Results 1 to 10 of 18
Thread: A6 C7 HBA retrofit
    Oct 2018
    Spain
    A6 C7 HBA retrofit
    I would appreciate your help, because I cannot Initialize unite 20
    I am afraid some hidden code is hiding the possibility of updating the modules .
    No hardware has been changed
    First, I copy last Log where failure appears
    Second, I copy the very initial log of the car
    Thanks a lot for your help!!
    VIN: WAUZZZ4G2GN060932   License Plate:
    Mileage: 83340km-51785mi   Repair Order:
    Chassis Type: 4G-AU57 (4G8)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 20 3B 42 44 46 52 53 5F
              62 72 85 8B 8E 8F 90
    VIN: WAUZZZ4G2GN060932   Mileage: 83340km-51785miles
    17-Instruments -- Status: Not registered 0101
    20-High Beam Assist. -- Status: Cannot be reached 0100
    Address 01: Engine (J623-CYPA)       Labels:. 06L-907-115-V1.clb
       Part No SW: 4G5 907 115 B    HW: 8T2 907 115
       Revision: --H13---
       Coding: 0A2500322466010B2002
       ASAM Dataset: EV_ECM20TFS0204G5907115B 001003
       ROD: EV_ECM20TFS0204G5907115B.rod
       VCID: 290E0B21597F715FBD7-807C
       Part No SW: 4G0 927 166 P    HW: 0B5 927 156 K
       Component: 0B5 20TFSIRdW H03 0001
       Revision: --H03---
       Coding: 100001
       ASAM Dataset: EV_TCMDL501021 001021
       ROD: EV_TCMDL501021.rod
       VCID: 3A2CC46DACD9CAC7C4D-806E
       Coding: 11A69E49886579929B00
       ROD: EV_ESP9BOSCHAU57X_004_AU57.rod
       VCID: 41DEB381C10F991F857-8014
       Part No SW: 4H0 907 064 GN    HW: 4H0 907 064 GN
       Component: BCM2 2.0      H37 0572
       Coding: 01A8700E000000000000
       VCID: 7BA20169E3E333CF9FB-802E
    Address 08: Auto HVAC (J255)       Labels:* None
       Part No SW: 4G0 820 043 BH    HW: 4G0 820 043 BH
       Component: KLIMA 2 ZONEN H14 0112
       Serial number: 21071500110058
       Coding: 64011008A50000
       ASAM Dataset: EV_AirCondiBasisUDS 003009
       ROD: EV_AirCondiBasisUDS_003.rod
       VCID: 6694401D88E19E27505-8032
       Part No SW: 4H0 907 063 DF    HW: 4H0 907 063 AF
       Revision: 13020001    Serial number: 00001070385502
       Coding: 2600001500F471E28181408060001D0CCF9CC30826090201000004206101150200400008010000
       Shop #: WSC 31416 572 00329
       VCID: 6FBA2539A79B5F6F233-803A
       Component: WWS57X 150704  H37 0080
       Serial number:         150712021524
       Coding: 0045F7
       Serial number: 24098434
       Coding: 02006D
       Component: E1 - LDS  H07 0044
       Serial number: 16 07 2015  00000207
       Serial number: AEA84AB7000000000001
    03395 - Control Module for High Beam Assistant
                        Reset counter: 106
                        Mileage: 83210 km
                        Date: 2019.08.15
                        Time: 10:30:20
    Address 10: Park/Steer Assist (J791)       Labels:| 4H0-919-475-7X5.clb
       Part No SW: 4G0 919 475 G    HW: 4H0 919 475 E
       Component: PARKHILFE PLA H06 0070
       Revision: --------    Serial number: 56231520200518
       Coding: 980B14
       ASAM Dataset: EV_EPHVA2CAU64X0000 001011
       ROD: EV_EPHVA2CAU64X0000.rod
       VCID: 3536D75185C725BF29F-8060
       Part No SW: 4G0 907 561 B    HW: 4G0 907 561
       Component: ACC3          H21 0053
       Coding: 7C04010202
       ASAM Dataset: EV_AdaptCruisContrAU57X 002014
       ROD: EV_AdaptCruisContrAU57X_002.rod
       Part No SW: 4H0 959 655 H    HW: 4H0 959 655 H
       Component: Airbag10.43   H82 0086
       Revision: --------    Serial number: 003P1005U6C$
       Coding: 30333130313630323532554A304C34473053
       VCID: 3B22C169A3E3F3CFDFB-806E
