Results 1 to 10 of 12
Thread: AUDI A6 (C7) intermittent (and very persistent) problem with ABS electronics
    Aug 2019
    Macedonia
    Exclamation AUDI A6 (C7) intermittent (and very persistent) problem with ABS electronics
    hello everyone,
    this is my first post here and i just want to congratulate you on a great and very informative forum you are running, one that i have been following for a while. unfortunately my first post is about a problem that i have with my car that has been going on for a while, and i have been unsuccessful in resolving it.
    what basically happens with the car is that from time to time the entire DIS cluster will light up with errors from most modules/ECUs (parking brake, adaptive suspension, engine, headlights, braking guard etc...). most of the systems go in limp mode when this happens. the errors rarely disappear on their own, sometimes after i turn off and start the car again, but most often after i turn off the car and disconnect and reconnect the cable to the ABS ECU. these errors can happen often (several times a day) or very rare (i have gone 6 months without errors on one occasion), and i'm unable to find a pattern here. also, it's not a rule, but often the errors will start to appear when driving on a rough road or driving over a road hole/bump.
    i have had it scanned on million occasions and as you can see from the autoscan below, most modules point towards lost communication with the ABS. on several occasions, the ABS was not even reachable when scanning with VCDS/ODIS.
    curiously, disconnecting and reconnecting the cable to the ABS ECU ALWAYS resolves the problem, albeit temporarily.
    at a certain point i was sure the ABS connector was faulty, so i rebuilt it with new contacts. this did not solve the problem, but what changed after rebuilding the connector is that when errors appeared they lasted very briefly and disappeared by themselves. this made me even more certain it's the connector, however this time i was sure the contacts are inappropriate (by design), considering their minimal contact area. so i decided to bypass the ABS connector using female spade connectors on the ECU side (which are very tight and i'm certain don't come loose during driving. in fact the ABS connector now can't be removed without first detaching the ECU from the ABS pump - it's that tight). to be able to disconnect the ABS in emergency, i have split the cable downstream into 3 smaller connectors (one for the power cables, and two for the 21 data connections). this worked for several months, but few days ago coming back from holiday the same errors reappeared with a vengeance. i can now start doubting the 3 new connectors i introduced downstream, but i think at this point this is becoming pointless and it's not the connectors at all?!?!
    i have also opened the ABS ECU, and checked (physically and with multimeter) each and every connection that can be checked - no connections are broken and they all show minimal resistance. bare in mind, there are also a lot of microscopic connections in the ECU, covered in silicone. i don't think anyone can check these, certainly not me at home with a multimeter. however, my subjective opinion is that the ECU is well built, and the fault is not in any broken connections. besides, disconnecting and reconnecting the ABS cable will not mend broken connections in the ECU each and every time.
    i have also checked the CAN wiring directly on the ABS connector, CAN high gives 2.7V, CAN low 2.3V and 60 ohms resistance between the two, exactly as per spec.
    reading a lot of stuff on different forums i have come across some thoughts/suggestions that such problems can be caused by rusted/loose negative connections to the chassis, however i have no idea where these cables are bolted to the chassis and where to check for rust?
    also, somebody suggested that the problem is within the ABS electronics, i.e. some of the chips there becomes stuck (like a memory overflow or some loop in software routines). disconnecting the power to the ECU clears the memory and the module starts functioning normally. this sounds logical, but as i mentioned before, sometimes errors resolve without even turning off the car. furthermore, somebody has also pointed that a faulty ABS sensor can feed junk data to the ABS ECU, leading to the above condition. as far as i can understand these sensors are analogue, giving voltage values to the ECU and there is no real "data" there? but is it possible that some other sensor (like lane keeping camera, or ACC radars) can really feed junk data that can block the ECU?
    anyways, here are two autoscans from the last two times this has happened, maybe someone can see and understand something in them that i don't...
    the car is euro spec AUDI A6 C7 (my 2011) 3.0 TDI 245HP quattro with 7-speed DCT.
    sorry for the lengthy post, but i tried to sum up everything from the past year.
    Tuesday,20,August,2019,14:36:07:30584
    VIN: WAUZZZ4G0BN016789   License Plate:
    Mileage: 144670km-89893mi   Repair Order:
    Chassis Type: 4G-AU57 (4G0)
    Scan: 01 02 03 05 06 08 09 0E 10 13 15 16 17 19 28 34 36 3B 3C 42
              44 46 47 52 53 55 56 5F 62 6C 6D 72 85 88 89 8B 8E 8F 90
    VIN: WAUZZZ4G0BN016789   Mileage: 144670km-89893miles
    3B-Sensor Elect. -- Status: Malfunction 0010
    8B-Adaptive Cruise 2 -- Status: Malfunction 0010
    8F-Pretens. Frt Left -- Status: Malfunction 0010
    90-Pretens. Frt Right -- Status: Malfunction 0010
    Address 01: Engine (J623-CDUC)       Labels:. 059-907-401-V2.clb
       Part No SW: 4G0 907 401 F    HW: 4G0 907 401
       Component: 3.0TDI EDC17  H37 0007
       Revision: 53H37---
       Coding: 0A254012046601020000
       Shop #: WSC 28918 001 1048576
       ASAM Dataset: EV_ECM30TDI0114G0907401F 001007
       ROD: EV_ECM30TDI0114G0907401F.rod
       VCID: 26150B6138607AB7905-8072
    5250 - Function Restriction due to Faults in Other Modules
              U1113 00 [040] - -
                        Fault Frequency: 20
                        Mileage: 144550 km
                        Date: 2019.08.20
                        Time: 09:32:23
                        Engine speed: 2239.50 /min
                        Normed load value: 43.1 %
                        Vehicle speed: 92 km/h
                        Coolant temperature: 87 °C
                        Intake air temperature: 33 °C
                        Voltage terminal 30: 14.080 V
                        ACC target acceleration: 0.000 m/s²
                        ACC control module received status-Bits 0-7: 0
                        Active brake system error status-Bits 0-7: 33
                        Status of ACC/CCS acceleration interface-Bits 0-7: 0
                        Acceleration: 1.114 m/s²
                        Engine status: COENG_RUNNING
                        Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
    4660 - Please Check Fault Codes in Control Module for ABS Brakes
              U1017 00 [040] - -
              [Software Incompatibility with Anti-Lockplease read DTC]
                        Fault Frequency: 21
                        Mileage: 144550 km
                        Date: 2019.08.20
                        Time: 09:32:23
                        Engine speed: 2222.50 /min
                        Normed load value: 65.5 %
                        Vehicle speed: 90 km/h
                        Voltage terminal 30: 14.040 V
