Hello All!
I have a VW Transporter 2011 with erro code from the All-wheel drive system. I have sent the control module placed in the rear axle for investigation to UK but no problem found. But I am a little confused and need some advice or tips how to proceed with fault finding. The car is converted into an ambulance, it is driveable but need the all-wheeldrive before the winter is coming.
Hope that you can help me in this issue.
Many thanks in advance.
Kind regard
//Kjell
Kind regard
//Kjell
Wednesday,21,August,2019,14:59:53:01232
VCDS Version: 19.6.1.0 (x64)
VIN: WV2ZZZ7HZBH119905 License Plate: RLT260
Mileage: 227550km-141393mi Repair Order:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 02 03 04 08 09 15 17 18 19 22 25 56 6E 0B
VIN: WV2ZZZ7HZBH119905 Mileage: 227550km-141393miles
22-AWD -- Status: Cannot be reached 1100
6E-Ctrl Head Roof -- Status: OK 0000
Address 01: Engine (J623-CFCA) Labels:. 03L-906-022-CFC.clb
Part No SW: 03L 906 022 JE HW: 03L 907 309 H
Component: R4 2,0L EDC H34 9114
Revision: 22H34--- Serial number: 00000000000000
Coding: 0125401A232600080000
Shop #: WSC 40953 222 92152
ASAM Dataset: EV_ECM20BTD01103L906022JE 002008
ROD: EV_ECM20BTD01103L906022JD_002.rod
VCID: 71D19679A0ADCAC766-8024
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0BT 300 011 K HW: 0BH 927 711 C
Component: DSG DQ500-7A H04 1409
Revision: 00H04V01
ROD: EV_TCMDQ500021_VW36.rod
VCID: 365B65658943ADFF73-8062
Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 G HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0105
Revision: 00H43001
Coding: 208764AD11A5049E26AB88716A6316
Shop #: WSC 02736 790 49152
VCID: 365B65658143ADFF73-8062
Reset counter: 22
Mileage: 227555 km
Date: 2014.01.11
Time: 16:03:47
Count: 17
Count: 8202
Count: 252
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E5 907 047 BF HW: 7E5 907 047 BF
Component: Climatic-T5 H20 0505
Revision: 00001010
Coding: 0000000002
Shop #: WSC 40963 222 88811
ROD: EV_ClimaT5Basis.rod
VCID: 74DF9F6DDFBFFFEF8D-8020
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 087 F HW: 7H0 937 087
Component: BCM T5GP H+4 H47 0230
Serial number: 0396 081110623
Coding: A0B0793A0E212013002808107D2B8DD40090430F60844000300000000000
Shop #: WSC 02734 790 00000
VCID: 37456861864954F768-8062
Subsystem 1 - Part No SW: 7E0 959 801 HW: 7E0 959 801 Labels: 7E0-959-80X-V1.CLB
Component: J386__TSG_FT 002 3311
Subsystem 2 - Part No SW: 7E0 959 802 HW: 7E0 959 802 Labels: 7E0-959-80X-V1.CLB
Component: J387__TSG_BT 002 3311
Subsystem 3 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB
Component: E221__MFL-TK6 H06 0022
Serial number: 70000000000000192644
Coding: E20000
Part No SW: 7E0 959 655 C HW: 7E0 959 655 C
Component: VW10Airbag007 H06 0013
Revision: -------- Serial number: 003HM000X9KI
Coding: 000000000000000000000000000000003037
Shop #: WSC 02734 790 50316
Serial number: 3495ZRB4059010DAEOIK
Serial number: 3505ZRB405T0891IF0LO
Part No SW: 7E0 920 870 CX HW: 7E0 920 870 CX
Component: KOMBI H21 0220
Coding: 160E00
VCID: 0131C6B9900DDA4796-8054
12653568 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 22
Mileage: 227555 km
Date: 2019.08.21
Time: 16:03:44
Address 18: Aux. Heat Labels: None
Part No: 7E0 815 071 A
Component: J737__Standheizung 0404
Revision: 00085000 Serial number: 09019275D00000
Coding: 0000031
Shop #: WSC 02757 790 00000
VCID: 237DAC31E2D12857A4-8076
Part No SW: 6N0 909 901 HW: 7H0 937 087
Component: GW-K-CAN TP20 0230
Coding: 042200
VCID: 70D7937DA3A7C3CF69-8024
Reset counter: 22
Mileage: 227555 km
Date: 2014.01.11
Time: 16:03:46
Address 22: AWD
Component: IMMO H21 0220
VCID: 6AE381158D7B391F27-803E
Part No SW: 5M0 035 186 AA HW: 5M0 035 186 AA
Component: Radio RCD310 016 0049
Revision: 00000000 Serial number: VWZ1Z2L0366647
Coding: 0100040000
Shop #: WSC 40391 222 09951
VCID: 6BED84118A8120175C-803E
Reset counter: 22
Mileage: 227555 km
Date: 2014.01.11
Time: 16:04:04
Address 6E: Ctrl Head Roof (J702) Labels:. 7E5-919-037-L2.clb
Part No SW: 7E5 919 037 F HW: 7E5 919 037 F
Component: Dachdisplay H16 0175
Revision: 11100010 Serial number: 193374
Coding: 000206
Shop #: WSC 02736 790 00000
VCID: 345F5F6D973FBFEF4D-8060
Address 0B: Sec. Air Heating Labels: None
Part No: 7E0 819 006 D
Component: J604 Standheizung 0401
Revision: L100300A Serial number: 00000000000000
VCID: 2867BB1D98F7CB0FF1-FFFE
00003 - Control Module
End-------------------------(Elapsed Time: 02:45)--------------------------
