Results 1 to 6 of 6
Thread: W12 won't crank
    New User
    Aug 2019
    W12 won't crank
    Goodmorning all!
    I'm from the Netherlands so excuse me in advance for my incorrect English and the long intro.
    I own a Audi a8 W12 from 2005. About 4 weeks ago i had an issue with the air suspension.
    Sometimes when i started the car and drove off, the suspension did not come up but dropped the car to his lowest position. I could hear the compressor but after a while he stopped working. Every time that happend i parked the car, shut it down, locked the doors and unlock the doors and start the car right up and problem solved.
    Untill 4 weeks ago. After about 100 meters from home i noticed the suspension again failed and stopped the car in the roadside, shut it off, lock the doors and try to start the car again. This time the starter seems to have problems turning around at normal speed to crank the car as if the battery was week.
    I switched the ignition to left and after a second again to the right to try again starting the car. Unfortunately the first start cycling was apparently not don yet. So i suppose i was cranking a car that was already cranking.. After that it did nothing more than clicking from the relays in the right footwell. No crank and no start.
    After several tries i gave up and called the roadside assistance. I saw him use the battery terminals (no ground pin) to jump the car but it didnt work at all. Just the clicking and the sound of the fuellpumps. After 5 hours struggling with the lowest car he ever seen we manage to load it on a truck to get the car home.
    Now before i have to pull out the complete engine to get the starter i wanne make sure its not just a fried module or electrical issue.
    Attached the latest scan after replacing and coding a new battery, 2 starter relays, suspension relay and checking all fuse and wiring. I have power from startrelay 2 but i don't now if the starter solenoid is getting that power because you can't get at the wiring on the starter without pulling out the engine
    Any input is very welcome!
    Zaterdag,17,Augustus,2019,22:07:20:29470
    VCDS -- Windows Gebaseerde VAG/VAS Emulator Loopt op Windows 10 x64
    VCDS Versie: HZH 18.9.1.0  HEX-V2 CB: 0.4508.4
    Data versie: 20190515 DS296.0
    www.Randstadcarsolutions.nl
    VIN: WAUZZZ4E65N011177   Kenteken:
    Chassis Type: 4E (4E0)
    Scan: 01 02 03 05 06 07 08 09 11 31 13 15 16 17 19 1E 25 34 36 37
              38 42 46 47 4F 52 53 55 56 61 62 72 76 77
    VIN: WAUZZZ4E65N011177   Kilometrage: 272530km
    00-Stuurhoek Sensor -- Status: OK 0000
    01-Motor -- Status: OK 0000
    02-Versnellingsbak -- Status: OK 0000
    03-ABS Systeem -- Status: Defect 0010
    05-Startbevoegdheid -- Status: OK 0000
    06-Stoelverst, R -- Status: OK 0000
    07-Bed.Paneel/Displ. -- Status: OK 0000
    08-Airco/Verwarming -- Status: Defect 0010
    09-Centr.Electr. -- Status: OK 0000
    11-Motor II -- Status: OK 0000
    31-Motorelektr.Verb. -- Status: OK 0000
    13-Afstandsregeling -- Status: Defect 0010
    16-Stuurwiel -- Status: OK 0000
    17-Instrumenten -- Status: OK 0000
    19-CAN-bus Interface -- Status: Defect 0010
    1E-Mediaplayer 2 -- Status: OK 0000
    25-Wegrijblokkering -- Status: OK 0000
    34-Niveauregeling -- Status: OK 0000
    36-Stoelverst, L -- Status: OK 0000
    37-Navigatie -- Status: OK 0000
    38-Dakelektronica -- Status: OK 0000
    42-Portierelektr.,LV -- Status: OK 0000
    46-Comfortsysteem -- Status: OK 0000
    47-Geluidsysteem -- Status: OK 0000
    52-Portierelectr.,RV -- Status: OK 0000
    53-Handrem -- Status: OK 0000
    55-Koplamp Niveau -- Status: OK 0000
    61-Accuregeling -- Status: OK 0000
    62-Portierelektr.,LA -- Status: OK 0000
    72-Portierelektr.,RA -- Status: OK 0000
    76-Parkeerhulp -- Status: OK 0000
    77-Telefoon -- Status: Kan niet bereikt worden 1100
    Adres 01: Motor        Labels: 07C-910-018-BHT1.lbl
       Onderdeel No SW: 4E0 910 018 E    HW: 4E0 906 018
       Component: 6.0L W12/4V     A  ª0060
       Revisie: --------    Serienummer: AUX3Z0DN153704
       Codering: 0011773
       Werkplaats#: WSC 44798 002 1048576
       VCID: 211E11A36DCEDBEFB13-8074
    Geen Fout Code Gevonden.