                        Acceleration: 0.991 m/s²
    7136 - No Communication with ABS Brake Control Module
              U0121 00 [032] - -
              [Lost Communication WithAnti-Lock Brake System (ABS) Control Module]
                        Fault Frequency: 15
                        Mileage: 144670 km
                        Date: 2019.08.20
                        Time: 14:01:21
                        Engine speed: 1184.00 /min
                        Vehicle speed: 255 km/h
                        Coolant temperature: 84 °C
                        Intake air temperature: 40 °C
                        Voltage terminal 30: 13.900 V
                        Cruise Control System (CCS): status-Bits 0-7: 209
                        selected gear-Bits 0-7: 4
    4713 - No Communication with ABS Brake Control Module
              U0121 00 [168] - -
                        Fault Frequency: 7
                        Mileage: 144640 km
                        Date: 2019.08.20
                        Time: 13:40:00
                        Engine speed: 1653.50 /min
                        Normed load value: 56.5 %
                        Coolant temperature: 85 °C
                        Intake air temperature: 38 °C
                        Voltage terminal 30: 13.660 V
                        Cruise Control System (CCS): status-Bits 0-7: 17
                        selected gear-Bits 0-7: 5
    Readiness: 1 1 0 0 0
       Part No SW: 4G2 927 156 H    HW: 0B5 927 156 K
       Component: 0B5 30 TDIRdW H03 0002
       Revision: --H03---    Serial number: 0000000467
       Coding: 000001
       Shop #: WSC 04940 001 00001
       ASAM Dataset: EV_TCMDL501021 A03005
       ROD: EV_TCMDL501021_A03.rod
       VCID: 3333E235FBB21F1F07B-8066
    18148 - No Communication with ABS Brake Control Module
              U0121 00 [040] - -
                        Fault Frequency: 20
                        Reset counter: 40
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:53
                        Engine speed: 1541 /min
                        Transmission input speed: 1541 /min
                        Transmission output speed: 511 /min
                        Engine torque: -48 Nm
                        Transmission fluid temperature: 89 °C
                        Accelerator position: 0.0 %
                        Clutch status: Kupplung 1 kann Moment übertragen
                        Voltage terminal 30: 14.300 V
                        Voltage_5V_CAN_pressuresensors-Param to DOP: 4.923 V
       Part No SW: 4G0 907 379 B    HW: 4G0 907 379 B
       Component: ESP PREMIUM   H09 0190
       Coding: 27A6C700E465E300DB00
       Shop #: WSC 02311 785 00200
       ASAM Dataset: EV_ESPPremiAU57X 003013
       ROD: EV_ESPPremiAU57X_003.rod
       VCID: 3039ED390AA424077A9-8064
    0486 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [Ldm_ApbFailureState]
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:35:11
                        VzRef: 00
                        Bit Info 1: 80
                        Bit Info 2: 2F
                        Bit Info 3: 20
                        Bit Info 4: 1F
                        F-Path: 02
                        F-Type: 06
                        Uz: A5
    0519 - FlexRay Databus
              U1031 00 [008] - No Synchronization
              [NET09_SyncLost_FlxrA]
                        Reset counter: 134
                        Mileage: 144550 km
                        Date: 2019.08.20
                        Time: 09:32:22
                        VzRef: 58
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 26
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: 6E
                        Uz: B8
       Part No SW: 4H0 907 064 AP    HW: 4H0 907 064 AP
       Component: BCM2 2.0      H24 0217
       Coding: 01A83000000000000000
       VCID: 77AB1625AFCA333FFB3-8022
       Serial number: 2311000034114014
                        Fault Status: 00101101
                        Fault Frequency: 19
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:53
       Part No SW: 4G8 959 760 B    HW: 4G8 959 760 B
       Component: MEM-BFS       H04 0153
       Revision: AA000000    Serial number: 00001002306755
       Coding: 0018320000006201000001010101112030303333283333
       VCID: 392FD01DD95EE54FCD7-806C
       Part No SW: 4G0 820 043 K    HW: 4G0 820 043 K
       Component: KLIMA 4 ZONEN H11 0056
       Serial number: 17021100040422
       Coding: 360100B824
       ASAM Dataset: EV_AirCondiComfoUDS 002029
       VCID: 270B06653F6A63BFAB3-8072
    0247 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [Motorsteuergerät: Fehlerspeicher auslesen]
                        Fault Frequency: 7
                        Reset counter: 134
                        Mileage: 144571 km
                        Date: 2019.08.20
                        Time: 09:45:47
                        Outside air temperature: 29.0 °C
                        Engine speed: 1987 /min
                        Vehicle speed: 87.00 km/h
    0330 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Bremsensteuergerät: kein Signal/keine Kommunikation]
                        Fault Frequency: 16
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:52
                        Voltage terminal 30: 14.32 V
                        Outside air temperature: 28.5 °C
                        Engine speed: 1740 /min
    0369 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Steuergerät für Spurhalteassistent: kein Signal / Kommunikation]
                        Fault Frequency: 26
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:53
                        Voltage terminal 30: 14.34 V
                        Engine speed: 1648 /min
       Part No SW: 4H0 907 063 N    HW: 4H0 907 063 F
       Component: BCM1 2.0      H12 0092
       Revision: 20012002    Serial number: 00000000961257
       Coding: 0200201150B48FE2C981008380001908CF9CC3082E080101000008402100
       VCID: 3333E235FB321F1F07B-8066
       Component: WWS57X 110213  H32 0051
       Serial number:         110214102924
       Coding: 0045F7
       Component: RLS  H04 0003
       Serial number: 11300730
       Coding: 02512B
       Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
       Component: E1 - LDS  H07 0044
       Serial number: 28 02 2011  00000056
       Serial number: 5C080495000000000001
                        Fault Frequency: 14
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:00
    01771 - Control Module for Headlight Range (J431)
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:00
    Address 0E: Media Player 1 (R161)       Labels: None
       Part No SW: 4H0 035 108 F    HW: 4H0 035 108
       Component: DVDCAlpine    H42 0200
       Revision: AA001001
       VCID: 231312754BD28F9FF7B-8076
    02283 - Video Connection to Output [End Unit]
                        Fault Status: 00101011
                        Fault Frequency: 23
                        Reset counter: 131
       Part No SW: 4H0 919 475 H    HW: 4H0 919 475 C
       Component: PARKHILFE ACC H07 0030
       Revision: 11001001    Serial number: 55901105301116
       Coding: 302B05
       ASAM Dataset: EV_EPHVA18AU57X0000 001002
       ROD: EV_EPHVA18AU57X0000_001.rod
       VCID: 372BD625EFCAF33F3B3-8062
    12656912 - Databus
              [Bremsensteuergerät - ESP_01 - kein Signal/keine Kommunikation]
                        Fault Frequency: 20
