External antenna
IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit 1
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach 1
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum 0.4
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel 0
IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher 1
IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko 1
IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd 1
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer 0
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI 0
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2 0
IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3 0
IDE11477-ENG128662-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_4 0
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI 0
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2 0
IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3 0
IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4 0
IDE11477-ENG128652-Interior lighting: parameter-p_dimmfaktor_farbwechsel_ab 1
IDE11477-ENG128651-Interior lighting: parameter-p_dimmfaktor_farbwechsel_auf 1
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI 0
IDE11477-ENG128653-Interior lighting: parameter-p_farbwechsel_delay 0
IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit 100%
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach 100%
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum 70%
IDE11477-ENG128516-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht 100%
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel 0%
IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher 100%
IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko 100%
IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd 100%
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren 0%
IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit 100%
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach 100%
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum 70%
IDE11477-ENG128513-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht 100%
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel 0%
IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher 100%
IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko 100%
IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd 100%
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren 0%
IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit 100%
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach 100%
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum 70%
IDE11477-ENG128515-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht 100%
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel 0%
IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher 100%
IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko 100%
IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd 100%
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren 0%
IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit 100%
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach 100%
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum 70%
IDE11477-ENG128512-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht 100%
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel 0%
IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher 100%
IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko 100%
IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd 100%
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren 0%
IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit 100%
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach 100%
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum 70%
IDE11477-ENG128517-Interior lighting: parameter-p_helligkeit_einausstieg_innenlicht 100%
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel 0%
IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher 100%
IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko 100%
IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd 100%
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren 0%
IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit 100%
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach 100%
IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum 0%
IDE11477-ENG128508-Interior lighting: parameter-p_helligkeit_entriegelt_innenlicht 100%
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel 0%
IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher 100%
IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko 100%
IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd 100%
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren 0%
IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit 100%
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach 100%
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum 70%
IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht 100%
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel 0%
IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher 100%
IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko 100%
IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd 100%
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren 0%
IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit 100%
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach 100%
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum 127%
IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht 100%
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel 0%
IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher 100%
IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko 100%
IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd 100%
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren 0%
IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit 126%
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach 126%
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum 126%
IDE11477-ENG128514-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht 0%
IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel 0%
IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher 126%
IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko 126%
IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd 126%
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren 0%
IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit 100%
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach 100%
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum 127%
IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht 100%
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel 0%
IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher 100%
IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko 100%
IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd 100%
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren 0%
IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit 100%
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach 100%
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum 126%
IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht 100%
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel 0%
IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher 100%
IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko 100%
IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd 100%
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren 0%
IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit 100%
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach 100%
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum 70%
IDE11477-ENG128509-Interior lighting: parameter-p_helligkeit_max_innenlicht 100%
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel 0%
IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher 100%
IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko 100%
IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd 100%
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren 0%
IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit 100%
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach 100%
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum 70%
IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht 100%
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel 0%
IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher 100%
IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko 100%
IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd 100%
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren 0%
IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit 100%
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach 100%
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum 70%
IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht 100%
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel 0%
IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher 100%
IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko 100%
IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd 100%
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren 0%
IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit 100%
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach 100%
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum 70%
IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht 100%
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel 0%
IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher 100%
IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko 100%
IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd 100%
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren 0%
IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte 200 ms
IDE11477-ENG128488-Interior lighting: parameter-p_t_verzoegerung_ausstieg_cockpit 0.0 s
IDE11477-ENG128502-Interior lighting: parameter-p_t_verzoegerung_ausstieg_dach 0.0 s
IDE11477-ENG128481-Interior lighting: parameter-p_t_verzoegerung_ausstieg_fussraum 0.0 s
IDE11477-ENG128467-Interior lighting: parameter-p_t_verzoegerung_ausstieg_innenlicht 0.0 s
IDE11477-ENG128495-Interior lighting: parameter-p_t_verzoegerung_ausstieg_miko 0.0 s
IDE11477-ENG128474-Interior lighting: parameter-p_t_verzoegerung_ausstieg_tueren 0.0 s
IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit 0.0 s
IDE11477-ENG128501-Interior lighting: parameter-p_t_verzoegerung_einstieg_dach 0.0 s
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum 2.0 s
IDE11477-ENG128466-Interior lighting: parameter-p_t_verzoegerung_einstieg_innenlicht 0.0 s
IDE11477-ENG128494-Interior lighting: parameter-p_t_verzoegerung_einstieg_miko 0.0 s
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren 0.0 s
IDE11477-ENG128490-Interior lighting: parameter-p_t_verzoegerung_entriegelt_cockpit 0.0 s
IDE11477-ENG128504-Interior lighting: parameter-p_t_verzoegerung_entriegelt_dach 0.0 s
IDE11477-ENG128483-Interior lighting: parameter-p_t_verzoegerung_entriegelt_fussraum 0.0 s
IDE11477-ENG128469-Interior lighting: parameter-p_t_verzoegerung_entriegelt_innenlicht 0.0 s
IDE11477-ENG128497-Interior lighting: parameter-p_t_verzoegerung_entriegelt_miko 0.0 s
IDE11477-ENG128476-Interior lighting: parameter-p_t_verzoegerung_entriegelt_tueren 0.0 s
IDE11477-ENG128489-Interior lighting: parameter-p_t_verzoegerung_oeffnen_cockpit 0.0 s
IDE11477-ENG128503-Interior lighting: parameter-p_t_verzoegerung_oeffnen_dach 0.0 s
IDE11477-ENG128482-Interior lighting: parameter-p_t_verzoegerung_oeffnen_fussraum 0.0 s
IDE11477-ENG128468-Interior lighting: parameter-p_t_verzoegerung_oeffnen_innenlicht 0.0 s
IDE11477-ENG128496-Interior lighting: parameter-p_t_verzoegerung_oeffnen_miko 0.0 s
IDE11477-ENG128475-Interior lighting: parameter-p_t_verzoegerung_oeffnen_tueren 0.0 s
IDE11477-ENG128491-Interior lighting: parameter-p_t_verzoegerung_schliessen_cockpit 0.0 s
IDE11477-ENG128505-Interior lighting: parameter-p_t_verzoegerung_schliessen_dach 0.0 s
IDE11477-ENG128484-Interior lighting: parameter-p_t_verzoegerung_schliessen_fussraum 0.0 s
IDE11477-ENG128470-Interior lighting: parameter-p_t_verzoegerung_schliessen_innenlicht 0.0 s
IDE11477-ENG128498-Interior lighting: parameter-p_t_verzoegerung_schliessen_miko 0.0 s
IDE11477-ENG128477-Interior lighting: parameter-p_t_verzoegerung_schliessen_tueren 0.0 s
IDE11477-ENG128492-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_cockpit 0.0 s
IDE11477-ENG128506-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_dach 0.0 s
IDE11477-ENG128485-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_fussraum 0.0 s
IDE11477-ENG128471-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_innenlicht 0.0 s
IDE11477-ENG128499-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_miko 0.0 s
IDE11477-ENG128478-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_tueren 0.0 s
IDE11477-ENG128493-Interior lighting: parameter-p_t_verzoegerung_verriegelt_cockpit 0.0 s
IDE11477-ENG128507-Interior lighting: parameter-p_t_verzoegerung_verriegelt_dach 0.0 s
IDE11477-ENG128486-Interior lighting: parameter-p_t_verzoegerung_verriegelt_fussraum 0.0 s
IDE11477-ENG128472-Interior lighting: parameter-p_t_verzoegerung_verriegelt_innenlicht 0.0 s
IDE11477-ENG128500-Interior lighting: parameter-p_t_verzoegerung_verriegelt_miko 0.0 s
IDE11477-ENG128479-Interior lighting: parameter-p_t_verzoegerung_verriegelt_tueren 0.0 s
IDE11477-ENG128663-Interior lighting: parameter-p_verzoegerung_berechnen 0
IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1 0
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10 0
IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2 0
IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3 0
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4 0
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5 0
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6 0
IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7 0
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8 0
IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9 0
IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1 0
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10 0
IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2 0
IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3 0
IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4 0
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5 0
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6 0
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7 0
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8 0
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9 0
IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1 0
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10 0
IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2 0
IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3 0
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4 0
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5 0
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6 0
IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7 0
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8 0
IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9 0
IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung installed
IDE11944-ENG141948-Keyless access and start authorization-Kessy installed
IDE11944-ENG246971-Keyless access and start authorization-Kessy BewegungsüberwachungIDGeber not active
IDE11944-ENG116653-Keyless access and start authorization-Kessy Komfort oeffnen not active
IDE11944-ENG116654-Keyless access and start authorization-Kessy Komfort schliessen active
IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung active
IDE11944-ENG179142-Keyless access and start authorization-Kessy Protokollvariante EntryExit not active
IDE11944-ENG179143-Keyless access and start authorization-Kessy Ruhephase EntryExit not active
IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung not active
IDE12302-SFT271873-Identification of sub-bus participant-Control Unit For Wiper Motor Not available
IDE12302-SFT271874-Identification of sub-bus participant-Rain Light Recognition Sensor Not available
IDE12302-SFT271875-Identification of sub-bus participant-Light switch Not available
IDE12302-SFT271876-Identification of sub-bus participant-Garage door opener control module Not available
