Results 1 to 10 of 15
Thread: Audi A6 C7.5 ldw/vze retrofit
    Jul 2019
    Trondheim, Norway
    Hi, i have been trying to fix this problem for the last 8 months.
    For starters, my car does not have the front window camera or the imageprocessor from the factory
    No ACC or matrix led lights.
    I have retrofitted the new front windscreen with the camera (85)
    I have modified the flexray cables so the go trought the imageproc (8E) (abs and all other stuff working)
    I have changed the sensor electronic (3B) from index H to K
    I suspect there is some codeing issues in the gateway that do not like the imageproc (8E)
    Any ideas?
    Sunday,25,August,2019,14:02:38:62878
    VIN: WAUZZZ4G5FN064973   License Plate:
    Chassis Type: 4G-AU57 (4G8)
    Scan: 01 02 03 05 08 09 15 16 17 19 28 36 3B 42 44 46 52 53 5F 62
              69 6C 6D 72 82 85 8E 8F 90 AC
    VIN: WAUZZZ4G5FN064973   Mileage: 96264km-59815miles
    17-Instruments -- Status: Malfunction 0110
    82-Heads Up Display -- Status: Malfunction 0010
    8E-Image Processing -- Status: Cannot be reached 0100
    Address 01: Engine (J623-CRTE)       Labels: Redir Fail!
       Part No SW: 4G2 907 311 C    HW: 4G2 907 401
       Component: 3.0TDI EDC17  H33 0007
       Revision: 92H33---
       Coding: 12254012053601030000
       Shop #: WSC 28389 002 1048576
       ASAM Dataset: EV_ECM30TDI0114G2907311C 001007
       ROD: EV_ECM30TDI0114G2907311C.rod
       VCID: 2502E37C24149867CA-8070
       Part No SW: 4G0 927 166 A    HW: 0B5 927 156 K
       Component: 0B5 30 TDIRdW H03 0009
       Revision: --H03---
       Coding: 100001
       ASAM Dataset: EV_TCMDL501021 001021
       ROD: EV_TCMDL501021.rod
       VCID: 2B16154442F0AE171C-807E
       Part No SW: 4G0 907 379 Q    HW: 4G0 907 379 Q
       Component: ESP9 Premium  H01 0420
       Coding: 17A69E41E8657982BB00
       ASAM Dataset: EV_ESP9BOSCHAU57X 003019
       ROD: EV_ESP9BOSCHAU57X_003.rod
       VCID: 3FCE5114A68822B7A0-806A
       Part No SW: 4H0 907 064 FN    HW: 4H0 907 064 EN
       Component: BCM2 2.0      H36 0560
       Coding: 01A9700E000000000000
       VCID: 7AB8E000F52AC79FD7-802E
       Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
       Component: KLIMA 4 ZONEN H14 0112
       Serial number: 30011500041629
       Coding: 360211B8210000
       VCID: 6386BD646AA02657E4-8036
    0276 - Engine Off Timer Performance
              P150A 00 [008] - -
                        Reset counter: 91
                        Mileage: 96264 km
                        Date: 2019.08.24
                        Time: 14:55:09
                        Voltage terminal 30: 11.93 V
       Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
       Revision: 15020001    Serial number: 00001002845902
       Coding: 2600001500349FE08181408380001D0CCF9CE60826090201000008206101150200400024030000
       VCID: 71AAC72CA85C84C766-8024
       Component: WWS57X 150124  H37 0080
       Serial number:         150130081946
       Coding: 0045F7
       Serial number: 23704895
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531 BG    HW: 4G0 941 531 BG
       Component: E1 - LDS  H07 0044
       Serial number: 28 02 2014  00001000
       Serial number: DBD80197000000000001
       Part No SW: 4H0 959 655 H    HW: 4H0 959 655 H
       Component: Airbag10.43   H82 0086
       Revision: --------    Serial number: 003P10033D6B
       Coding: 30333130313730323736554A304C34473053
       VCID: 3B362504B2903E978C-806E
       Serial number: 3575HRB405P33HNGA0R-
       Serial number: 3585HRB405D33RVK81T5
       Serial number: 3515JRB4016533VUN1QW
       Serial number: 3525JRB4006534EADOSB
       Serial number: 3554VRB400S52RDAI1CY
       Serial number: 3564VRB401052RDAO269
       Revision: C0068538    Serial number: 90862OB500081
       Coding: 000015
       VCID: 3B362504BA903E978C-806E
       Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
       Serial number: 17 12 2014  E0064336
       Part No SW: 4G8 920 933 Q    HW: 4G8 920 933 Q
       Component: TDieRdw       H07 0043
       Revision: 03001036    Serial number: 658050215596016
       Coding: 03AF12000B410008020000
       ASAM Dataset: EV_RBD4K 004048
       ROD: EV_RBD4K_AU57.rod
       VCID: 3E302C10A1822BBFAB-806A
    16776969 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [LDW_02_FR keine Kommunikation]