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:52
       Part No SW: 4G0 907 561     HW: 4G0 907 561
       Component: ACC3          H15 0160
       Coding: 3E04010202
       ASAM Dataset: EV_AdaptCruisContrAU57X 001003
       ROD: EV_AdaptCruisContrAU57X_001.rod
       VCID: 678B4665FFEAA3BF6B3-8032
    10 Faults Found:
    23552 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [FAULT_CIM_TIMEOUT_Linie_07]
                        Reset counter: 134
                        Mileage: 144668 km
                        Date: 2019.08.20
                        Time: 13:55:11
                        Control Module temperature: 39 °C
                        Voltage terminal 15: 14.015 V
                        Velocity_vehicle_reference: 32.59 m/s
                        Longitudinal_acceleration_vehicle_reference: -0.38 m/s²
    23808 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [FAULT_CIM_TIMEOUT_Linie_08]
                        Reset counter: 134
                        Mileage: 144668 km
                        Date: 2019.08.20
                        Time: 13:55:11
    24064 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [FAULT_CIM_TIMEOUT_Linie_Master]
                        Reset counter: 134
                        Mileage: 144652 km
                        Date: 2019.08.20
                        Time: 13:46:22
                        Voltage terminal 15: 14.003 V
                        Velocity_vehicle_reference: 31.88 m/s
                        Longitudinal_acceleration_vehicle_reference: -0.02 m/s²
    25856 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [FAULT_CIM_TIMEOUT_BVObjekt_07]
                        Reset counter: 134
                        Mileage: 144670 km
                        Date: 2019.08.20
                        Time: 14:01:18
                        Control Module temperature: 47 °C
                        Voltage terminal 15: 14.082 V
                        Velocity_vehicle_reference: 23.44 m/s
                        Longitudinal_acceleration_vehicle_reference: -3.42 m/s²
    26880 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [FAULT_CIM_TIMEOUT_BVOBMaster]
                        Reset counter: 134
                        Mileage: 144670 km
                        Date: 2019.08.20
                        Time: 14:01:18
    27136 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [FAULT_CIM_TIMEOUT_BVS_STATUS]
                        Reset counter: 134
                        Mileage: 144670 km
                        Date: 2019.08.20
                        Time: 14:01:18
    77056 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [FAULT_CIM_TIMEOUT_BV_TIME]
                        Fault Frequency: 16
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:53
                        Control Module temperature: 33 °C
                        Voltage terminal 15: 14.320 V
                        Velocity_vehicle_reference: 20.66 m/s
                        Longitudinal_acceleration_vehicle_reference: -0.62 m/s²
    105984 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [FAULT_CIS_EPB_FAIL]
                        Reset counter: 134
                        Mileage: 144670 km
                        Date: 2019.08.20
                        Time: 14:02:28
                        Control Module temperature: 46 °C
                        Voltage terminal 15: 12.617 V
                        Velocity_vehicle_reference: -0.01 m/s
    140288 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [FAULT_CIS_ECD_FAIL]
                        Reset counter: 134
                        Mileage: 144670 km
                        Date: 2019.08.20
                        Time: 14:02:34
                        Voltage terminal 15: 12.563 V
    145152 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [FAULT_CIS_SWA_FAIL]
                        Reset counter: 134
                        Mileage: 144670 km
                        Date: 2019.08.20
                        Time: 14:02:28
       Component: Airbag10.43   H40 0040
       Revision: --------    Serial number: 003JG001PWX0
       Coding: 30323436313330303335554A304C34473053
       VCID: 3635DB21E8C00A37205-8062
       Serial number: 3575HRB404T0ATOCBP08
       Serial number: 3585HRB404T07OTS504
       Serial number: 3515JRB406109GGSBG6C
       Serial number: 3525JRB406909GGSAPL1
       Serial number: 3554VRB40516PGAKJ92V
       Serial number: 3564VRB404T6PGAKIPB/
    7 Faults Found:
    1048832 - Databus
              [CAN: 0x100 ESP_01 Timeout]
                        Fault Frequency: 15
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:53
    1049088 - Databus
              [CAN: 0x101 ESP_02 Timeout]
                        Fault Frequency: 15
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:53
    1049093 - Databus
              [CAN: 0x101 ESP_02 error value ESP_Querbeschleunigung]
                        Reset counter: 134
                        Mileage: 144550 km
                        Date: 2019.08.20
                        Time: 09:32:23
    1049094 - Databus
              [CAN: 0x101 ESP_02 error value ESP_Laengsbeschleunigung]
                        Reset counter: 134
                        Mileage: 144550 km
                        Date: 2019.08.20
                        Time: 09:32:23
    1049095 - Databus
              [CAN: 0x101 ESP_02 error value ESP_Gierrate]
                        Reset counter: 134
                        Mileage: 144550 km
                        Date: 2019.08.20
                        Time: 09:32:23
    1049344 - Databus
              [CAN: 0x103 ESP_03 Timeout]
                        Fault Frequency: 15
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:53
    1049866 - Databus
              [CAN: 0x39C Gateway_05 Old value from ESP_07]
                        Fault Frequency: 9
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:54
       Part No SW: 4H0 953 568 G    HW: 4H0 953 568 G
       Component: Lenks.Modul   H03 0003
       Revision: --------    Serial number: 90372KBP0020B
       Coding: 0000FC
       VCID: 372BD625EF4AF33F3B3-8062
       Component: E221 - MFL  H08 0009
       Serial number: 05 05 2012  C0063401
                        Fault Frequency: 19
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:53
       Part No SW: 4G8 920 930 T    HW: 4G8 920 930 T
       Component: TDieRdwAcc    H34 0309
       Revision: 19100073    Serial number: 658180211593030
       Coding: 138E09005F050008000000
       ASAM Dataset: EV_RBD4K 004033
       ROD: EV_RBD4K_AU57.rod
       VCID: 3E25C301C0F0C277F85-806A
    16776968 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [ESP_02 keine Kommunikation]
                        Fault Frequency: 20
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:52
    16776969 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [LDW_02_FR keine Kommunikation]
                        Fault Frequency: 21
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:52
    16776973 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [RDK_01 keine Kommunikation]
                        Fault Frequency: 7
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:53
    16776980 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [VZE_01 keine Kommunikation]
                        Fault Frequency: 21
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:52
       Part No SW: 4G0 907 468 C    HW: 4G0 907 468 A
       Component: J533--Gateway H08 0204