IDE12302-SFT271877-Identification of sub-bus participant-Garage Door Opener Operating Unit Not available
IDE12302-SFT271894-Identification of sub-bus participant-Sensor For Anti Theft Alarm System Not available
IDE12302-SFT271896-Identification of sub-bus participant-Alarm horn Not available
IDE12302-SFT271904-Identification of sub-bus participant-Sun Roof Not available
IDE12302-SFT271910-Identification of sub-bus participant-Ceiling Light Module Not available
IDE12302-SFT271928-Identification of sub-bus participant-Roof Blind Not available
IDE12302-SFT271947-Identification of sub-bus participant-Relative Air Humidity Interior Sender Not available
IDE12302-SFT271966-Identification of sub-bus participant-Neck Heating Left Not available
IDE12302-SFT271967-Identification of sub-bus participant-Neck Heating Right Not available
IDE12302-SFT272065-Identification of sub-bus participant-Seat Backrest Fan 1 Front Left Not available
IDE12302-SFT272067-Identification of sub-bus participant-Seat Cushion Fan 1 Front Left Not available
IDE12302-SFT272069-Identification of sub-bus participant-Seat Backrest Fan 1 Front Right Not available
IDE12302-SFT272071-Identification of sub-bus participant-Seat Cushion Fan 1 Front Right Not available
IDE12302-ENG246961-Identification of sub-bus participant-Remote_Control Not available
IDE12302-ENG246960-Identification of sub-bus participant-steering_column_switch Not available
IDE12412-ENG154526-LIN Ambient light color list-Blauwert_Farbe_1_lin 0
IDE12412-ENG154527-LIN Ambient light color list-Blauwert_Farbe_10_lin 0
IDE12412-ENG154537-LIN Ambient light color list-Blauwert_Farbe_2_lin 0
IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin 0
IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin 0
IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin 0
IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin 0
IDE12412-ENG154563-LIN Ambient light color list-Blauwert_Farbe_7_lin 0
IDE12412-ENG154564-LIN Ambient light color list-Blauwert_Farbe_8_lin 0
IDE12412-ENG154565-LIN Ambient light color list-Blauwert_Farbe_9_lin 0
IDE12412-ENG154645-LIN Ambient light color list-Gruenwert_Farbe_1_lin 0
IDE12412-ENG154646-LIN Ambient light color list-Gruenwert_Farbe_10_lin 0
IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin 0
IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin 0
IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin 0
IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin 0
IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin 0
IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin 0
IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin 0
IDE12412-ENG154684-LIN Ambient light color list-Gruenwert_Farbe_9_lin 0
IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin 0
IDE12412-ENG154734-LIN Ambient light color list-Rotwert_Farbe_10_lin 0
IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin 0
IDE12412-ENG154764-LIN Ambient light color list-Rotwert_Farbe_3_lin 0
IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin 0
IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin 0
IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin 0
IDE12412-ENG154770-LIN Ambient light color list-Rotwert_Farbe_7_lin 0
IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin 0
IDE12412-ENG154772-LIN Ambient light color list-Rotwert_Farbe_9_lin 0
MAS01490-ENG142027-Energy management-Energiemanagement Abschaltung active
MAS01490-ENG116830-Energy management-Energy_Management_Adaptation Energy management active
MAS01490-ENG142256-Energy management-Hochvoltfahrzeug not installed
MAS01490-ENG141950-Energy management-Hybrid vehicle No
MAS01490-ENG133400-Energy management-Praediktives_Energiemanagement not active
MAS01490-ENG141978-Energy management-Recuperation active
MAS01490-ENG142037-Energy management-Zweitbatterie not installed
MAS08228-ENG133434-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze 1200 lx
MAS08228-ENG133435-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze 2200 lx
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle 0 lx
MAS08228-ENG133433-Light sensor-Einschaltgrenze_CHO_LHO 600 lx
MAS08228-ENG133437-Light sensor-Helligkeitsgrenze_Licht__einschalten 1200 lx
MAS08228-ENG133438-Light sensor-Helligkeitsgrenze_Licht_ausschalten 2200 lx
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red 00 00
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell 2000 lx
MAS08228-ENG142230-Light sensor-HMI_Exterior_light_on_highway not active
MAS08228-ENG142231-Light sensor-HMI_Exterior_light_on_rain not active
MAS08228-ENG142232-Light sensor-HMI_exterior_light_sensitivity frueh
MAS08228-ENG142229-Light sensor-HMI_Wiper_Comfort_Rain_Sensor_OFF not active
MAS08228-ENG126628-Light sensor-LS_Error_Ausgabe not active
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung 0 mV
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke 0 lx
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung 0 mV
MAS08228-ENG133439-Light sensor-Minimale_Beleuchtungsstaerke 0 lx
MAS08228-ENG133443-Light sensor-Tunnel_einschalt_verzoegerung 2
ENG153709-ENG154696-Aktivierung_Entwicklungsdiagnose-log_dtc_status not active
ENG153709-ENG154697-Aktivierung_Entwicklungsdiagnose-log-dtc_DFCC 00 00 00
ENG153709-ENG154714-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG-DTC First_dtc
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren active
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT active
ENG141683-ENG141975-Allwetterlicht_Spoiler-tt_spoiler not installed
ENG153710-ENG154516-Ambience_lightning_color_list_2-Blauwert Farbe 11 0
ENG153710-ENG154517-Ambience_lightning_color_list_2-Blauwert Farbe 12 0
ENG153710-ENG154518-Ambience_lightning_color_list_2-Blauwert Farbe 13 0
ENG153710-ENG154519-Ambience_lightning_color_list_2-Blauwert Farbe 14 0
ENG153710-ENG154520-Ambience_lightning_color_list_2-Blauwert Farbe 15 0
ENG153710-ENG154521-Ambience_lightning_color_list_2-Blauwert Farbe 16 0
ENG153710-ENG154522-Ambience_lightning_color_list_2-Blauwert Farbe 17 0
ENG153710-ENG154523-Ambience_lightning_color_list_2-Blauwert Farbe 18 0
ENG153710-ENG154524-Ambience_lightning_color_list_2-Blauwert Farbe 19 0
ENG153710-ENG154525-Ambience_lightning_color_list_2-Blauwert Farbe 20 0
ENG153710-ENG154539-Ambience_lightning_color_list_2-Blauwert_Farbe_21 0
ENG153710-ENG154541-Ambience_lightning_color_list_2-Blauwert_Farbe_22 0
ENG153710-ENG154543-Ambience_lightning_color_list_2-Blauwert_Farbe_23 0
ENG153710-ENG154545-Ambience_lightning_color_list_2-Blauwert_Farbe_24 0
ENG153710-ENG154547-Ambience_lightning_color_list_2-Blauwert_Farbe_25 0
ENG153710-ENG154549-Ambience_lightning_color_list_2-Blauwert_Farbe_26 0
ENG153710-ENG154551-Ambience_lightning_color_list_2-Blauwert_Farbe_27 0
ENG153710-ENG154553-Ambience_lightning_color_list_2-Blauwert_Farbe_28 0
ENG153710-ENG154555-Ambience_lightning_color_list_2-Blauwert_Farbe_29 0
ENG153710-ENG154558-Ambience_lightning_color_list_2-Blauwert_Farbe_30 0
ENG153710-ENG154635-Ambience_lightning_color_list_2-Gruenwert Farbe 11 0
ENG153710-ENG154636-Ambience_lightning_color_list_2-Gruenwert Farbe 12 0
ENG153710-ENG154637-Ambience_lightning_color_list_2-Gruenwert Farbe 13 0
ENG153710-ENG154638-Ambience_lightning_color_list_2-Gruenwert Farbe 14 0
ENG153710-ENG154639-Ambience_lightning_color_list_2-Gruenwert Farbe 15 0
ENG153710-ENG154640-Ambience_lightning_color_list_2-Gruenwert Farbe 16 0
ENG153710-ENG154641-Ambience_lightning_color_list_2-Gruenwert Farbe 17 0
ENG153710-ENG154642-Ambience_lightning_color_list_2-Gruenwert Farbe 18 0
ENG153710-ENG154643-Ambience_lightning_color_list_2-Gruenwert Farbe 19 0
ENG153710-ENG154644-Ambience_lightning_color_list_2-Gruenwert Farbe 20 0
ENG153710-ENG154658-Ambience_lightning_color_list_2-Gruenwert_Farbe_21 0
ENG153710-ENG154660-Ambience_lightning_color_list_2-Gruenwert_Farbe_22 0
ENG153710-ENG154662-Ambience_lightning_color_list_2-Gruenwert_Farbe_23 0
ENG153710-ENG154664-Ambience_lightning_color_list_2-Gruenwert_Farbe_24 0
ENG153710-ENG154666-Ambience_lightning_color_list_2-Gruenwert_Farbe_25 0
ENG153710-ENG154668-Ambience_lightning_color_list_2-Gruenwert_Farbe_26 0
ENG153710-ENG154670-Ambience_lightning_color_list_2-Gruenwert_Farbe_27 0
ENG153710-ENG154672-Ambience_lightning_color_list_2-Gruenwert_Farbe_28 0
ENG153710-ENG154674-Ambience_lightning_color_list_2-Gruenwert_Farbe_29 0
ENG153710-ENG154677-Ambience_lightning_color_list_2-Gruenwert_Farbe_30 0
ENG153710-ENG154723-Ambience_lightning_color_list_2-Rotwert Farbe 11 0
ENG153710-ENG154724-Ambience_lightning_color_list_2-Rotwert Farbe 12 0
ENG153710-ENG154725-Ambience_lightning_color_list_2-Rotwert Farbe 13 0
ENG153710-ENG154726-Ambience_lightning_color_list_2-Rotwert Farbe 14 0
ENG153710-ENG154727-Ambience_lightning_color_list_2-Rotwert Farbe 15 0
ENG153710-ENG154728-Ambience_lightning_color_list_2-Rotwert Farbe 16 0
ENG153710-ENG154729-Ambience_lightning_color_list_2-Rotwert Farbe 17 0
ENG153710-ENG154730-Ambience_lightning_color_list_2-Rotwert Farbe 18 0
ENG153710-ENG154731-Ambience_lightning_color_list_2-Rotwert Farbe 19 0
ENG153710-ENG154732-Ambience_lightning_color_list_2-Rotwert Farbe 20 0
ENG153710-ENG154746-Ambience_lightning_color_list_2-Rotwert_Farbe_21 0
ENG153710-ENG154748-Ambience_lightning_color_list_2-Rotwert_Farbe_22 0
ENG153710-ENG154750-Ambience_lightning_color_list_2-Rotwert_Farbe_23 0
ENG153710-ENG154752-Ambience_lightning_color_list_2-Rotwert_Farbe_24 0
ENG153710-ENG154754-Ambience_lightning_color_list_2-Rotwert_Farbe_25 0
ENG153710-ENG154756-Ambience_lightning_color_list_2-Rotwert_Farbe_26 0
ENG153710-ENG154758-Ambience_lightning_color_list_2-Rotwert_Farbe_27 0
ENG153710-ENG154760-Ambience_lightning_color_list_2-Rotwert_Farbe_28 0
ENG153710-ENG154762-Ambience_lightning_color_list_2-Rotwert_Farbe_29 0
ENG153710-ENG154765-Ambience_lightning_color_list_2-Rotwert_Farbe_30 0
ENG153711-ENG154528-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_11_lin 0
ENG153711-ENG154529-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_12_lin 0
ENG153711-ENG154530-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_13_lin 0
ENG153711-ENG154531-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_14_lin 0
ENG153711-ENG154532-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_15_lin 0
ENG153711-ENG154533-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_16_lin 0
ENG153711-ENG154534-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_17_lin 0
ENG153711-ENG154535-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_18_lin 0
ENG153711-ENG154536-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_19_lin 0
ENG153711-ENG154538-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_20_lin 0
ENG153711-ENG154540-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_21_lin 0
ENG153711-ENG154542-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_22_lin 0
ENG153711-ENG154544-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_23_lin 0
ENG153711-ENG154546-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_24_lin 0
ENG153711-ENG154548-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_25_lin 0
ENG153711-ENG154550-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_26_lin 0
ENG153711-ENG154552-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_27_lin 0
ENG153711-ENG154554-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_28_lin 0
ENG153711-ENG154556-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_29_lin 0
ENG153711-ENG154559-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_30_lin 0
ENG153711-ENG154647-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_11_lin 0
ENG153711-ENG154648-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_12_lin 0
ENG153711-ENG154649-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_13_lin 0
ENG153711-ENG154650-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_14_lin 0
ENG153711-ENG154651-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_15_lin 0
ENG153711-ENG154652-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_16_lin 0
ENG153711-ENG154653-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_17_lin 0
ENG153711-ENG154654-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_18_lin 0
ENG153711-ENG154655-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_19_lin 0
ENG153711-ENG154657-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_20_lin 0
ENG153711-ENG154659-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_21_lin 0
ENG153711-ENG154661-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_22_lin 0
ENG153711-ENG154663-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_23_lin 0
ENG153711-ENG154665-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_24_lin 0
ENG153711-ENG154667-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_25_lin 0
ENG153711-ENG154669-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_26_lin 0
ENG153711-ENG154671-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_27_lin 0
ENG153711-ENG154673-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_28_lin 0
ENG153711-ENG154675-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_29_lin 0
ENG153711-ENG154678-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_30_lin 0
ENG153711-ENG154735-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_11_lin 0
ENG153711-ENG154736-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_12_lin 0
ENG153711-ENG154737-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_13_lin 0
ENG153711-ENG154738-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_14_lin 0
ENG153711-ENG154739-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_15_lin 0
ENG153711-ENG154740-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_16_lin 0
ENG153711-ENG154741-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_17_lin 0
ENG153711-ENG154742-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_18_lin 0
ENG153711-ENG154743-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_19_lin 0
ENG153711-ENG154745-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_20_lin 0
ENG153711-ENG154747-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_21_lin 0
ENG153711-ENG154749-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_22_lin 0
ENG153711-ENG154751-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_23_lin 0
ENG153711-ENG154753-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_24_lin 0
ENG153711-ENG154755-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_25_lin 0
ENG153711-ENG154757-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_26_lin 0
ENG153711-ENG154759-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_27_lin 0
ENG153711-ENG154761-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_28_lin 0
ENG153711-ENG154763-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_29_lin 0
ENG153711-ENG154766-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_30_lin 0
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1 1
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10 1
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11 1
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12 1
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13 1
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14 1
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15 1
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2 1
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3 1
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4 1
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5 1
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6 1
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7 1
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8 1
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9 1
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1 door
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10 door
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11 door
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12 door
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13 door
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14 door
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15 door
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2 door
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3 door
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4 door
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5 door
