Results 1 to 5 of 5
Thread: 13' Golf 2.5l No ECM Connection crank, no-start
    Verified VCDS User your watermelon's Avatar
    Aug 2019
    2013 Golf No ECM Communication
    car cranks but doesn't start. Has been doing it ever since a new sound system was installed. And yes I already unplugged all of it including the wiring and the actual head unit,same result. The shop put in fuses into the engine bay fuse box because apparently it was missing some. My guess is something is blocking a connection to the ECM somewhere here is the full scan.
    Friday,23,August,2019,15:05:20:27550
    VIN: WVWBB7AJ3DW130103   License Plate:
    Mileage: 161110km-100109mi   Repair Order:
    Chassis Type: AJ-VW36 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 56
    VIN: WVWBB7AJ3DW130103   Mileage: 161110km-100109miles
    Address 01: Engine
       Part No SW: 09G 927 750 LM    HW: 09G 927 750 LM
       Component: AQ 250 6F           2252
       Revision: 00H97000    Serial number:
       Coding: 0000840
       VCID: 074B9B8C932B8DDF8B3-8052
                        Fault Status: 00101101
                        Reset counter: 0
                        Mileage: 158823 km
                        Date: 2013.12.03
                        Time: 20:27:29
                        Reset counter: 190
                        Mileage: 161117 km
                        Date: 2014.01.11
                        Time: 00:00:07
                        Reset counter: 185
                        Mileage: 161117 km
                        Reset counter: 185
                        Mileage: 161117 km
    18275 - Powertrain Data Bus
                P1867 - 000 - Missing Message from Steering Wheel (J527) - Intermittent
                        Reset counter: 185
                        Mileage: 161117 km
       Revision: 00H31001
       Coding: 114B400C492500FA880C02E4921C0041B70000
       VCID: 7DA7F964CDF7D70FA1F-8028
                        Reset counter: 108
                        Mileage: 161117 km
                        Date: 2014.01.11
                        Time: 00:00:43
                        Count: 2
                        Count: 12
                        Count: 20992
                        Count: 8208
                        Count: 44032
                        Count: 1
                        Count: 255
                        Reset counter: 108
                        Mileage: 161117 km
                        Date: 2014.01.11
                        Time: 00:00:43
                        Count: 2
                        Count: 12
                        Count: 20992
                        Count: 8233
                        Count: 44032
                        Count: 1
                        Count: 255
                        Reset counter: 108
                        Mileage: 160839 km
                        Date: 2013.12.31
                        Time: 00:00:48
                        Count: 2
                        Count: 12
                        Count: 29184
                        Count: 16390
                        Count: 49664
                        Count: 254
                        Reset counter: 108
                        Mileage: 161116 km
                        Date: 2014.01.11
                        Time: 17:44:25
                        Count: 12
                        Count: 20992
                        Count: 8194
                        Count: 44800
                        Count: 1
                        Count: 255
       Part No SW: 7N0 907 426 BG    HW: 7N0 907 426 BG
       Component: AC Manuell    H20 0505
       Revision: 00001018
       Coding: 0010002002
       VCID: 7AADF278DC59E03784D-802E
    6 Faults Found:
              U1111 00 [009] - -
              [Motorsteuergerät - kein Signal/Kommunikation]
                        Fault Frequency: 82
                        Reset counter: 108
                        Mileage: 161116 km
                        Date: 2019.08.21
                        Time: 17:44:26
    13701392 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Bremsensteuergerät - kein Signal/Kommunikation]
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2019.08.21
                        Time: 00:00:06
    13701408 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Diagnoseinterface für Datenbus - kein Signal/Kommunikation]
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2019.08.21
                        Time: 00:00:42
              U1111 00 [008] - -
              [Steuergerät im Schalttafeleinsatz - kein Signal/Kommunikation]
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2019.08.21
                        Time: 00:00:42
    13701488 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Türsteuergerät Fahrerseite - kein Signal/Kommunikation]
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2019.08.21
                        Time: 23:25:39
    9481748 - High Pressure Sensor
              B10AE 14 [008] - Open or Short to Ground
                        Fault Frequency: 7
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2019.08.23
                        Time: 01:07:29
       Part No SW: 1K0 937 084 J    HW: 1K0 937 084 J
       Component: BCM PQ35  B   111 0709
       Revision: AC111709
       Coding: 6F180A1A90272A04008800C11000044448010386424D8960648020200040
       VCID: 35372144B547CF4F29F-8060
       Component: Wischer 04021  26  0512
       Coding: 009795
    24 Faults Found:
                        Fault Status: 00101010
                        Reset counter: 143
                        Mileage: 160746 km
                        Date: 2013.12.30
                        Time: 14:35:59