       Revision: --------    Serial number: 00000000104008
       Coding: 00CD077D00
       ROD: EV_GatewUDS_AU57.rod
       Component: J367-BDM  H07 0140
       Serial number: 00000000005650619708
       Voltage stabilizer:
       Serial number: 11045001033011200410
    6653 - Image processing control module
              U1079 00 [008] - No communication
                        Fault Frequency: 19
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:52
                        Voltage terminal 30: 14.4 V
                        Voltage terminal 15: 14.4 V
                        System status: Terminal 15 on
                        Engine running: On
                        IN ZAS_Te_X: On
                        Terminal 15 status: On
                        Datenfeld: 0
    4352 - ABS Control Module on FlexRay Data Bus
              U10BD 00 [008] - No Communication
              [Lost Communication With Vehicle Dynamics Control Module]
                        Fault Frequency: 22
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:52
                        Voltage terminal 30: 14.3 V
                        Voltage terminal 15: 14.3 V
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
       Part No SW: 4G0 919 158 D    HW: 4G0 919 158 D
       Component: KLIMA FOND    H07 0056
       Serial number: 19021100040082
       Coding: 00
       ASAM Dataset: EV_ClimaContrUnitRearUDS 002012
    0136 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Fault Frequency: 17
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:52
                        Voltage terminal 30: 14.41 V
       Part No SW: 4G0 907 553 B    HW: 4G0 907 553
       Component: LUFE-DAEMPFER H17 0778
       Coding: 008002
       ASAM Dataset: EV_AirSuspe 003022
       ROD: EV_AirSuspe_VW51.rod
       VCID: 2A0DFF512C785ED7B4D-807E
    0008 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Fault Frequency: 13
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:53
    0009 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Fault Frequency: 13
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:53
    0006 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Fault Frequency: 11
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:53
    0007 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Fault Frequency: 9
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:53
    0648 - Function Restriction due to Implausible Message(s)
              U1112 00 [008] - -
                        Fault Frequency: 10
                        Reset counter: 134
                        Mileage: 144550 km
                        Date: 2019.08.20
                        Time: 09:32:23
       Component: MEM-FS        H04 0153
       Revision: AA000000    Serial number: 00001002306757
       Coding: 0018330000016201000001010101112030303333203333
       Part No SW: 4G0 907 637 B    HW: 4G0 907 637 B
       Component: SARA 6D       H02 0004
       Revision: --------    Serial number: EJ1BPA4200DZ160
       ASAM Dataset: EV_SARA 006014
       ROD: EV_SARA_006.rod
       VCID: 2D07F44D1D9649EF51F-8078
    3801346 - Function Restricted due to Missing Message(s)
              U1111 00 [044] - -
              [Internal Monitoring (MSG)]
                        Fault Frequency: 22
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:52
                        DCU Temperature: 46 °C
                        Voltage Clamp 15: 14.7 V
                        Voltage Clamp 30: 14.4 V
                        Ignition Cycle Count: 50068
                        WAUZZZ4G0BN016789
       Part No SW: 4G0 907 566 C    HW: 4G0 907 566
       Component: J769  SWA MasterH01 0020
       Revision: 00H01000    Serial number: 6PZ 010 287-01
       Coding: 0000101
       VCID: 2F3BEE451B1A3BFF633-807A
       Subsystem 1 - Part No: 4G0 907 568 C
       Component: J770  SWA Slave H01 0020
       Subsystem 2 - Serial number: 6PZ 010 287-21
       Subsystem 3 - Serial number: 5F01.03.1100H010003CD21904˙
       Subsystem 4 - Serial number: D21904˙
                        Reset counter: 134
                        Mileage: 144550 km
                        Date: 2019.08.20
                        Time: 09:32:23
                        Fault Frequency: 21
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:52
       Part No SW: 4G8 959 793 B    HW: 4G8 959 793
       Component: TSG FA        H04 0210
       Coding: 011F06205E00628202080003
       Shop #: WSC 02312 785 00200
       VCID: 3FDBBE05C77ACB7FF33-806A
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:57
       Part No SW: 4G0 909 144 L    HW: 4G0 909 144 F
       Component: RCEPS         H32 0010
       Revision: 00001000    Serial number: 0024040880
       Coding: 101001010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       VCID: 323DE73104A816170CD-8066
    3158273 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Ausfall Botschaft "PDU_ESP_01"]
                        Fault Frequency: 20
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:53
                        Write only channel
    3158336 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Ausfall Botschaft "PDU_HCA_01"]
                        Fault Frequency: 19
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:53
                        Write only channel
       Revision: 00002001    Serial number: 0144584148
       Coding: 0100062000B93480832008040C0100000000000000000000000000000000
                        Fault Frequency: 19
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:53
       Part No SW: 4G0 035 223 A    HW: 4G0 035 223 A
       Component: BOSE G3 C7    H07 0070
       Revision: CJ007000    Serial number: 00000000023919
       VCID: 1B632A9573A2B75F3FB-804E
    03278 - Functionality Limited due to Missing Messages
                        Reset counter: 134
                        Mileage: 144581 km
                        Date: 2019.08.20
                        Time: 09:52:37
                        Bin. Bits: 00001000
       Part No SW: 4G8 959 792 C    HW: 4G8 959 792 A
       Component: TSG BF        H04 0210
       Coding: 011F06205E00628202080002
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:57
       Revision: --------    Serial number: 00000000046518
       ROD: EV_ParkiBrake_VW51.rod
    6 Faults Found:
    328448 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [FC_ESP_01_MESSAGE_TIMEOUT]
                        Fault Frequency: 20
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:52
                        Internal Fault ID: 89
                        Vehicle speed: 74 km/h
                        Red operating lamp: OFF
                        Red warning lamp: OFF
                        Green operating lamp: OFF
                        Yellow warning lamp: On
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
                        Auto Adjust: not active
                        Internal Parking Brake state: Dynamic
    328704 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [FC_ESP_02_MESSAGE_TIMEOUT]
                        Fault Frequency: 20
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:52
                        Internal Fault ID: 90
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
    328960 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [FC_ESP_03_MESSAGE_TIMEOUT]
                        Fault Frequency: 20
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:52
                        Internal Fault ID: 91
