I've just bought a TT with some electrical issues. I'd be grateful for any advice which could help me narrow it down to which modules/wiring are causing issues.
The car has the following problems:
I think that's everything!
Any pointers very gratefully received.
Scans below:
Scan 1:
Scan 2:
- It was sold to me running fine until a hot start, then it wouldn't start until it had cooled down (no orange lights, engine turns over fine, just doesn't fire). Now it's hard to start, only runs for a little while and the EPC light is on.
- I ran a diagnostic this morning (first scan) and engine temperature/RPM readings looked fine. I cleared error codes. Then a while later the engine died at around 90degC. Would not re-start.
- Re-scanning, the Engine module had disappeared (see second scan).
- Keyfobs don't work, Lock button in car works, unlock doesn't. This morning after pressing the lock button, the EPC light started flashing and there were clicks from under the dashboard in time with the flashing. This seems to tie in with the time the car started to lose the Engine module.
- Fuel flap and boot work fine, windows don't drop on opening doors. Roof doesn't work, air break doesn't work but clicks once in one direction.
- Rear window fell in a few weeks ago in hot weather. I guess it's possible the CCM got wet?
- Clicking from diff with ignition on (this ties in with the Haldex data bus issue).
- Stability light comes on intermittently while driving.
Scans below:
Scan 1:
Sunday,25,August,2019,10:43:45:31354
VCDS Version: 19.6.1.0 (x64) HEX-NET CB: 0.4508.4
VIN: License Plate: TT SCAN 1
Chassis Type: XX (8N - Audi TT (1999 > 2007))
Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
VIN: XXXXXXXXXXXXXXXXX
Address 01: Engine Labels: 06A-906-032-APX.clb
Part No: 8L0 906 018 M
Component: 1.8L R4/5VT 0002
Coding: 05710
Shop #: WSC 06435
VCID: 393AD2442123E8879E-5118
17834 - EVAP Purge Valve (N80)
P1426 - 35-00 - Open Circuit
17931 - Crash Signal from Airbag Controller
P1523 - 35-00 - Implausible Signal
16885 - Vehicle Speed Sensor
P0501 - 35-10 - Implausible Signal - Intermittent
Address 03: ABS Brakes Labels: 8N0-907-379-MK20-E.clb
Part No: 8N0 907 379 E
Component: ESP 20 CAN V005
Coding: 18446
Shop #: WSC 06435
VCID: 3E30C158380DCFBFAB-4AE0
49-00 - No Communications
Address 08: Auto HVAC Labels: 8N0-820-043.lbl
Part No: 8N0 820 043 A
Component: TT-KLIMAVOLLAUTOMAT D03
Coding: 00041
Shop #: WSC 06435
VCID: 281C0700CA89610FF1-2580
00792 - A/C Pressure Switch (F129)
Address 15: Airbags Labels: 8N8-909-601.lbl
Part No: 8N8 909 601
Component: Airbag Front+Seite 1005
Coding: 10102
Shop #: WSC 06435
VCID: 77BE147C57B73EF7A8-5118
Address 17: Instruments Labels: 8Nx-920-xxx-17.lbl
Part No: 8N2 920 930 C
Component: KOMBI+WEGFAHRS. M73 D55
Coding: 06444
Shop #: WSC 00469
VCID: 3228E568FC551BDF5F-4AE0
XXXXXXXXXXXXXXXXX AUZ5Z0C6116070
Address 22: AWD Labels: 02D-900-554.lbl
Part No: 02D 900 554 B
Component: HALDEX LSC ECC 0006
VCID: 1F0E1CDC9FC7A6B780-4AE0
01312 - Powertrain Data Bus
37-00 - Faulty
Address 35: Centr. Locks Labels:. 8Nx-962-267.lbl
Part No: 8N7 962 267 B
Component: Central Lock D04
Coding: 04816
Shop #: WSC 06314
VCID: 3FCEBC5C3F07C6B7A0-4EEA
01366 - Opened Due to Crash Signal
35-00 - -
00955 - Key 1
09-10 - Adaptation Limit Surpassed - Intermittent
01559 - Drivers Door
61-00 - Won't De-Safe
01134 - Alarm Horn (H12)
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8N7 951 177
Component: Innenraumueberw. D13
Coding: 00001
VCID: 7BB6084C6B9F1A97CC-5160
Address 55: Headlight Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D003
Coding: 00010
Shop #: WSC 06435
VCID: 65824E34FD1BBC670A-51CE
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 4B0 035 186
Component: Radio 0001
Coding: 00207
Shop #: WSC 02324
VCID: 5DF266D4D54BF4A7D2-4AE0
00852 - Loudspeaker(s); Front
36-00 - Open Circuit
End----------(Elapsed Time: 02:33, VBatt start/end: 13.7V/13.6V)-----------
Coding: 05710
Shop #: WSC 06435
Coding: 18446
Shop #: WSC 06435
Coding: 00041
Shop #: WSC 06435
Coding: 10102
Shop #: WSC 06435
Coding: 06444
Shop #: WSC 00469
37-00 - Faulty
Coding: 04816
Shop #: WSC 06314
35-00 - -
00955 - Key 1
59-00 - Can't Unlock
Coding: 00001
Coding: 00010
Shop #: WSC 06435
VCID: 65824E34FD1BBC670A-51A8
Coding: 00207
Shop #: WSC 02324
End----------(Elapsed Time: 02:33, VBatt start/end: 12.3V/12.3V)-----------
Scan 2:
Sunday,25,August,2019,12:34:16:31354
VIN: License Plate: TT SCAN 2
Coding: 18446
Shop #: WSC 06435
Coding: 00041
Shop #: WSC 06435
Coding: 10102
Shop #: WSC 06435
Coding: 06444
Shop #: WSC 00469
VCID: 3228E568FC551BDF5F-4B00
VCID: 1F0E1CDC9FC7A6B780-4B00
37-00 - Faulty
Coding: 04816
Shop #: WSC 06314
VCID: 3FCEBC5C3F07C6B7A0-4EC8
35-00 - -
00955 - Key 1
Coding: 00001
Coding: 00010
Shop #: WSC 06435
Coding: 00207
Shop #: WSC 02324
End----------(Elapsed Time: 02:36, VBatt start/end: 12.4V/12.4V)-----------
