Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Mk7 golf trunk / remote issues
    Aug 2019
    Dublin, Ireland
    Hi guys , I’m wondering can anyone help us.
    We’ve just bought 2015 vw golf mk7 R.
    The previous owner has done some coding / changes to the car and isn’t sure what he did exactly or where to start?
    He changed the operation of how the boot lid works so for example ( car has kessy)
    If I walk up to car and hit open on the remote the boot remains locked and won’t open, if I then hit lock on the remote i can walk up and the boot will open.
    Also on the first start in the morning if I walk up to the car and hit the boot open button on the key fob the boot releases but actually sets off the factory alarm.
    It’s a very confusing issue I’ve gone through the menus on the infotainment and nothing changed this operation.
    I would be ever so grateful if anyone could shed some light on this issue.
    I will include in a full vehicle scan below.
    [Back]
    Wednesday,21,August,2019,12:50:51:11308
    VCDS Version: 19.6.1.0 (x64)
    VIN: WVWZZZAUZFW239900   License Plate: 2015 golf R
    Mileage: 69224km-43013mi   Repair Order:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 20 22 2B 42 44 47 52
              55 5F A9
    VIN: WVWZZZAUZFW239900   Mileage: 69224km-43013miles
    VIN: WVWZZZAUZFW239900   License Plate: 151DDAVE
              55 5F A9
    A9-Struct. Borne Sound -- Status: Not registered 0001
    Address 01: Engine (J623-CJXC)       Labels:. 06K-907-425-V1.clb
       Part No SW: 5G0 906 259 E    HW: 06K 907 425 B
       Component: 2.0l R4 TFSI  H13 0005
       Revision: --H13---
       Coding: 091D00322466050B3004
       ASAM Dataset: EV_ECM20TFS0205G0906259E 001005
       ROD: EV_ECM20TFS0205G0906259E.rod
       VCID: 3065E5826B0F7FCF29-8064
    15072 - Engine Start Blocked by Immobilizer
              P1570 00 [104] - -
                        Mileage: 69089 km
                        Date: 2019.08.19
                        Time: 19:40:55
                        Engine speed: 1320.50 /min
                        Normed load value: 5.9 %
                        Coolant temperature: 91 °C
                        Intake air temperature: 58 °C
                        Voltage terminal 30: 12.089 V
                        FRF_IMMO_SNAPSHOT_BYTE1: 25
                        FRF_IMMO_SNAPSHOT_BYTE2: 127
                        FRF_IMMO_SNAPSHOT_BYTE3: 140
                        FRF_IMMO_SNAPSHOT_BYTE4: 27
                        FRF_IMMO_SNAPSHOT_BYTE5: 16
                        FRF_IMMO_SNAPSHOT_BYTE6: 0
                        Engine: operating status: IS
    Readiness: 0010 0001
       Part No SW: 0D9 300 012 L    HW: 02E 927 770 AQ
       Component: DQ250-6A MQB  H53 4522
       Revision: 03253104    Serial number: TFK01501121573
       ROD: EV_TCMDQ250021.rod
       VCID: 1F47163E0691F0B780-804A
       Part No SW: 3Q0 907 379 R    HW: 3Q0 907 379 G
       Component: ESC           H42 0711
       Revision: 00000000    Serial number: 60165000001724
       Coding: 01FA93A1542329750780070041C36980C92A94E0E08296F7184250F8C208
       VCID: 4993A866E8952E070E-801C
       Revision: 00021000    Serial number: 0357554449
       Coding: 030C0C
       VCID: 3A71C7AABD73B59F97-806E
       Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
       Revision: 00001K08
       Coding: 00120014200100011005000000101000
       VCID: 6AD137EA8D53C51F27-803E
       Component: BCM MQBAB H   H18 0137
       Serial number: 01011501900387
       Coding: 03111B46C64122F30BA44080B10407281800000000000000000000000000
       ROD: EV_BCMBOSCH_013.rod
       VCID: 000575429B2F2F4F99-8054
       Component: WWS    150103  042 0551
       Serial number:         150108205225
       Component: RLHS  037 0059
       Serial number: S4Y15M01D21H22M40S18
       Coding: 00A8DD
       Serial number: 000000000ZY1500704XA
       Serial number: 00000000000031523620
       Sun Roof:
       Component: J245 PS73.403  H02 0003
       Serial number: 0000FST0002MHGL00000
       Coding: 181801
    197644 - Control Circuit for Fuel Tank Flap
              B1263 01 [008] - Electrical Failure
                        Fault Frequency: 45
                        Reset counter: 89
                        Mileage: 69089 km
                        Date: 2019.08.19
                        Time: 19:31:03
       Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0048
       Revision: --------    Serial number: 39391501405271
       Coding: 0071151011
       VCID: 3D7BCCB6AC5D82A7B2-8068
       Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
       Component: ACC Bosch MQB H05 0304
       Serial number: 17121403271532
       Coding: 001C1300FE0739
       VCID: 3875DDA2837FA78F61-806C
       Part No SW: 5Q0 907 376     HW: 5Q0 907 376
       Component: DAEMPFUNGS-SG H16 0115
       Serial number: 20121441350052
       ROD: EV_DRCONTITEMIC_VW37.rod
       VCID: 76E9139AC9EB11FFB3-8022