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
    329216 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [FC_ESP_05_MESSAGE_TIMEOUT]
                        Fault Frequency: 20
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:52
                        Internal Fault ID: 92
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
    459264 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [FC_SIGNAL_ESP_LAENGSBESCHL_ERROR_VALUE]
                        Reset counter: 134
                        Mileage: 144550 km
                        Date: 2019.08.20
                        Time: 09:32:23
                        Internal Fault ID: 138
                        Vehicle speed: 510 km/h
                        Yellow warning lamp: OFF
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
                        Internal Parking Brake state: Emergency running mode
    463616 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [FC_SIGNAL_ESP_QBIT_LAENGSBESCHLEUNIGUNG_QBIT]
                        Reset counter: 134
                        Mileage: 144550 km
                        Date: 2019.08.20
                        Time: 09:32:23
                        Internal Fault ID: 185
                        Vehicle speed: 88 km/h
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
    Address 55: Headlight Range (J431)       Labels:| 4H4-907-357-V1.clb
       Part No SW: 4H4 907 357 A    HW: 4H4 907 357 A
       Component: ....AFS13.... H01 0011
       Serial number: 110210-0004-037
       Coding: 11216F33F91AEB00
       ASAM Dataset: EV_AdvanFrontSyste 005001
       ROD: EV_AdvanFrontSyste_AU21.rod
    H02 0006
       Coding: 1D0000
    H02 0006
       Coding: 1D0000
    0001 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Timeout CAN-Message ESP_02  (0x101)]
                        Fault Frequency: 20
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:53
    0061 - Function Restriction due to Implausible Message(s)
              U1112 00 [008] - -
              [Fehlerhafter DLC der CAN-Messages Kamera_Status  (0x318)]
                        Fault Frequency: 16
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:54
    337156 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Timeout CAN-Message ESP_03  (0x103)]
                        Fault Frequency: 20
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:53
       Part No SW: 4G0 035 053 J    HW: 4G0 035 053
       Component: Radio U Basic H52 0133
       Revision: AB001007    Serial number: 050BO0B7544019
       Coding: 010003010000000001
       VCID: 25170C6D45E671AF99F-8070
                        Fault Frequency: 7
                        Reset counter: 134
                        Mileage: 144668 km
                        Date: 2019.08.20
                        Time: 13:55:24
                        Bin. Bits: 00000000 00000100
       Part No SW: 4G0 035 670 Q    HW: 4G0 035 670
       Component: H-BNT-EU      H46 1034
       Revision: --------    Serial number: 428J80B7514996
       Coding: 050100000003F9EF7D308B3E00000003080001000000000000
       Shop #: WSC 28274 134 100328
       VCID: 313FE83D012E2D0F757-8064
       Subsystem 1 - Part No: 8R0 060 884 GA
       Component: EUR 2019  2802
       Subsystem 2 - Part No SW: 4G1 919 610 C    HW: 4G1 919 612 L
       Component: E380 BDT C7  H08 0204
       Serial number: 90349KBP0006D
       Subsystem 3 - Part No: 8R0 060 961 A
       Component: CD-Database  2712
                        Reset counter: 134
                        Mileage: 144668 km
                        Date: 2019.08.20
                        Time: 13:55:24
                        Bin. Bits: 00000000 10000000
                        Bin. Bits: 00000010 00000000
                        Bin. Bits: 00000000 00000010
                        Bin. Bits: 00000000 00000000
    02259 - Information Display and Control Head (Front) (J685)
                        Reset counter: 94
                        Mileage: 144670 km
                        Date: 2019.08.20
                        Time: 14:03:17
                        Voltage: 13.40 V
                        Fault Frequency: 18
                        Reset counter: 134
                        Mileage: 144670 km
                        Date: 2019.08.20
                        Time: 14:01:54
                        Bin. Bits: 00000000 01100000
       Part No SW: 4G8 959 795 C    HW: 4G8 959 795 A
       Component: TSG HL        H03 0210
       Coding: 010F04204000628202080002
       VCID: 42DDB7F1B488A6979CD-8016
       Part No SW: 4G0 907 441 A    HW: 4H0 907 441
       Component: SG Rueckfahrkamera  0050
       Revision: --H04---    Serial number: 525 PA8J12F0CG
       Coding: 1020004
       VCID: 25170C6D49E671AF99F-8070
                        Fault Frequency: 17
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:52
                            Reverse OFF
                        Count: 3
       Part No SW: 4G5 959 107     HW: 4G5 959 107
       Component: HDSG-Modul    H01 0036
       Revision: 13001001    Serial number: 046100202
       Coding: 111104C000
       ASAM Dataset: EV_HDSGAu571 001001
       ROD: EV_HDSGAu571.rod
       VCID: 6FBB2E45D71A7BFF233-803A
    0044 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:56
       Component: TSG HR        H03 0210
       Part No SW: 4G0 907 217     HW: 4H0 907 217 A
       Component: DPC-SG        H24 0034
       Coding: EE060000
       ROD: EV_OnBoardCamerDPC.rod
       VCID: 65974C6D05E6B1AF59F-8030
    0703 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [ESP_timeout]
                        Fault Frequency: 23
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:53
                        Outside air temperature: -36.0 °C
                        Voltage terminal 15: 14.1 V
                        Control Module temperature: 41.0 °C
       Serial number: 00456842018901
       Coding: 662FF2
       ROD: EV_IVBDriveSideFrnt.rod
       VCID: 2F3BEE45179A3BFF633-807A
       Serial number: 00456842126601
       Coding: 262FF2
       Part No SW: 4G0 907 541     HW: 4G0 907 541
       Coding: 3E04010202
       ASAM Dataset: EV_AdaptCruisContr2AU57X 001002
       ROD: EV_AdaptCruisContr2AU57X_001.rod
    10 Faults Found:
    27904 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [FAULT_CIM_TIMEOUT_ESP_02]
                        Fault Frequency: 19
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:53
                        Voltage terminal 15: 14.332 V
                        Velocity_vehicle_reference: 20.48 m/s
                        Longitudinal_acceleration_vehicle_reference: -0.70 m/s²
    28160 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [FAULT_CIM_TIMEOUT_ESP_03]
                        Fault Frequency: 19
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:53
    28416 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [FAULT_CIM_TIMEOUT_ESP_05]
                        Reset counter: 134
                        Mileage: 144670 km
                        Date: 2019.08.20
                        Time: 14:01:19
                        Control Module temperature: 48 °C
                        Voltage terminal 15: 14.126 V
                        Velocity_vehicle_reference: 22.88 m/s
                        Longitudinal_acceleration_vehicle_reference: -0.57 m/s²
    28672 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [FAULT_CIM_TIMEOUT_ESP_07]
                        Reset counter: 134
