Results 1 to 10 of 13
Thread: Transporter T5 GP retrofit BCM from T6 ==> instrument lighting is fading in and out
Hybrid View
    Jan 2019
    Hallo @ all, i retrofitet the BCM from a T6 into a T5 GP.
    I changed
    - 7H0 937 090 B BCM PQ25 Max4 H74 0712
    to
    - 7E0 937 090 C BCM PQ25 Max4 H82 0752
    Everything is working whell, but the "instrument lighting" is fading in and out when enabled, the Time for the fading can be adjusted by the Light-Intensity-Switch.
    Here is the info from the BCM:
       Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
       Component: BCM PQ25 Max4 H82 0752
       Revision: B9082001    Serial number: 4000 088181300
       Coding: E0A0393A0A21201301280E716EAB8FD50694662F60857851320000020040
       Shop #: WSC 12345 123 12345
       VCID: 2B02F23693056C2F4F5-807E
       Component: RLS 071013 05  54  0403
       Coding: 02252E
       Subsystem 2 - Part No SW: 7E0 959 801 J    HW: 7E0 959 801 J  Labels: 7E0-959-80X-V2.CLB
       Component: J386__TSG_FT  003 8652
       Serial number: KU0KU008101300018609
       Coding: 0400A1
       Subsystem 3 - Part No SW: 7E0 959 802 J    HW: 7E0 959 802 J  Labels: 7E0-959-80X-V2.CLB
       Component: J387__TSG_BT  003 8652
       Serial number: KU0KU002101300011203
       Coding: 1400A1
       Subsystem 4 - Part No SW: 7E0 959 442 A    HW: 7E0 959 442 A  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H02 0103
       Serial number: 29150002355190075477
       Coding: B4FFFF
    Does someone have and Idea ?
    Greetings
    Dennis
    Jan 2019
    Found the Issue.
    It looks like the T6 BCM 7E0 937 090 C is not capable of suplying the needed current for the Instrument lighting.
    Thats the source of the lighting fading in and out ....
    With T5 BCM 7H0 937 090 B the Klemme 58_out from T73b Pin 1 or later T73b Pin 4 had enoth current.
    In T6 an aditional Relay J602 is needed, which is controlled by T73 pin 7
    Oct 2015
    London
    Hi Dennis,
    May I ask you for the reason of the t6 BCM retrofit?
    What would you like to achive?
    I have a Caravelle T5.1 and resally interested every upgrades tweeks and trick.
    If yuou do not mind would you tell me a bit more?
    Jan 2019
    The T6 BCM is needed for ACC Retrofit.
    But the BCM is the easy Part of it.
    ABS, Steering Wheel, Airbag ECU need to be changed, too.
    And Component Protection and SWAP need to be solved, too.
  5. Likes Uwe, Robert-VW liked this post
    Oct 2015
    London
    Quote Originally Posted by dnoermann View Post
    Thank you Sir, so I do not need to worry about it. I am lucky I have ACC
    Jan 2019
    Quote Originally Posted by Limalex View Post
    Hm, that is impossible
    May i ask which exact Year/Month is your Car ?
    Bacause ACC was only available @ the T6, which started in Mid 2015.
  8. Likes Uwe liked this post
    Oct 2015
    London
    Well You might right. Lets clarify
    Is not the ACC the cruise control?
    My one 2012/November Caravelle Executive
  10. #8
    Oct 2015
    London
    Ok you deffenetly right myone not adaptive
    watching this thread with interrest.
    But I need to surt ouit my MFSW first
    Are you planning to do a How to guide?
  11. #9
    Oct 2015
    London
    Lets see i have to work some other things out before i do a howto ...
    Happy to wait
    So basically if you succeed you will Be able to use t6 steering wheel with a cruise control?
    Which BCM you trying to fit ? Is it the latest Euro 6?
  12. #10
    Jan 2019
    I already did succeed
    ACC is successfully retrofittet from the T6, and that needed the T6 Steering-wheel with ACC Buttons.
    BCM used is in the scan in my first Post.
    But still lot of work to do to make it doable for others ...
