Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: 2010 A4 2.0T w/multiple issues; ESP/TPMS/Parking Brake Malfunction
    Aug 2019
    Jef, thanks for the suggestions. I'll see about getting a smoke test done. I did visual on top and underneath my engine, saw no evidence of an oil leak at the eng/trans mating point or even previously after looking at the belly pans. Still though, the smoke test should point out a failure of the RMS. If that comes back good, guess I can see how much vacuum there is at the dipstick.
    Jack, in my Air Force career as an aircraft maintainer, there is a position in flight safety which carries the nickname 'FOD God'...it fits you.
  2. #12
    I prefer just being a regular asshole & stating the obvious ......... FOD is one of them!
    https://safety.army.mil/
    Ja Thanks!
  3. #13
    Jun 2015
    Scotland
    Your original question asked why the abs, Tpms, handbrake, lights are coming on. And you will fix the engine fault later, but I would suggest all your other lights are just due to the fuel trim fault and the modules all sharing the fact that there is a fault somewhere.
    The crank case ventilation system and how it works at idle would be what I’d look at next. After a smoke test. As trim is as previously noted is high at idle.
    What makes you think there is a fault with the actual turbo?