                        Mileage: 144670 km
                        Date: 2019.08.20
                        Time: 14:01:21
                        Voltage terminal 15: 14.143 V
                        Velocity_vehicle_reference: 18.71 m/s
                        Longitudinal_acceleration_vehicle_reference: -0.14 m/s²
    28928 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [FAULT_CIM_TIMEOUT_ESP_08]
                        Fault Frequency: 25
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:53
                        Voltage terminal 15: 14.255 V
                        Velocity_vehicle_reference: 20.52 m/s
                        Longitudinal_acceleration_vehicle_reference: -1.18 m/s²
    94976 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [FAULT_CIS_QDCPSS_FAIL]
                        Reset counter: 134
                        Mileage: 144668 km
                        Date: 2019.08.20
                        Time: 13:57:05
                        Control Module temperature: 41 °C
                        Voltage terminal 15: 13.697 V
                        Velocity_vehicle_reference: 1.68 m/s
    105472 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [FAULT_CIS_VDC_FAIL]
                        Reset counter: 134
                        Mileage: 144668 km
                        Date: 2019.08.20
                        Time: 13:57:05
              U1113 00 [008] - -
                        Reset counter: 134
                        Mileage: 144550 km
                        Date: 2019.08.20
                        Time: 09:32:23
                        Voltage terminal 15: 14.287 V
                        Velocity_vehicle_reference: 25.18 m/s
                        Longitudinal_acceleration_vehicle_reference: 1.65 m/s²
              U1113 00 [008] - -
                        Reset counter: 134
                        Mileage: 144670 km
                        Date: 2019.08.20
                        Time: 14:02:34
                        Voltage terminal 15: 12.619 V
                        Velocity_vehicle_reference: -0.00 m/s
    144896 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [FAULT_CIS_US_FAIL]
                        Fault Frequency: 18
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:53
                        Voltage terminal 15: 14.337 V
                        Velocity_vehicle_reference: 20.39 m/s
                        Longitudinal_acceleration_vehicle_reference: -0.25 m/s²
       Part No SW: 4G0 907 107 B    HW: 4H0 907 107
       Component: BV-SG         H28 0034
       Serial number: 000040182202117
       Coding: 04C0BB181111
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
       VCID: 25170C6D456671AF99F-8070
    7 Faults Found:
    0028 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [ESP_ESP_01_Signal_Error]
                        Reset counter: 134
                        Mileage: 144550 km
                        Date: 2019.08.20
                        Time: 09:32:24
                        Outside air temperature: 28.0 °C
                        Voltage terminal 15: 14.2 V
                        Control Module temperature: 42.0 °C
    0063 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [SWA_Signal_error]
                        Reset counter: 134
                        Mileage: 144550 km
                        Date: 2019.08.20
                        Time: 09:32:24
    0121 - FlexRay Databus
              [Halt-Fehler_/_Kompletter_Syncverlust]
                        Fault Priority: 9
                        Fault Frequency: 50
                        Reset counter: 134
                        Mileage: 144550 km
                        Date: 2019.08.20
                        Time: 09:32:22
    0173 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [APS_Signal_Error_Master]
                        Reset counter: 134
                        Mileage: 144637 km
                        Date: 2019.08.20
                        Time: 13:37:50
                        Outside air temperature: 35.5 °C
                        Voltage terminal 15: 12.0 V
                        Control Module temperature: 0.0 °C
    0091 - Function Limitation due to Missing Video Data
              C1108 00 [008] - -
              [DPC_SystemError]
                        Fault Frequency: 15
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:52
    0179 - Development Code 4
              B2F04 00 [008] - -
              [MGT_task_stuck_bTask_HCA]
                        Fault Priority: 9
                        Fault Frequency: 13
                        Reset counter: 134
                        Mileage: 144570 km
                        Date: 2019.08.20
                        Time: 09:45:07
                        Control Module temperature: 44.0 °C
    0185 - Development Code 4
              B2F04 00 [008] - -
              [MGT_task_stuck_eTask_RSF]
                        Fault Priority: 9
                        Fault Frequency: 11
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:52
       Part No SW: 4H0 980 945     HW: 4H0 980 945
       Component: RGS-VL        H05 0070
       Coding: 0066E608031F037E070308014240C2010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
    12583684 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Fault Frequency: 20
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:53
    12583686 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Fault Frequency: 20
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:53
    12583687 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Fault Frequency: 20
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:53
       Part No SW: 4H0 980 946     HW: 4H0 980 946
       Component: RGS-VR        H05 0070
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       VCID: 70B92D39CA2464073A9-8024
              U1111 00 [008] - -
                        Fault Frequency: 20
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:53
              U1111 00 [008] - -
                        Fault Frequency: 20
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:53
              U1111 00 [008] - -
                        Fault Frequency: 20
                        Reset counter: 134
                        Mileage: 144554 km
                        Date: 2019.08.20
                        Time: 09:34:53
    End----------(Elapsed Time: 02:36, VBatt start/end: 13.5V/14.0V)-----------
    Wednesday,21,August,2019,12:30:35:30584
    Mileage: 144820km-89986mi   Repair Order:
    VIN: WAUZZZ4G0BN016789   Mileage: 144820km-89986miles
       Revision: 53H37---
              U1113 00 [032] - -
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:35
                        Engine speed: 2031.50 /min
                        Normed load value: 59.6 %
                        Coolant temperature: 88 °C
                        Intake air temperature: 52 °C
                        Voltage terminal 30: 13.740 V
                        Active brake system error status-Bits 0-7: 1
                        Acceleration: -0.137 m/s²
              U1017 00 [032] - -
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:33
                        Engine speed: 1214.50 /min
                        Normed load value: 0.4 %
                        Acceleration: -0.106 m/s²
              U0121 00 [032] - -
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:33
                        Engine speed: 1236.50 /min