    Gereedheid: 0110 1101
    Adres 02: Versnellingsbak        Labels: 09E-927-156.lbl
       Onderdeel No SW: 4E0 910 156 T    HW: 09E 927 156 A
       Component: AG6 09E 6,0L4V RdW  0090
       Revisie: --H01---    Serienummer:        0042901
       Codering: 0000001
       Werkplaats#: WSC 02313 785 00200
       VCID: 3332EBEBC732597F53F-8066
    Adres 03: ABS Systeem        Labels: 4E0-910-517.lbl
       Onderdeel No SW: 4E0 910 517 E    HW: 4E0 614 517 AM
       Component: ESP 5.7 allrad  H44 0240
       Codering: 0008637
       Werkplaats#: WSC 02313 000 00000
       VCID: 251605B379E637CFCDB-8070
    1 Fout Gevonden:
    01826 - Sensor stuurhoek (G85) voedingsspanning contact 30
    Adres 05: Startbevoegdheid        Labels: 4E0-910-131.lbl
       Onderdeel No SW: 4E0 910 131     HW: 4E0 909 131
       Component:     FBS AUDID3  H04 0140
       Revisie: 01404004    Serienummer: AUX3Z0DN153704
       Codering: 0263168
       Werkplaats#: WSC 02311 785 00200
       VCID: 58E87C477E145A2786D-800C
       Subsysteem 1 - Onderdeel No: XXXXXXXXXXX
    Adres 06: Stoelverst, R        Labels: Geen
       Onderdeel No SW: 4E0 910 760 C    HW: 4E0 959 760
       Component: Sitzmemory BFS H08  0060
       Revisie: 00000000    Serienummer: 5DS 008 795-03
       Codering: 4063328
       VCID: 23121BAB77D2C9FFA3F-8076
    Adres 07: Bed.Paneel/Displ.        Labels: 4E0-910-7xx-07.clb
       Onderdeel No SW: 4E0 910 732 K    HW: 4E0 035 729
       Component: Interfacebox    H43 3460
       Revisie: 00000000    Serienummer: 343JR047541338
       Codering: 0000001
       Werkplaats#: WSC 12345 123 12345
       VCID: 2A0CF68F10F818B7E09-807E
       Subsysteem 1 - Onderdeel No: 4E0 910 609 C
       Component: Bedienteil MMI  H42 0100
       Subsysteem 2 - Serienummer: 301KV047585294
       Subsysteem 3 - Serienummer: 7405.11.0400000000201B0018ÿ
       Subsysteem 4 - Serienummer: 1B0018ÿ
    Adres 08: Airco/Verwarming        Labels: Geen
       Onderdeel No SW: 4E0 910 043 A    HW: 4E0 820 043 A
       Component: KLIMAAUTOMAT    016 0340
       Revisie: 00000029    Serienummer: 00000000056442
       Codering: 0012297
       VCID: 1B62234B4FA2F13F6BF-804E
    1 Fout Gevonden:
    01206 - Signaal voor tijdsduur contact uit
                014 - defect
    Adres 09: Centr.Electr.        Labels: 4E0-910-279.clb
       Onderdeel No SW: 4E0 910 279 L    HW: 4E1 955 113 B
       Component: ILM Fahrer      H12 0210
       Codering: 0133121
       VCID: 313EE1E33D2E6B6F213-8064
       Subsysteem 1 - Onderdeel No: 4E1 910 113 B
       Component: Wischer WWS D3  H50 0400
       Codering: 00000037
       Subsysteem 2 - Onderdeel No: 4E0 910 557   Labels: 8K0-955-559.CLB
       Component: REGENLICHTSENSORH10 0040
       Codering: 00141886
    Adres 11: Motor II        Labels: 07C-910-018-BHT2.lbl
       Codering: 0011773
    Adres 13: Afstandsregeling        Labels: Geen
       Onderdeel No SW: 4E0 910 561 F    HW: 4E0 907 561 F
       Component: ABSTANDSREGELUNGH03 0020
       Codering: 0041168
    1 Fout Gevonden:
    01316 - Remmenregelapparaat
                013 - Storinggeheugen afvragen - MIL AAN
                 Bevries Frame:
                        Fout Status: 11111101
                        Fout Prioriteit: 5
                        Fout Frekwentie: 2
                        Reset teller: 30
                        Kilometrage: 10392 km
                        Tijd Indicatie: 0
                        Datum: 2004.04.01
                        Tijd: 05:14:00
                 Bevries Frame:
                        Temperatuur: 31.0°C
                        Voltage: 12.54 V
                        Bin. Bits: 00000000
    Adres 15: Airbags        Labels: 4E0-910-655-84.lbl
       Onderdeel No SW: 4E0 910 655     HW: 4E0 959 655 G
       Component: Airbag 8.4E+    H10 0940
       Codering: 0430707
       VCID: 63925BAB375289FFE3F-8036
    Adres 16: Stuurwiel        Labels: 4E0-910-549.lbl
       Onderdeel No SW: 4E0 910 549     HW: 4E0 953 549
       Codering: 0012151
       VCID: 659645B33966F7CF0DB-8030
       Component: Lenkradmodul    H05 0080
    Adres 17: Instrumenten        Labels: 4E0-910-xxx-17.lbl
