Results 11 to 20 of 30
Thread: I have number of codes here some I think I know what is wrong others I do not.
    Verified Coal Cracker
    Mar 2014
    Wilkes-Barre, PA
    Only way you will feel the air in exhaust is.
    Apply vac with a hand pump to Kombi and jumper the pump to run constant. Jumper at relay or apply direct power.
    Engine off you should feel air (no exhaust leak) and hear it.
    If you have second person take vac away from kombi and apply it. Kombi allows flow into exhaust. Could be stuck closed?
    Good Luck
  2. Likes Jack@European_Parts liked this post
  3. #12
    Sounds like it's time for coat hanger abortion of the SAI port with follow up baby bottle brushes, no?
    You could get festive and make a video while installing a Trojan on the cars tail pipe and see if the SAI pump will blow it up?
  4. #13
    Aug 2019
    Canada
    not yet it looks like someone stripped the allen key bolt so now I have to get creative as to how to remove it :-(
  5. #14
  6. #15
    Aug 2019
    Canada
    Thank you that did the trick
    there does not seem to be that much build up in the passageways. I did verify that the kombi valve is working as it passes or shuts off the airflow based on the vacuum being pulled. Note the amount of air coming out of the kombi valve is less than directly out of the outlet of the pump but I assume that is because the corrugated hose to the kombi valve creates a lot of restriction.
    while the pump is running and I have vacuum I place a piece of paper over the exhaust tip and there did not seem like anything was happening. in fact, there seemed to be a little vacuum.
    So still unsure about what to do next
  7. #16
    Aug 2019
    Canada
    Did you clear the pipe through the exhaust conduit yet and after the combi valve?
    Of course air is clear from pump to valve, what could possibly obstruct this?
  9. #18
    Aug 2019
    Canada
    yes there was no build up just carbon discoloration
  10. #19
    So if combi is removed and you blow compressed air in, the tail pipe will blow up a Trojan when attached?
  11. #20
    Aug 2019
    Canada
    so using compressed air I can blow off two rubber gloves fitted over the tail pipes. I connected the combi vale and the SAI and turned it on and that also blew the rubber gloves off the tail pipes. (I suspect that previously when I only put my hand over one tail pipel it just forced the air out the other)
    So as far as I can tell it all works so why am I getting that code?