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6 door
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7 door
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8 door
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9 door
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1 not installed
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10 not installed
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11 not installed
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12 not installed
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13 not installed
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14 not installed
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15 not installed
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2 not installed
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3 not installed
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4 not installed
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5 not installed
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6 not installed
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7 not installed
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8 not installed
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9 not installed
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12 0
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1 0
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10 0
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11 0
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13 0
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14 0
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15 0
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16 0
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17 0
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18 0
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19 0
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2 0
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20 0
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3 0
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4 0
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5 0
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6 0
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7 0
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8 0
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9 0
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1 0
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10 0
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11 0
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12 0
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13 0
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14 0
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15 0
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16 0
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17 0
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18 0
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19 0
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2 0
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20 0
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3 0
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4 0
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5 0
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6 0
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7 0
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9 0
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8 0
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1 not installed
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10 not installed
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11 not installed
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12 not installed
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13 not installed
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14 not installed
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15 not installed
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16 not installed
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17 not installed
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18 not installed
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19 not installed
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2 not installed
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20 not installed
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3 not installed
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4 not installed
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5 not installed
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6 not installed
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7 not installed
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9 not installed
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8 not installed
ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente Keine_Spannungsanforderung
ENG153712-ENG154602-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_0 1
ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1 1
ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10 1
ENG153712-ENG154605-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_11 1
ENG153712-ENG154606-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_12 1
ENG153712-ENG154607-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_13 1
ENG153712-ENG154608-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_14 1
ENG153712-ENG154609-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_15 1
ENG153712-ENG154610-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_2 1
ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3 1
ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4 1
ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5 1
ENG153712-ENG154614-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_6 1
ENG153712-ENG154615-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_7 1
ENG153712-ENG154616-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_8 1
ENG153712-ENG154617-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_9 1
ENG141649-ENG122212-Außenlicht_Blinker-ABBA_Blinken not active
ENG141649-ENG133379-Außenlicht_Blinker-Abbruch Komfortblinken active
ENG141649-ENG116590-Außenlicht_Blinker-Blinkkontrolleuchte fuer Anhaenger separte
ENG141649-ENG121966-Außenlicht_Blinker-Crash flashing not active
ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken not active
ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung not active
ENG141649-ENG142194-Außenlicht_Blinker-dynamisch_blinken_10 not active
ENG141649-ENG142195-Außenlicht_Blinker-Dynamische_Blink_Delay 50 ms
ENG141649-ENG126819-Außenlicht_Blinker-Emergency_alert_blinken not active
ENG141649-ENG154601-Außenlicht_Blinker-Fahrerassistenz_Blinkenfunktionen Warnblinke_zulaessig
ENG141649-ENG115774-Außenlicht_Blinker-Komfortblinken active
ENG141649-ENG116587-Außenlicht_Blinker-Komfortblinken Blinkzyklen 5
ENG141649-ENG122208-Außenlicht_Blinker-Multi_kollisions_Blinken not active
ENG141649-ENG122209-Außenlicht_Blinker-Notwarn_blinken_NBA_Phase_2 not active
ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing not active
ENG141649-ENG154711-Außenlicht_Blinker-PreCrash_RECAS PreCrash_passiv
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links not active
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts not active
ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken not active
ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing not active
ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken not active
ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken not active
ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz not active
ENG141649-ENG246997-Außenlicht_Blinker-Warnblinken_TP_max 120 min
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS not active
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN not active
ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf not active
ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu not active
ENG141647-ENG141986-Außenlicht_Front-Abblendlicht_Leuchtentyp H7
ENG141647-ENG246962-Außenlicht_Front-ABL Redundanz Check sperren not active
ENG141647-ENG116705-Außenlicht_Front-Allwetterlicht Ausschaltgrenze 350 km/h
ENG141647-ENG116704-Außenlicht_Front-Allwetterlicht Einschaltgrenze 350 km/h
ENG141647-ENG115833-Außenlicht_Front-Fahrlicht bei Tag Daytime running lights
ENG141647-ENG142193-Außenlicht_Front-Geschwindigkeitsabhaengiges TFL 5 km/h
ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich not active
ENG141647-ENG115832-Außenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht not active
ENG141647-ENG142191-Außenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument not active
ENG141647-ENG142190-Außenlicht_Front-Signaturlicht_verbaut not installed
ENG141647-ENG116592-Außenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht active
ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich active
ENG141647-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten active
ENG141647-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO not active
ENG141647-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht not active
ENG141647-ENG115733-Außenlicht_Front-Tagfahrlichtkontrollleuchte not active
ENG141647-ENG142192-Außenlicht_Front-TFL_Abschaltung_ueber_Geschwindigkeit not active
ENG141647-ENG116591-Außenlicht_Front-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge active
ENG141647-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren limitieren
ENG141648-ENG141987-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht No
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit 0 km/h
ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA not active
ENG141648-ENG115831-Aussenlicht_Heck-Schlusslicht mit Bremslichtfunktion not active
ENG141648-ENG142004-Aussenlicht_Heck-Umgreifende_Heckklappe not installed
ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather lights not installed
ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung begrenzen auf Mindestverfügbarkeit
ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung begrenzen auf Mindestverfügbarkeit
ENG141656-ENG142188-Außenlicht_uebergreifend-bewusstes Standlicht Aktive Begrenzung
ENG141656-ENG246968-Außenlicht_uebergreifend-CHo_LHo_Nachlauf 0 ms
ENG141656-ENG115656-Außenlicht_uebergreifend-Coming Home Leuchten Fog light
ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus automatic
ENG141656-ENG116604-Außenlicht_uebergreifend-Coming-home Einschaltereignis Driver door
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach not active
ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig kein_Hinweis
ENG141656-ENG137034-Außenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer Faktor fuer x5 Minuten
ENG141656-ENG154619-Außenlicht_uebergreifend-Fernlicht_LH Sollspannungsanforderung 13.5
ENG141656-ENG154177-Außenlicht_uebergreifend-Fog light Sollspannungsanforderung 13.5
ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung 46400 lx
ENG141656-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung 12 lx
ENG141656-ENG142189-Außenlicht_uebergreifend-HVLM_Ladezustandsanzeige No
ENG141656-ENG115858-Außenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht integriert in Suchbeleuchtung
ENG141656-ENG142185-Außenlicht_uebergreifend-LCM_blinker false
ENG141656-ENG141992-Außenlicht_uebergreifend-LDS_mit_AFL Yes
ENG141656-ENG141991-Außenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht No
ENG141656-ENG141990-Außenlicht_uebergreifend-LDS_mit_Nebellicht Yes
ENG141656-ENG141993-Außenlicht_uebergreifend-LDS_mit_Standlichtstellung Yes
ENG141656-ENG115657-Außenlicht_uebergreifend-Leaving-Home Verbausstatus Enabled
ENG141656-ENG141989-Außenlicht_uebergreifend-Lichtdrehschalter (LDS) discrete
ENG141656-ENG115862-Außenlicht_uebergreifend-Lichtwarnungsverhalten klemmenabhaengig
ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module installed
ENG141656-ENG98354-Außenlicht_uebergreifend-Low beam Sollspannungsanforderung 13.5
ENG141656-ENG115863-Außenlicht_uebergreifend-Menueeinstellung CHO LHO Menuesteuerung Zeit aktivieren
ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome 90 seconds
ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP 90 seconds
ENG141656-ENG116602-Außenlicht_uebergreifend-Menuesteuerung Coming Home Werkseinstellung active
ENG141656-ENG116606-Außenlicht_uebergreifend-Menuesteuerung Leaving-home Freischaltung per BAP active
ENG141656-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert not active
ENG141656-ENG126816-Außenlicht_uebergreifend-Standlicht aus active
ENG141656-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht not active
ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit 6 s
ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal Sollspannungsanforderung 13.5
ENG141656-ENG126817-Außenlicht_uebergreifend-Umfeldleuchte als Manoevrierleuchte not active
ENG126647-ENG98399-debug_light_function-Activation 0
ENG126647-ENG101417-debug_light_function-Adresse 0
ENG126647-ENG126820-debug_light_function-Bitmask 0
ENG126647-ENG126821-debug_light_function-Divisor 0
ENG126647-ENG98827-debug_light_function-Offset 0
ENG126647-ENG126822-debug_light_function-Polaritaet 0
ENG246955-ENG246967-digital_key-central_locking_digital_key_general not installed
ENG246955-ENG246972-digital_key-komfortbedienung_fh_oeffnen_ueber_btle not active
ENG246955-ENG246973-digital_key-komfortbedienung_fh_oeffnen_ueber_btle_sonderfunktion not active
ENG246955-ENG246974-digital_key-komfortbedienung_fh_oeffnen_ueber_nfc_fahrertuer not active
ENG246955-ENG246975-digital_key-komfortbedienung_fh_schliessen_ueber_btle not active
ENG246955-ENG246976-digital_key-komfortbedienung_fh_schliessen_ueber_btle_sonderfunktion not active
ENG246955-ENG246977-digital_key-komfortbedienung_fh_schliessen_ueber_nfc_fahrertuer not active
ENG141675-ENG115658-Dimmunt_KL_58xs_PWM-x0 0.00%
ENG141675-ENG101574-Dimmunt_KL_58xs_PWM-X1 50.00%
ENG141675-ENG99557-Dimmunt_KL_58xs_PWM-X2 100.00%
ENG141675-ENG115659-Dimmunt_KL_58xs_PWM-y0 0.00%
ENG141675-ENG99777-Dimmunt_KL_58xs_PWM-Y1 50.00%
ENG141675-ENG100480-Dimmunt_KL_58xs_PWM-Y2 100.00%
ENG141650-MAS13782-Fernlicht_assistent-Will Beam assistant: responsivity adjustable via BAP present
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung AFS: FLA: Fernlicht ueber AFS
ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset not active
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent present
ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung present
ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA not active
ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung 800 ms
ENG141682-ENG115836-Front_wiper-Frontwischer Notlaufprogramm active
ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlauf active
ENG141682-ENG154620-Front_wiper-Frontwischer Spannungsanforderung_konfig Sollspannungsanforderung 13.5
ENG141682-ENG133394-Front_wiper-Frontwischer_Abtauposition not active
ENG141682-ENG141966-Front_wiper-Frontwischertyp Direct
ENG141682-ENG116617-Front_wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung active
ENG141682-ENG116615-Front_wiper-Menuesteuerung Frontwischer not active
ENG141682-ENG154706-Front_wiper-Mindestwaschzeit_Frontwischer 0 ms
ENG141682-ENG115771-Front_wiper-Regensensor aktivieren Deactivating
ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay 300 ms
ENG141682-ENG116616-Front_wiper-Tippwischen mit erhoehter Wischfrequenz active
ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status not active
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung not active
ENG141682-ENG126844-Front_wiper-Washer_Tipwiping_Variant not active
ENG141682-ENG116613-Front_wiper-Wischer abparken bei Oeffnen der Motorhaube not active
ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus not active
ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube active
ENG99457-ENG117394-Head area heater-blower_speed 1
ENG99457-ENG98971-Head area heater-Temperature -2
ENG141645-MAS00211-HW_Verbau-Insufficient brake fluid installed
ENG141645-MAS00212-HW_Verbau-Insufficient washer fluid installed
ENG141645-MAS00213-HW_Verbau-Insufficient coolant installed
ENG141645-MAS00214-HW_Verbau-Brake pad wear not installed