                        Voltage: 14.05 V
                            Term 50 Off
                        Fault Status: 00101110
                        Reset counter: 146
                        Mileage: 133390 km
                        Date: 2018.03.23
                        Time: 22:20:42
                        Voltage: 14.10 V
                            Term 50 Off
                        Reset counter: 148
                        Mileage: 159049 km
                        Date: 2013.12.06
                        Time: 11:14:35
                        Voltage: 12.10 V
                            Term 50 Off
                        Reset counter: 108
                        Mileage: 161116 km
                        Date: 2014.01.11
                        Time: 17:44:26
                        Voltage: 12.65 V
                            Term 50 Off
                        Fault Status: 01101010
                        Reset counter: 108
                        Mileage: 153141 km
                        Date: 2013.09.24
                        Time: 15:33:29
                        Voltage: 13.90 V
                            Term 50 Off
                        Reset counter: 146
                        Mileage: 153141 km
                        Date: 2013.09.24
                        Time: 17:52:17
                        Voltage: 14.10 V
                            Term 50 Off
                        Fault Frequency: 10
                        Reset counter: 148
                        Mileage: 161116 km
                        Date: 2014.01.11
                        Time: 18:03:06
                        Voltage: 12.60 V
                            Term 50 Off
                        Reset counter: 146
                        Mileage: 153141 km
                        Date: 2013.09.24
                        Time: 19:16:14
                            Term 15 Off
                        Voltage: 12.20 V
                            Term 50 Off
                        Reset counter: 148
                        Mileage: 161116 km
                        Date: 2014.01.11
                        Time: 18:03:17
                            Term 15 Off
                        Voltage: 12.65 V
                            Term 50 Off
    00927 - Terminal 30 (Right)
                        Fault Frequency: 7
                        Reset counter: 108
                        Mileage: 160979 km
                        Date: 2014.01.07
                        Time: 00:02:23
                            Term 15 Off
                        Voltage: 12.60 V
                            Term 50 Off
    02391 - Terminal 30 Reference
                        Reset counter: 108
                        Mileage: 160979 km
                        Date: 2014.01.07
                        Time: 00:21:11
                            Term 15 Off
                        Voltage: 12.70 V
                            Term 50 Off
                        Reset counter: 147
                        Mileage: 153141 km
                        Date: 2013.09.24
                        Time: 19:53:23
                        Voltage: 13.95 V
                            Term 50 Off
    00153 - Windshield Wiper Motor;  Driver Side (V216)
                        Reset counter: 148
                        Mileage: 160979 km
                        Date: 2014.01.07
                        Time: 01:26:25
                        Voltage: 12.50 V
                            Term 50 Off
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2014.01.11
                        Time: 00:00:07
                        Voltage: 12.55 V
                            Term 50 Off
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2014.01.11
                        Time: 00:00:43
                        Voltage: 12.55 V
                            Term 50 Off
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2014.01.11
                        Time: 00:02:05
                        Voltage: 12.55 V
                            Term 50 Off
    01516 - Terminal 30; Left
                        Fault Status: 00101011
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2014.01.11
                        Time: 21:26:44
                            Term 15 Off
                        Voltage: 12.60 V
                            Term 50 Off
    03266 - Control Circuit for Signal Horn
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 108
                        Mileage: 161117 km
                        Date: 2014.01.11
                        Time: 21:45:10
                            Term 15 Off
                        Voltage: 12.55 V
                            Term 50 Off
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2014.01.11
                        Time: 23:25:37
                        Voltage: 12.00 V
                            Term 50 Off
    00059 - Terminal 30 for Interior Lighting
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2014.01.12
                        Time: 02:14:49
                            Term 15 Off
                        Voltage: 12.20 V
                            Term 50 Off
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2014.01.12
                        Time: 02:15:06
                            Term 15 Off
                        Voltage: 12.20 V
                            Term 50 Off
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2014.01.12
                        Time: 02:16:28
                        Voltage: 11.95 V
                            Term 50 Off
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2014.01.13
                        Time: 01:07:30