       Component: AirbagVW20    014 0385
       Serial number: 003F6R0F6YFZ
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 4183B046D0A5E647D6-8014
       Subsystem 1 - Part No SW: -----------    HW: 480 001 601 15
       Serial number: 35767000000D8AF09210
       Subsystem 2 - Part No SW: -----------    HW: 480 001 501 15
       Serial number: 3586700000027D29B21X
       Subsystem 3 - Part No SW: -----------    HW: 480 401 401 15
       Serial number: 35165029B1901DA44356
       Subsystem 4 - Part No SW: -----------    HW: 480 401 401 15
       Serial number: 3526502A9196FF40912I
       Subsystem 5 - Part No SW: -----------    HW: 480 401 501 15
       Serial number: 3556502C319121A483E8
    Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
       Part No SW: 5Q0 953 507 EC    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 15011504401108
       Coding: 0C10
       ROD: EV_SMLSKLOMQB_010_VW37.rod
       VCID: 7BFF02AEF2C94C97CC-802E
    No ASAM data for: "EV_SMLSKLOMQB" (VW37)
       Part No SW: 5G1 920 758     HW: 5G1 920 758
       Component: KOMBI         304 4310
       Coding: 27AD08183F80040800887E011400000000000000
       VCID: 6CDD31F287A7DB2F55-8038
    9456128 - Engine Control Module (ECM) not authorized
              B104A 00 [009] - -
                        Fault Frequency: 17
                        Mileage: 69089 km
                        Date: 2019.08.19
                        Time: 19:40:54
       Part No SW: 5Q0 907 530 AC    HW: 5Q0 907 530 F
       Component: GW MQB High   128 1204
       Revision: --------    Serial number: 0002965523
       Coding: 030100042F085900EF00027A9C0F00010001050000000000000000000000
       ASAM Dataset: EV_GatewLear 011020
       ROD: EV_GatewLear_011.rod
       VCID: 72E12F8AA5830DDF9F-8026
       Component: E221__MFL-DC1  H10 0038
       Serial number: 36150000025040075025
       Coding: 2DFFFF
       Serial number: 5565015503
    66304 - Databus
              U1124 00 [009] - Additional Installations Detected
                        Fault Frequency: 62
                        Reset counter: 49
                        Mileage: 69084 km
                        Date: 2019.08.19
                        Time: 19:16:12
                        Terminal 15: On
    Address 20: High Beam Assist. (J844)       Labels:| 8X0-857-511.clb
       Part No SW: 5G0 857 511 D    HW: 5G0 857 511 D
       Component: FLA           H05 0002
       Revision: AA001001
       Coding: 02028864727264565625393E01
       VCID: 2B5FF2EE42291C171C-807E
       Serial number: HA1-00017.11.14
       Coding: 0001
       VCID: 4689A35AF98BC17FE3-8012
       Revision: 00000000    Serial number: 15000010357001
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 346DE9929F1743EF4D-8060
       Part No SW: 5Q0 959 593 D    HW: 5Q0 959 593 B
       Serial number: 150115BA612242
       Coding: 003F1220D001040000001000
       VCID: 4281BF4AD5A3FD5FCF-8016
       Serial number: 00000000000005016677
       Coding: 0D0000
              B1487 54 [008] - Missing Calibration / Basic Setting
                        Reset counter: 87
                        Mileage: 69167 km
                        Date: 2019.08.20
                        Time: 14:16:40
       Coding: 8103
       VCID: 3777DE9E8E61A8F768-8062
    Address 47: Sound System (J525)       Labels:| 5G0-035-456.clb
       Part No SW: 5G0 035 456     HW: 5G0 035 456
       Component: MIB_lite_amp  H40 0060
       Serial number: VWZ8Z1EC40244W%
       Coding: 120000008AAA8A0000
       ASAM Dataset: EV_AMPMst11CALPI 001007
       ROD: EV_AMPMst11CALPI.rod
       VCID: 63CF5ACE6A799457E4-8036
       Part No SW: 5Q0 959 592 D    HW: 5Q0 959 592 B
       Serial number: 120115BAC07127
       Coding: 003F1020DE01040000801000
       Serial number: 00000000000004937392
       Coding: 150000
       Coding: 02A602000B010200
       VCID: 4085B542DBAFEF4FD9-8014
       Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
       Coding: 2E0000
       Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
       Coding: 2E0000
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH1.clb
       Part No SW: 5G0 035 043 E    HW: 5G0 035 043 D
       Component: MU-H-N-EU     H44 0376
       Serial number: A309A0F7521764
       Coding: 027300010000000011110002000800001F0207F60100010057
       ASAM Dataset: EV_MUHig4CHBAS 001040
       ROD: EV_MUHig4CHBAS_VW37.rod
       VCID: 204515C23BEFCF4FB9-8074
       Component: ABT_High  H62 0031
       Serial number: VWZ8Z9PU300AUZ
       Subsystem 2 - Part No SW: V03 959 801 DG    HW: -----------
       Component: ECE 2016/2017  --- 0153
       Component: Gracenote  --- 1010
       Part No SW: 5G0 907 159 B    HW: 4H0 907 159 A
       Component: SAS-GEN 2     H07 0006
       Serial number: 141121201809
       VCID: 2D5BFCF67C3D122702-8078
    End-------------------------(Elapsed Time: 05:56)--------------------------
    ^^^^ hmm............. has the ECU on this car been tuned - Immobilizer problem?