ENG141645-ENG142026-HW_Verbau-Druckklappe not installed
ENG141645-ENG141963-HW_Verbau-Elektrische Laderaumabdeckung aktiv not active
ENG141645-ENG142012-HW_Verbau-Elektrische_Laderaumabdeckung not installed
ENG141645-ENG141952-HW_Verbau-Exterior temp. sensor installed
ENG141645-ENG142005-HW_Verbau-Kontaktschalter_fuer_Motorhaube installed
ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelung not installed
ENG141645-ENG142036-HW_Verbau-PTC Zuheizer not installed
ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15 active
ENG141645-ENG142003-HW_Verbau-Status_Tankdeckelverriegelung not active
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0 -100.00%
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1 -100.00%
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2 -100.00%
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3 -100.00%
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4 -100.00%
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5 -100.00%
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6 -100.00%
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7 -100
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8 -100.00%
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9 -100.00%
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0 100.00%
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1 90.00%
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2 80.00%
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3 70.00%
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4 60.00%
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5 50.00%
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6 40.00%
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7 30.00%
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8 15.00%
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9 0.00%
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0 maximize
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0 maximize
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0 maximize
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0 0
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0 0
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0 0
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0 0
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0 0
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0 0
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0 not active
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0 Always
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0 not active
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0 not active
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0 not active
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0 not active
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0 not active
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0 not active
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0 not active
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0 not active
ENG141657-ENG116167-Leuchte 35 LED Warnblinktaster C48-Dimming Direction CD 15 maximize
ENG141657-ENG116171-Leuchte 35 LED Warnblinktaster C48-Dimming Direction EF 15 maximize
ENG141657-ENG116175-Leuchte 35 LED Warnblinktaster C48-Dimming Direction GH 15 maximize
ENG141657-ENG116162-Leuchte 35 LED Warnblinktaster C48-Dimmwert AB 15 100
ENG141657-ENG116166-Leuchte 35 LED Warnblinktaster C48-Dimmwert CD 15 0
ENG141657-ENG116170-Leuchte 35 LED Warnblinktaster C48-Dimmwert EF 15 0
ENG141657-ENG116174-Leuchte 35 LED Warnblinktaster C48-Dimmwert GH 15 0
ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15 63
ENG141657-ENG116566-Leuchte 35 LED Warnblinktaster C48-Lampendefektbitposition 15 0
ENG141657-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15 41 - LED Kleinleistung
ENG141657-ENG116163-Leuchte 35 LED Warnblinktaster C48-Lichtansteuerung HD AB 15 Always
ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15 Warnblinktaster_Suchbeleuchtung
ENG141657-ENG116161-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion B 15 not active
ENG141657-ENG116164-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion C 15 not active
ENG141657-ENG116165-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion D 15 not active
ENG141657-ENG116168-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion E 15 not active
ENG141657-ENG116169-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion F 15 not active
ENG141657-ENG116172-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion G 15 not active
ENG141657-ENG116173-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion H 15 not active
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10 maximize
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10 maximize
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10 maximize
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10 0
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10 0
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10 0
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10 0
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10 0
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10 0
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10 not active
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10 Always
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10 not active
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10 not active
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10 not active
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10 not active
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10 not active
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10 not active
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10 not active
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10 not active
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11 maximize
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11 maximize
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11 maximize
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11 0
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11 0
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11 0
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11 0
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11 0
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11 0
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11 not active
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11 Always
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11 not active
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11 not active
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11 not active
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11 not active
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11 not active
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11 not active
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11 not active
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11 not active
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12 maximize
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12 maximize
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12 maximize
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12 100
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12 0
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12 100
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12 0
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12 22
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12 38
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12 10 - allgemeine Scheinwerfer
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12 Always
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12 Nebellicht links
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12 Abbiegelicht links
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12 not active
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12 not active
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12 Coming Home oder Leaving Home aktiv
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12 not active
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12 not active
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12 not active
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13 maximize
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13 maximize
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13 maximize
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13 100
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13 0
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13 100
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13 0
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13 23
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13 42
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13 10 - allgemeine Scheinwerfer
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13 Always
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13 Nebellicht rechts
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13 Abbiegelicht rechts
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13 not active
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13 not active
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13 Coming Home oder Leaving Home aktiv
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13 not active
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13 not active
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13 not active
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16 minimize
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16 minimize
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16 maximize
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16 10
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16 0
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16 0
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16 0
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16 2A
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16 1A
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16 43 - allgemeine LED
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16 Always
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16 Daytime running lights
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16 Brake light
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16 not active
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16 Coming Home oder Leaving Home aktiv
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16 not active
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16 not active
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16 not active
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17 minimize
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17 minimize
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17 maximize
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17 10
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17 0
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17 0
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17 0
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17 29
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17 0A
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17 43 - allgemeine LED
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17 Always
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17 Daytime running lights
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17 Brake light
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17 not active
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17 Coming Home oder Leaving Home aktiv
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17 not active
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17 not active
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17 not active
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18 maximize
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18 maximize
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18 maximize
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18 100
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18 0
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18 0
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18 0
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18 16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18 8
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18 12 - Blinkleuchten
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18 Always
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18 Blinken links Hellphase
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18 not active
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18 not active
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18 not active
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18 not active
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18 not active
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18 not active
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18 not active
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19 maximize
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19 maximize
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19 maximize
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19 100
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19 0
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19 0
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19 0
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19 18
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19 18
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19 12 - Blinkleuchten
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19 Always
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19 Blinken rechts Hellphase
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19 not active
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19 not active
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19 not active
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19 not active
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19 not active
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19 not active
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19 not active
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1 maximize
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1 maximize
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1 maximize
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1 0
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1 0
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1 0
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1 0
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1 0
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1 0
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1 not active
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1 Always
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1 not active
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1 not active
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1 not active
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1 not active
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1 not active
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1 not active
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1 not active
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1 not active
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20 maximize
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20 maximize
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20 maximize
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20 127
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20 0
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20 0
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20 0
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20 2B
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20 9
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20 43 - allgemeine LED
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20 Always