       Onderdeel No SW: 4E0 910 930 K    HW: 4E0 920 930 K
       Component: KOMBIINSTR. VDO H53 0200
       Revisie: D02         Serienummer: AUDID3DN000836
       Codering: 0000104
    Adres 19: CAN-bus Interface        Labels:. 4E0-910-468.clb
       Onderdeel No SW: 4E0 910 468     HW: 4E0 907 468 B
       Component: Gateway         H7
       Revisie: 7    Serienummer: 1500404A0106B0
       Codering: FEFEFBDC2B3104
    1 Fout Gevonden:
    01303 - Zender/ontvanger van telefoon
                004 - Geen Signaal/Communicatie
                 Bevries Frame:
                        Fout Status: 01100100
                        Fout Prioriteit: 3
                        Fout Frekwentie: 1
                        Reset teller: 30
                        Kilometrage: 272536 km
                        Tijd Indicatie: 0
                        Datum: 2004.04.01
                        Tijd: 05:23:46
    Adres 1E: Mediaplayer 2        Labels: 4E0-910-111.lbl
       Onderdeel No SW: 4E0 910 111 F    HW: 4E0 035 111
       Component: CD-Changer      H43 0470
       Revisie: 00000501    Serienummer: AUZ5ZBC1024295
       Werkplaats#: WSC 00000 000 00000
       VCID: 1C6020574AACF607625-8048
    Adres 25: Wegrijblokkering        Labels: 4E0-910-131.lbl
       Codering: 0263168
       XXXXXXXXXXX ELV                 XXXX
    Adres 34: Niveauregeling        Labels: 4E0-910-553.clb
       Onderdeel No SW: 4E0 910 553 J    HW: 4E0 907 553 F
       Component: LUFTFDR.-CDC    H06 6310
       Codering: 0015510
       Werkplaats#: WSC 42710 001 1048576
    Adres 36: Stoelverst, L        Labels: Geen
       Component: Sitzmemory FS  H08  0060
       Codering: 4063330
    Adres 37: Navigatie        Labels: 4E0-910-88x-37.lbl
       Onderdeel No SW: 4E0 910 888 P    HW: 4E0 919 887 C
       Component: MNS ECE         H43 1060
       Revisie: 00000000    Serienummer: 353J-047586256
       Werkplaats#: WSC 00100 211 16775
       VCID: 3B22C3CBEF62913F8BF-806E
    Adres 38: Dakelektronica        Labels: 4E0-910-135.lbl
       Onderdeel No SW: 4E0 910 135 A    HW: 4E0 907 135 A
       Component: Dachknoten D3   H02 0090
       Serienummer: 00000426000083
       Codering: 0003200
       VCID: 1D662D5351B6FF0F95B-8048
    Adres 42: Portierelektr.,LV        Labels: 4E1-910-802-42.lbl
       Onderdeel No SW: 4E1 910 802 B    HW: 4E1 959 801 B
       Component: Türsteuer.FS BRM002 0060
       Codering: 0028461
       VCID: 201814A766C4D2E7BED-8074
    Adres 46: Comfortsysteem        Labels:. 4E0-910-289.lbl
       Onderdeel No SW: 4E0 910 289 A    HW: 4E0 907 289
       Component: Komfortgeraet   H04 0040
       Revisie: 00400004    Serienummer:  W040411090111
       Codering: 0004184
       VCID: 270A0FBB03EA25DFFF7-8072
       Subsysteem 1 - Onderdeel No: 4E0 907 719
       Component: Neigungssensor  H03 0020
    Adres 47: Geluidsysteem        Labels: 4E0-910-223.lbl
       Onderdeel No SW: 4E0 910 223 K    HW: 4E0 035 223 A
       Component: DSP-Amp.-High   H13 0440
       Revisie: PROD_01     Serienummer: 00000000007543
       Codering: 0000016
    Adres 4F: Centr. Electr. II        Labels: Geen
       Onderdeel No SW: 4E0 910 280 A    HW: 4E0 907 280 A
       Component: ILM Beifahrer   H09 0040
       Revisie:             Serienummer: 00000000050643
       Codering: 0010101
       VCID: 1E642A5F5CB0E4178C1-804A
    Adres 52: Portierelectr.,RV        Labels: 4E1-910-802-52.lbl
       Onderdeel No SW: 4E1 910 802 B    HW: 4E1 959 802 B
       Component: Türsteuer.BF BRM002 0060
       Codering: 0028461
    Adres 53: Handrem        Labels: 4E0-910-801.clb
       Onderdeel No SW: 4E0 910 801 A    HW: 4E0 907 801
       Component: EPB  AV1C1010   H01 1010
       Revisie: AV1C1010
       Codering: 0000631
    Adres 55: Koplamp Niveau        Labels: 4E0-910-357.lbl
       Onderdeel No SW: 4E0 910 357     HW: 4E0 907 357
       Component: Pre-AFS         H01 0040
       Revisie: 00000001    Serienummer:
       Codering: 0000003
       VCID: 629C5EAF284880F7E89-8036
    Adres 56: Radio        Labels: 4E0-910-541.lbl
       Onderdeel No SW: 4E0 910 541 Q    HW: 4E0 035 541 B
       Component: TUNER EU/US/RDW H41 0620
