Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: 2004 vw beetle avh, code for part the it doesnt have?
    Aug 2019
    Aug 2019
    I confirmed engine codes and checked the others as well
  3. #13
    Vehicle Identification No. 3VWCK21C53M404423
    Model New Beetle
    BE
    Date of production 28.06.2002
    Model year 2003
    Sales type 1C15H4
    Engine Code AVH
    Transmission Code EGT
    Emission standard 0GN Emission standard ULEV 1
    Looks like a G297 can be a G187 or maybe G188 no?
    Maybe tone out as per pins directly & to verify, then see what changes in diagnostic stack for codes with a decade box?
    Did you unplug the OXS sensors or consumers yet when the problem happens to see if problem vacates?
  4. #14
    Aug 2019
    what do you think of the diagram, its listed as for the AVH. Do you have a screen shot of the one you are using that shows the g279? that would really help.
  5. #15
    Nope figure it out on your own by asking yourself the aforementioned questions & by isolation would be much more fulling no?
    Maybe you found a discrepancy and thank you for showing a screen shot it looks right to me what you have and maybe the stack is wrong, now figure out how with decade box, right?
    Thank you for proving to me you are using a schematic.........
  6. #16
    Did you check the grounds under battery as per TSB and overlay for ground lug to coil pack?
    What part number MAF is in this because I suspect it is FOD?
    17551 load calculation cross check
    p1143-35-00 upper limit exceeded
    17553 mass air flow sensor g70
    p1145-35-10 short to plus intermittent
  7. #17
    Did you clean and lubricate the TV yet in this car?
  8. #18
    Aug 2019
    car is fixed. talked customer into a new throttle body and all is well. Nostrajackass thanks for your help, (good name btw) I dont not believe this car has a g297 even though others claimed it did. I suspect its the g187. I think they were not actually checking diagrams just repeating what the code said and i all ready knew. I think this maybe a fault with ross-tech software as i saw this problem mentioned other places but never resolved. When i called to talk to ross tech about this, they wanted to charge me $40 for a case file or something like that. I hope others find this looking for info on this code.
  9. Likes jyoung8607, Uwe liked this post
  10. #19
    Glad you fixed it OP........congratulations!
