Results 1 to 3 of 3
Thread: 2015 Passat Tdi Se -Airbag Control Module/No Communication
    Aug 2019
    Texas, USA
    Hello Good people,
    My name is Bryan. I am the proud owner of a 2015 Passat tdi se. I am new to VCDS, This ismy first postas well as my first autoscan. I purchased the Hex can cable as a result of my airbag failure dashboard light coming on. Prior to ordering the cable I checked all fuses which all of them looked good, I removed the airbag control module and checked the connector for bent pins/noticeable damage and the module looked ok as well as the connector. With most of the faults reading the airbag control module has no communication I am guessing the ACM went out. Has anyone had these same faults and have any advice as to the best and most cost effective way to fix this? Any advice would be greatly appreciated.
    Thursday,22,August,2019,19:42:18:06070
    VCDS Version: 19.6.1.0  HEX-V2 CB: 0.4508.4
    VIN: 1VWBV7A36FC093834   License Plate:
    Chassis Type: A3-VW41 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 4F 52 56 62 72
              75 77
    VIN: 1VWBV7A36FC093834   Mileage: 78100km-48529miles
    15-Airbags -- Status: Malfunction 1010
    Address 01: Engine (J623-CVCA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 997 016 D    HW: 04L 907 309 K
       Component: R4 2.0l TDI   H20 9466
       Revision: 8AH20---
       Coding: 011D0012032410080000
       Shop #: WSC 04909 444 00000
       ASAM Dataset: EV_ECM20TDI01104L997016D 004002
       ROD: EV_ECM20TDI01104L997016D.rod
       VCID: 34311C564EBA14C71E1-8060
    4710 - No Communications with Airbag Control Module
              U0151 00 [040] - -
                        Mileage: 78015 km
                        Time: 00:00:00
                        Coolant temperature: 50 °C
                        Intake air temperature: 51 °C
                        Voltage terminal 30: 12.460 V
                        Limitation: accelerator pedal: 140.0 Nm
                        Cruise Control System (CCS): status-Bits 0-7: 2
                        selected gear-Bits 0-7: 0
       Part No SW: 02E 300 061 T    HW: 02E 927 770 AL
       Component: GSG DSG AG6     531 4518
       Revision: 05653104    Serial number: 00001501270285
       Shop #: WSC 09003 957 00200
       VCID: 2517F112F9E07D4F99F-8070
    28907 - No Communications with Cruise Control (Front) Distance Sensor
                U0235 - 000 -  - Intermittent
                        Fault Frequency: 73
                        Reset counter: 39
                        Mileage: 64385 km
                        Date: 2019.03.23
                        Time: 15:29:17
       Part No SW: 1K0 907 379 BS    HW: 1K0 907 379 BS
       Revision: 00H46001
       Coding: C54BC0F5492B00FDA31303E7921D0042A1100012
       VCID: 04518C965E1A6447EE1-8050
                        Reset counter: 46
                        Mileage: 78015 km
                        Count: 12
                        Count: 16384
                        Count: 8226
                        Count: 44544
                        Count: 65280
                        Count: 1
    02214 - Tire Pressure Warning
                        Reset counter: 6
                        Mileage: 78060 km
                        Date: 2019.08.22
                        Time: 08:53:48
                        Count: 16384
                        Count: 32768
                        Count: 8704
                        Count: 16401
                        Count: 49223
                        Count: 65534
                        Count: 65276
                        Count: 768
       Part No SW: 561 907 426 J    HW: 561 907 426 J
       Component: AC Manuell    H02 0404
       Revision: 00001K01
       Coding: 0010001002
       ASAM Dataset: EV_ACManuaElectGen2BHTC 001002
       ROD: EV_ACManuaElectGen2BHTC_VW36.rod
       VCID: 221DEA0EE44E8A77FCD-8076
    13701600 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Airbagsteuergerät - kein Signal/Kommunikation --> Fehlende Botschaft [ID] von Airbagsteuergerät]
                        Fault Frequency: 12
                        Reset counter: 46
                        Mileage: 78015 km
                        Date: 2019.08.21
                        Time: 19:52:02
       Part No SW: 5K0 937 085 AB    HW: 5K0 937 085 AB
       Component: BCM PQ35 B+   122 0174
       Revision: BH122001
       Coding: EF200E1B902B08D4098800010600044800F1A08640801520648060000C70
       VCID: 73B3DF4A0BB453FFC7B-8026
                        Reset counter: 46
                        Mileage: 78015 km
                        Date: 2019.08.21
                        Time: 19:52:02
                        Voltage: 12.25 V
       Part No SW: 5C0 959 655 AB    HW: 5C0 959 655 AB
       Component: AirbagVW10    500 0975
       Serial number: 003LZD06CKG/
       Coding: 00004D53
       Shop #: WSC 49769 002 1048576
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 72BDDA4E742E5AF7CCD-8026
       Serial number: 6940000Y150001C14K0B
       Coding: 303044
       Serial number: 3572MSME45101D4EZZZZ
       Serial number: 3582MSME40743C4EZZZ%
       Serial number: 3516KSME041B6735ZZZQ
       Serial number: 3526KSME115A6935ZZZU
       Serial number: 3556LSME60336634ZZZP
       Serial number: 3566LSME69086634ZZZ.