       Revisie: 00000000    Serienummer: 304KU047604487
       Codering: 0000001
       VCID: 2E04FA9F2C1074973C1-807A
    Adres 61: Accuregeling        Labels: 4E0-910-181.lbl
       Onderdeel No SW: 4E0 910 181 C    HW: 4E0 915 181 C
       Component: J0644 BEM       H11 0510
       Revisie: 00000000    Serienummer: 00000000014183
       Werkplaats#: WSC 00100 211 06074
       Subsysteem 1 - Onderdeel No: 000 915 105 DL
       Component: von VA0  381214E1CC
       Codering: 303030393135313035444C56413033383132313445314343
       Werkplaats#: WSC 00097 211 95421
    Adres 62: Portierelektr.,LA        Labels: 4E0-910-802.lbl
       Onderdeel No SW: 4E0 910 802 A    HW: 4E0 959 801 C
       Component: Türsteuer.HL BRM002 0060
       Codering: 0028461
    Adres 72: Portierelektr.,RA        Labels: 4E0-910-802.lbl
       Onderdeel No SW: 4E0 910 802 A    HW: 4E0 959 802 C
       Component: Türsteuer.HR BRM002 0060
       Codering: 0028461
    Adres 76: Parkeerhulp        Labels: 4E0-910-283.lbl
       Onderdeel No SW: 4E0 910 283 A    HW: 4E0 919 283 B
       Component: Parkhilfe 8-Kan H12 0020
       Revisie: --.--.--    Serienummer: 08720428600554
       Codering: 0001108
    Adres 77: Telefoon
    Einde-------(Verstreken Tijd: 02:11, VBatt start/eind: 12.6V/12.6V)--------
    Dinsdag,13,Augustus,2019,20:16:38:29470
    Kilometrage: 272530km   Reparatie Order:
    01-Motor -- Status: Defect 0010
    09-Centr.Electr. -- Status: Defect 0010
    42-Portierelektr.,LV -- Status: Defect 0010
    52-Portierelectr.,RV -- Status: Defect 0010
    62-Portierelektr.,LA -- Status: Defect 0010
       Codering: 0011773
    1 Fout Gevonden:
    19510 - Startmotor draait niet
                P3054 - 001 - Mechanisch geblokkeerd of elektrische storing
       Codering: 0000001
       Codering: 0008637
    1 Fout Gevonden:
       Codering: 0263168
       Codering: 4063328
       Codering: 0000001
       Codering: 0012297
    1 Fout Gevonden:
                014 - defect
       Codering: 0133121
       Codering: 00000037
       Codering: 00141886
    2 Fouten Gevonden:
    01317 - Regelapparaat met display in dashboard (J285)
                004 - Geen Signaal/Communicatie - Intermitterend
                 Bevries Frame:
                        Fout Status: 00100100
                        Fout Prioriteit: 2
                        Fout Frekwentie: 1
                        Reset teller: 70
                        Tijd Indicatie: 0
                        Datum: 2019.08.10
                        Tijd: 16:28:38
    01800 - Lichtschakelaar (E1)
                008 - Onaannem. signaal - Intermitterend
                 Bevries Frame:
                        Fout Status: 00101000
                        Fout Prioriteit: 2
                        Fout Frekwentie: 2
                        Reset teller: 70
                        Tijd Indicatie: 0
       Codering: 0011773
       Codering: 0041168
    1 Fout Gevonden:
                 Bevries Frame:
                        Fout Prioriteit: 5
                        Fout Frekwentie: 3
                        Reset teller: 30
                        Tijd Indicatie: 0
                        Datum: 2019.08.07
                        Tijd: 20:42:00
                 Bevries Frame:
                        Temperatuur: 41.0°C
                        Voltage: 12.16 V
                        Bin. Bits: 00100000
       Codering: 0430707
       Codering: 0012151
       Codering: 0000104
    1 Fout Gevonden:
                 Bevries Frame:
                        Fout Prioriteit: 3
                        Fout Frekwentie: 1
                        Reset teller: 30
                        Tijd Indicatie: 0
                        Datum: 2004.03.28
                        Tijd: 03:35:08
       Codering: 0263168
       Codering: 0015510
       Codering: 4063330
       Codering: 0003200
       Codering: 0028461
    1 Fout Gevonden:
    00532 - Voedingsspanning
                011 - Onderbreking - Intermitterend
                 Bevries Frame:
                        Fout Status: 00101011
                        Fout Prioriteit: 3
                        Fout Frekwentie: 0
                        Reset teller: 70