       Serial number: 3575HRB404R3CGVGAPDL
       Serial number: 3585HRB404P3CGVG7OVY
       Serial number: 3515JRB405R3GICEE06I
       Serial number: 3525JRB405L3G5J43GMI
       Serial number: 3554VRB405B3G5J24OV
       Serial number: 3564VRB40593G5J2P0VY
       Part No SW: 4H0 953 568 G    HW: 4H0 953 568 G
       Revision: --------    Serial number: 90372OGP00022
       Coding: 00003C
       VCID: 372ADD599F4BD7AF3B3-8062
       Serial number: 09 06 2015  C0022386
       Part No SW: 4G8 920 934 F    HW: 4G8 920 934 F
       Component: TBenRdwAcc    H10 0104
       Revision: 06001087    Serial number: 658240715596019
       Coding: 138608000F450008050000
       ASAM Dataset: EV_RBD4K 004055
       ROD: EV_RBD4K_AU57.rod
       VCID: 3430EA558EBD3CB71E1-8060
       Part No SW: 4G8 907 468 F    HW: 4G8 907 468
       Component: J533--Gateway H14 0083
       Revision: --------    Serial number: 00000001933616
       Coding: C0CD072918
       ASAM Dataset: EV_GatewPkoUDS 001028
       Serial number: 9616267303
       Voltage stabilizer:
       Serial number: 15051500000000000055
    5701 - High Beam Assistant Control Module
              U1070 00 [009] - No Communication
                        Reset counter: 106
                        Mileage: 83210 km
                        Date: 2019.08.15
                        Time: 10:30:57
                        Voltage terminal 30: 14.3 V
                        Voltage terminal 15: 14.3 V
                        Control Module temperature: 24 °C
                        System status: Terminal 15 on
                        Engine running: On
                        IN ZAS_Te_X: On
                        Terminal 15 status: On
                        Datenfeld: 0
    0021 - Control Module Incorrectly Coded
              U1014 00 [009] - -
              [Steuergerät falsch codiert (CAN)]
                        Fault Frequency: 18
                        Reset counter: 110
                        Mileage: 83012 km
                        Date: 2019.08.14
                        Time: 10:13:39
                        Voltage terminal 30: 14.2 V
                        Voltage terminal 15: 14.2 V
                        Control Module temperature: 27 °C
                        Engine running: On
                       IN ZAS_Te_X: On
                        Datenfeld: 0
    Address 20: High Beam Assist.
       Component: SARA 6D       H04 0056
       Revision: --------    Serial number: EJ1BPA8209WC3H
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 3634D05D98C12EA7205-8062
       Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
       Component: TSG FA        H04 0507
       Coding: 011C17015C00628002080003
       VCID: 45D6A791D5A7B53FB9F-8010
       Part No SW: 4G0 909 144 S    HW: 4G0 909 144 G
       Component: RCEPS         H43 0012
       Revision: 00001000    Serial number: 0006006213
       Coding: 101100010001
       ASAM Dataset: EV_RCEPS 009013
       ROD: EV_RCEPS_009.rod
       VCID: 392EDB61A9DFC1DFCD7-806C
       Revision: 00002001    Serial number: 0375319625
       Coding: 0100063800B90080833008040C010E470000000000000000000000000000
       Coding: 011C17015E04628002080002
       Shop #: WSC 31416 000 00000
       VCID: 46D4A09DE8A1BE27B05-8012
    00380 - Special Vehicle Control Module (J608)
                        Fault Frequency: 47
                        Reset counter: 110
                        Mileage: 83012 km
                        Date: 2019.08.14
                        Time: 10:13:36
       Revision: --------    Serial number: 00000001544296