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20 Brake light
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20 not active
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20 not active
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20 not active
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20 not active
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20 not active
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20 not active
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20 not active
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21 maximize
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21 maximize
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21 maximize
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21 127
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21 0
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21 0
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21 0
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21 2D
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21 19
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21 43 - allgemeine LED
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21 Always
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21 Brake light
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21 not active
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21 not active
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21 not active
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21 not active
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21 not active
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21 not active
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21 not active
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22 maximize
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22 maximize
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22 maximize
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22 127
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22 0
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22 0
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22 0
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22 2C
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22 29
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22 42 - LED dritte Bremsleuchte
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22 only_if_closed
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22 Brake light
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22 Quittierungsfunktion 1
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22 not active
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22 not active
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22 not active
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22 not active
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22 not active
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22 not active
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23 maximize
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23 minimize
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23 maximize
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23 10
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23 127
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23 0
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23 0
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23 35
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23 0A
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23 43 - allgemeine LED
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23 only_if_closed
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23 Daytime running lights
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23 Brake light
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23 not active
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23 Coming Home oder Leaving Home aktiv
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23 not active
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23 not active
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23 not active
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24 maximize
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24 minimize
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24 maximize
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24 10
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24 127
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24 0
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24 0
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24 36
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24 1A
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24 43 - allgemeine LED
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24 only_if_closed
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24 Daytime running lights
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24 Brake light
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24 not active
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24 Coming Home oder Leaving Home aktiv
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24 not active
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24 not active
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24 not active
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25 maximize
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25 minimize
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25 maximize
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25 75
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25 0
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25 0
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25 0
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25 30
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25 28
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25 43 - allgemeine LED
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25 only_if_closed
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25 not active
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25 not active
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25 not active
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25 Coming Home oder Leaving Home aktiv
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25 not active
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25 not active
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25 not active
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26 maximize
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26 maximize
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26 maximize
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26 100
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26 0
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26 0
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26 0
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26 0
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26 0
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26 43 - allgemeine LED
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26 Always
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26 not active
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26 not active
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26 not active
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26 not active
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26 not active
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26 not active
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26 not active
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27 minimize
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27 minimize
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27 maximize
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27 10
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27 127
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27 0
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27 0
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27 37
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27 9
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27 41 - LED Kleinleistung
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27 only_if_closed
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27 not active
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27 Brake light
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27 not active
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27 Coming Home oder Leaving Home aktiv
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27 not active
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27 not active
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27 not active
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28 maximize
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28 maximize
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28 maximize
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28 100
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28 0
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28 100
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28 0
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28 31
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28 0B
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28 9 - allgemeine Glühlampe 27W: auch H15
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28 only_if_closed
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28 Rueckfahrlicht
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28 not active
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28 not active
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28 not active
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28 Coming Home oder Leaving Home aktiv
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28 not active
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28 not active
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28 not active
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29 maximize
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29 maximize
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29 maximize
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29 100
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29 0
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29 100
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29 0
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29 32
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29 1B
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29 9 - allgemeine Glühlampe 27W: auch H15
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29 only_if_closed
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29 Rueckfahrlicht
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29 not active
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29 not active
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29 not active
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29 Coming Home oder Leaving Home aktiv
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29 not active
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29 not active
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29 not active
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2 maximize
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2 maximize
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2 maximize
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2 0
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2 0
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2 0
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2 0
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2 0
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2 0
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2 not active
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2 Always
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2 not active
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2 not active
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2 not active
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2 not active
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2 not active
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2 not active
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2 not active
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2 not active
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30 maximize
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30 maximize
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30 maximize
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30 100
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30 0
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30 0
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30 0
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30 2
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30 0
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30 36 - LED Kleinleistung
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30 Always
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30 Footwell light
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30 not active
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30 not active
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30 not active
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30 not active
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30 not active
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30 not active
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30 not active
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31 maximize
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31 maximize
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31 maximize
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31 0
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31 0
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31 0
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31 0
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31 0
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31 0
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31 not active
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31 Always
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31 not active
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31 not active
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31 not active
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31 not active
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31 not active
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31 not active
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31 not active
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31 not active
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32 maximize
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32 maximize
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32 maximize
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32 0
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32 0
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32 0
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32 0
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32 0
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32 0
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32 not active
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32 Always
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32 not active
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32 not active
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32 not active
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32 not active
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32 not active
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32 not active
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32 not active
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32 not active