                        Reset counter: 91
                        Mileage: 96264 km
                        Date: 2019.08.25
                        Time: 13:57:29
    16776980 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [VZE_01 keine Kommunikation]
                        Reset counter: 91
                        Mileage: 96264 km
                        Date: 2019.08.25
                        Time: 13:57:29
       Part No SW: 4G8 907 468     HW: 4G8 907 468
       Component: J533--Gateway H13 0075
       Revision: --------    Serial number: 00000001719911
       Coding: C0CD078118
       ASAM Dataset: EV_GatewPkoUDS 001024
       VCID: 75A2F33CD434A8E7BA-8020
       Serial number: 3565135603
       Voltage stabilizer:
       Serial number: 14112700000000000490
    6653 - Image processing control module
              U1079 00 [009] - No communication
                        Reset counter: 51
                        Mileage: 96264 km
                        Date: 2019.08.25
                        Time: 13:50:19
                        Voltage terminal 30: 13.7 V
                        Voltage terminal 15: 13.7 V
                        Control Module temperature: 24 °C
                        System status: Terminal 15 on
                        Engine running: On
                        IN ZAS_Te_X: On
                        Terminal 15 status: On
                        Datenfeld: 0
       Part No SW: 4G0 919 158 R    HW: 4G0 919 158 R
       Component: KLIMA FOND    H08 0112
       Serial number: 04021500040558
       Coding: 20
       Revision: AA000000    Serial number: 00000134103691
       Coding: 0058130000006001000001010101102030303232203232
       VCID: 77BEF934C638DAF7A8-8022
       Component: SARA 6D       H04 0056
       Revision: --------    Serial number: EJ1BPA820BD7D5
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 3620343089B2E3FF73-8062
       Coding: 011F17014E00628002080002
       VCID: 47DE49F4F6586A7718-8012
       Part No SW: 4G0 909 144 M    HW: 4G0 909 144 G
       Component: RCEPS         H41 0011
       Revision: 00001000    Serial number: 0008397702
       Coding: 101000010001
       ASAM Dataset: EV_RCEPS 009010
       ROD: EV_RCEPS_009.rod
       VCID: 33260D249AC0F6D754-8066
       Revision: 00002001    Serial number: 0359813205
       Coding: 0100063820B930008320090028010F470000000000000000000000000000
       VCID: 46C044F0F152737FE3-8012
       Revision: --------    Serial number: 00000001356261
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2D121B5C7CE4A02702-8078
    Address 5F: Information Electr. (J794)       Labels:* 4G1-035-MIB-HGH2.clb
       Part No SW: 4G1 035 044 D    HW: 4G1 035 044
       Component: MU-H-LN-EU    041 0389
       Serial number: A589B0F7507774
       Coding: 01750201FF0A000013110001000A00132F0006E5F1700100DF
       VCID: 200CF2683B367D4FB9-8074
       Subsystem 1 - Part No SW: V03 959 801 FD    HW: -----------
       Component: ECE 2017/2018  --- 0161
       Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A
       Serial number: AUZ8Z9FY8013QG
       Multimedia Operating Unit:
       Serial number: 90349OB2000V5
       Component: Gracenote2  --- 1012
    6733 - Control Head Module; Rear Right
              U12B0 00 [009] - No Communication
              [Smart display carrier 1: no signal/communication]
                        Reset counter: 51
                        Mileage: 96264 km
                        Date: 2019.08.24
                        Time: 16:01:49
                        Voltage terminal 30: 12.1 V
    7193 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Lane departure warning: heading control (0x19) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 51
                        Mileage: 96264 km
                        Date: 2019.08.24
                        Time: 16:01:52
                        BAP-BAP_Function_ID: 02
    7201 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Road sign display (0x21) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 51
                        Mileage: 96264 km
                        Date: 2019.08.24
                        Time: 16:01:55
       Coding: 010F15004000628002080002
       VCID: 49DA4FCCE04C9C070E-801C
    Address 69: Trailer (J345)       Labels:| 4H0-907-383-V2.clb