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2D06FF316D976D7F51F-8078
       Part No SW: 4G1 035 043 R    HW: 4G1 035 043
       Component: MU-H-N-EU     042 0335
       Serial number: A591G0F7539704
       Coding: 01750101FF0A000013110001000A00002F0006E5F17001009F
       Subsystem 1 - Part No SW: V03 959 801 PR    HW: -----------
       Component: ECE 2018  --- 0166
       Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A
       Component: DU8 C7 SV  H63 0006
       Serial number: AUZ8Z9FY802A8J
       Multimedia Operating Unit:
       Serial number: 90349OGN00088
       Component: Gracenote  --- 1010
       Coding: 010815004000628002080002
       VCID: 49CEABA1F9BF515F5D7-801C
       Part No SW: 4H0 907 217 F    HW: 4H0 907 217 A
       Component: DPC-SG        H27 0081
       Coding: 6A040000
       ROD: EV_OnBoardCamerDPC.rod
       VCID: 2C00F235568D6477461-8078
       Part No SW: 4G0 907 541 B    HW: 4G0 907 541
       Coding: 7C04010202
       ASAM Dataset: EV_AdaptCruisContr2AU57X 002012
       ROD: EV_AdaptCruisContr2AU57X_002.rod
       VCID: 270A0D194F6B472FAB3-8072
       Part No SW: 4H0 907 107 H    HW: 4H0 907 107
       Component: BV-SG         H33 0092
       Serial number: 005000622207157
       Coding: 0480A9181111
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
       Coding: 00660600031F0376000308014248D2010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 313EE34171AF099F757-8064
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       VCID: 323CEC4D74A932870CD-8066
    End----------(Elapsed Time: 01:42, VBatt start/end: 13.3V/13.3V)-----------
    Sunday,15,November,2015,10:52:07:33490
    VCDS Version: 12.12.3.0 (x64)
    Data version: 20140905
    VIN: WAUZZZ4G2GN060932   License Plate: 5050
    Chassis Type: 4G (4G8)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 3B 42 44 46 52 53 5F 62
              72 85 8B 8E 8F 90
    Address 01: Engine (J623-CYPA)       Labels: None
       Revision: --H13---
       ROD: N/A
       VCID: 295F8BFF487BF056EC3-807C
    No ASAM data for: "EV_ECM20TFS0204G5907115B" (AU57)
    Address 02: Auto Trans (J217)       Labels: 0B5-927-156.clb
       Revision: --H03---
       Coding: 100001
       VCID: 3A7D44B3BDDD4BCE959-806F
    Address 03: ABS Brakes (J104)       Labels: 4G0-907-379.clb
       ROD: N/A
       VCID: 418F335FD00B1816D43-8014
    No ASAM data for: "EV_ESP9BOSCHAU57X" (AU57)
       VCID: 7BF381B7FA67B2C6CEF-802E
       ROD: EV_AirCondiBasisUDS.rod
       VCID: 66C5C0C399E51F2E011-8033
    Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063.clb
       Coding: 2600001400349FE28181408000001D0C0F9CC30826090201000004206101150200400008010000
       VCID: 6FEBA5E7BE1FDE66727-803A
       Coding: 0045F7
       Coding: 02006D
    Address 10: Park/Steer Assist (J791)       Labels: None
       Coding: 980B14
       ROD: EV_EPHVA2CAU57X0000.rod
       VCID: 3567578F94C3A4B678B-8060
    Address 13: Auto Dist. Reg (J428)       Labels: 4H0-907-561.clb
       Coding: 7C04010202
       ROD: EV_AdaptCruisContrAU57X.rod
    Address 15: Airbags (J234)       Labels: 4H0-959-655.clb
       VCID: 3B7341B7B2E772C68EF-806E
       Crash sensor for front airbag; passenger side:
       Coding: 00003C
       VCID: 377B5D8786CF56A66A7-8062
    Address 17: Instruments (J285)       Labels: 4H0-920-xxx-17.clb
       ROD: EV_RBD4K.rod
       VCID: 34616A8B9FB9BDBE4F5-8061
       Coding: C0CD072918
       ROD: EV_GatewPkoUDS.rod
       Voltage stabilizer:
       ROD: EV_SARA2_AU57.rod
       VCID: 3665508389C5AFAE711-8063
       VCID: 4587274FCC233436E8B-8010
    Address 44: Steering Assist (J500)       Labels: None
