- Jul 17, 2019
- 15
- 19
- Trondheim, Norway
- C?ID=369124
Hi, i have been trying to fix this problem for the last 8 months.
For starters, my car does not have the front window camera or the imageprocessor from the factory
No ACC or matrix led lights.
I have retrofitted the new front windscreen with the camera (85)
I have modified the flexray cables so the go trought the imageproc (8E) (abs and all other stuff working)
I have changed the sensor electronic (3B) from index H to K
I suspect there is some codeing issues in the gateway that do not like the imageproc (8E)
Any ideas?
Regards Rizzio
Any ideas?
Sunday,25,August,2019,14:02:38:62878
VCDS Version: 19.6.1.0 (x64) HEX-NET CB: 0.4508.4
VIN: WAUZZZ4G5FN064973 License Plate:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 28 36 3B 42 44 46 52 53 5F 62
69 6C 6D 72 82 85 8E 8F 90 AC
VIN: WAUZZZ4G5FN064973 Mileage: 96264km-59815miles
17-Instruments -- Status: Malfunction 0110
82-Heads Up Display -- Status: Malfunction 0010
8E-Image Processing -- Status: Cannot be reached 0100
Address 01: Engine (J623-CRTE) Labels: Redir Fail!
Part No SW: 4G2 907 311 C HW: 4G2 907 401
Component: 3.0TDI EDC17 H33 0007
Revision: 92H33---
Coding: 12254012053601030000
Shop #: WSC 28389 002 1048576
ASAM Dataset: EV_ECM30TDI0114G2907311C 001007
ROD: EV_ECM30TDI0114G2907311C.rod
VCID: 2502E37C24149867CA-8070
Part No SW: 4G0 927 166 A HW: 0B5 927 156 K
Component: 0B5 30 TDIRdW H03 0009
Revision: --H03---
Coding: 100001
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_TCMDL501021 001021
ROD: EV_TCMDL501021.rod
VCID: 2B16154442F0AE171C-807E
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 Q HW: 4G0 907 379 Q
Component: ESP9 Premium H01 0420
Coding: 17A69E41E8657982BB00
ASAM Dataset: EV_ESP9BOSCHAU57X 003019
ROD: EV_ESP9BOSCHAU57X_003.rod
VCID: 3FCE5114A68822B7A0-806A
Part No SW: 4H0 907 064 FN HW: 4H0 907 064 EN
Component: BCM2 2.0 H36 0560
Coding: 01A9700E000000000000
VCID: 7AB8E000F52AC79FD7-802E
Part No SW: 4G0 820 043 CD HW: 4G0 820 043 CD
Serial number: 30011500041629
Coding: 360211B8210000
VCID: 6386BD646AA02657E4-8036
0276 - Engine Off Timer Performance
P150A 00 [008] - -
Reset counter: 91
Mileage: 96264 km
Date: 2019.08.24
Time: 14:55:09
Voltage terminal 30: 11.93 V
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
Part No SW: 4H0 907 063 DH HW: 4H0 907 063 AH
Component: BCM1 2.0 H20 0311
Revision: 15020001 Serial number: 00001002845902
Coding: 2600001500349FE08181408380001D0CCF9CE60826090201000008206101150200400024030000
VCID: 71AAC72CA85C84C766-8024
Component: WWS57X 150124 H37 0080
Serial number: 150130081946
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 23704895
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 BG HW: 4G0 941 531 BG
Component: E1 - LDS H07 0044
Serial number: 28 02 2014 00001000
Serial number: DBD80197000000000001
Part No SW: 4H0 959 655 H HW: 4H0 959 655 H
Component: Airbag10.43 H82 0086
Revision: -------- Serial number: 003P10033D6B
Coding: 30333130313730323736554A304C34473053
VCID: 3B362504B2903E978C-806E
Serial number: 3575HRB405P33HNGA0R-
Serial number: 3585HRB405D33RVK81T5
Serial number: 3515JRB4016533VUN1QW
Serial number: 3525JRB4006534EADOSB
Serial number: 3554VRB400S52RDAI1CY
Serial number: 3564VRB401052RDAO269
Part No SW: 4H0 953 568 K HW: 4H0 953 568 K
Component: Lenks.Modul H06 0005
Revision: C0068538 Serial number: 90862OB500081
Coding: 000015
VCID: 3B362504BA903E978C-806E