       Part No SW: 4G8 907 383 B    HW: 4G8 907 383 B
       Component: Anhaenger     H14 0137
       Revision: 7B001001    Serial number: 0359195306
       Coding: 0100000202000000
    Address 6C: Back-up Cam. (J772)       Labels:| 4S0-980-556.clb
       Part No SW: 4S0 980 556 A    HW: 5Q0 980 556 B
       Component: RVC Compact   H12 0201
       Coding: 0275000103002007000040
       Shop #: WSC 17873 123 50804
       ASAM Dataset: EV_CamSysRVRVCPANAAU57X 002003
       ROD: EV_CamSysRVRVCPANAAU57X_002_AU57.rod
       VCID: 393A3F0CB8AC0C879E-806C
    10489856 - No Basic Setting
              B2010 00 [009] - -
              [RearView system not calibrated]
                        Reset counter: 51
                        Mileage: 96264 km
                        Date: 2019.08.25
                        Time: 13:49:43
                        passive
       Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
       Component: HDSG-Modul    H05 0150
       Revision: 14005001    Serial number: 022501421
       Coding: 093205C011
       ROD: EV_HDSGAu571.rod
    Address 82: Heads Up Display (J898)       Labels:| 4G0-919-604.clb
       Part No SW: 4G0 919 604 M    HW: 4G0 919 604 M
       Component: HeadUpDisplay H07 0304
       Coding: AF0000
       ASAM Dataset: EV_HUDContiC7 001025
       ROD: EV_HUDContiC7.rod
       VCID: 3522333C94B4E8E77A-8060
    16776965 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 51
                        Mileage: 96264 km
                        Date: 2019.08.24
                        Time: 16:25:28
    16776970 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [VZE_01_ keine Kommunikation]
                        Reset counter: 51
                        Mileage: 96264 km
                        Date: 2019.08.24
                        Time: 16:25:28
       Part No SW: 4H0 907 217 F    HW: 4H0 907 217 A
       Component: DPC-SG        H27 0081
       Coding: 72040000
       ROD: EV_OnBoardCamerDPC.rod
       VCID: 2C14165847FEA92F15-8078
    6 Faults Found:
    0703 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [ESP_timeout]
                        Reset counter: 91
                        Mileage: 96264 km
                        Date: 2019.08.24
                        Time: 16:52:18
                        Outside air temperature: -41.5 °C
                        Voltage terminal 15: 11.6 V
                        Control Module temperature: 50.0 °C
    0722 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [LWS_Timeout]
                        Reset counter: 91
                        Mileage: 96264 km
                        Date: 2019.08.24
                        Time: 16:52:18
    0728 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [SARA_timeout]
                        Reset counter: 91
                        Mileage: 96264 km
                        Date: 2019.08.24
                        Time: 16:52:18
    0733 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [BCM2_Timeout]
                        Reset counter: 91
                        Mileage: 96264 km
                        Date: 2019.08.24
                        Time: 16:52:18
    0715 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Gateway_timeout]
                        Reset counter: 91
                        Mileage: 96264 km
                        Date: 2019.08.24
                        Time: 16:52:18
    0701 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Motor_timeout]
                        Reset counter: 91
                        Mileage: 96264 km
                        Date: 2019.08.24
                        Time: 16:52:18
    Address 8E: Image Processing
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 312A072C60DCC4C726-8064
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       VCID: 3228082065DAFFDF5F-8066
       Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
       Component: SCR-Stg-G2    H10 0012
       Revision: 00000000    Serial number: 150090361
       ROD: EV_RDCMA00100_008.rod
    End----------(Elapsed Time: 01:49, VBatt start/end: 12.4V/12.4V)-----------
    Regards Rizzio
    Audi A6 C7.5 FL 2015
    Retrofited: Hud, Back up cam, dab+, Vze
    In progress: Lane assist, Nvc
    Apr 2018
    ITALY
    8E CANNOT BE REACHED. you have a wiring issue.