    Aug 2019
    Dublin, Ireland
    Yes the car has a system called Autowatch ghost it’s a immobiliser so if car is attempted to start with out entering the code you’ll get a message in cluster saying “immobiliser active “ which logs a fault also.
    Problem with boot was there before ghost was installed.
    Aug 2019
    Dublin, Ireland
    Anyone any suggestions I could even try .. completely lost at this stage .. please
    shane: scratching my head - not much hair there to scratch!!!
    The inclusion of Autowatch seems suspicious to me - but I must accept your assurance that the fault preceded the immobilizer issue. The fuel flap error could be implicated in the way the alarm is responding - how does this DTC manifest in the way the flap operates (or. doesn't operate)?
    But the most intriguing aspect of your post must Shirley be the changed behavior of the boot lid at "first start in the morning". This might indicate (and I emphasize "might") that the way that the offending module(s) wakes-up after sleeping (a very apt description for "morning start") is a consideration. Again wild conjecture - but perhaps leave the car unattended for a long period of time during the day- does the morning-start dynamic repeat?
    Finally - here's my cut-down version of the WD for the rear-lid-lock-unit on a mk7
    The pin-out descriptors for the connections on the BCM are as follows
    • Socket A/pin 9 Rear lid central locking motor -V53-
    • Socket A/pin 53 Terminal 31
    • Socket A/pin 52 Rear lid contact switch for anti-theft alarm-F123-
    Just to eliminate the possibility of a wiring/connector problem -perhaps grab a multimeter and confirm the correct operation of the pins on the boot-lid pug. Particularly pin #1 (from BCM pin A/52)- if this pin doesn't change state when the siren sounds, then arming the anti-theft unit isn't happening from this point
  6. Likes Uwe, shanefuture liked this post
    Aug 2019
    Dublin, Ireland
    Hi Don , thanks for your reply and time!
    The Autowatch system was fitted a few days after we took delivery of the car and the boot was acting funny From when we first went to look at car. (So immobiliser issue is 100% Autowatch related!)
    Funny you mention the fuel flap.
    I was back at it last night going through the adaptions in the hope something might stick out to me on a boot/ load area setting but nothing did but the fuel flap actuator is now quite noisy on opening as if the motor is giving up on the Job.
    The reason I say first thing in the morning it’s just to be fully sure the car has gone to sleep.
    These symptoms would be the same after a hour or so left sitting.
    I’m not great at reading the scans do you see something with the fuel flap and what would that indicate or suggest to you ?
    Thanks again and very much appreciate your help
    shane:
    So - here's the thing - the DC actuator that drives the fuel flap (regardless of its form) has a characteristic whereby as the load on the device increases, the electrical current in circuit will increase and the speed will then tend to decrease. For a healthy actuator circuit, the designed load and therefore the designed current will be set so as not to trip the threshold for the monitoring system. But observations like increased noise and high heat in actuator devices often signifies increased load - which tends to confirm the DTC in BCM.
    The other interesting aspect of the DTC is the "fault frequency" which suggests that the error has happened on 45 x occasions since first detected. So this is not an intermittent problem - it's a confirmed "aged error". Which all suggests that it's probably time to either repair or replace the device (I think).
  9. Likes Uwe liked this post
  10. #8
    Aug 2019
    Dublin, Ireland
    Hey Don,
    just to confirm we are talking about the faults in the petrol flap now?
    should i just replace this regardless or do you think it may also be causing the bootlid issue.
    ive a video recorded a video of the boot fault which shows the "issue" probably better than i explain.
    i don't think i can post a video here , id love to be able to show you whats happening.
    again appreciate your help.
  11. #9
    Aug 2019
    Dublin, Ireland
    and also to say the "noisy" actuator on the fuel flap I've only noticed that noise in the last few days.
    the flap itself locks/unlocks without issue so far.
  12. #10
    Aug 2019
    Dublin, Ireland
    Watch “Untitled” on Vimeo: https://vimeo.com/356679942?ref=em-share
  13. Likes Uwe liked this post