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33 maximize
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33 maximize
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33 maximize
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33 0
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33 0
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33 0
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33 0
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33 0
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33 0
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33 not active
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33 Always
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33 not active
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33 not active
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33 not active
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33 not active
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33 not active
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33 not active
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33 not active
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33 not active
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34 maximize
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34 maximize
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34 maximize
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34 0
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34 0
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34 0
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34 0
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34 0
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34 0
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34 not active
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34 Always
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34 not active
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34 not active
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34 not active
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34 not active
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34 not active
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34 not active
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34 not active
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34 not active
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3 maximize
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3 maximize
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3 maximize
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3 0
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3 0
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3 0
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3 0
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3 0
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3 0
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3 not active
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3 Always
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3 not active
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3 not active
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3 not active
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3 not active
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3 not active
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3 not active
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3 not active
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3 not active
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4 maximize
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4 maximize
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4 maximize
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4 0
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4 0
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4 0
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4 0
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4 0
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4 0
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4 not active
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4 Always
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4 not active
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4 not active
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4 not active
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4 not active
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4 not active
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4 not active
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4 not active
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4 not active
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5 maximize
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5 maximize
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5 maximize
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5 0
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5 0
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5 0
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5 0
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5 0
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5 0
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5 not active
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5 Always
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5 not active
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5 not active
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5 not active
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5 not active
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5 not active
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5 not active
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5 not active
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5 not active
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6 maximize
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6 maximize
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6 maximize
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6 127
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6 0
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6 0
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6 0
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6 1A
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6 36
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6 5 - LED Abblendlicht
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6 Always
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6 Abblendlicht links
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6 Lichthupe generell
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6 not active
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6 not active
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6 not active
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6 not active
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6 not active
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6 not active
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7 maximize
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7 maximize
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7 maximize
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7 127
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7 0
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7 0
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7 0
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7 1B
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7 40
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7 5 - LED Abblendlicht
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7 Always
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7 Abblendlicht rechts
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7 Lichthupe generell
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7 not active
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7 not active
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7 not active
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7 not active
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7 not active
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7 not active
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8 maximize
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8 maximize
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8 maximize
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8 127
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8 127
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8 0
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8 0
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8 49
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8 3A
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8 5 - LED Abblendlicht
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8 Always
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8 Versorgungsbedarf der LCM Module
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8 not active
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8 Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8 not active
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8 not active
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8 not active
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8 not active
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9 maximize
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9 maximize
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9 maximize
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9 127
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9 127
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9 0
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9 0
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9 4A
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9 44
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9 5 - LED Abblendlicht
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9 Always
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9 Versorgungsbedarf der LCM Module
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9 not active
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9 Parking light right
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9 not active
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9 not active
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9 not active
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9 not active
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck 0C 08 00 16 02 00 64 00 00 00 00 00 00 00 00 00 0C 18 00 18 04 00 64 00 00 00 00 00 00 00 00 00 2B 09 00 2B 18 00 7F 00 00 00 00 00 00 00 00 00 2B 19 00 2D 18 00 7F 00 00 00 00 00 00 00 00 00 2A 29 00 2C 18 24 FF 00 00 00 00 00 00 00 00 00 2B 0A 00 35 08 14 8A 18 00 7F 1E 00 80 00 00 00 2B 1A 00 36 08 14 8A 18 00 7F 1E 00 80 00 00 00 2B 28 00 30 08 00 CB 00 00 00 1E 00 80 00 00 00 2B 00 00 00 08 00 64 00 00 00 00 00 00 00 00 00 29 09 00 37 08 00 8A 18 00 FF 1E 00 80 00 00 00 09 0B 00 31 19 00 E4 00 00 00 1E 00 64 00 00 00 09 1B 00 32 19 00 E4 00 00 00 1E 00 64 00 00 00
ENG141662-Leuchtenkonfiguration_Sonstiges 2B 1A 00 2A 08 14 0A 18 00 80 1E 00 80 00 00 00 2B 0A 00 29 08 14 0A 18 00 80 1E 00 80 00 00 00 24 00 00 02 2B 00 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00
ENG141658-ENG142197-Leuchtweitenregulierung-1_Sensor_LWR 1-Sensor_LWR
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges 0 mm
ENG141658-ENG142201-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe not active
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze 90.00%
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze 10.00%
ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung -127.0 ms
ENG141658-ENG142209-Leuchtweitenregulierung-diagnose_soll_toleranz 15%
ENG141658-ENG142203-Leuchtweitenregulierung-Entprellung_Fehlerlampe 10.0 s
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1 -8.00 mm/%
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2 -8.00 mm/%
ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3 -8.00 mm/%
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1 -8.00 mm/%
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2 -8.00 mm/%
ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3 -8.00 mm/%
ENG141658-ENG142198-Leuchtweitenregulierung-Fahrwerk_Variante Variante_1
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR 0.00%
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf 0.00 Hz
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung normal
ENG141658-ENG142202-Leuchtweitenregulierung-Logik_PWM_Signal Negative
ENG141658-ENG154702-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_1 0 mm
ENG141658-ENG154703-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_2 0 mm
ENG141658-ENG154704-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_3 0 mm
ENG141658-ENG154705-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_4 0 mm
ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand 0 mm
ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe 0 mm
ENG141658-ENG142226-Leuchtweitenregulierung-lwr_pwm_obere_schwelle 95.00%
ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle 5.00%
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr 0 km/h
ENG141658-ENG142222-Leuchtweitenregulierung-pa_fDynFiltStatLwr 100 Hz
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung 0.00 Hz
ENG141658-ENG142200-Leuchtweitenregulierung-Quelle_Hoehenwerte BCM
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed not installed
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht active
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese 20.00%
ENG141658-ENG154776-Leuchtweitenregulierung-sLWR_nach_Motorstart not active
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad 0.0 %/s
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht -100.00%
ENG141658-ENG142196-Leuchtweitenregulierung-sLWR_verbaut not installed
ENG141658-ENG142205-Leuchtweitenregulierung-Zyklus_sLWR 0.00 s
ENG246957-ENG246963-Lichttaster-Anzeigezeit_LTM_PopUp1 2.0 s
ENG246957-ENG246964-Lichttaster-Anzeigezeit_LTM_PopUp1_lang 10 s
ENG246957-ENG246965-Lichttaster-Beleuchtung_Auto_LED_bei_Nebelfunktion active
ENG246957-ENG246966-Lichttaster-Beleuchtung_LTM_Auto_LED_58xt_logik active
ENG246957-ENG246978-Lichttaster-Licht_anforderung_FAS Nicht_verbaut
ENG246957-ENG246979-Lichttaster-Licht_anforderung_Pilopark not active
ENG246957-ENG246980-Lichttaster-Licht_Reaktivierungs_grenze 100 m
ENG246957-ENG246981-Lichttaster-Lichttastermodul lds
ENG246957-ENG246982-Lichttaster-LTM_Anzeige_Config 1
ENG246957-ENG246983-Lichttaster-LTM_Beleuchtung_Geschwindigkeits_Schwelle 30 km/h
ENG246957-ENG246984-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig not active
ENG246957-ENG246985-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig_Parameter active
ENG246957-ENG246986-Lichttaster-LTM_BGL_Wegabhängig active
ENG246957-ENG246987-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig not active
ENG246957-ENG246988-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig_Parameter active
ENG246957-ENG246989-Lichttaster-LTM_GlobalOFF_Wegabhängig active
ENG246957-ENG246990-Lichttaster-LTM_GlobalOFF_Zündungsabhängig not active
ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1 not active
ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2 not active
ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3 not active
ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4 not active
ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5 not active
ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6 not active
ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ not active
ENG153727-ENG154566-LIN-SMLS_konfig_1-blinker_entprellen 40 ms
ENG153727-ENG154578-LIN-SMLS_konfig_1-blinker_gra_entprellen 40 ms
ENG153727-ENG154579-LIN-SMLS_konfig_1-blinker_sperrzeit 100 ms
ENG153727-ENG154597-LIN-SMLS_konfig_1-erkennung_fahrt 10 ms
ENG153727-ENG154618-LIN-SMLS_konfig_1-fas_entprellen 40 ms
ENG153727-ENG154624-LIN-SMLS_konfig_1-grahebel_entprellen 40 ms
