Results 1 to 9 of 9
Thread: 2015 Golf MK7 R BOOT / REMOTE FOB ISSUES
    New User
    Aug 2019
    Ireland
    Hi guys , first time posting here so hopefully I'm in the right section.
    I've also purchased the vcds kit in the hope i can possibly rectify some coding I'm told was done by the previous owner.
    i'll do my best to explain the car itself has keyless entry , I've also gone through all settings on infotainment and nothing fixed it.
    so my issue is when i walk up with my key in hand to open boot with keyless entry it stays locked.
    so i press the lock button on the remote and presto i can then pull latch and the boot opens.
    if i come out first thing in the morning and just hold down the boot open on key fob the boot releases but sets the car alarm off.
    i hope I've explained this issue fairly well its basically the boot lock appears to work in reverse.
    all functions are working just the wrong way around.
    im not sure what to do from here do i need to post a vehicle scan or can any suggest any pointers.
    thanks for reading and hopefully i can get some help.
    Yes, please do post an Auto-Scan so people can see how this car is equipped and configured.
    New User
    Aug 2019
    Ireland
    Ok Great I’ll try do it in the morning!
    New User
    Aug 2019
    Ireland
    Wednesday,21,August,2019,12:50:51:11308
    VCDS Version: 19.6.1.0 (x64)
    VIN: WVWZZZAUZFW239900   License Plate: 151DDAVE
    Mileage: 69224km-43013mi   Repair Order:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 20 22 2B 42 44 47 52
              55 5F A9
    VIN: WVWZZZAUZFW239900   Mileage: 69224km-43013miles
              55 5F A9
    A9-Struct. Borne Sound -- Status: Not registered 0001
    Address 01: Engine (J623-CJXC)       Labels:. 06K-907-425-V1.clb
       Part No SW: 5G0 906 259 E    HW: 06K 907 425 B
       Component: 2.0l R4 TFSI  H13 0005
       Revision: --H13---
       Coding: 091D00322466050B3004
       ASAM Dataset: EV_ECM20TFS0205G0906259E 001005
       ROD: EV_ECM20TFS0205G0906259E.rod
       VCID: 3065E5826B0F7FCF29-8064
    15072 - Engine Start Blocked by Immobilizer
              P1570 00 [104] - -
                        Mileage: 69089 km
                        Date: 2019.08.19
                        Time: 19:40:55
                        Engine speed: 1320.50 /min
                        Normed load value: 5.9 %
                        Coolant temperature: 91 °C
                        Intake air temperature: 58 °C
                        Voltage terminal 30: 12.089 V
                        FRF_IMMO_SNAPSHOT_BYTE1: 25
                        FRF_IMMO_SNAPSHOT_BYTE2: 127
                        FRF_IMMO_SNAPSHOT_BYTE3: 140
                        FRF_IMMO_SNAPSHOT_BYTE4: 27
                        FRF_IMMO_SNAPSHOT_BYTE5: 16
                        FRF_IMMO_SNAPSHOT_BYTE6: 0
                        Engine: operating status: IS
    Readiness: 0010 0001
       Part No SW: 0D9 300 012 L    HW: 02E 927 770 AQ
       Component: DQ250-6A MQB  H53 4522
       Revision: 03253104    Serial number: TFK01501121573
       ROD: EV_TCMDQ250021.rod
       VCID: 1F47163E0691F0B780-804A
       Part No SW: 3Q0 907 379 R    HW: 3Q0 907 379 G
       Component: ESC           H42 0711
       Revision: 00000000    Serial number: 60165000001724
       Coding: 01FA93A1542329750780070041C36980C92A94E0E08296F7184250F8C208
       VCID: 4993A866E8952E070E-801C
       Revision: 00021000    Serial number: 0357554449
       Coding: 030C0C
       VCID: 3A71C7AABD73B59F97-806E
       Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
       Revision: 00001K08
       Coding: 00120014200100011005000000101000
       VCID: 6AD137EA8D53C51F27-803E
       Component: BCM MQBAB H   H18 0137
       Serial number: 01011501900387