    my Golf came out of the factory with 13 ECUs. now she has 20. and counting
  3. Likes Uwe, MasterTommy liked this post
    Oct 2018
    Spain
    Dear Rizzio, as you know I have some similar problem (you have participated in my post “Audi A6 C7 HBA Retrofit”) and, I am afraid, at the end of the day, we both will end in some “new manufacturers configuration software firewall”. The purpose: keeping their profits, the alibi: Peoples’ safety.
    But as far as I know, there is no independent entity for cars’ manufactures software verification and validation.
    For this reason I want to keep this forum where independent opinions can appear , some of them “insane”, but if they can avoid future “cheating configuration for roller mode Diesel engines testing” I will like to participate
    Best regards
    Juan
    Jul 2019
    Trondheim, Norway
    I’ve been working on this problem all day. And if someone have any ideas where this failes, give me som pointers.
    I have checked all wires (not ones, twice , but checked 4 times)
    Pinout is as follows. From gateway pin 7 to 8E pin 3, gateway pin23 to 8E pin 4.
    8E pin 9 to Abs pin 11, 8E pin 10 to abs pin 23.
    Do we agree on this being correct?
    Pin 1 from 8E goes to the fusebox, and pin 2 goes to earth at the bottom of the right A pillar
    So if the car is pickey on the power, where should the wires go?
    And is my gateway coded the right way?
    Any ideas for adaptations or coding?
    May 2017
    From what pin exactly from fusebox you’re taking the power?
    Because most likely the imageprocessor is not getting power and that causes the cannot be reached issue.
    Apr 2018
    ITALY
    also, on other vehicles the lane assist camera HAS to be powered by a switched fuse (Terminal 15), so check your WD.
  8. Likes Uwe liked this post
    Jul 2019
    Trondheim, Norway
    Found the fault. Wire snap in the kufatec wireloom. Fixing the wires now, new update when im done rewiring.
    The imageproc up and running.
    But i now have a new problem.
    Outside operating area.
    Coding for the 8E does not include my mib2 high version. i have Rcm, 3G+ and no navi
    Could this be fixed with vcds or Vag can Pro?
  10. Likes Uwe, PetrolDave liked this post
  11. #8
    Feb 2016
    Czech Republic
    I can post my car A6 Avant 3.0 TDI 2015+, if it help
    But it have also Acc, Side Assist.
    Hope it help:
       Component: 3.0TDI EDC17  H34 0003
       Revision: 92H34---
       Coding: 12254012046601030000
       Shop #: WSC 01286 386 08256
       ASAM Dataset: EV_ECM30TDI0114G2907311C 001003
       VCID: 2502051A24D1A66286-8070
       Component: 0B5 30 TDIRdW H03 0008
       Revision: --H03---
       Coding: 100001
       VCID: 2B16F3224235901250-807E
       Coding: 17A6DE49E8657B929B00
       ROD: EV_ESP9BOSCHAU57X.rod
       VCID: 41CAB18AD0B96A429A-8014
       Part No SW: 4H0 907 064 GP    HW: 4H0 907 064 GP
       Component: BCM2 2.0      H37 0572
       Coding: 05A96F0E000000000000
       VCID: 7DB20D7AE4C1CEA2BE-8028
       Part No SW: 4G8 959 760 C    HW: 4G8 959 760 C
       Component: MEM-BFS       H04 0154
       Revision: AA000000    Serial number: 00000016109954
       Coding: C018320085006201010001010101112030303333283333
       Shop #: WSC 02311 785 00200
       VCID: 3A38C666B56F399ADB-806E
       Serial number: 19101500040623
       Coding: 368211BE250000
       VCID: 63865B026A651852A8-8036
    Address 09: Cent. Elect. (J519)       Labels:. User\4H0-907-063-V2.clb
       Part No SW: 4H0 907 063 DG    HW: 4H0 907 063 AG
       Revision: 14020001    Serial number: 00001172356502
       Coding: 0105001440349FE2C9014084A0001800CF9CC7082E08020180000894E101170200400009090000
