Results 11 to 20 of 39
Thread: 1.8T ( 20 V. ) Fault codes but no MIL light... ?
    Isn't vacuum used & switched by diverter valve to permit secondary safety boost pulses & not the WG control?
    Vacuum is not used to control the WG in a 1.8T, isn't it boost always diverted to WG spring motor and blocked by N75 to permit WG closed by spring tension and boost increased by this method of N75 recirculating boost to turbo at T connection?
    Isn't the spring strength of WG air motor also equally Important to hold exhaust to turbine up be spun and permit boost build up?
    Don't you think you should read SSP & RTFB for explained operations of design & function?
  2. #12
    Verified VCDS User 2stroke's Avatar
    Feb 2019
    Sweden
    1. Isn't vacuum used & switched by diverter valve to permit secondary safety boost pulses & not the WG control ?
    2. Vacuum is not used to control the WG in a 1.8T,
    isn't it boost always diverted to WG spring motor and blocked by N75 to permit WG closed by spring tension and boost increased by this method of N75 recirculating boost to turbo at T connection ?
    3. Isn't the spring strength of WG air motor also equally Important to hold exhaust to turbine up be spun and permit boost build up ?
    4. Don't you think you should read SSP & RTFB for explained operations of design & function ?
    1. & 2. Of course it is not vacuum from the intake that controlls the wastegate actuator. ( My bad )
    3. I have no knowledge of this.
    4. I am a beginner/rookie to this so I have no reason not to want to learn more and be taught about the 1.8T engine.
  3. #13
    Feb 2019
    Sweden
    Question
    Did you read the links ?
    Yes, but I'm unsure what to do exactly.
    Feel free to explain in a bit more understandable way.
  4. #14
    I suggest you pickup a repair manual and post a complete auto-scan, it's mysteriously missing.
  5. #15
    Time to pick up the repair manual and actually read it.
  6. #16
    Feb 2019
    Sweden
    Question
    I suggest you post a complete auto-scan, it's mysteriously missing.
     Saturday , 24 , August , 2019 , 12:31:53
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7
    VCDS Version: 19.6.1.0 (x64)
    VIN:       License Plate:
    Mileage: 207550 Km - 128965 miles   Repair Order:
              67 69 75 76 77
    VIN:      Mileage: 207550 Km - 128965 miles
    Address 01: Engine        Labels: 06B-906-018-AVJ.lbl
       Part No SW: 8E0 909 518 AQ    HW: 8E0 909 018 B
       Component: 1.8L R4/5VT     G   0020
       Coding: 0011711
       Shop #: WSC 00000 000 08192
       VCID: 7F353E7C2DBBB1B7E0-FFFE
    16683 - Boost Pressure Regulation
                P0299 - 002 - Control Range Not Reached - Intermittent
    17511 - Oxygen (Lambda) Sensor Heating; B1 S1
                P1103 - 008 - Performance too Low - Intermittent
    16523 - Oxygen (Lambda) Sensor B1 S2
                P0139 - 004 - Response too Slow - Intermittent
    Readiness: 0000 1100
       Part No SW: 8E0 910 517 J    HW: 8E0 614 517 BH
       Component: ESP8 quattro    H06 0140
       Coding: 0004871
       Shop #: WSC 06335 000 00000
       VCID: 2E6B3338B951883F3B-807A
       Part No: 8E0 820 043 BM
       Component:   A4 Klimaautomat   3233
       Coding: 00000
       VCID: 6DE9F43427D7332742-FFFE
       Part No: 8E0 907 279 N
       Component: int. Lastmodul  ECE 0907
       Coding: 11041
       Shop #: WSC 65536
       VCID: 3D490474373763A7B2-FFFE
       Part No SW: 8E0 959 655 G    HW: 8E0 959 655 G
       Component:    Airbag 9.41  H14 4230
       Revision: 91H14423    Serial number: 0036M00CNEGA
       Coding: 0031612
       VCID: 3B4D0A6C7A236D978C-806E
       Subsystem 1 - Serial number: 6332DRB406699399Y
       Subsystem 2 - Serial number: 6342DRB4069B131CR
       Subsystem 3 - Serial number: 6352ARB403388589Q
       Subsystem 4 - Serial number: 6362ARB403383BE1Q
       Subsystem 5 - Serial number: 63729RB4030A5692I
       Subsystem 6 - Serial number: 63829RB4030A56A4M
       Part No: 8E0 953 549 Q
       Component: Lenksáulenmodul     0801
       Coding: 02042
       Shop #: WSC 06335
       VCID: 41B178844BCF0747D6-FFFE
       Part No SW: 8E0 920 931 S    HW: 8E0 920 931 S
       Component: KOMBI+WFS 3     H10 0200
       Revision: 0200        Serial number: AUX6Z0G0059191
       Coding: 0007118
       Shop #: WSC 73249 020 01196
       VCID: 384715604815468F61-FFFE
       Coding: 0007118
       Part No: 8E0 951 177
       Component: Innenraumueberw.   0804
       Coding: 00001
       VCID: 6BEDFA2C19C33D175C-FFFE
       Part No: 8E0 959 433 CR
       Component: Komfortgerát TBF    4336
       Coding: 07018
       Shop #: WSC 06335
       VCID: 033DB28C1153D55784-FFFE
       Subsystem 1 - Part No: 8E1959801H
       Component: Tőrsteuer.FS BRM 0606
       Subsystem 2 - Part No: 8E1959802H
       Component: Tőrsteuer.BF BRM 0606
       Part No: 8P0 907 357 H
       Coding: 0000005
       VCID: 3FB57E7C6E3B71B7A0-806A
    Address 56: Radio        Labels: 8J0-035-1xx-56.clb
       Part No SW: 8E0 035 186 AL    HW: 8E0 035 186 AL
       Component: R Concert2+     H01 0270
       Revision: 00H01000    Serial number: AUZ1Z3G8322819
       Coding: 0230021
       VCID: 71D1E8446BEFD7C766-FFFE
    End-------------------------(Elapsed Time: 08:25)--------------------------
  7. #17
    Feb 2019
    Sweden
    This was not the answer I was hoping for.
    I would like help setting up/adjust the wastegate actuator on my 1.8T engine.
  8. #18
    The ECU appears to be modified.
  9. #19
    Quote Originally Posted by 2stroke View Post
    It might be easier if you only posted questions on this subject in the thread you have started, posting in multiple threads ALWAYS causes confusion
    Can you confirm whether the engine ECU has been "chip tuned" as Jack suspects - see your original thread?
  10. Likes Uwe, Jack@European_Parts liked this post
  11. #20
    Set it as per RTFB.............