                        Voltage: 12.30 V
                            Term 50 Off
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2014.01.13
                        Time: 01:07:31
                        Voltage: 12.35 V
                            Term 50 Off
       Part No SW: 5C0 959 655 M    HW: 5C0 959 655 M
       Component: AirbagVW10G   014 0726
       Serial number: 003L4R01K09%
       Coding: 00004737
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 3C21346096ED1E07D61-8068
       Serial number: ---0000R--00006HUQ00
       Serial number: 3572MSME2B2E5076ZZZ/
       Serial number: 3582MSME48325376ZZZW
       Serial number: 3512QSME5E1C2B35ZZZ1
       Serial number: 3522QSME74572B48ZZZ/
       Serial number: 35527SME2F66272FZZZV
       Serial number: 35627SME3946272FZZZP
              U0155 00 [008] - -
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2019.08.21
                        Time: 00:00:42
    12656896 - No Communication with ABS Brake Control Module
              U0121 00 [008] - -
              [Lost Communication With Vehicle Dynamics Control Module]
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2019.08.21
                        Time: 00:00:06
    12666368 - No Communication with Diagnostic Gateway
              U0146 00 [008] - -
              [Lost Communication With Gateway]
                        Reset counter: 148
    12674816 - Immobilizer Control Module
              U0167 00 [008] - No Communications
              [Lost Comminication with Immobilizer]
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2019.08.21
                        Time: 00:00:42
       Part No SW: 5K0 953 507 AE    HW: 5K0 953 549
       Component: Lenks.Modul   008 0090
       Revision: --------    Serial number:  90440MC5001F4
       Coding: 5880140000
       ROD: EV_SMLSNGKUDS_A05.rod
       VCID: 73B3DF5CFB33917FC7B-8026
    0516 - Databus
                        Fault Frequency: 9
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2019.08.22
                        Time: 02:16:26
    332564 - Databus
                        Reset counter: 0
                        Mileage: 161117 km
                        Date: 2019.08.21
                        Time: 00:00:42
    332580 - Databus
                        Reset counter: 0
                        Mileage: 161117 km
                        Date: 2019.08.21
                        Time: 00:00:42
    332596 - Databus
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2019.08.21
                        Time: 00:00:42
       Part No SW: 5K0 920 973 B    HW: 5K0 920 973 B
       Coding: 270F01
       VCID: 303910504AA5EA677A9-8064
    9453074 - Fuel Level Sensor 1
              B103E 1B [008] - Resistance Too High
                        Reset counter: 148
    12604928 - Combination / Chassis CAN Bus (SAE Bus D)
              U0056 00 [008] - Performance
              [Datenbus Kombi/Fahrwerk: keine Kommunikation]
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2019.08.21
                        Time: 00:00:42
    12648448 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Steuergerät für Motor: keine Kommunikation]
                        Reset counter: 108
                        Mileage: 161116 km
                        Date: 2019.08.21
                        Time: 17:44:25
    12648704 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Steuergerät für Getriebe: keine Kommunikation]
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2019.08.22
                        Time: 02:16:27
    12656896 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Steuergerät für Bremse: keine Kommunikation]
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2019.08.21
                        Time: 00:00:06
       Part No SW: 7N0 907 530 AF    HW: 7N0 907 530 AF
       Component: J533  Gateway H52 1634
       Revision:   H52       Serial number: 020313F1001346
       Coding: 350000
       VCID: 74B1DC40FEBD9647DE1-8020
                        Reset counter: 108
                        Mileage: 161117 km
                        Date: 2014.01.13
                        Time: 23:25:27
       Part No SW: 5N0 919 879     HW: 5N0 919 879
       Component: Kompass         002 0002
       Revision: 00002000    Serial number: 1225223RMTXE07
       VCID: 7EA5FE68CCF1CC17B85-802A
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2014.01.11
                        Time: 00:00:43
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2014.01.11
                        Time: 00:00:43
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2014.01.13
                        Time: 01:07:35
       VCID: 6A8DC238ACF950B774D-803E
    9456681 - Key
              B104C 29 [008] - Implausible Signal
                        Mileage: 138601 km
                        Date: 2018.06.17
                        Time: 00:05:07
    13762816 - Databus
              U1201 00 [008] - No Communications
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2019.08.21
                        Time: 00:00:42
       Component: Tuer-SG         009 2117
       Coding: 0001076
       VCID: 313F15544D2FE36F757-8064
    00912 - Window Regulator Switch; Front Left (E40)
       Part No: 1K0 909 144 P
       Component: EPS_ZFLS Kl. 69     3305
       Revision: 00H22000
       VCID: 372B2B4CA34B3D5F3B3-8062
                        Reset counter: 108
                        Mileage: 161116 km
                        Date: 2014.01.11
                        Time: 17:44:26
                        Voltage: 12.50 V
                            DU
                        Temperature: 47.0°C
                        RPM: 1498 /min