                        Kilometrage: 272528 km
                        Tijd Indicatie: 0
                        Datum: 2004.03.26
                        Tijd: 00:00:42
       Codering: 0004184
       Codering: 0000016
       Codering: 0010101
       Codering: 0028461
    1 Fout Gevonden:
                 Bevries Frame:
                        Fout Prioriteit: 3
                        Fout Frekwentie: 0
                        Reset teller: 70
                        Tijd Indicatie: 0
                        Datum: 2004.03.26
                        Tijd: 01:01:22
       Revisie: AV1C1010
       Codering: 0000631
       Codering: 0000003
       Codering: 0000001
       Codering: 0028461
    1 Fout Gevonden:
                 Bevries Frame:
                        Fout Prioriteit: 3
                        Fout Frekwentie: 0
                        Reset teller: 70
                        Tijd Indicatie: 0
                        Datum: 2004.03.26
                        Tijd: 00:00:42
       Codering: 0028461
       Codering: 0001108
    Adres 77: Telefoon
    Einde-------(Verstreken Tijd: 02:03, VBatt start/eind: 12.2V/12.1V)--------
    Zaterdag,17,Augustus,2019,22:07:49:29470
       Codering: 0011773
       Codering: 0000001
       Codering: 0008637
    1 Fout Gevonden:
       Codering: 0263168
       Codering: 4063328
       Codering: 0000001
       Codering: 0012297
    1 Fout Gevonden:
                014 - defect
       Codering: 0133121
       Codering: 00000037
       Codering: 00141886
       Codering: 0011773
       Codering: 0041168
    1 Fout Gevonden:
                 Bevries Frame:
                        Fout Prioriteit: 5
                        Fout Frekwentie: 2
                        Reset teller: 30
                        Tijd Indicatie: 0
                        Datum: 2004.04.01
                        Tijd: 05:14:00
                 Bevries Frame:
                        Temperatuur: 31.0°C
                        Voltage: 12.54 V
                        Bin. Bits: 00000000
       Codering: 0430707
       Codering: 0012151
       Codering: 0000104
    1 Fout Gevonden:
                 Bevries Frame:
                        Fout Prioriteit: 3
                        Fout Frekwentie: 1
                        Reset teller: 30
                        Tijd Indicatie: 0
                        Datum: 2004.04.01
                        Tijd: 05:23:46
       Codering: 0263168
       Codering: 0015510
       Codering: 4063330
       Codering: 0003200
       Codering: 0028461
       Codering: 0004184
       Codering: 0000016
       Codering: 0010101
       Codering: 0028461
       Revisie: AV1C1010
       Codering: 0000631
       Codering: 0000003
       Codering: 0000001
       Codering: 0028461
       Codering: 0028461
       Codering: 0001108
    Adres 77: Telefoon
                    Adres 03: ABS Systeem  (4E0 910 517 E)
    22:09:13
      -2.5°   Steering Angle Sensor (G85)
      12.56 V   Supply Voltage (Terminal 30)
      Stuurho. 1   Steering Angle Sensor (G85)
      Motor 1   Transmission
      Versn.-bak 1   Engine
      Instr.-pan. 1   Instrument Cluster
      Afstand 1   Adaptive Cruise Control (ACC)
      Gateway 1   CAN-Gateway
      Parkeerrem 1   Electric Parking Brake (EPB)
      N/A   Level Control System
    22:09:15
      12.64 V   Supply Voltage (Terminal 30)
      Versn.-bak 1   Engine
    Zaterdag,17,Augustus,2019,22:12:54:29470
                    Adres 19: CAN-bus Interface  (4E0 910 468 )
    22:12:52
      Actieve   Wake-Up Line
          CAN-Comfort Static
          CAN-Infotainment Static
          CAN-Powertrain Static
             1   Ring Break Diagnostic Wire
          CAN-Gateway Status
      2-kabel   CAN-Comfort Status
      El.cont.sl 1   Access/Start Authorization (J518)
          Driver (J589) Identification
      Telefoon 0   Telephone Electronics (R36)
      12.50 V   Voltage Terminal 30
      12.60 V   Voltage Terminal 15
    Thanks for the Auto-Scan, but can I ask that you download the latest English version (19.6.1 today) from the Ross-Tech website and install that in parallel with your Dutch version and post an Auto-Scan from that here?