    9445892 - Seat occupied recognition control module
              B1022 04 [137] - Internal System Fault
                        Mileage: 74506 km
                        Date: 2019.07.17
                        Time: 08:21:37
       Part No SW: 1K5 953 521 BM    HW: 5K0 953 569 AE
       Component: LENKS.MODUL   016 0162
       Revision: FF010042    Serial number: 20150219200629
       Coding: 088A140000
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 79AFED62295829AF8D7-802C
       Component: E221__MFL-8LP  H07 0023
       Serial number: 00000000000001044553
       Coding: E20000
    Address 17: Instruments (J285)       Labels:| 5K0-920-XXX-17.clb-SRI1
       Part No SW: 561 920 970 G    HW: 561 920 970 G
       Component: KOMBI         H05 0813
       Coding: 231E01
       VCID: 1E65DEFED036AE97D85-804A
    12669184 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Steuergerät für Airbag: keine Kommunikation]
                        Reset counter: 46
                        Mileage: 78015 km
                        Date: 2019.08.21
                        Time: 19:52:01
       Part No SW: 7N0 907 530 AR    HW: 7N0 907 530 AM
       Component: J533  Gateway H55 1653
       Revision:   H55       Serial number: 08041503000791
       Coding: 461000
       VCID: 005980864A027867CA9-8054
                        Fault Status: 00110100
                        Reset counter: 46
                        Mileage: 78015 km
                        Date: 2019.08.21
                        Time: 19:52:00
    Address 1C: Position Sensing
       Component: IMMO          H05 0813
       VCID: 6A8DC22E5CFE923774D-803E
    Address 2E: Media Player 3
       Component: TUER-SG FT    002 0525
       Revision: 13110009    Serial number: 0009474590
       Coding: 0404B5
       ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
       ROD: EV_TSGFPQ25BRFVW46X.rod
       VCID: 5BE397EA83A4FBBFFFB-800E
       Slave Driver:
       Subsystem 1 - Part No SW: 561 959 811 B    HW: 561 959 811 B  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG_HL  006 5470
       Serial number: 14102630150413190222
       Coding: 800000
    68107 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Front CAN AirBag]
                        Reset counter: 46
                        Mileage: 78015 km
                        Date: 2019.08.21
                        Time: 19:52:02
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 215    3501
       Revision: 00H22000
       VCID: 392F2D626558E9AFCD7-806C
       Part No SW: 7N0 907 532     HW: 7N0 907 530 AM
       Component: EZE_2         H55 1653
       Coding: 01030108
       VCID: 6FBBD33A679C771F233-803A
       Subsystem 1 - Part No SW: 561 959 591 A    HW: 561 959 591 A
       Component: J245 P05 9BA3  H08 0005
       Serial number: 53388786011429501475
       Coding: 181100
       Subsystem 2 - Part No SW: 561 919 204 B    HW: 561 919 204 B
       Component: Analoguhr  009 0005
       Component: TUER-SG BT    002 0525
       Revision: 15110009    Serial number: 0009433614
       Coding: 0404B4
       ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
       ROD: EV_TSGBPQ25BRFVW46X.rod
       VCID: 5CE194F686AAFC87F61-8008
       Slave Passenger:
       Subsystem 1 - Part No SW: 561 959 812 B    HW: 561 959 812 B  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG_HR  006 5470
       Serial number: 14102631150413115755
       Coding: 800000
              U1111 00 [008] - -
              [Front CAN AirBag]
                        Reset counter: 46
                        Mileage: 78015 km
                        Date: 2019.08.21
                        Time: 19:52:01
       Part No SW: 1K0 035 188 F    HW: 1K0 035 188 F
       Component: Radio Prem-8  H08 0009
       Revision: -----13S    Serial number: VWZ4Z7R3697276
       Coding: 0100044004000B
       VCID: 2B03072A93044B3F4FB-807E
                        Fault Frequency: 25
                        Reset counter: 184
                        Mileage: 64343 km
                        Date: 2019.03.23
                        Time: 11:38:42
                        Reset counter: 31
                        Date: 2063.15.31
                        Time: 07:30:16
       Part No SW: 561 035 285 A    HW: 561 035 285 A
       Component: OCULowUSA     020 0156
       Serial number: 000003554140535
       Coding: 02140102C21632007F1606C00000
       ASAM Dataset: EV_OCULow 002009
       ROD: EV_OCULow_002.rod
       VCID: 1471BCD62EFAF4C77E1-8040
    0035 - Databus
              [CAN TO Airbag]
                        Fault Frequency: 12
                        Reset counter: 46
                        Mileage: 78015 km
                        Date: 2019.08.21
                        Time: 19:52:06
       Part No SW: 5N0 035 729 E    HW: 5N0 035 729 E
       Component: TELEFON       H07 0593
       Revision: 1B001001    Serial number: 00007666968540
       Coding: 0A10030080010110
       ROD: EV_UHVUMI.rod
       VCID: 323D1A4EB4AE1AF70CD-8066
    End----------(Elapsed Time: 01:38, VBatt start/end: 13.2V/13.2V)-----------
    16.4905° S, 151.7375° W
    We have a Ross-Tech wiki page for the fault code B1022-Seat occupied recognition control module that maybe of some help.
    Since the 'Seat Occupied Recognition Control Module (J706)' has an "Internal System Fault" it is most likely that the J706 is faulty.
    However I would still check the power, ground and signal connection to the Air Bag controller. There is a three pin connector [T3aj] on the J706, see the Official Factory Wiring Diagrams for more details.
    If you do end up replacing the J706 controller, I strongly recommend to use same exact part number or a newer version/part number if available. (Check with your local Volkswagen Parts department)
    Use this Ross-Tech wiki page to help with the Basic Settings for the Seat Occupied Recognition Control Module (J706).
    Hope this helps,
    drpeter
  3. Likes Uwe liked this post
    Aug 2019
    Texas, USA
    Will do and thank you very much! Should time permit given my hectic work schedule I hope to find the time to look more into this matter on Sunday. I will post status once I do, Thanks again!