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2014.01.13
                        Time: 00:01:37
                        Voltage: 12.13 V
                            DU
                        Temperature: 30.0°C
                        RPM: 1498 /min
                        Speed: 50.0 km/h
                        Speed: 50.0 km/h
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2014.01.11
                        Time: 00:02:02
                        Voltage: 12.38 V
                            DU
                        Temperature: 47.0°C
                        RPM: 1498 /min
                000 - - - MIL ON
                        Fault Status: 11100000
                        Battery Volts: 12.5 V
                            PD
                        Temperature: 42.0°C
                        Count: 2
                        Steering Angle: 0.00°
                        Count: 1
                            SteerAng n.Init
       Coding: 0001076
       VCID: 323D1A584829D8770CD-8066
    Address 56: Radio        Labels:
       VCID: 55F781C41C07EF4FC9F-FFFE
    End----------(Elapsed Time: 01:05, VBatt start/end: 12.5V/12.5V)-----------
    Friday,23,August,2019,18:52:04:27550
    Dealer/Shop Name: Jared's Shop
    Address 01: Engine
       Coding: 0000840
                        Reset counter: 197
                        Mileage: 161117 km
                        Date: 2014.01.10
                        Time: 00:00:07
                        Reset counter: 165
                        Mileage: 161117 km
                        Reset counter: 165
                        Mileage: 161117 km
                        Reset counter: 165
                        Mileage: 161117 km
       Revision: 00H31001
                        Reset counter: 108
                        Mileage: 161117 km
                        Date: 2014.01.10
                        Time: 00:00:43
                        Count: 2
                        Count: 12
                        Count: 20992
                        Count: 8208
                        Count: 44032
                        Count: 1
                        Count: 255
                        Reset counter: 108
                        Mileage: 161117 km
                        Date: 2014.01.10
                        Time: 00:00:43
                        Count: 2
                        Count: 12
                        Count: 20992
                        Count: 8233
                        Count: 44032
                        Count: 1
                        Count: 255
                        Fault Status: 00101100
                        Reset counter: 108
                        Mileage: 161117 km
                        Date: 2014.01.13
                        Time: 00:03:43
                        Count: 2
                        Count: 12
                        Count: 20992
                        Count: 105
                        Count: 44032
                        Count: 255
                        Reset counter: 108
                        Mileage: 160839 km
                        Date: 2013.12.30
                        Time: 00:00:48
                        Count: 2
                        Count: 12
                        Count: 29184
                        Count: 16390
                        Count: 49664
                        Count: 254
                        Reset counter: 108
                        Mileage: 161116 km
                        Date: 2014.01.10
                        Time: 17:44:25
                        Count: 12
                        Count: 20992
                        Count: 8194
                        Count: 44800
                        Count: 1
                        Count: 255
       Revision: 00001018
       Coding: 0010002002
    6 Faults Found:
              U1111 00 [009] - -
                        Fault Frequency: 91
                        Reset counter: 108
                        Mileage: 161116 km
                        Date: 2019.08.20
                        Time: 17:44:26
              U1111 00 [008] - -
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2019.08.20
                        Time: 00:00:06
              U1111 00 [008] - -
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2019.08.20
                        Time: 00:00:42
              U1111 00 [008] - -
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2019.08.20
                        Time: 00:00:42
              U1111 00 [008] - -
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2019.08.20
                        Time: 23:25:39
                        Fault Frequency: 9
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2019.08.22
                        Time: 01:07:29
       Revision: AC111709
       Coding: 009795
    25 Faults Found:
                        Reset counter: 143
                        Mileage: 160746 km
                        Date: 2013.12.29
                        Time: 14:35:59
                        Voltage: 14.05 V
                            Term 50 Off
                        Reset counter: 146
                        Mileage: 133390 km
                        Date: 2018.03.22
                        Time: 22:20:42
                        Voltage: 14.10 V
                            Term 50 Off
                        Reset counter: 148
                        Mileage: 159049 km
                        Date: 2013.12.05
                        Time: 11:14:35
                        Voltage: 12.10 V
                            Term 50 Off
                        Reset counter: 108
                        Mileage: 161116 km
                        Date: 2014.01.10