    Most of us aren't very proficient in Dutch (my Dad worked for Philips NV for 40 years and even I'm not!), and the newer version may offer some improved diagnostics.
  3. Likes Uwe, Boki Ar liked this post
    New User
    Aug 2019
    Hereby the newest scan with the english and newest version. The funny thing is, i dont have a fault code regarding the starter.
    Thursday,22,August,2019,20:37:19:29470
    VIN: WAUZZZ4E65N011177   License Plate:
    VIN: WAUZZZ4E65N011177   Mileage: 272530km-169342miles
    Address 01: Engine        Labels: 07C-910-018-BHT1.lbl
       Part No SW: 4E0 910 018 E    HW: 4E0 906 018
       Revision: --------    Serial number: AUX3Z0DN153704
       Coding: 0011773
       Shop #: WSC 44798 002 1048576
       VCID: 211E11A36DCEDBEFE57-8074
    Readiness: 0110 1101
       Part No SW: 4E0 910 156 T    HW: 09E 927 156 A
       Revision: --H01---    Serial number:        0042901
       Shop #: WSC 02313 785 00200
       VCID: 3332EBEBC732597F07B-8066
    Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
       Part No SW: 4E0 910 517 E    HW: 4E0 614 517 AM
       Coding: 0008637
       Shop #: WSC 02313 000 00000
       VCID: 251605B379E637CF99F-8070
    Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
       Part No SW: 4E0 910 131     HW: 4E0 909 131
       Revision: 01404004    Serial number: AUX3Z0DN153704
       Coding: 0263168
       Shop #: WSC 02311 785 00200
       VCID: 58E87C477E145A27D29-800C
       Part No SW: 4E0 910 760 C    HW: 4E0 959 760
       Revision: 00000000    Serial number: 5DS 008 795-03
       Coding: 4063328
       VCID: 23121BAB77D2C9FFF7B-8076
    Address 07: Control Head        Labels: 4E0-910-7xx-07.clb
       Part No SW: 4E0 910 732 K    HW: 4E0 035 729
       Revision: 00000000    Serial number: 343JR047541338
       VCID: 2A0CF68F10F818B7B4D-807E
       Subsystem 1 - Part No: 4E0 910 609 C
       Subsystem 2 - Serial number: 301KV047585294
       Subsystem 3 - Serial number: 7405.11.0400000000201B0018ÿ
       Subsystem 4 - Serial number: 1B0018ÿ
       Part No SW: 4E0 910 043 A    HW: 4E0 820 043 A
       Revision: 00000029    Serial number: 00000000056442
       Coding: 0012297
       VCID: 1B62234B4FA2F13F3FB-804E
                014 - Defective
    Address 09: Cent. Elect.        Labels: 4E0-910-279.clb
       Part No SW: 4E0 910 279 L    HW: 4E0 907 279 L
       Coding: 0133121
       VCID: 313EE1E33D2E6B6F757-8064
       Subsystem 1 - Part No: 4E1 910 113 B
       Coding: 00000037
       Shop #: WSC 02313
       Coding: 00141886
       Shop #: WSC 02313
    Address 11: Engine II        Labels: 07C-910-018-BHT2.lbl
       Coding: 0011773
    Address 13: Auto Dist. Reg        Labels: None
       Part No SW: 4E0 910 561 F    HW: 4E0 907 561 F
       Coding: 0041168
                        Fault Status: 11111101
                        Reset counter: 30
                        Mileage: 10392 km
                        Date: 2004.04.06
                        Time: 03:45:00
                        Temperature: 35.0°C
                        Voltage: 11.90 V
                        Bin. Bits: 00000000
    Address 15: Airbags        Labels: 4E0-910-655-84.lbl
       Part No SW: 4E0 910 655     HW: 4E0 959 655 G
       Coding: 0430707
       VCID: 63925BAB375289FFB7B-8036
    Address 16: Steering wheel        Labels: 4E0-910-549.lbl
       Part No SW: 4E0 910 549     HW: 4E0 953 549
       Coding: 0012151
       VCID: 659645B33966F7CF59F-8030
       Part No SW: 4E0 910 930 K    HW: 4E0 920 930 K
       Revision: D02         Serial number: AUDID3DN000836
       Coding: 0000104
    Address 19: CAN Gateway        Labels:. 4E0-910-468.clb
       Part No SW: 4E0 910 468     HW: 4E0 907 468 B
       Revision: 7    Serial number: 1500404A0106B0
       Coding: FEFEFBDC2B3104
                        Reset counter: 30
                        Mileage: 272536 km
