Results 1 to 3 of 3
Thread: 2005 Audi A3 MFSW retrofit problem
    Pirate
    Aug 2019
    Poland
    Hi, i'm trying do retrofit multifunction steering wheel, well multifunction airbag to be precise (old type, 4-spoke, used on 8L also) on to my Audi a3 8p. I bought steering wheel module 61340390, airbag wiring 8P0 971 589G, my steering column module is 8P0 953 549 B. I get the following fault codes:
    Removed.  Data from a clone/pirated copy of VCDS is not welcome here.
    I checked power, ground and lin with my multimeter and everything appears to be correct. Can You please help me?
    We'll need to see a full unedited VCDS Auto-Scan to be able to help you.
    Quote Originally Posted by amper View Post
    Getting help in this forum requires the use of a legitimate VCDS system.
    http://www.ross-tech.com/distributors.php#pl
    Let us know if/when you get one and we'll adjust your forum status.