                        Time: 17:44:26
                        Voltage: 12.65 V
                            Term 50 Off
                        Reset counter: 108
                        Mileage: 153141 km
                        Date: 2013.09.23
                        Time: 15:33:29
                        Voltage: 13.90 V
                            Term 50 Off
                        Reset counter: 146
                        Mileage: 153141 km
                        Date: 2013.09.23
                        Time: 17:52:17
                        Voltage: 14.10 V
                            Term 50 Off
                        Fault Frequency: 14
                        Reset counter: 148
                        Mileage: 161116 km
                        Date: 2014.01.10
                        Time: 18:03:06
                        Voltage: 12.60 V
                            Term 50 Off
                        Reset counter: 146
                        Mileage: 153141 km
                        Date: 2013.09.23
                        Time: 19:16:14
                            Term 15 Off
                        Voltage: 12.20 V
                            Term 50 Off
                        Reset counter: 148
                        Mileage: 161116 km
                        Date: 2014.01.10
                        Time: 18:03:17
                            Term 15 Off
                        Voltage: 12.65 V
                            Term 50 Off
                        Reset counter: 108
                        Mileage: 160979 km
                        Date: 2014.01.06
                        Time: 00:02:23
                            Term 15 Off
                        Voltage: 12.60 V
                            Term 50 Off
                        Reset counter: 108
                        Mileage: 160979 km
                        Date: 2014.01.06
                        Time: 00:21:11
                            Term 15 Off
                        Voltage: 12.70 V
                            Term 50 Off
                        Reset counter: 147
                        Mileage: 153141 km
                        Date: 2013.09.23
                        Time: 19:53:23
                        Voltage: 13.95 V
                            Term 50 Off
                        Reset counter: 148
                        Mileage: 160979 km
                        Date: 2014.01.06
                        Time: 01:26:25
                        Voltage: 12.50 V
                            Term 50 Off
                        Fault Frequency: 9
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2014.01.10
                        Time: 00:00:07
                        Voltage: 12.55 V
                            Term 50 Off
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2014.01.10
                        Time: 00:00:43
                        Voltage: 12.55 V
                            Term 50 Off
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2014.01.10
                        Time: 00:02:05
                        Voltage: 12.55 V
                            Term 50 Off
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2014.01.10
                        Time: 21:26:44
                            Term 15 Off
                        Voltage: 12.60 V
                            Term 50 Off
                        Reset counter: 108
                        Mileage: 161117 km
                        Date: 2014.01.10
                        Time: 21:45:10
                            Term 15 Off
                        Voltage: 12.55 V
                            Term 50 Off
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2014.01.10
                        Time: 23:25:37
                        Voltage: 12.00 V
                            Term 50 Off
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2014.01.11
                        Time: 02:14:49
                            Term 15 Off
                        Voltage: 12.20 V
                            Term 50 Off
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2014.01.11
                        Time: 02:15:06
                            Term 15 Off
                        Voltage: 12.20 V
                            Term 50 Off
                        Fault Frequency: 7
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2014.01.11
                        Time: 02:16:28
                        Voltage: 11.95 V
                            Term 50 Off
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2014.01.12
                        Time: 01:07:30
                        Voltage: 12.30 V
                            Term 50 Off
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2014.01.12
                        Time: 01:07:31
                        Voltage: 12.35 V
                            Term 50 Off
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2014.01.13
                        Time: 00:00:01
                            Term 15 Off
                        Voltage: 12.55 V
                            Term 50 Off
       Coding: 00004737
              U0155 00 [008] - -
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2019.08.20
                        Time: 00:00:42
              U0121 00 [008] - -
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2019.08.20
                        Time: 00:00:06
              U0146 00 [008] - -
                        Reset counter: 148
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2019.08.20
                        Time: 00:00:42
       Coding: 5880140000
    0516 - Databus
                        Fault Frequency: 9
