Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: DPF soot
  1. #21
    That's a learned value and isn't going to change much if at all.
    What bothers me is that it's different that the pressure value with key on, engine off. I can't recall whether the pressure reading should be zero, or whether the pressure reading plus the offset should equal zero, nor do I have a UDS TDI handy to look at right now..
  2. #22
    Sep 2018
    Ah ok tbh I have never had much to do with this before having my problems
    Iím calling Audi tomorrow to get a pressure sensor took it off today and I thrown a fault up plugged back in cleared fine
    I have what type it is now to get the exact one and I will try that
    I went out this evening for a regen while driving till the Dpf light went out and managed to get it down to 1.99 from 8.01 then it settled at 2.22 after the Dpf light went out
    Iím not sure a -2.26 reading on the soot mass messured is correct it was at 0.01 back 3rd July big the calculated was up at 21.25g at that point
  3. #23
    Sep 2018
    Replaced the pressure sensor now and done adaptions differential pressure is now 0 hPa when ignition on engine off and idle 8hPa
    Differential offset is now at 0 hPa
    Just doing a standing regen now
  4. Likes Uwe liked this post
  5. #24
    Sep 2018
    Update since I changed the sensor zero trouble from the car at all so seems to have sorted the issue
    Cheers for the help etc
  6. Likes Uwe liked this post