ENG153727-ENG154634-LIN-SMLS_konfig_1-grenze_v 1 km/h
ENG153727-ENG154686-LIN-SMLS_konfig_1-hupe_entprellen 40 ms
ENG153727-ENG154690-LIN-SMLS_konfig_1-hupe_indien_entprellen 500 ms
ENG153727-ENG154692-LIN-SMLS_konfig_1-k_i 0.5
ENG153727-ENG154693-LIN-SMLS_konfig_1-k_i_offset 5 °C
ENG153727-ENG154694-LIN-SMLS_konfig_1-k_p 13.00%
ENG153727-ENG154695-LIN-SMLS_konfig_1-leistung_lrh 110 W
ENG153727-ENG154699-LIN-SMLS_konfig_1-lrh_entprellen 40 ms
ENG153727-ENG154713-LIN-SMLS_konfig_1-pwm_lrh 25 Hz
ENG153727-ENG154773-LIN-SMLS_konfig_1-s_NWDF_spg 0
ENG153727-ENG154777-LIN-SMLS_konfig_1-soll_0 39 °C
ENG153727-ENG154778-LIN-SMLS_konfig_1-soll_1 43 °C
ENG153727-ENG154779-LIN-SMLS_konfig_1-soll_2 47 °C
ENG153727-ENG154786-LIN-SMLS_konfig_1-speedlimiter_entprellen 40 ms
ENG153727-ENG154788-LIN-SMLS_konfig_1-temlenkradheizung_aus 50 °C
ENG153727-ENG154804-LIN-SMLS_konfig_1-verriegelt_entprellen 0 ms
ENG153727-ENG246995-LIN-SMLS_konfig_1-w_zss_direktansteuerung 0 ms
ENG153727-ENG154811-LIN-SMLS_konfig_1-wischer_entprellen 40 ms
ENG153727-ENG154823-LIN-SMLS_konfig_1-wischer_intervall_entprellen 40 ms
ENG153727-ENG154824-LIN-SMLS_konfig_1-wischer_winterstellung 60 s
ENG153727-ENG154830-LIN-SMLS_konfig_1-zeit_temperatur_statisch_lrh 30 s
ENG153728-IDE00329-LIN-SMLS_konfig_2-Buttons for multi-function display not installed
ENG153728-IDE02694-LIN-SMLS_konfig_2-Signal horn activation Always
ENG153728-IDE02711-LIN-SMLS_konfig_2-Rear Window Wiper installed
ENG153728-IDE02745-LIN-SMLS_konfig_2-Ignition key removal lock not installed
ENG153728-MAS00128-LIN-SMLS_konfig_2-Distance Regulation not installed
ENG153728-MAS00242-LIN-SMLS_konfig_2-Driver assistance systems button not installed
ENG153728-MAS05091-LIN-SMLS_konfig_2-CCS Switch not installed
ENG153728-MAS06090-LIN-SMLS_konfig_2-CCS on turn signal switch not installed
ENG153728-MAS06091-LIN-SMLS_konfig_2-Contact bounce suppression for signal horn not active
ENG153728-MAS08540-LIN-SMLS_konfig_2-reading P locked not active
ENG153728-ENG154465-LIN-SMLS_konfig_2-diagnosis limitation not active
ENG153728-ENG154623-LIN-SMLS_konfig_2-gra_grahebel_2_st installed
ENG153728-ENG154461-LIN-SMLS_konfig_2-speed_limiter_button not installed
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0 0.00%
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1 5.00%
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2 50.00%
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3 75.00%
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4 110
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5 126.5
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0 0.00%
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1 6.00%
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2 16.00%
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3 30.00%
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4 60.00%
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5 100.00%
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0 -5.00%
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1 -5.00%
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2 -5.00%
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3 -5.00%
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4 -5.00%
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0 -5
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1 -5
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2 -5
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3 -5
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4 -5
ENG122979-ENG141954-Networking-A/C electronics installed
ENG122979-ENG141968-Networking-Anhaengeranschlussgeraet installed
ENG122979-ENG141974-Networking-Bremsen_Steuergeraet installed
ENG122979-ENG141953-Networking-Getriebesteuergeraet installed
ENG122979-ENG99457-Networking-Head area heater not installed
ENG122979-ENG142040-Networking-Kunden_spezifisches_Funktions_SG not installed
ENG122979-ENG141969-Networking-UGDO installed
ENG124714-ENG142044-OCU-DWA_push active
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare active
ENG124714-ENG246970-OCU-IAA -Nutzer_management not installed
ENG124714-OCU- installed
ENG124714-ENG142261-OCU-Remote HuF Abbruch 20 km/h
ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz 3 Hz
ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1 80 s
ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3 2000 ms
ENG124714-ENG125657-OCU-Remote_Unlock_Lock Via ZV-Absicherung Light
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar active
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten 4
ENG98831-ENG133402-Personalization-Automatische_ Schluesselzuordnung not active
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar active
ENG98831-ENG126848-Personalization-Personalisierung_aktiv active
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion profiles_active
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar active
ENG98831-ENG142030-Personalization-Profil_Variante Konto (v. 1.x)
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1 active
ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2 active
ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3 active
ENG98831-ENG133407-Personalization-PSO_FSG_Setup2_Bit_4 not active
ENG141646-MAS01065-Querschnitts_funktionen-Brand VW
ENG141646-ENG141980-Querschnitts_funktionen-Bedien_und_Anzeigeprotokoll active
ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung active
ENG141646-ENG141967-Querschnitts_funktionen-Codierungsabsicherung not active
ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21 active
ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus Pin A31
ENG141646-ENG154685-Querschnitts_funktionen-Hupe Sollspannungsanforderung 13.5
ENG141646-ENG115810-Querschnitts_funktionen-Klemmenfehler auf CAN ausgeben active
ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme not_installed
ENG141646-ENG141983-Querschnitts_funktionen-Schnittstelle_TrackingSystem not active
ENG141646-ENG141964-Querschnitts_funktionen-Steering alignment Left
ENG141646-ENG141965-Querschnitts_funktionen-Traffic side Right
ENG122927-RLS_close_glazing 2.0 s
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off 120 s
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on 10 s
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off 65 km/h
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on 140 km/h
ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle 6000 lx
ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high 12
ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low 6
ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht 30 s
ENG122929-RLS_LIN_Communication 4 s
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn 200 lx
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day 500 lx
ENG122930-RLS_tunel_gateway_recognize 5 s
ENG122935-RLS_Washer_Front 15 s
ENG122926-RLS_wiper_position_parking 15 s
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung 10
ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system not installed
ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel active
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit 2000 ms
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit 800 ms
ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit 0 ms
ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit 0 ms
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit 800 ms
ENG115729-ENG154424-Scheinwerferreinigung-Waschen Keine_Spannungsanforderung
ENG153742-ENG154567-SMLS_konfig_entw-blinker_err_el_kurzschluss 200 ms
ENG153742-ENG154568-SMLS_konfig_entw-blinker_err_el_unterbrechung 1000 ms
ENG153742-ENG154569-SMLS_konfig_entw-blinker_err_fernlicht_haengt_aus 5000 ms
ENG153742-ENG154570-SMLS_konfig_entw-blinker_err_fernlicht_haengt_ein 300 s
ENG153742-ENG154571-SMLS_konfig_entw-blinker_err_gra_haengt_aus 5000 ms
ENG153742-ENG154572-SMLS_konfig_entw-blinker_err_gra_haengt_ein 300 s
ENG153742-ENG154573-SMLS_konfig_entw-blinker_err_lichthupe_haengt_aus 5000 ms
ENG153742-ENG154574-SMLS_konfig_entw-blinker_err_lichthupe_haengt_ein 300 s
ENG153742-ENG154575-SMLS_konfig_entw-blinker_err_unplausibel 200 ms
ENG153742-ENG154576-SMLS_konfig_entw-blinker_err_weckkontakthaengt_aus 0 ms
ENG153742-ENG154577-SMLS_konfig_entw-blinker_err_weckkontakthaengt_ein 0 ms
ENG153742-ENG154594-SMLS_konfig_entw-entprellung_unplausibel 0 ms
ENG153742-ENG154595-SMLS_konfig_entw-entprellzeit_ueberspannung 90000 ms
ENG153742-ENG154596-SMLS_konfig_entw-entprellzeit_unterspannung 90000 ms
ENG153742-ENG154622-SMLS_konfig_entw-gra_ea_error 200 ms
ENG153742-ENG154625-SMLS_konfig_entw-grahebel_err_el_kurzschluss 200 ms
ENG153742-ENG154626-SMLS_konfig_entw-grahebel_err_el_unterbrechung 1000 ms
ENG153742-ENG154627-SMLS_konfig_entw-grahebel_err_gra_haengt_aus 5000 ms
ENG153742-ENG154628-SMLS_konfig_entw-grahebel_err_gra_haengt_ein 300 s
ENG153742-ENG154629-SMLS_konfig_entw-grahebel_err_unplausibel 200 ms
ENG153742-ENG154687-SMLS_konfig_entw-hupe_err_hinweis 2000 ms
ENG153742-ENG154688-SMLS_konfig_entw-hupe_err_hupe_haengt_aus 5000 ms
ENG153742-ENG154689-SMLS_konfig_entw-hupe_err_hupe_haengt_ein 60 s
ENG153742-ENG154700-SMLS_konfig_entw-lrh_kurzschluss_entprellen 20 ms
ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen 0 ms
ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen 0 s
ENG153742-ENG154707-SMLS_konfig_entw-n_fehler_verriegelt 0
ENG153742-ENG154780-SMLS_konfig_entw-spannung_obere_schwelle 16.5 V
ENG153742-ENG154781-SMLS_konfig_entw-spannung_obere_schwelle_funkt_einschr 15.5 V
ENG153742-ENG154782-SMLS_konfig_entw-spannung_untere_schwelle 8.5 V
ENG153742-ENG154783-SMLS_konfig_entw-spannung_untere_schwelle_funkt_einschr 8.5 V
ENG153742-ENG154805-SMLS_konfig_entw-verriegelt_err_el_kurzschluss 0 ms
ENG153742-ENG154806-SMLS_konfig_entw-verriegelt_err_unplausibel_aus 0 ms
ENG153742-ENG154807-SMLS_konfig_entw-verriegelt_err_unplausibel_ein 0 ms
ENG153742-ENG154808-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_aus 0 ms
ENG153742-ENG154809-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_ein 0 s
ENG153742-ENG154812-SMLS_konfig_entw-wischer_err_el_kurzschluss 200 ms
ENG153742-ENG154813-SMLS_konfig_entw-wischer_err_el_unterbrechung 1000 ms
ENG153742-ENG154814-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_aus 0.0 s
ENG153742-ENG154815-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_ein 0 s
ENG153742-ENG154816-SMLS_konfig_entw-wischer_err_mfa_haengt_aus 5000 ms
ENG153742-ENG154817-SMLS_konfig_entw-wischer_err_mfa_haengt_ein 300 s
ENG153742-ENG154818-SMLS_konfig_entw-wischer_err_unplausibel 200 ms
ENG153742-ENG154819-SMLS_konfig_entw-wischer_err_waschen_haengt_aus 5000 ms
ENG153742-ENG154820-SMLS_konfig_entw-wischer_err_waschen_haengt_ein 300 s
ENG153742-ENG154821-SMLS_konfig_entw-wischer_err_wischen_haengt_aus 5000 ms
ENG153742-ENG154822-SMLS_konfig_entw-wischer_err_wischen_haengt_ein 300 s
ENG116588-ENG248517-Sonderfunktionen-Blinkerueberwachug Sonderfunktions-SG not installed
ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker MFG
ENG116588-Sonderfunktionen- not enabled
ENG116588-ENG141979-Sonderfunktionen-Sonderfunktionen 1 not installed
ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen not active
ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus by convenience operation via remote control key
ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen not active
ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung active
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung not active
ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel active
ENG141635-ENG126610-Spiegelverstellung-Signalisierung_Spiegelanklappung not active
ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt active
ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung not active
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron not active
ENG153700-ENG154515-Steering Column Switch-Anzahl_fehler_P-verriegelt 250
ENG153700-ENG154621-Steering Column Switch-Geschwindigkeitesschwele_erkennung_fahrt_P_plausibel 10 km/h
ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter LIN
ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel 1000 ms
ENG153700-ENG154829-Steering Column Switch-Zeit_t_P-verriegelt_entprellen 40 ms
ENG141678-ENG115658-Suchbeleuchtung_58_xs_Bus_Kennlinie-x0 0.0 lx
ENG141678-ENG101574-Suchbeleuchtung_58_xs_Bus_Kennlinie-X1 8.0 lx
ENG141678-ENG99557-Suchbeleuchtung_58_xs_Bus_Kennlinie-X2 50.0 lx
ENG141678-ENG102140-Suchbeleuchtung_58_xs_Bus_Kennlinie-X3 80.0 lx
ENG141678-ENG102936-Suchbeleuchtung_58_xs_Bus_Kennlinie-X4 100.0 lx
ENG141678-ENG115659-Suchbeleuchtung_58_xs_Bus_Kennlinie-y0 6
ENG141678-ENG99777-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y1 6
ENG141678-ENG100480-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y2 20
ENG141678-ENG100773-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y3 50
ENG141678-ENG100631-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y4 100
ENG141679-ENG115658-Suchbeleuchtung_58xt_Bus_Kennlinie-x0 0.0 lx
ENG141679-ENG101574-Suchbeleuchtung_58xt_Bus_Kennlinie-X1 8.0 lx
ENG141679-ENG99557-Suchbeleuchtung_58xt_Bus_Kennlinie-X2 50.0 lx
ENG141679-ENG102140-Suchbeleuchtung_58xt_Bus_Kennlinie-X3 80.0 lx
ENG141679-ENG102936-Suchbeleuchtung_58xt_Bus_Kennlinie-X4 100.0 lx
ENG141679-ENG115659-Suchbeleuchtung_58xt_Bus_Kennlinie-y0 6
ENG141679-ENG99777-Suchbeleuchtung_58xt_Bus_Kennlinie-Y1 6
ENG141679-ENG100480-Suchbeleuchtung_58xt_Bus_Kennlinie-Y2 20
ENG141679-ENG100773-Suchbeleuchtung_58xt_Bus_Kennlinie-Y3 50
ENG141679-ENG100631-Suchbeleuchtung_58xt_Bus_Kennlinie-Y4 100
ENG141666-ENG115658-Suchbeleuchtung_Abdimmen-x0 0 ms
ENG141666-ENG101574-Suchbeleuchtung_Abdimmen-X1 200 ms
ENG141666-ENG115664-Suchbeleuchtung_Abdimmen-x10 2000 ms
ENG141666-ENG99557-Suchbeleuchtung_Abdimmen-X2 400 ms
ENG141666-ENG102140-Suchbeleuchtung_Abdimmen-X3 600 ms
ENG141666-ENG102936-Suchbeleuchtung_Abdimmen-X4 800 ms
ENG141666-ENG103548-Suchbeleuchtung_Abdimmen-X5 1000 ms
ENG141666-ENG113992-Suchbeleuchtung_Abdimmen-X6 1200 ms
ENG141666-ENG115661-Suchbeleuchtung_Abdimmen-x7 1400 ms
ENG141666-ENG115662-Suchbeleuchtung_Abdimmen-x8 1600 ms
ENG141666-ENG115663-Suchbeleuchtung_Abdimmen-x9 1800 ms
ENG141666-ENG115659-Suchbeleuchtung_Abdimmen-y0 100.00%
ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1 100.00%
ENG141666-ENG115668-Suchbeleuchtung_Abdimmen-y10 0.00%
ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2 95.00%
ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3 80.00%
ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4 40.00%
ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5 20.00%
ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6 10.00%
ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7 5.00%
ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8 3.00%
ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9 1.00%
ENG141663-ENG142240-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xd PWM 0.00 s
ENG141663-ENG154582-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xs_PWM 0.00 s
ENG141663-ENG154583-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xt_PWM 0.00 s
ENG141663-ENG154584-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xd_PWM 0.00 s
ENG141663-ENG154585-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xt_PWM 0.00 s
ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung HMI
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen 20.0 s
ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen 3.0 s
ENG141663-ENG116598-Suchbeleuchtung_allgemein-KL58 Einschalten mit Rampe not active
ENG141663-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten not_active
ENG141663-ENG116600-Suchbeleuchtung_allgemein-Lichtsensor wirkt auf Suchbeleuchtung active
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS 2
ENG141663-ENG154712-Suchbeleuchtung_allgemein-PWM_Daempfung_Aufdimmen_KL58xs_PWM 0.00 s
ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert 50%
ENG141663-ENG142234-Suchbeleuchtung_allgemein-Umgebungs_helligkeit_auswahl Fotosensor_Kombi
ENG141663-ENG115819-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Aktivierung Always active
ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor 0.1
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert 10.00%
ENG141667-ENG115658-Suchbeleuchtung_Fotosensor-x0 0
ENG141667-ENG101574-Suchbeleuchtung_Fotosensor-X1 50