                        Date: 2004.04.06
                        Time: 03:57:49
    Address 1E: Media Player 2        Labels: 4E0-910-111.lbl
       Part No SW: 4E0 910 111 F    HW: 4E0 035 111
       Revision: 00000501    Serial number: AUZ5ZBC1024295
       VCID: 1C6020574AACF607361-8048
    Address 25: Immobilizer        Labels: 4E0-910-131.lbl
       Coding: 0263168
    Address 34: Level Control        Labels: 4E0-910-553.clb
       Part No SW: 4E0 910 553 J    HW: 4E0 907 553 F
       Coding: 0015510
       Shop #: WSC 42710 001 1048576
       Coding: 4063330
       Part No SW: 4E0 910 888 P    HW: 4E0 919 887 C
       Revision: 00000000    Serial number: 353J-047586256
       Shop #: WSC 00100 211 16775
       VCID: 3B22C3CBEF62913FDFB-806E
    Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
       Part No SW: 4E0 910 135 A    HW: 4E0 907 135 A
       Serial number: 00000426000083
       Coding: 0003200
       VCID: 1D662D5351B6FF0FC1F-8048
    Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
       Part No SW: 4E1 910 802 B    HW: 4E1 959 801 B
       Coding: 0028461
       VCID: 201814A766C4D2E7EA9-8074
    Address 46: Central Conv.        Labels:. 4E0-910-289.lbl
       Part No SW: 4E0 910 289 A    HW: 4E0 907 289
       Revision: 00400004    Serial number:  W040411090111
       Coding: 0004184
       VCID: 270A0FBB03EA25DFAB3-8072
       Subsystem 1 - Part No: 4E0 907 719
    Address 47: Sound System        Labels: 4E0-910-223.lbl
       Part No SW: 4E0 910 223 K    HW: 4E0 035 223 A
       Revision: PROD_01     Serial number: 00000000007543
       Coding: 0000016
    Address 4F: Centr. Electr. II        Labels: None
       Part No SW: 4E0 910 280 A    HW: 4E0 907 280 A
       Revision:             Serial number: 00000000050643
       Coding: 0010101
       VCID: 1E642A5F5CB0E417D85-804A
    Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
       Part No SW: 4E1 910 802 B    HW: 4E1 959 802 B
       Coding: 0028461
    Address 53: Parking Brake        Labels: 4E0-910-801.clb
       Part No SW: 4E0 910 801 A    HW: 4E0 907 801
       Revision: AV1C1010
       Coding: 0000631
    Address 55: Headlight Range        Labels: 4E0-910-357.lbl
       Part No SW: 4E0 910 357     HW: 4E0 907 357
       Coding: 0000003
       VCID: 629C5EAF284880F7BCD-8036
       Part No SW: 4E0 910 541 Q    HW: 4E0 035 541 B
       Revision: 00000000    Serial number: 304KU047604487
       VCID: 2E04FA9F2C107497685-807A
    Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
       Part No SW: 4E0 910 181 C    HW: 4E0 915 181 C
       Revision: 00000000    Serial number: 00000000014183
       Shop #: WSC 00100 211 06074
       Subsystem 1 - Part No: 000 915 105 DL
       Coding: 303030393135313035444C56413033383132313445314343
       Shop #: WSC 00097 211 95421
    Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
       Part No SW: 4E0 910 802 A    HW: 4E0 959 801 C
       Coding: 0028461
    Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
       Part No SW: 4E0 910 802 A    HW: 4E0 959 802 C
       Coding: 0028461
    Address 76: Park Assist        Labels: 4E0-910-283.lbl
       Part No SW: 4E0 910 283 A    HW: 4E0 919 283 B
       Revision: --.--.--    Serial number: 08720428600554
       Coding: 0001108
    Address 77: Telephone
    End----------(Elapsed Time: 01:59, VBatt start/end: 12.0V/12.0V)-----------
    Controller Software Versions:
    ECU 1 = Engine        0060
    ECU 2 = Auto Trans        0090
    ECU 3 = ABS Brakes        0240
    ECU 4 = Acc/Start Auth.        014
    Sub ECU 4 > 1 = Acc/Start Auth.        XXX
    ECU 5 = Seat Mem. Pass        0060
    ECU 6 = Control Head        3460
    Sub ECU 6 > 1 = Control Head        2010
    ECU 7 = Auto HVAC        0340
    ECU 8 = Cent. Elect.        0210
    Sub ECU 8 > 1 = Cent. Elect.        0400
    Sub ECU 8 > 2 = Cent. Elect.        0040