       VCID: 70AC244EA393B3CA25-8024
       Component: WWS57X 150827  H38 0080
       Serial number:         150920100926
       Coding: 0045F7
       Serial number: 20788606
       Coding: 02006D
       Serial number: 22 10 2015  00000323
       Subsystem 4 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0300
       Serial number: WA121418000014967796
       Coding: 020300
       Subsystem 5 - Part No SW: 4H0 907 658     HW: 4H0 907 658
       Serial number: 1B1840D7000000000001
    Address 10: Park/Steer Assist (J791)       Labels:| 4H0-919-475-7X5.clb
       Part No SW: 4G0 919 475 H    HW: 4H0 919 475 E
       Component: PARKHILFE PLA H06 0080
       Revision: --------    Serial number: 56261528901101
       Coding: B82B16
       ASAM Dataset: EV_EPHVA2CAU64X0000 001014
       ROD: EV_EPHVA2CAU64X0000.rod
       VCID: 3620D2568977DDFA3F-8062
       Part No SW: 4G0 907 561 B    HW: 4G0 907 561
       Component: ACC3          H21 0053
       Coding: 7E04010202
       ASAM Dataset: EV_AdaptCruisContrAU57X 002014
       ROD: EV_AdaptCruisContrAU57X_002.rod
       VCID: 291A092A48C98202A2-807C
       Revision: --------    Serial number: 003P1006XR7G
       Coding: 30333130313730323539554A304C34473053
       VCID: 3B36C362B2550092C0-806E
       Serial number: 3575HRB40553LHKE2PM+
       Serial number: 3585HRB405J3LHKEC1K/
       Serial number: 3515JRB405P3JK6278SQ
       Serial number: 3525JRB405R3K164HG9C
       Serial number: 3554VRB4008553H0D15I
       Serial number: 3564VRB4006553H4CPRN
       Revision: --------    Serial number: 90372OJQ00077
       Coding: 0004FD
       VCID: 383CDC6E8B632B8A2D-806C
       Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
       Component: E221 - MFL  H08 0009
       Serial number: 29 06 2011  11148824
       Part No SW: 4G8 920 934 H    HW: 4G8 920 934 H
       Component: TDieRdwAcc    H11 0104
       Revision: 07001088    Serial number: 658131015596041
       Coding: 038612001F550008080000
       ASAM Dataset: EV_RBD4K 004055
       ROD: EV_RBD4K.rod
       Part No SW: 4G8 907 468 F    HW: 4G8 907 468
       Component: J533--Gateway H14 0083
       Revision: --------    Serial number: 00000002019450
       Coding: C0CD078118
       ASAM Dataset: EV_GatewPkoUDS 001028
       Serial number: 4304577903
       Voltage stabilizer:
       Serial number: 15072900000000000376
       Part No SW: 4G0 919 158 K    HW: 4G0 919 158 K
       Component: KLIMA FOND    H07 X299
       Serial number: 17051300040785
       Coding: 20
       ASAM Dataset: EV_ClimaContrUnitRearUDS 004002
       VCID: 373EDF528E7D24F224-8062
       Part No SW: 4G0 907 553 G    HW: 4G0 907 553 F
       Component: LUFE-DAEMPFER H19 0783
       Coding: 008002
       ASAM Dataset: EV_AirSuspe 003025
       ROD: EV_AirSuspe_VW51.rod
       VCID: 2F2EE732762DEC327C-807A
       Component: MEM-FS        H04 0154
       Revision: AA000000    Serial number: 00000016110514
       Coding: C0183B0085016201010001010101112030303333203333
       Revision: --------    Serial number: EJ1BPA820ADWCS
       ROD: EV_SARA2.rod
       Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
       Component: SWA Master    H07 0060
       Serial number: 0383839204
       Coding: 040311
       VCID: 393AD96AB8693282D2-806C
       Lane Change Assistant 2:
       Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
       Component: SWA Slave  H07 0060
       Serial number: 0384004426
       Coding: 040311
       Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
       Component: TSG FA        H04 0511
       Coding: 011F17015E00628002080013
       VCID: 45C2A59ACC914662A6-8010
