Results 21 to 30 of 39
Thread: 1.8T ( 20 V. ) Fault codes but no MIL light... ?
  1. #21
    Verified VCDS User 2stroke's Avatar
    Feb 2019
    Sweden
    The ECU appears to be modified.
    Yes,
    The car has the below software:
    ( but I think the car is very tired/lazy )
  2. #22
    Feb 2019
    Sweden
    It might be easier if you only posted questions on this subject in the thread you have started,
    posting in multiple threads ALWAYS causes confusion
    Can you confirm whether the engine ECU has been "chip tuned" as Jack suspects - see your original thread ?
    Yes,
    the car has the following software:
    Set it as per RTFB.............
    Since you know this very well, I ask you how to check/set up the wastegate actuator ?
  3. #23
    Well get a stock OEM ECU or flash to stock and rescan the car.
  4. Likes PetrolDave liked this post
  5. #24
    I do know, but I expect you to pick up a book and read it and ask questions based on the repair book that you don't understand?
    Why should I write what is already written?
  6. Likes Uwe liked this post
  7. #25
    +1
    It appears that the chip tune has removed some of the diagnostics in the ECU, which makes fault finding very difficult /impossible.
  8. #26
    Since this is discussing the SAME CAR and the SAME FAULT as this thread https://forums.ross-tech.com/showthr...t-no-MIL-light shouldn't the posts from here be merged into that thread ?????
  9. Likes Uwe liked this post
  10. #27
    Feb 2019
    Sweden
    I can not get hold of the ( http://www.bentleypublishers.com/aud...ir-manual.html ) over here in Sweden !
    As simple as that.
  11. #28
    Feb 2019
    Sweden
    Question
    which makes fault finding very difficult/impossible.
    How can you see from the diagnostics above that the software has been changed ?
    What values, etc., are missing and/or incorrect ?
    (trying to learn here )
  12. #29
    Quote Originally Posted by 2stroke View Post
    Take a look at the readiness values
  13. #30
    As simple as that.
    You don't need to get the Bentley book, a FAR better source of information relevant to your car is the erWin website https://erwin.audi.com/erwin/showHome.do
    Just create an account, buy a 1 hour subscription and download every document relevant to your car as PDF files
  14. Likes Jack@European_Parts, Uwe liked this post
