Hello all, I've been trying to pinpoint the issue affecting my Avant lately. Seems the problem has gotten worse over time. I can clear codes, then drive for a minute or two before my gauge cluster lights up with ESP, TPMS, and then the Parking Brake malfunction. If I shut down the car, restart, and drive over 34mph, the lights turn off only to illuminate while I begin to slow down.
I've run a full scan to show you what is being found. Some info upfront, I am fully aware about my engine code P1297. My turbo does have an issue with the wastegate, seems to still produce sufficient boost at all times. I'm putting that repair off till I figure out what's causing everything to light up everytime my car is driven.
The lean code P2187 is relatively new, that one popped once I completed a carbon cleaning--I 'think' I can figure that one out eventually. More likely my injectors, I've searched for air leaks using the C&C spray method, looked at the PVC diaphragm, MAF, tubing...you get the point.
Anyways, here's my scan...
Wednesday,21,August,2019,11:23:28:06641
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4508.4
Dealer/Shop Name: VALDIESEL
VIN: WAU4FAFL0AA011905 License Plate:
Chassis Type: FL-AU48 (8T0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 42 46 47 52 53 55 56 5F 62
6D 72
VIN: WAU4FAFL0AA011905 Mileage: 203270km-126306miles
Address 01: Engine (DL0MA-CAEB) Labels:| 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 AL HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H14 0001
Revision: E1H14---
Coding: 010C010A190F0160
Shop #: WSC 58751 001 1048576
ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001
ROD: EV_ECM20TFS0118K2907115AL.rod
VCID: 79AFEF500958CDDF8D7-802C
U1113 00 [047] - -
Mileage: 203259 km
Date: 2019.08.20
Time: 20:54:45
Engine speed: 1576.50 /min
Normed load value: 4.7 %
Vehicle speed: 22 km/h
Coolant temperature: 96 °C
Intake air temperature: 52 °C
Voltage terminal 30: 13.523 V
U1113 00 [096] - -
Mileage: 203262 km
Date: 2019.08.21
Time: 08:29:10
Engine speed: 3557.00 /min
Normed load value: 53.3 %
Vehicle speed: 50 km/h
Coolant temperature: 71 °C
Intake air temperature: 31 °C
2999 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 00 [101] - -
Mileage: 203267 km
Date: 2019.08.21
Time: 11:08:50
Engine speed: 1679.50 /min
Normed load value: 6.3 %
Vehicle speed: 37 km/h
Coolant temperature: 78 °C
Intake air temperature: 46 °C
Voltage terminal 30: 13.216 V
4105 - Bank 1; System too Lean at Idle
P2187 00 [237] - -
Mileage: 203259 km
Date: 2019.08.20
Time: 20:55:51
Engine speed: 816.50 /min
Normed load value: 9.4 %
Coolant temperature: 100 °C
Intake air temperature: 56 °C
Voltage terminal 30: 13.617 V
Readiness: 0000 0001
Address 02: Auto Trans (J217) Labels:| 0B6-927-156.clb
Part No SW: 8K0 927 158 J HW: 0B6 927 156
Component: 0B6 20TFSIUSA H04 0003
Revision: --H04---
Coding: 001012
Shop #: WSC 06335 000 00000
ASAM Dataset: EV_TCMAL651 A01006
ROD: EV_TCMAL651.rod
VCID: 3D273B405DF031FFE1F-8068
2505 - Torque Management Feedback Signal A
P2637 00 [047] - -
Mileage: 203259 km
Date: 2019.08.20
Time: 20:54:48
Engine speed: 818.00 /min
Transmission input speed: 677 /min
Transmission output speed: 288 /min
Engine torque: 24 Nm
Transmission fluid temperature: 82 °C
Accelerator position: 0.0 %
Clutch status: 0
Part No SW: 8K0 907 379 CA HW: 8K0 907 379 AN
Component: ESP8 quattro H04 0010
Coding: 150D18
Shop #: WSC 06341 128 28888
VCID: 7AADF05C0CDEC6C784D-802E
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 48
Mileage: 203259 km
Date: 2019.08.20
Time: 20:54:45
Hex Value: 0x18C0
Hex Value: 0x4006
Hex Value: 0x1226
Hex Value: 0x46AB
Hex Value: 0x00FF
Reset counter: 48
Mileage: 203259 km
Date: 2019.08.20
Time: 20:54:46
Hex Value: 0x11C0
Hex Value: 0x6206
Hex Value: 0x1232
Hex Value: 0x02AC
Hex Value: 0x00FF
Part No SW: 8K0 907 064 DH HW: 8K0 907 064 DH
Component: BCM2 1.1 H02 0321
Coding: 0D0200
VCID: 79AFEF5009D8CDDF8D7-802C
Subsystem 1 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H36 0042
Serial number: 0209000034294009
Reset counter: 48
Mileage: 203256 km
Date: 2019.08.20
Time: 20:44:43
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T1 820 043 AK HW: 8T1 820 043 AK
Component: KLIMA 3 ZONEN H08 0171
Revision: C1000000 Serial number: 01031120091137
Coding: 64102000
Shop #: WSC 22129 444 54812
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H25 0380
Revision: 10025001 Serial number: 00000000386277
Coding: 26001011063CAF010000080300003D0D0F1C460800010161000000
Shop #: WSC 06335 123 12345
VCID: 3C213644466A38F7D61-8068
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 290509 H06 0070