Subsystem 1 - Part No SW: 4G0 951 528 C HW: 4G0 951 528 C
Serial number: 17 12 2014 E0064336
Part No SW: 4G8 920 933 Q HW: 4G8 920 933 Q
Component: TDieRdw H07 0043
Revision: 03001036 Serial number: 658050215596016
Coding: 03AF12000B410008020000
ASAM Dataset: EV_RBD4K 004048
ROD: EV_RBD4K_AU57.rod
VCID: 3E302C10A1822BBFAB-806A
16776969 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[LDW_02_FR keine Kommunikation]
Reset counter: 91
Mileage: 96264 km
Date: 2019.08.25
Time: 13:57:29
16776980 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[VZE_01 keine Kommunikation]
Reset counter: 91
Mileage: 96264 km
Date: 2019.08.25
Time: 13:57:29
Part No SW: 4G8 907 468 HW: 4G8 907 468
Component: J533--Gateway H13 0075
Revision: -------- Serial number: 00000001719911
Coding: C0CD078118
ASAM Dataset: EV_GatewPkoUDS 001024
VCID: 75A2F33CD434A8E7BA-8020
Serial number: 3565135603
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663 F
Component: J532_DCDCStab H23 0022
Serial number: 14112700000000000490
6653 - Image processing control module
U1079 00 [009] - No communication
Reset counter: 51
Mileage: 96264 km
Date: 2019.08.25
Time: 13:50:19
Voltage terminal 30: 13.7 V
Voltage terminal 15: 13.7 V
Control Module temperature: 24 °C
System status: Terminal 15 on
Engine running: On
IN ZAS_Te_X: On
Terminal 15 status: On
Datenfeld: 0
Part No SW: 4G0 919 158 R HW: 4G0 919 158 R
Component: KLIMA FOND H08 0112
Serial number: 04021500040558
Coding: 20
Part No SW: 4G8 959 760 HW: 4G8 959 760
Component: MEM-FS H03 0157
Revision: AA000000 Serial number: 00000134103691
Coding: 0058130000006001000001010101102030303232203232
VCID: 77BEF934C638DAF7A8-8022
Component: SARA 6D H04 0056
Revision: -------- Serial number: EJ1BPA820BD7D5
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 3620343089B2E3FF73-8062
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0507
Coding: 011F17014E00628002080002
VCID: 47DE49F4F6586A7718-8012
Part No SW: 4G0 909 144 M HW: 4G0 909 144 G
Component: RCEPS H41 0011
Revision: 00001000 Serial number: 0008397702
Coding: 101000010001
ASAM Dataset: EV_RCEPS 009010
ROD: EV_RCEPS_009.rod
VCID: 33260D249AC0F6D754-8066
Revision: 00002001 Serial number: 0359813205
Coding: 0100063820B930008320090028010F470000000000000000000000000000
Component: TSG BF H03 0507
VCID: 46C044F0F152737FE3-8012
Part No SW: 4H0 907 801 H HW: 4H0 907 801 A
Component: EPB-4 H04 0015
Revision: -------- Serial number: 00000001356261
ROD: EV_ParkiBrake_VW51.rod
VCID: 2D121B5C7CE4A02702-8078
Address 5F: Information Electr. (J794) Labels:* 4G1-035-MIB-HGH2.clb
Part No SW: 4G1 035 044 D HW: 4G1 035 044
Component: MU-H-LN-EU 041 0389
Serial number: A589B0F7507774
Coding: 01750201FF0A000013110001000A00132F0006E5F1700100DF
VCID: 200CF2683B367D4FB9-8074
Subsystem 1 - Part No SW: V03 959 801 FD HW: -----------
Component: ECE 2017/2018 --- 0161
Subsystem 2 - Part No SW: 4G1 919 605 A HW: 4G1 919 605 A
Component: DU8 C7 SV H63 0007
Serial number: AUZ8Z9FY8013QG
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 4G1 919 610 F HW: 4G1 919 610 F
Component: E380 BDT C7 H20 0250
Serial number: 90349OB2000V5
Component: Gracenote2 --- 1012
6733 - Control Head Module; Rear Right
U12B0 00 [009] - No Communication
[Smart display carrier 1: no signal/communication]
Reset counter: 51
Mileage: 96264 km
Date: 2019.08.24
Time: 16:01:49
Voltage terminal 30: 12.1 V