       Coding: 03111B46C64122F30BA44080B10407281800000000000000000000000000
       ROD: EV_BCMBOSCH_013.rod
       VCID: 000575429B2F2F4F99-8054
       Component: WWS    150103  042 0551
       Serial number:         150108205225
       Component: RLHS  037 0059
       Serial number: S4Y15M01D21H22M40S18
       Coding: 00A8DD
       Serial number: 000000000ZY1500704XA
       Serial number: 00000000000031523620
       Sun Roof:
       Component: J245 PS73.403  H02 0003
       Serial number: 0000FST0002MHGL00000
       Coding: 181801
    197644 - Control Circuit for Fuel Tank Flap
              B1263 01 [008] - Electrical Failure
                        Fault Frequency: 45
                        Reset counter: 89
                        Mileage: 69089 km
                        Date: 2019.08.19
                        Time: 19:31:03
       Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0048
       Revision: --------    Serial number: 39391501405271
       Coding: 0071151011
       VCID: 3D7BCCB6AC5D82A7B2-8068
       Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
       Component: ACC Bosch MQB H05 0304
       Serial number: 17121403271532
       Coding: 001C1300FE0739
       VCID: 3875DDA2837FA78F61-806C
       Part No SW: 5Q0 907 376     HW: 5Q0 907 376
       Component: DAEMPFUNGS-SG H16 0115
       Serial number: 20121441350052
       ROD: EV_DRCONTITEMIC_VW37.rod
       VCID: 76E9139AC9EB11FFB3-8022
       Component: AirbagVW20    014 0385
       Serial number: 003F6R0F6YFZ
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 4183B046D0A5E647D6-8014
       Subsystem 1 - Part No SW: -----------    HW: 480 001 601 15
       Serial number: 35767000000D8AF09210
       Subsystem 2 - Part No SW: -----------    HW: 480 001 501 15
       Serial number: 3586700000027D29B21X
       Subsystem 3 - Part No SW: -----------    HW: 480 401 401 15
       Serial number: 35165029B1901DA44356
       Subsystem 4 - Part No SW: -----------    HW: 480 401 401 15
       Serial number: 3526502A9196FF40912I
       Subsystem 5 - Part No SW: -----------    HW: 480 401 501 15
       Serial number: 3556502C319121A483E8
    Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
       Part No SW: 5Q0 953 507 EC    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 15011504401108
       Coding: 0C10
       ROD: EV_SMLSKLOMQB_010_VW37.rod
       VCID: 7BFF02AEF2C94C97CC-802E
    No ASAM data for: "EV_SMLSKLOMQB" (VW37)
       Part No SW: 5G1 920 758     HW: 5G1 920 758
       Component: KOMBI         304 4310
       Coding: 27AD08183F80040800887E011400000000000000
       VCID: 6CDD31F287A7DB2F55-8038
    9456128 - Engine Control Module (ECM) not authorized
              B104A 00 [009] - -
                        Fault Frequency: 17
                        Mileage: 69089 km
                        Date: 2019.08.19
                        Time: 19:40:54
       Part No SW: 5Q0 907 530 AC    HW: 5Q0 907 530 F
       Component: GW MQB High   128 1204
       Revision: --------    Serial number: 0002965523
       Coding: 030100042F085900EF00027A9C0F00010001050000000000000000000000
       ASAM Dataset: EV_GatewLear 011020
       ROD: EV_GatewLear_011.rod
       VCID: 72E12F8AA5830DDF9F-8026
       Component: E221__MFL-DC1  H10 0038
       Serial number: 36150000025040075025
       Coding: 2DFFFF
       Serial number: 5565015503
    66304 - Databus
              U1124 00 [009] - Additional Installations Detected
                        Fault Frequency: 62
                        Reset counter: 49
                        Mileage: 69084 km
                        Date: 2019.08.19
                        Time: 19:16:12
                        Terminal 15: On
    Address 20: High Beam Assist. (J844)       Labels:| 8X0-857-511.clb
