Results 11 to 20 of 24
Thread: DPF soot
    Sep 2018
    Yes I have I think I will try and find it
    So having a -2.26 reading kinda says I have a faulty sensor ?
  2. #12
    Quote Originally Posted by Matt k View Post
    I'm not sure. A negative number is certainly puzzling.
  3. #13
    Sep 2018
    Sep 2018
    This was my other post with a Auto scan there are zero faults also
    It is very strange as I would expect a fault code if it was fault sensor
  5. #15
    Sep 2018
    Hi uwe
    Plugged in to my car this morning and the differential pressure readings was 2hPa with engine off and then idle it was at 8hPa reved to 2500 and was at 25hPa
    Iím not 100% what these readings are though is that what I should be expecting ?
    Cheers Matt
    Uwe did you see my reading when I checked the differential pressure readings
  6. #16
    Yes, I went back and saw them.
    What do you have in this measuring value?
    IDE00428 -- Particle filter: offset for differential press.
    Is this ECU mapped/chipped?
  7. #17
    Sep 2018
    I canít remember will have to plug the car back in and check
    Yes itís got a remap I think . Does that make any difference ?
  8. #18
    Yes it’s got a remap I think . Does that make any difference ?
    Some remaps "mess up" some diagnostics ...
  9. Likes Uwe liked this post
  10. #19
    Sep 2018
    So you think thatís the cause of all my problems ?
  11. #20
    Sep 2018
    Uwe the IDE00428 particle filter offset is 1hPa
    With just ignition on
    And the same at idle