7193 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Lane departure warning: heading control (0x19) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 51
Mileage: 96264 km
Date: 2019.08.24
Time: 16:01:52
BAP-BAP_Function_ID: 02
7201 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Road sign display (0x21) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 51
Mileage: 96264 km
Date: 2019.08.24
Time: 16:01:55
Component: TSG HL H03 0507
Coding: 010F15004000628002080002
VCID: 49DA4FCCE04C9C070E-801C
Address 69: Trailer (J345) Labels:| 4H0-907-383-V2.clb
Part No SW: 4G8 907 383 B HW: 4G8 907 383 B
Component: Anhaenger H14 0137
Revision: 7B001001 Serial number: 0359195306
Coding: 0100000202000000
Address 6C: Back-up Cam. (J772) Labels:| 4S0-980-556.clb
Part No SW: 4S0 980 556 A HW: 5Q0 980 556 B
Component: RVC Compact H12 0201
Coding: 0275000103002007000040
Shop #: WSC 17873 123 50804
ASAM Dataset: EV_CamSysRVRVCPANAAU57X 002003
ROD: EV_CamSysRVRVCPANAAU57X_002_AU57.rod
VCID: 393A3F0CB8AC0C879E-806C
10489856 - No Basic Setting
B2010 00 [009] - -
[RearView system not calibrated]
Reset counter: 51
Mileage: 96264 km
Date: 2019.08.25
Time: 13:49:43
passive
Part No SW: 4G9 959 107 C HW: 4G9 959 107 B
Component: HDSG-Modul H05 0150
Revision: 14005001 Serial number: 022501421
Coding: 093205C011
ROD: EV_HDSGAu571.rod
Component: TSG HR H03 0507
Address 82: Heads Up Display (J898) Labels:| 4G0-919-604.clb
Part No SW: 4G0 919 604 M HW: 4G0 919 604 M
Component: HeadUpDisplay H07 0304
Coding: AF0000
ASAM Dataset: EV_HUDContiC7 001025
ROD: EV_HUDContiC7.rod
VCID: 3522333C94B4E8E77A-8060
16776965 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 51
Mileage: 96264 km
Date: 2019.08.24
Time: 16:25:28
16776970 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[VZE_01_ keine Kommunikation]
Reset counter: 51
Mileage: 96264 km
Date: 2019.08.24
Time: 16:25:28
Part No SW: 4H0 907 217 F HW: 4H0 907 217 A
Component: DPC-SG H27 0081
Coding: 72040000
ROD: EV_OnBoardCamerDPC.rod
VCID: 2C14165847FEA92F15-8078
0703 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[ESP_timeout]
Reset counter: 91
Mileage: 96264 km
Date: 2019.08.24
Time: 16:52:18
Outside air temperature: -41.5 °C
Voltage terminal 15: 11.6 V
Control Module temperature: 50.0 °C
0722 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[LWS_Timeout]
Reset counter: 91
Mileage: 96264 km
Date: 2019.08.24
Time: 16:52:18
0728 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[SARA_timeout]
Reset counter: 91
Mileage: 96264 km
Date: 2019.08.24
Time: 16:52:18
0733 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[BCM2_Timeout]
Reset counter: 91
Mileage: 96264 km
Date: 2019.08.24
Time: 16:52:18
0715 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Gateway_timeout]
Reset counter: 91
Mileage: 96264 km
Date: 2019.08.24
Time: 16:52:18
0701 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Motor_timeout]
Reset counter: 91
Mileage: 96264 km
Date: 2019.08.24
Time: 16:52:18
Address 8E: Image Processing
Component: RGS-VL H13 0080
Coding: 00060000031F030000030801424CDA010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 312A072C60DCC4C726-8064
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 3228082065DAFFDF5F-8066
Part No SW: 4H0 907 355 D HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0012
Revision: 00000000 Serial number: 150090361
ROD: EV_RDCMA00100_008.rod
End----------(Elapsed Time: 01:49, VBatt start/end: 12.4V/12.4V)-----------
Regards Rizzio