       Part No SW: 5G0 857 511 D    HW: 5G0 857 511 D
       Component: FLA           H05 0002
       Revision: AA001001
       Coding: 02028864727264565625393E01
       VCID: 2B5FF2EE42291C171C-807E
       Serial number: HA1-00017.11.14
       Coding: 0001
       VCID: 4689A35AF98BC17FE3-8012
       Revision: 00000000    Serial number: 15000010357001
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 346DE9929F1743EF4D-8060
       Part No SW: 5Q0 959 593 D    HW: 5Q0 959 593 B
       Serial number: 150115BA612242
       Coding: 003F1220D001040000001000
       VCID: 4281BF4AD5A3FD5FCF-8016
       Serial number: 00000000000005016677
       Coding: 0D0000
              B1487 54 [008] - Missing Calibration / Basic Setting
                        Reset counter: 87
                        Mileage: 69167 km
                        Date: 2019.08.20
                        Time: 14:16:40
       Coding: 8103
       VCID: 3777DE9E8E61A8F768-8062
    Address 47: Sound System (J525)       Labels:| 5G0-035-456.clb
       Part No SW: 5G0 035 456     HW: 5G0 035 456
       Component: MIB_lite_amp  H40 0060
       Serial number: VWZ8Z1EC40244W%
       Coding: 120000008AAA8A0000
       ASAM Dataset: EV_AMPMst11CALPI 001007
       ROD: EV_AMPMst11CALPI.rod
       VCID: 63CF5ACE6A799457E4-8036
       Part No SW: 5Q0 959 592 D    HW: 5Q0 959 592 B
       Serial number: 120115BAC07127
       Coding: 003F1020DE01040000801000
       Serial number: 00000000000004937392
       Coding: 150000
       Coding: 02A602000B010200
       VCID: 4085B542DBAFEF4FD9-8014
       Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
       Coding: 2E0000
       Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
       Coding: 2E0000
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH1.clb
       Part No SW: 5G0 035 043 E    HW: 5G0 035 043 D
       Component: MU-H-N-EU     H44 0376
       Serial number: A309A0F7521764
       Coding: 027300010000000011110002000800001F0207F60100010057
       ASAM Dataset: EV_MUHig4CHBAS 001040
       ROD: EV_MUHig4CHBAS_VW37.rod
       VCID: 204515C23BEFCF4FB9-8074
       Component: ABT_High  H62 0031
       Serial number: VWZ8Z9PU300AUZ
       Subsystem 2 - Part No SW: V03 959 801 DG    HW: -----------
       Component: ECE 2016/2017  --- 0153
       Component: Gracenote  --- 1010
       Part No SW: 5G0 907 159 B    HW: 4H0 907 159 A
       Component: SAS-GEN 2     H07 0006
       Serial number: 141121201809
       VCID: 2D5BFCF67C3D122702-8078
    End-------------------------(Elapsed Time: 05:56)--------------------------
    New User
    Aug 2019
    Ireland
    Just posted the autoscan hopefully that makes some sense to the more knowledgeable folk on here.
    Would be very grateful if anyone could help.
    New User
    Aug 2019
    Ireland
    Hi uwe , I’ve done that but no luck with a reply , I’m unable to post in the verified section aswel? Can you help me please 🙏🏻
  7. #7
    Quote Originally Posted by Davers1 View Post
    Less than 12 hours passed between the time you posted your scan and the time you posted this.
    Personally, I'm not sure what's up with your car. I don't think it's the remotes themselves, but some kind of configuration problem with your BCM. What changes have you made to it?
    I’m unable to post in the verified section aswel? Can you help me please ����
    That's because you're not Verified. The system you're using is registered to someone named "Shane", whereas your profile here says your name is "Dave".
  8. Likes Viking liked this post
  9. #8
    New User
    Aug 2019
    Ireland
    No problem Shane is my boss hopefully he can sort this.
    I haven’t done any coding I bought the car with the boot like this , the previous owner did coding but wasn’t sure what he did?
    Thanks for your time
  10. #9
