Results 1 to 9 of 9
Thread: Coding for LED Bulb Out dash warning light 2013 Golf 2.5L
    May 2016
    Canada
    Greetings!
    Changed some of the lights in the back of my 2013 Golf 2.5L with LED and of course I received the amber 'Bulb Out' light on dashboard.
    I have the VagCom cable registered for the car but I wanna be sure I do the right coding on Bit 18 and not do some irreversible damage to the coding.
    Found this on youtube but not sure if applies to my car:
    https://www.youtube.com/watch?v=-J91O3ClPCY
    I will gladly use some wisdom and knowledegeable advise from any of you. Thanks.
    Gonna need you to post a VCDS Auto-Scan of your Golf to suggest needed changes, which might be adaptation not coding.
  3. Likes Uwe liked this post
    May 2016
    Canada
    Saturday,17,August,2019,11:15:08:64309
    VIN: WVWDA7AJ1DW101XXX   License Plate:
    Chassis Type: AJ-VW36 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
    VIN: WVWDA7AJ1DW101307   Mileage: 71440km-44390miles
    Address 01: Engine (CBT)       Labels: 07K-906-055-CBT.clb
       Part No SW: 07K 906 055 DH    HW: 07K 907 309 B
       Component: 2,5l R5/4V      G01 3848
       Revision: T4H06---    Serial number:
       Coding: 0000075
       VCID: 77A8E2B9B3C2F7EFFB3-8022
       Part No SW: 09G 927 750 LM    HW: 09G 927 750 LM
       Component: AQ 250 6F           2252
       Revision: 00H97000    Serial number:
       Coding: 0000840
       VCID: 07489279C322876F8B3-8052
       Revision: 00H31001
       Coding: 114B400C492200FB880E02E492200041310000
       VCID: 7DA4F0919DFEDDBFA1F-8028
       Part No SW: 7N0 907 426 BH    HW: 7N0 907 426 BH
       Component: AC Manuell    H20 0505
       Revision: 00001018
       Coding: 0010004002
       VCID: 7BA0FE89836AD38F9FB-802E
       Part No SW: 1K0 937 084 J    HW: 1K0 937 084 J
       Component: BCM PQ35  B   111 0709
       Revision: AC111709
       Coding: 6F180A1A94232EC4008000C15000044448010386524D8D60648020200040
       VCID: 353428B1E54EC5FF29F-8060
       Component: Wischer 19091  26  0512
       Coding: 009795
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 205
                        Mileage: 71447 km
                        Date: 2014.01.07
                        Time: 23:03:38
                            Term 15 On
                        Voltage: 14.05 V
                            Term 50 Off
    00984 - Left Tail Light (M4)
                        Reset counter: 205
                        Mileage: 71447 km
                        Date: 2014.01.07
                        Time: 23:03:39
                            Term 15 On
                        Voltage: 14.10 V
                            Term 50 Off
    00985 - Right Tail Light (M2)
                        Reset counter: 205
                        Mileage: 71447 km
                        Date: 2014.01.07
                        Time: 23:03:39
                            Term 15 On
                        Voltage: 14.10 V
                            Term 50 Off
                        Reset counter: 205
                        Mileage: 71447 km
                        Date: 2014.01.07
                        Time: 23:03:39
                            Term 15 On
                        Voltage: 14.10 V
                            Term 50 Off
       Part No SW: 5C0 959 655 M    HW: 5C0 959 655 M
       Component: AirbagVW10G   014 0726
       Serial number: 003L4R00U2RS
       Coding: 00004734
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 3C223D95C6E414B7D61-8068
       Serial number: 3572MSME2F062372ZZZU
       Serial number: 3582MSME54586072ZZZV
       Serial number: 3512QSME543E2071ZZZR
       Serial number: 3522QSME762D192BZZZ0
       Serial number: 35527SME24694A2EZZZR
       Serial number: 35627SME5D264C2EZZZZ
       Part No SW: 5K0 953 507 AE    HW: 5K0 953 549
       Revision: --------    Serial number:  90440LIM000WI
       Coding: 5880140000
       ROD: EV_SMLSNGKUDS_A05.rod
       VCID: 73B0D6A9AB3A9BCFC7B-8026
       Part No SW: 5K0 920 863     HW: 5K0 920 863
       Component: KOMBI         H05 0705
       Coding: 370F00
       VCID: 6C82CDD5F6044437061-8038
       Part No SW: 7N0 907 530 AB    HW: 7N0 907 530 AB
       Component: J533  Gateway H47 1633
       Revision:   H47       Serial number: 150912F1000407
       Coding: 350002
       VCID: 70BAD9A5DAACA0D73A9-8024
                        Reset counter: 205
                        Mileage: 71447 km
                        Date: 2014.01.07
                        Time: 23:02:05
       Component: IMMO          H05 0705
       VCID: 6A8ECBCDFCF05A0774D-803E
       Coding: 0001204
       VCID: 313C1CA11D26E9DF757-8064
       Part No: 1K0 909 144 P
       Component: EPS_ZFLS Kl. 69     3305
       Revision: 00H22000
       VCID: 372822B9F34237EF3B3-8062
       Coding: 0001204
       VCID: 323E13AD1820D2C70CD-8066
    Address 56: Radio
       Coding: 0001168
       Shop #: WSC 01357 011 1012552
       VCID: 353428B1E94EC5FF29F-8060
       Coding: 0001168
       VCID: 36362FBDF448CEE7205-8062
    End----(Elapsed Time: 00:52, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
    Hah! Byte 18 is not masked with 00:
       Revision: AC111709
    May 2016
    Canada
    Forget my ignorance, Uwe, what would that means and what do I need to do?
    Danke!
    Quote Originally Posted by Val View Post
    Danke!
    It means it's relatively safe to change byte 18 because you know what it needs to be changed back to if your changes don't work out. However, I am by no means an expert on byte 18 values, so I'm not going to suggest any values to try.
  8. Likes PetrolDave, Val liked this post
    May 2016
    Canada
    Thanks again.
    In the youtube video I attached on my first post, the guy changed the Binary and just clicked on Byte 18 and the new value just loaded without input.
    Is that one way of doing it and another way is just inputting the Byte 18 value?
    Ain't no way I can find out the right value for my car unless I found someone with the same car who has successfully done it? Or going to a dealer with it and have them re-code it?
  10. #8
    May 2016
    Canada
    Thanks again.
    I think I know why he did it like that. This was the old way of changing Byte 18 and I believe is no longer there in the new version of VCDS. I've seen some posts saying that there are combinations from 00 to 15, is that the case?
  11. #9
    May 2016
    Canada
    So I looked under the options I have under Byte 18 and I took a screen shot for it but unfortunately I can't post it here. Mine looks like it is 03 set for Golf (5K1/VW360) NAR, is there a setting for LEDs in one of the other models like GTI or should I just use 02 Golf (5k1/VW360) RoW? Seems like the logical choice... Is it safe to go back to original setting if not clearing the Bulb Burn out dash light? Thanks