ENG141667-ENG115664-Suchbeleuchtung_Fotosensor-x10 0
ENG141667-ENG99557-Suchbeleuchtung_Fotosensor-X2 100
ENG141667-ENG102140-Suchbeleuchtung_Fotosensor-X3 200
ENG141667-ENG102936-Suchbeleuchtung_Fotosensor-X4 253
ENG141667-ENG103548-Suchbeleuchtung_Fotosensor-X5 0
ENG141667-ENG113992-Suchbeleuchtung_Fotosensor-X6 0
ENG141667-ENG115661-Suchbeleuchtung_Fotosensor-x7 0
ENG141667-ENG115662-Suchbeleuchtung_Fotosensor-x8 0
ENG141667-ENG115663-Suchbeleuchtung_Fotosensor-x9 0
ENG141667-ENG115659-Suchbeleuchtung_Fotosensor-y0 0 lx
ENG141667-ENG99777-Suchbeleuchtung_Fotosensor-Y1 50 lx
ENG141667-ENG115668-Suchbeleuchtung_Fotosensor-y10 0 lx
ENG141667-ENG100480-Suchbeleuchtung_Fotosensor-Y2 100 lx
ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3 200
ENG141667-ENG100631-Suchbeleuchtung_Fotosensor-Y4 500
ENG141667-ENG102174-Suchbeleuchtung_Fotosensor-Y5 0
ENG141667-ENG113993-Suchbeleuchtung_Fotosensor-Y6 0 lx
ENG141667-ENG115665-Suchbeleuchtung_Fotosensor-y7 0 lx
ENG141667-ENG115666-Suchbeleuchtung_Fotosensor-y8 0 lx
ENG141667-ENG115667-Suchbeleuchtung_Fotosensor-y9 0 lx
ENG141665-ENG115658-Suchbeleuchtung_Hochdimmen-x0 0 ms
ENG141665-ENG101574-Suchbeleuchtung_Hochdimmen-X1 200 ms
ENG141665-ENG115664-Suchbeleuchtung_Hochdimmen-x10 2000 ms
ENG141665-ENG99557-Suchbeleuchtung_Hochdimmen-X2 400 ms
ENG141665-ENG102140-Suchbeleuchtung_Hochdimmen-X3 600 ms
ENG141665-ENG102936-Suchbeleuchtung_Hochdimmen-X4 800 ms
ENG141665-ENG103548-Suchbeleuchtung_Hochdimmen-X5 1000 ms
ENG141665-ENG113992-Suchbeleuchtung_Hochdimmen-X6 1200 ms
ENG141665-ENG115661-Suchbeleuchtung_Hochdimmen-x7 1400 ms
ENG141665-ENG115662-Suchbeleuchtung_Hochdimmen-x8 1600 ms
ENG141665-ENG115663-Suchbeleuchtung_Hochdimmen-x9 1800 ms
ENG141665-ENG115659-Suchbeleuchtung_Hochdimmen-y0 0.00%
ENG141665-ENG99777-Suchbeleuchtung_Hochdimmen-Y1 1.00%
ENG141665-ENG115668-Suchbeleuchtung_Hochdimmen-y10 100.00%
ENG141665-ENG100480-Suchbeleuchtung_Hochdimmen-Y2 3.00%
ENG141665-ENG100773-Suchbeleuchtung_Hochdimmen-Y3 5.00%
ENG141665-ENG100631-Suchbeleuchtung_Hochdimmen-Y4 11.00%
ENG141665-ENG102174-Suchbeleuchtung_Hochdimmen-Y5 22.00%
ENG141665-ENG113993-Suchbeleuchtung_Hochdimmen-Y6 40.00%
ENG141665-ENG115665-Suchbeleuchtung_Hochdimmen-y7 80.00%
ENG141665-ENG115666-Suchbeleuchtung_Hochdimmen-y8 95.00%
ENG141665-ENG115667-Suchbeleuchtung_Hochdimmen-y9 100.00%
ENG141669-ENG115658-Suchbeleuchtung_KL 58xs max-x0 0 lx
ENG141669-ENG101574-Suchbeleuchtung_KL 58xs max-X1 8 lx
ENG141669-ENG99557-Suchbeleuchtung_KL 58xs max-X2 50 lx
ENG141669-ENG102140-Suchbeleuchtung_KL 58xs max-X3 500 lx
ENG141669-ENG115659-Suchbeleuchtung_KL 58xs max-y0 100
ENG141669-ENG99777-Suchbeleuchtung_KL 58xs max-Y1 100
ENG141669-ENG100480-Suchbeleuchtung_KL 58xs max-Y2 100
ENG141669-ENG100773-Suchbeleuchtung_KL 58xs max-Y3 100
ENG141668-ENG115658-Suchbeleuchtung_KL 58xs min-x0 0 lx
ENG141668-ENG101574-Suchbeleuchtung_KL 58xs min-X1 8 lx
ENG141668-ENG99557-Suchbeleuchtung_KL 58xs min-X2 50 lx
ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3 510 lx
ENG141668-ENG115659-Suchbeleuchtung_KL 58xs min-y0 6
ENG141668-ENG99777-Suchbeleuchtung_KL 58xs min-Y1 6
ENG141668-ENG100480-Suchbeleuchtung_KL 58xs min-Y2 100
ENG141668-ENG100773-Suchbeleuchtung_KL 58xs min-Y3 100
ENG141674-ENG115658-Suchbeleuchtung_KL_58xd_log_Bus-x0 0.00%
ENG141674-ENG101574-Suchbeleuchtung_KL_58xd_log_Bus-X1 6.00%
ENG141674-ENG99557-Suchbeleuchtung_KL_58xd_log_Bus-X2 16.00%
ENG141674-ENG102140-Suchbeleuchtung_KL_58xd_log_Bus-X3 30.00%
ENG141674-ENG102936-Suchbeleuchtung_KL_58xd_log_Bus-X4 60.00%
ENG141674-ENG103548-Suchbeleuchtung_KL_58xd_log_Bus-X5 100.00%
ENG141674-ENG115659-Suchbeleuchtung_KL_58xd_log_Bus-y0 10
ENG141674-ENG99777-Suchbeleuchtung_KL_58xd_log_Bus-Y1 10
ENG141674-ENG100480-Suchbeleuchtung_KL_58xd_log_Bus-Y2 100
ENG141674-ENG100773-Suchbeleuchtung_KL_58xd_log_Bus-Y3 150
ENG141674-ENG100631-Suchbeleuchtung_KL_58xd_log_Bus-Y4 220
ENG141674-ENG102174-Suchbeleuchtung_KL_58xd_log_Bus-Y5 253
ENG141673-ENG115658-Suchbeleuchtung_KL_58xd_max-x0 0 lx
ENG141673-ENG101574-Suchbeleuchtung_KL_58xd_max-X1 8 lx
ENG141673-ENG99557-Suchbeleuchtung_KL_58xd_max-X2 200 lx
ENG141673-ENG102140-Suchbeleuchtung_KL_58xd_max-X3 300 lx
ENG141673-ENG102936-Suchbeleuchtung_KL_58xd_max-X4 500 lx
ENG141673-ENG115659-Suchbeleuchtung_KL_58xd_max-y0 16
ENG141673-ENG99777-Suchbeleuchtung_KL_58xd_max-Y1 16
ENG141673-ENG100480-Suchbeleuchtung_KL_58xd_max-Y2 100
ENG141673-ENG100773-Suchbeleuchtung_KL_58xd_max-Y3 100
ENG141673-ENG100631-Suchbeleuchtung_KL_58xd_max-Y4 100
ENG141672-ENG115658-Suchbeleuchtung_KL_58xd_min-x0 0 lx
ENG141672-ENG101574-Suchbeleuchtung_KL_58xd_min-X1 50 lx
ENG141672-ENG99557-Suchbeleuchtung_KL_58xd_min-X2 220 lx
ENG141672-ENG102140-Suchbeleuchtung_KL_58xd_min-X3 300 lx
ENG141672-ENG102936-Suchbeleuchtung_KL_58xd_min-X4 500 lx
ENG141672-ENG115659-Suchbeleuchtung_KL_58xd_min-y0 6
ENG141672-ENG99777-Suchbeleuchtung_KL_58xd_min-Y1 16
ENG141672-ENG100480-Suchbeleuchtung_KL_58xd_min-Y2 25
ENG141672-ENG100773-Suchbeleuchtung_KL_58xd_min-Y3 30
ENG141672-ENG100631-Suchbeleuchtung_KL_58xd_min-Y4 50
ENG141677-ENG115658-Suchbeleuchtung_KL_58xd_PWM-x0 0
ENG141677-ENG101574-Suchbeleuchtung_KL_58xd_PWM-X1 10
ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2 50
ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3 100
ENG141677-ENG102936-Suchbeleuchtung_KL_58xd_PWM-X4 220
ENG141677-ENG103548-Suchbeleuchtung_KL_58xd_PWM-X5 253
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0 2.00%
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1 2.00%
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2 6.00%
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3 10.00%
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4 80.00%
ENG141677-ENG102174-Suchbeleuchtung_KL_58xd_PWM-Y5 100.00%
ENG141670-ENG115658-Suchbeleuchtung_KL_58xt min-x0 0 lx
ENG141670-ENG101574-Suchbeleuchtung_KL_58xt min-X1 8 lx
ENG141670-ENG99557-Suchbeleuchtung_KL_58xt min-X2 50 lx
ENG141670-ENG102140-Suchbeleuchtung_KL_58xt min-X3 500 lx
ENG141670-ENG115659-Suchbeleuchtung_KL_58xt min-y0 6
ENG141670-ENG99777-Suchbeleuchtung_KL_58xt min-Y1 6
ENG141670-ENG100480-Suchbeleuchtung_KL_58xt min-Y2 100
ENG141670-ENG100773-Suchbeleuchtung_KL_58xt min-Y3 100
ENG141671-ENG115658-Suchbeleuchtung_KL_58xt_max-x0 0 lx
ENG141671-ENG101574-Suchbeleuchtung_KL_58xt_max-X1 8 lx
ENG141671-ENG99557-Suchbeleuchtung_KL_58xt_max-X2 50 lx
ENG141671-ENG102140-Suchbeleuchtung_KL_58xt_max-X3 500 lx
ENG141671-ENG115659-Suchbeleuchtung_KL_58xt_max-y0 100
ENG141671-ENG99777-Suchbeleuchtung_KL_58xt_max-Y1 100
ENG141671-ENG100480-Suchbeleuchtung_KL_58xt_max-Y2 100
ENG141671-ENG100773-Suchbeleuchtung_KL_58xt_max-Y3 100
ENG141676-ENG115658-Suchbeleuchtung_KL_58xt_PWM-x0 0.00%
ENG141676-ENG101574-Suchbeleuchtung_KL_58xt_PWM-X1 50.00%
ENG141676-ENG99557-Suchbeleuchtung_KL_58xt_PWM-X2 100.00%
ENG141676-ENG115659-Suchbeleuchtung_KL_58xt_PWM-y0 0.00%
ENG141676-ENG99777-Suchbeleuchtung_KL_58xt_PWM-Y1 50.00%
ENG141676-ENG100480-Suchbeleuchtung_KL_58xt_PWM-Y2 100.00%
ENG141680-ENG115658-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-x0 0 lx
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1 10 lx
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2 100 lx
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3 500 lx
ENG141680-ENG102936-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X4 800 lx
ENG141680-ENG103548-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X5 1020 lx
ENG141680-ENG115659-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-y0 0
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1 20
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2 80
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3 180
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4 300
ENG141680-ENG102174-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y5 500
ENG141664-ENG115633-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x0 0 ms
ENG141664-ENG115634-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x1 2000 ms
ENG141664-ENG115635-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x2 3000 ms
ENG141664-ENG115636-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x3 4000 ms
ENG141664-ENG115637-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x4 5100 ms
ENG141664-ENG115638-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y0 1.00%
ENG141664-ENG115639-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y1 5
ENG141664-ENG115640-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y2 15
ENG141664-ENG115641-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y3 40
ENG141664-ENG115642-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y4 100
ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen not active
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen active
ENG141632-ENG116645-Sunroof-SAD Richtung Komfortoeffnen tilting
ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1 installed
ENG141632-ENG141971-Sunroof-Schiebedachmodul_MD_3 not installed
ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rollo installed
ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule CAN
ENG141634-ENG142013-Verdecksteuergeraet-Cabrio_Verdeck not_installed
ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck active
ENG141634-ENG128459-Verdecksteuergeraet-easycloselight_aktiv not active
ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb not active
ENG141634-ENG142259-Verdecksteuergeraet-Kick_and_close not installed
ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global active
ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen active
ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließen active
ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf not active
ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen active
ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung nur wenn mind. 1 Raste zu
ENG141634-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden Always
ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit installed
ENG141634-ENG116717-Verdecksteuergeraet-Verdeck mit Schiebedach not active
ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung active
ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy active
ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder active
ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung active
ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessy active
ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinder active
ENG141634-ENG115869-Verdecksteuergeraet-Virtuelles_Pedal active
ENG141634-ENG126611-Verdecksteuergeraet-virtuelles_pedal_HMI_einstellbar active
ENG141634-ENG142257-Verdecksteuergeraet-Virtuelles_Pedal_Verbau installed
ENG141634-ENG246994-Verdecksteuergeraet-Virtuelles_Pedal_Version Version_1_2
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1 00 00
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2 00 00
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3 00 00
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4 00 00
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1 00 00
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2 00 00
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3 00 00
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4 00 00
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5 00 00
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6 00 00
ENG141651-ENG116632-ZV allgemein-Bewusstes Safe mit 2. Betaetigung der FFB not active
ENG141651-ENG133387-ZV allgemein-Deaktivierung_Laderaumschliessung_extern not active
ENG141651-ENG125653-ZV allgemein-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster active
ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein active
ENG141651-ENG115754-ZV allgemein-Funk bei Klemme 15 ein active
ENG141651-ENG141981-ZV allgemein-Lock_Unlock_Taster_direkt not installed
ENG141651-ENG142019-ZV allgemein-Lock_Unlock_Toggle_Taster not installed
ENG141651-ENG133388-ZV allgemein-LS_Taster_Togglefunktion not active
ENG141651-ENG116633-ZV allgemein-Menuesteuerung Tuerentriegelung active
ENG141651-ENG115755-ZV allgemein-Notschließfunktion active
ENG141651-ENG133389-ZV allgemein-Nutzfahrzeug_Schliessung not active
ENG141651-ENG141957-ZV allgemein-Radio freq. 315MHz
ENG141651-ENG141958-ZV allgemein-Tankschloss Bidirectional
ENG141651-ENG133390-ZV allgemein-Wiederverriegelung_Laderaum ZV_Wiederveriegelung
ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung Einzeltuerentriegelung
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion installed
ENG141654-ENG116628-ZV Autolock-Autolock Autounlock wirkt auf Heck active
ENG141654-ENG116621-ZV Autolock-automatisches Entriegeln active
ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit active
ENG141654-ENG116706-ZV Autolock-Autounlock NAR active
ENG141654-ENG116622-ZV Autolock-Geschwindigkeitsabhaengige Tankdeckelverriegelung not active
ENG141654-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock not active
ENG141655-ENG116627-ZV Crash-Heckdeckel-Bedienstellen nachCrash temporaer sperren active
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen not active
ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash not active
ENG141653-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckels active
ENG141653-ENG126839-ZV Heck-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang not active
ENG141653-ENG116707-ZV Heck-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster not active
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster via_CAN
ENG141653-ENG133386-ZV Heck-Heckfreigabe_Ohne_Verzoegerung not active
ENG141653-ENG142245-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen active
ENG141653-ENG141998-ZV Heck-Heckschloss_mit_Vorraste Yes
ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung Kontaktsteuerung mit Mindestansteuerzeit
ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster 0.0 s
ENG141653-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt not active
ENG141653-ENG141982-ZV Heck-Tausch_Tank_Hecktreiberausgang No
ENG141653-ENG115760-ZV Heck-ZV entriegelt auch Heckdeckel active
ENG141653-ENG116629-ZV Heck-ZV Heck nur direkt auswerfen not active
ENG141653-ENG141997-ZV Heck-ZV_Heck_Schlosstyp 1 or 2 notch rear actuator
ENG141681-IDE02021-ZV Komfort-Comfort closing active
ENG141681-IDE02022-ZV Komfort-Comfort opening not active
ENG141681-ENG141984-ZV Komfort-elektrischer_Fensterheber_hinten Yes
ENG141681-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen active
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen not active
ENG141681-ENG116662-ZV Komfort-FH SAD Kl15Aus Freigabezeit 600 s
ENG141681-ENG116648-ZV Komfort-Freigabenachlauf FH bei Kl 15 aus active
ENG141681-ENG122993-ZV Komfort-Freigabenachlauf FH bei Tueroeffnen abbrechen active
ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen active
ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen active
ENG141681-ENG115670-ZV Komfort-Komfortbedienung global active
ENG141681-ENG116642-ZV Komfort-Komfortoeffnen nur FH Fahrertuer not active
ENG141681-ENG122994-ZV Komfort-Menuesteuerung Komfortbedienung einstellbar adjustable
ENG141681-ENG122186-ZV Komfort-Menuesteuerung Regenschliessen not active
ENG141681-ENG246991-ZV Komfort-pa_Two_Keys not active
ENG141681-ENG125656-ZV Komfort-Regenschliessen_art once
ENG141681-ENG125655-ZV Komfort-Regenschliessen_ein_aus not active
ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen not active
ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen not active
ENG141652-ENG141999-ZV Türkonfiguration-Fond_Schloss 2-Motorenschloesser
ENG141652-ENG142043-ZV Türkonfiguration-HFT_Invertierung_Drehfallensignal nicht invertiert
ENG141652-ENG142039-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Beifahrerseite not installed
ENG141652-ENG142038-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Fahrerseite not installed
ENG141652-ENG142001-ZV Türkonfiguration-Schiebetuer_links No
ENG141652-ENG142002-ZV Türkonfiguration-Schiebetuer_rechts No
ENG141652-ENG142041-ZV Türkonfiguration-Schiebetueren_Crafter not installed
ENG141652-ENG142244-ZV Türkonfiguration-Schiebetuerschloss_direkt_BCM Driver side
ENG141652-ENG116631-ZV Türkonfiguration-Schliessung der Schiebetuer bei geoeffneter Tankklappe not active
ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR Yes
ENG141652-ENG141959-ZV Türkonfiguration-Viertuerer Yes