       Component: RCevo         H53 0202
       Revision: 00000002    Serial number: 0000308997
       Coding: 101101010001
       ASAM Dataset: EV_RCEPS 106007
       ROD: EV_RCEPS_106.rod
       VCID: 3A38C666BD6F399ADB-806E
       Revision: 00002001    Serial number: 0382776124
       Coding: 01000E3820B93081C32009840C030F4F0000000000000000000000000000
       Subsystem 1 - Part No SW: 4G0 947 135 B    HW: 4G0 947 135
       Serial number: 0000000AP00016043045
       Subsystem 2 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
       Serial number: 93656352
       Coding: 011F17015E00628002080002
       VCID: 46C0A296F1974D7AAF-8012
       Revision: --------    Serial number: 00000001621928
       VCID: 2D12FD3A7C219E224E-8078
       Coding: 04FA02202A170200
       VCID: 3424E85E9F0BCFEA01-8060
       Coding: E01F00
       Coding: E01F00
       Matrix Headlamp Powermodule 1 Left:
       Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
       Component: MxB LeiMo li.  H03 0031
       Coding: E01F00
       Matrix Headlamp Powermodule 1 Right:
       Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
       Component: MxB LeiMo re.  H03 0031
       Coding: E01F00
       Part No SW: 4G1 035 044 H    HW: 4G1 035 044
       Component: MU-H-LN-EU    042 0924
       Serial number: A589J0F7540746
       Coding: 01750201FF0A000013110001000A00102F0006E5F17001009F
       Shop #: WSC 41834 002 1048576
       VCID: 2404181E2FEB5F6A91-8070
       Subsystem 1 - Part No SW: V03 959 801 PR    HW: -----------
       Component: ECE 2018  --- 0166
       Serial number: AUZ8Z9FY8037VG
       Serial number: 90349OJD0000G
       VCID: 49DAA9AAE089A20242-801C
       Part No SW: 4H0 907 428 E    HW: 7P6 907 441 G
       Component: TopView       H08 0361
       Revision: 11001001    Serial number: 82330JG0121226
       Coding: 0213000001010000000102000000
       ASAM Dataset: EV_CamerSysteTopViewAUDI 008028
       ROD: EV_CamerSysteTopViewAUDI_008_AU57.rod
       Component: HDSG-Modul    H05 0151
       Revision: 14005001    Serial number: 280501070
       Coding: 093205C030
       Coding: FA160000
       VCID: 2C14F03E473B972A59-8078
       Serial number: 00002607222501
       Coding: 766FF0
       Shop #: WSC 06745 128 28888
       ROD: EV_IVBDriveSideFrnt.rod
       Serial number: 00002607253001
       Coding: 366FF0
       Part No SW: 4G0 907 541 B    HW: 4G0 907 541
       Coding: 7E04010202
       ASAM Dataset: EV_AdaptCruisContr2AU57X 002012
       ROD: EV_AdaptCruisContr2AU57X_002.rod
       VCID: 271E0F125EDDB472B4-8072
       Part No SW: 4H0 907 107 H    HW: 4H0 907 107
       Component: BV-SG         H33 0090
       Serial number: 005000622610157
       Coding: 04C0BB181111
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
       Component: RGS-VL        H14 0080
       Coding: 0066E608031F0376070308014240C2010000
       ROD: EV_RGS_L.rod
       VCID: 312AE14A6019FAC26A-8064
       Component: RGS-VR        H14 0080
       ROD: EV_RGS_R.rod
       VCID: 3228EE46651FC1DA13-8066
       Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
       Component: SCR-Stg-G2    H10 0013
       Revision: 00000000    Serial number: 152741199
  12. Likes Uwe liked this post
  13. #9
    Feb 2016
    Czech Republic
    Do you also have Image unit for Facelifted Car ?
    4H0907107H ? Or you used from prefacelift car ?
    So you have also MIB 2 (if i understand, it is not clear)
    If yes, i can download from my car adaptation channels
  14. #10
    Jul 2019
    Trondheim, Norway
    I have facelift H image proc, and yes, i do have the mib2 high mmi
    I’m going to attack this problem again on sunday.
    And yes, adaptations would help