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2019.08.21
                        Time: 02:16:26
    332564 - Databus
                        Reset counter: 0
                        Mileage: 161117 km
                        Date: 2019.08.20
                        Time: 00:00:42
    332580 - Databus
                        Reset counter: 0
                        Mileage: 161117 km
                        Date: 2019.08.20
                        Time: 00:00:42
    332596 - Databus
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2019.08.20
                        Time: 00:00:42
       Coding: 270F01
                        Reset counter: 148
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2019.08.20
                        Time: 00:00:42
              U1111 00 [009] - -
                        Reset counter: 108
                        Mileage: 161116 km
                        Date: 2019.08.20
                        Time: 17:44:25
              U1111 00 [008] - -
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2019.08.21
                        Time: 02:16:27
              U1111 00 [008] - -
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2019.08.20
                        Time: 00:00:06
       Coding: 350000
                        Reset counter: 108
                        Mileage: 161117 km
                        Date: 2014.01.12
                        Time: 23:25:27
                        Fault Status: 00110100
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2014.01.13
                        Time: 00:00:10
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2014.01.13
                        Time: 01:49:27
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2014.01.13
                        Time: 01:49:27
    01304 - Radio
                        Reset counter: 108
                        Mileage: 161117 km
                        Date: 2014.01.13
                        Time: 00:01:14
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2014.01.10
                        Time: 00:00:43
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2014.01.10
                        Time: 00:00:43
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2014.01.13
                        Time: 00:00:14
    9456681 - Key
                        Mileage: 138601 km
                        Date: 2018.06.16
                        Time: 00:05:07
    13762816 - Databus
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2019.08.20
                        Time: 00:00:42
       Coding: 0001076
       Revision: 00H22000
                        Reset counter: 108
                        Mileage: 161116 km
                        Date: 2014.01.10
                        Time: 17:44:26
                        Voltage: 12.50 V
                            DU
                        Temperature: 47.0°C
                        RPM: 1498 /min
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2014.01.13
                        Time: 00:00:09
                        Voltage: 12.38 V
                            DU
                        Temperature: 36.0°C
                        RPM: 1498 /min
                        Reset counter: 148
                        Mileage: 161117 km
                        Date: 2014.01.10
                        Time: 00:02:02
                        Voltage: 12.38 V
                            DU
                        Temperature: 47.0°C
                        RPM: 1498 /min
                000 - - - MIL ON
                            PD
                        Temperature: 42.0°C
                        Count: 2
                        Count: 1
                            SteerAng n.Init
       Coding: 0001076
    Address 56: Radio
    End----------(Elapsed Time: 00:52, VBatt start/end: 12.2V/12.2V)-----------
    Engine is also not reading at all and a lot of other errors most likely caused by the ECM not talking what could it be?
    HQ
    Thank you for posting the full Auto-Scan!
    For any control module to communicate, you MUST have the following:
    Lets start with the barest of bones basics... fuses. You need to verify they are to factory design.
    SB6, SB7, SB10, SB13
    There are more, but I think those will be the starting point. TAKE PHOTOS of your fuse box before you touch it!!! Then pull those fuses out, one at a time, make sure they are good, no signs of hot spots, melting, ect. Maybe even swap them around with another fuse of the same value. Then make sure things look like the photo. More than once, or twice... or the number of fingers on my hands, people pull fuses out to inspect and then put back in the wrong location making things worse... don't be "that guy".
    I would also suggest you get the factory wiring diagram for your vehicle from erwin.vw.com. Purchase the cheapest option and then print to PDF the living crap out of EVERYTHING you can get your hands on, that way you have it after the subscription expires.
    Report back on your fuses and we'll dig deeper if needed. If you are unsure of anything, just ask and the forum's jackass, Jack, will chime in. He means well, just some times his medication needs to be adjusted.
    Jef
  3. Likes Uwe, your watermelon liked this post
    Aug 2019
    Thank you! turns out the shop moved a lot of fuses around (almost all of them in a different place). "Re-located" them and boom car started right up You're the man!
  6. #4
    Thank you for the report OP
    Induced FOD wins again!
    HQ
    Quote Originally Posted by your watermelon View Post
    ... that guy.... always causing more problems than solutions.
    Jef
  8. Likes jyoung8607, Uwe liked this post