                        Normed load value: 0.8 %
                        Voltage terminal 30: 13.760 V
                        selected gear-Bits 0-7: 2
              U0121 00 [032] - -
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:32
                        Engine speed: 1273.00 /min
       Coding: 000001
              U0121 00 [032] - -
                        Reset counter: 40
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:32
                        Engine speed: 1272 /min
                        Transmission input speed: 1272 /min
                        Transmission output speed: 239 /min
                        Engine torque: -56 Nm
                        Transmission fluid temperature: 92 °C
                        Clutch status: Beide Kupplungen können Moment übertragen
                        Voltage terminal 30: 13.700 V
                        Voltage_5V_CAN_pressuresensors-Param to DOP: 4.924 V
              U1113 00 [008] - -
                        Fault Frequency: 19
                        Reset counter: 134
                        Time: 00:00:00
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 02
                        Bit Info 3: 00
                        Bit Info 4: 1F
                        F-Path: 02
                        F-Type: 06
                        Uz: A2
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:32
                        VzRef: 1F
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 24
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: 6E
                        Uz: B4
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:33
       Coding: 360100B824
              U1113 00 [008] - -
                        Reset counter: 134
                        Mileage: 144819 km
                        Date: 2019.08.20
                        Time: 16:06:39
                        Outside air temperature: 37.0 °C
                        Engine speed: 1879 /min
                        Vehicle speed: 38.00 km/h
              U1111 00 [008] - -
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:32
                        Voltage terminal 30: 13.91 V
                        Engine speed: 1371 /min
              U1111 00 [008] - -
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:32
                        Voltage terminal 30: 13.93 V
                        Engine speed: 1282 /min
       Coding: 0045F7
       Coding: 02512B
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:00
       Revision: AA001001
                        Reset counter: 134
       Coding: 302B05
    12656912 - Databus
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:32
       Coding: 3E04010202
    10 Faults Found:
    22528 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [FAULT_CIM_TIMEOUT_Linie_03]
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:33
                        Voltage terminal 15: 13.964 V
                        Velocity_vehicle_reference: 8.81 m/s
                        Longitudinal_acceleration_vehicle_reference: -0.41 m/s²
    22784 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [FAULT_CIM_TIMEOUT_Linie_04]
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:33
    23040 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [FAULT_CIM_TIMEOUT_Linie_05]
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:33
    23296 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [FAULT_CIM_TIMEOUT_Linie_06]
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:33
              U1111 00 [008] - -
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:33
              U1111 00 [008] - -
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:33
              U1111 00 [008] - -
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:33
              U1113 00 [008] - -
                        Reset counter: 134
                        Mileage: 144820 km
                        Date: 2019.08.20
                        Time: 19:56:51
                        Control Module temperature: 38 °C
                        Voltage terminal 15: 11.711 V
              U1113 00 [008] - -
                        Reset counter: 134
                        Mileage: 144820 km
                        Date: 2019.08.20
                        Time: 19:56:51
              U1113 00 [008] - -
                        Reset counter: 134
                        Mileage: 144820 km
                        Date: 2019.08.20
                        Time: 19:56:51
    6 Faults Found:
    1048832 - Databus
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:32
    1049088 - Databus
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:32
    1049093 - Databus
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:33
    1049094 - Databus
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:33
    1049095 - Databus
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:33
    1049344 - Databus
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:32
       Coding: 0000FC
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:32
              U1111 00 [008] - -
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:32
              U1111 00 [008] - -
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:32
              U1111 00 [008] - -
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:32
       Coding: 00CD077D00
       Voltage stabilizer:
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:32
                        Voltage terminal 30: 13.9 V
                        Voltage terminal 15: 14.0 V
                        Control Module temperature: 59 °C
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:33
                        Voltage terminal 30: 14.0 V
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
       Coding: 00
              U1111 00 [008] - -
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:32
                        Voltage terminal 30: 14.04 V
       Coding: 008002
              U1111 00 [008] - -
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:33
              U1111 00 [008] - -
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:33
              U1111 00 [008] - -
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:33
              U1111 00 [008] - -
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:33
              U1112 00 [008] - -
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:34
              U1111 00 [040] - -
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:32
                        DCU Temperature: 58 °C
                        Voltage Clamp 15: 14.4 V
                        Voltage Clamp 30: 14.0 V
                        Ignition Cycle Count: 50098
                        WAUZZZ4G0BN016789
       Coding: 0000101
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:32
                        Reset counter: 134
                        Date: 2011.01.01
                        Time: 00:00:00
              U1111 00 [008] - -
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:33
                        Write only channel
              U1111 00 [008] - -
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:33
                        Write only channel
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:33
    6 Faults Found:
              U1111 00 [008] - -
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:32
                        Vehicle speed: 32 km/h
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
              U1111 00 [008] - -
