Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Transporter T5 GP retrofit BCM from T6 ==> instrument lighting is fading in and out
    Jan 2019
    Quote Originally Posted by Limalex View Post
    So basically if you succeed you will Be able to use t6 steering wheel with a cruise control?
    Which BCM you trying to fit ? Is it the latest Euro 6?
    I already did succeed
    ACC is successfully retrofittet from the T6, and that needed the T6 Steering-wheel with ACC Buttons.
    BCM used is in the scan in my first Post.
    But still lot of work to do to make it doable for others ...
  2. #12
    Oct 2015
    London
    Quote Originally Posted by dnoermann View Post
    Great well done than!
    I think Kufatec after some donor T6 to try retrofitting ACC and start stop function for 900. euros, but it is in Germany
    Honestly all the lorries I driving has ACC and they causing issues all the time especially in bad wether and heavy rain. Sensors need regular cleaning.
    I wondering what is your experience? Where are the sensors fitted?
    The other hand I love the idea to use cruise control from the steering wheel.
    Just an out of topic question. You might know the answer. With an upgraded BCM the adaptation of the EURO 6 engine and ECU would be possible?
  3. #13
    Jan 2019
    Just in the Front like in the T6.
  4. Likes myounus liked this post