    ECU 9 = Engine II        0060
    ECU 10 = Auto Dist. Reg        0020
    ECU 11 = Airbags        0940
    ECU 12 = Steering wheel        0040
    Sub ECU 12 > 1 = Steering wheel        5008
    ECU 13 = Instruments        Labels:
    ECU 14 = CAN Gateway        H7
    ECU 15 = Media Player 2        0470
    ECU 16 = Immobilizer        0140
    Sub ECU 16 > 1 = Immobilizer        XXX
    ECU 17 = Level Control        6310
    ECU 18 = Seat Mem. Drvr        0060
    ECU 19 = Navigation        1060
    ECU 20 = Roof Electronics        00
    ECU 21 = Door Elect, Driver
    ECU 22 = Central Conv.        0040
    Sub ECU 22 > 1 = Central Conv.        3002
    ECU 23 = Sound System        0440
    ECU 24 = Centr. Electr. II        0
    ECU 25 = Door Elect, Pass.        0
    ECU 26 = Parking Brake        1010
    ECU 27 = Headlight Range        004
    ECU 28 = Radio        0620
    ECU 29 = Battery Regul.        0510
    Sub ECU 29 > 1 = Battery Regul.
    ECU 30 = Door, Rear Left        006
    ECU 31 = Door, Rear Right        00
    ECU 32 = Park Assist        0020
    ECU 33 =
  5. Likes Boki Ar liked this post
  6. #4
    Near Philadelphia, PA, USA
    Not wanting to give bad news, I suspect that the starter is locked into the starter gear. That is, the starter is unable to turn because the gears are locked together and are jammed. I see nothing in the scan that would indicate a control failure.
    When you turn the key, do the lights dim real bad? That is, is the current draw on the stalled starter motor so high, it drops the system voltage? I think the answer is obviously yes owing to the clicking starter relay.
    Don't know if you can see the starter - but if you can get to it, you might try a bang with a tool on the starter case.. see if the gear will let loose. Else, I think you have to do what you said you do not wish to do - pull whatever is necessary to get to the starter. If my guess is correct, you may find it difficult to pull the starter once you get to it.
    New User
    Aug 2019
    Thank you for the short replay. No problem , i was already prepared for bad news. Just wanted to make sure i did not missed something and try getting the starter for nothing.
    When i turn the key there is no dimming of the lights at all, just some clicks and pumpnoises. From underneith i can see the startercase and tried tapping it before but that also did'nt work.
    Tommorow i will start getting the starter pulled. I share my possible successes or failures here for future similar cases.
    Quote Originally Posted by Follymans View Post
    Let's not be hasty... have you checked the relays? Have you checked that the circuit to be sure that the starter motor is getting full voltage and that the leads to the starter can carry the high starting current? No dimming of the lights means no current draw. Could it be an open winding or failed brushes? Sure. But owing to how difficult it is to pull, I would sure exhaust all other possibilities first.
    So from your report, I think my premise of a stuck rotor is wrong. Now I do not think the starter is getting the current it needs to start turning. I would consult wiring diagrams and all connections, making certain that both the power lead and the ground connection to the engine are proper. If the 12 volt is not making it to the starter, then there is a control circuit problem. If it is making it to the starter and the starter is pulling no current, then something happened to the starter.
    Test your logic by load testing the wires through a headlight or some other load that will pull several amps. Do not trust just voltage readings. You need to know the circuit can push amps at 12 volts. If it cannot, you have control circuit problem. If it is, then again it points to the starter.
  9. Likes Uwe, PetrolDave, D-Dub, JayVanWabbitGTI liked this post