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:32
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
              U1111 00 [008] - -
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:32
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
              U1111 00 [008] - -
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:32
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
              U1113 00 [008] - -
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:33
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
              U1113 00 [008] - -
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:33
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
    H02 0006
       Coding: 1D0000
    H02 0006
       Coding: 1D0000
              U1111 00 [008] - -
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:32
              U1112 00 [008] - -
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:33
              U1111 00 [008] - -
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:32
       Subsystem 2 - Part No SW: 4G0 919 605 A    HW: 4G0 919 605 A
       Serial number: AUZ8ZDB1300E1PE
       Subsystem 3 - Part No SW: 4G1 919 610 C    HW: 4G1 919 612 L
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:42
                        Reset counter: 134
                        Mileage: 144670 km
                        Date: 2019.08.20
                        Time: 14:37:02
                        Voltage: 13.90 V
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:35
       Coding: 1020004
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:32
                            Reverse OFF
                        Count: 3
       Coding: 111104C000
       Coding: EE060000
              U1111 00 [008] - -
              [ESP_timeout]
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:32
                        Outside air temperature: -31.5 °C
                        Voltage terminal 15: 13.7 V
                        Control Module temperature: 46.0 °C
       Coding: 662FF2
       Coding: 262FF2
       Coding: 3E04010202
    10 Faults Found:
              U1111 00 [008] - -
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:33
                        Voltage terminal 15: 14.004 V
                        Velocity_vehicle_reference: 8.72 m/s
                        Longitudinal_acceleration_vehicle_reference: -0.45 m/s²
              U1111 00 [008] - -
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:33
              U1111 00 [008] - -
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:33
              U1111 00 [008] - -
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:35
                        Voltage terminal 15: 13.999 V
                        Velocity_vehicle_reference: 7.51 m/s
                        Longitudinal_acceleration_vehicle_reference: -0.39 m/s²
              U1111 00 [008] - -
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:35
              U1113 00 [008] - -
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:34
                        Voltage terminal 15: 14.002 V
                        Velocity_vehicle_reference: 8.20 m/s
                        Longitudinal_acceleration_vehicle_reference: -3.24 m/s²
              U1113 00 [008] - -
                        Reset counter: 134
                        Mileage: 144820 km
                        Date: 2019.08.20
                        Time: 19:56:51
                        Control Module temperature: 37 °C
                        Voltage terminal 15: 11.793 V
              U1113 00 [008] - -
                        Reset counter: 134
                        Mileage: 144820 km
                        Date: 2019.08.20
                        Time: 19:56:51
              U1113 00 [008] - -
              [FAULT_CIS_US_FAIL]
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:33
                        Voltage terminal 15: 14.007 V
                        Velocity_vehicle_reference: 8.70 m/s
                        Longitudinal_acceleration_vehicle_reference: -0.21 m/s²
              U1113 00 [008] - -
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:33
       ROD: EV_BC7.rod
              U1113 00 [008] - -
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:36
                        Voltage terminal 15: 13.9 V
                        Control Module temperature: 54.0 °C
              U1113 00 [008] - -
              [SWA_Signal_error]
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:36
                        Fault Priority: 9
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:32
       ROD: EV_RGS_L.rod
              U1111 00 [008] - -
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:32
              U1111 00 [008] - -
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:32
              U1111 00 [008] - -
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:32
       ROD: EV_RGS_R.rod
              U1111 00 [008] - -
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:32
              U1111 00 [008] - -
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:32
              U1111 00 [008] - -
                        Reset counter: 134
                        Mileage: 144818 km
                        Date: 2019.08.20
                        Time: 16:05:32
    End----(Elapsed Time: 02:38, VBatt start/end: 12.1V/12.1V. VIgn 12.0V)-----
  2. Likes Uwe liked this post
  3. #2
    Aug 2019
    Romania
    we seem to have the same problem. Can you please check your auto trans connector and see if you had coolant ingress?
    Aug 2019
    Macedonia
    Quote Originally Posted by Geosan1638 View Post
    does your car lose communication with the ABS or the AutoTrans ECU?
    Aug 2019
    Romania
    just the ABS.
    Aug 2019
    Macedonia
    did you manage to solve the problem by cleaning the trans connector? cause this is really weird problem, and it happens from time to time, so you can never be sure you fixed it...
    Aug 2019
    Macedonia
    i have looked through your autoscan, you have a newer ABS module (4G0 907 379 F), whereas mine is revision B. it seems unlikely that the exact same problem will happen for different HW/SW revisions...
    Jan 2018
    Cheshire UK
    try connecting the flexray cable (2 core) directly to the sensor electronics (3B) under the centre console at the rear. Seems to a communication error that i can think of. Failing that replace the abs ecu
    A6 BiTdi Avant MTM
    Retrofitted: Full Led Headlights, DAB, Full Electric Seats, Power Tailgate, Surround View Cameras, Genuine RS6 Grille, RS6 Seats,Leather Door Armrests, Soft Close Doors, Rear Side Blinds, Electric Steering Column, LED Sill Plates, Ambient Lighting Pack, High Beam Assist, Eibach Springs, Led Roof Console, 4 Zone Climate, Rear Heated Seats, Head Up Display, Side assist, Alcantara Interior Retrim
  9. Likes vladomkd liked this post
  10. #8
    Aug 2019
    Macedonia
    Quote Originally Posted by morski View Post
    i'm sorry could you elaborate... isn't the ABS unit directly connected to the sensor electronics already?
  11. #9
    Jan 2018
    Cheshire UK
    Yes it is but seeing as you have a comms error on the flexray i would see what happens if its connected to it directly
    A6 BiTdi Avant MTM
  12. #10
    Aug 2019
    Macedonia
    Should this connection run in parallel to the existing one? Also, what about all the specs coming with flexray (termination, wiring in twisted pair etc...)?