       ROD: EV_RCEPS.rod
       VCID: 397F5BBFB8DB40D69C3-806C
    Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
       Coding: 011C17015E00628002080002
       VCID: 46852043F1253F2EE11-8013
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 2D577FEF7C93EC7600B-8078
       Part No SW: 4G1 035 043 E    HW: 4G1 035 043
       ROD: EV_MUHig6C3Gen2HBAS.rod
       VCID: 204996DB3B41311EBBD-8075
       Engine Control Module 2:
       Subsystem 1 - Part No SW: V03 959 801 F    HW: -----------
       Component: ECE 2015/2016  --- 0122
       Seat Adjustment Driver Side:
       Sound System:
       Door Electronics Rear Left:
       VCID: 499F2B7FE03BD0560C3-801C
    Address 85: On Board Cam. (J852)       Labels: None
       Coding: 6A040000
       VCID: 2C5172EB4789E57E175-8079
    Address 8B: Adaptive Cruise 2 (J428)       Labels: 4H0-907-561.clb
       Coding: 7C04010202
       ROD: EV_AdaptCruisContr2AU57X.rod
       VCID: 275B8DC75E6FC626FA7-8072
    Address 8E: Image Processing (J851)       Labels: None
       Component: BV-SG         H33 0090
       ROD: EV_BC7.rod
       ROD: EV_RGS_L.rod
       VCID: 316F639F60AB8896243-8064
       ROD: EV_RGS_R.rod
       VCID: 326D6C9365ADB38E5D9-8067
    End   -
    OP is verified. Moving to Retrofits.
    I'll note that the second scan above (the "initial" scan) is from a clone, but I will let that slide since he has come clean with a properly registered HEX-V2.
    Since HBA "Cannot Be Reached" I suspect a wiring problem.
    Oct 2018
    Spain
    No cable problem
    I don’t expect any problems with cables because the car has ACC and this system shares cabling from the front mirror sensor and image processor (and ACC performances are ok)
    is there any other HBA dedicated cable I should check?
    Thanks a lot
    Quote Originally Posted by Juan View Post
    AFAIK the ACC doesn't make use of the 20 camera module, only the front radar?
    I would check fuses and wiring to the 20 module using the WD relevant to your car.
    Sep 2018
    Spain
    Can you say what connections you have made and what coding?
    Oct 2018
    Spain
    I haven’t changed any cable, nor pins in connector. Hardware remains as first day!
    the only change has been in configuration (by means of legal vcds interface) and you can see it from my initial message
    Is there any dedicated fuse for this hba function? because I am checking Audi wiring schemata and I cannot find it
  7. #7
    Sep 2018
    Spain
    hba is in the rearview mirror. It is not the camera of the acc or lane assist.
  8. #8
    Sep 2018
    Spain
    Dec 2016
    Amsterdam
    Are you sure youre not looking at a photosensor for a mirror with dimming function?
    Also, anything that is not needed (wires, control modules, brackets, etc) for how the car came out of the factory is never fitted to your car and will have to be retrofit.
    Current:
  10. #10
    Oct 2018
    Spain
    Ok, HBA ifunction is in rear mirror electronics, but my car has that rear mirror electronics suitable for HBA, and those units do not report any power supply fault (they are properly connected to main supply), CONCLUSION: there is no wiring problem and unit 20 has to be availabe for VCDS.
    Address 8E: Image Processing (J851) Part No SW: 4H0 907 107 H HW: 4H0 907 107------------------------------------
    Address 85: On Board Cam. (J852) Part No SW: 4H0 907 217 F HW: 4H0 907 217 A
    Address 3B: Sensor Elect. (J849) Part No SW: 4G0 907 637 K HW: 4G0 907 637 F
    I am lost.. I know there is a wrong step in my rationale, Please tell me what`s wrong