Serial number: SWF09050295678
Coding: 00FD11
Component: RLS H04 0003
Serial number: 10486921
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
Serial number: 00000000001905092042
Subsystem 4 - Part No SW: 8K0 907 410 B HW: 8K0 907 410 B
Component: HOMELINK H01 0010
Address 15: Airbags (J234) Labels:* 8K0-959-655.clb
Part No SW: 8K0 959 655 H HW: 8K0 959 655 H
Component: AirbagVW-AU10 H37 0520
Serial number: 003EGD020U80
Coding: 303836354230303030304A55304C384B3053
VCID: 42DD48BC240E4E079CD-8016
Subsystem 1 - Part No SW: 8K0 959 339 B HW: 8K0 959 339 B
Component: BF-Gewichtss. H01 0030
Serial number: 5810000R0900002R8J
Serial number: 6334MSME482124486
Serial number: 6344MSME482453516
Serial number: 6352QSME6F2F2424R
Serial number: 6362QSME0A2E140EN
Serial number: 63732SME2B2F5026%
Serial number: 63832SME64294818%
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90304IEL000AM
Coding: 000037
VCID: 3D273B405D7031FFE1F-8068
Component: E221 - MFL H02 0003
Part No SW: 8K0 920 980 M HW: 8K0 920 980 M
Component: KOMBIINSTR. H19 0253
Revision: 00100000 Serial number: BXM749W59
Coding: 8B1711000300D705020000
Part No SW: 8T0 907 468 T HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0101
Revision: EB700052 Serial number: 5200E0950682C2
Coding: 00C303
VCID: 52FD78FCF4EEDE872CD-8006
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H06 0160
Serial number: 1907C0CC070509
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
Part No SW: 8K0 959 760 D HW: 8K0 959 760 D
Component: MEM-FS H06 0073
Revision: AA000000 Serial number: 00001001283601
Coding: 00581B00000000000000
VCID: 3B23355843643FCFDFB-806E
Part No SW: 8K0 959 793 H HW: 8K0 959 793 D
Component: TSG FA H11 0306
Revision: Serial number: 0000008915449
Coding: 011C13204E00410001
VCID: 45D753A035A0793FB9F-8010
Revision: 00002001 Serial number: 0117401349
Coding: 0126063A207A741700B0020000000000
Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719
Component: GTO BF H06 0050
Serial number: 00000000000000139384
Component: LIN BACKUP HO H03 1301
Subsystem 3 - Part No SW: 8K0 959 591 A HW: 8K0 959 591
Component: J245 PS133 H06 0041
Subsystem 4 - Part No SW: 8K0 959 591 A HW: 8K0 959 591
Component: J394 PS228 H06 0041
02616 - Fuel Tank Cap; Unlock
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 46
Mileage: 203256 km
Date: 2019.08.20
Time: 20:50:38
02615 - Fuel Tank Cap; Lock
Reset counter: 46
Mileage: 203261 km
Date: 2019.08.20
Time: 21:01:54
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
Part No SW: 8T0 035 223 AK HW: 8T0 035 223 AK
Component: DSP Prem H08 0170
Revision: 00008001 Serial number: 34881004301503
VCID: 77ABE9683FCCDBAFFB3-8022
Part No SW: 8K0 959 792 H HW: 8K0 959 792 D
Component: TSG BF H11 0306
Revision: Serial number: 0000008888864
VCID: 44D14EA43E9A4037AE1-8010
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0090
Revision: 00000003 Serial number: 00000000379855
VCID: 34311E646E3AF0B71E1-8060
Fault Status: 11101101
Reset counter: 48
Mileage: 203259 km
Date: 2019.08.20
Time: 20:54:46
Voltage: 13.80 V
Count: 58
Speed: 16.0 km/h
Hex Value: 0x02E0
Hex Value: 0x0004
Hex Value: 0x0101
Part No: 8K5 907 357
Coding: 0000004
Shop #: WSC 06334 000 00000
VCID: 77ABE96833CCDBAFFB3-8022
Part No SW: 4F0 035 082 A HW: 4F0 035 082
Component: Radio U SIRIU H45 0021
Revision: AB001007 Serial number: 335EL097515111
Coding: 020000010000000001
VCID: 1D67DBC0FDB051FFC1F-8048
Part No SW: 8T1 035 664 A HW: 8T1 035 664 A
Component: H-BN-NA H41 0042
Revision: -------- Serial number: 490EX097505743
Coding: 010200010106A1EC41000B0C000000030000
VCID: 3635246C7846E2A7205-8062
Subsystem 1 - Part No: 8R0 060 884 F
Component: NAR 2009/2010 5304
Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
Component: DU7 High H43 0306
Serial number: 9356EM091003744
Subsystem 3 - Part No SW: 8T0 919 609 G HW: 8T0 919 609 G
Component: E0380 Bedient H08 0100
Serial number: 00000000296169
Subsystem 4 - Part No: 8R0 906 961 A
Component: CD-Database 1293
Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
Component: TSG HL H10 0306
Revision: Serial number: 0000101225748
Coding: 010C13204000210001
VCID: 42DD48BC248E4E079CD-8016
Address 6D: Trunk Elect. (J605) Labels: Redir Fail!
Part No SW: 8K9 827 851 A HW: 8K9 827 851 A
Component: J605 Master H27 0300
Revision: -------- Serial number: 8K9827851A
Subsystem 1 - Part No SW: 8K9 827 852 A HW: 8K9 827 852 A
Component: J756 Slave H27 0300
Serial number: 8K9827852A
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H10 0306
Revision: Serial number: 0000101225769
End----(Elapsed Time: 02:10, VBatt start/end: 12.0V/11.7V. VIgn 11.9V)-----
