Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: VW Passat 1.6 2011 RHD ABS, Traction Control, amber Parking light on
  1. #21
    Jun 2019
    Hi, I've changed the ABS pump ecu from what was in the car 3AA 614 109 AB to 3AA 614 109 BM (3AA 614 109 BM this is what I was advised that should be in my vehicle. I've re-applied the code however I still have the ABS light, Traction control light and the amber Parking light on. I have cleared out the lights, they go off but turn on when I drive the car 10/15 meters.
    any guidance will be appreciated
    Saturday,24,August,2019,13:07:09:25558
    VCDS Version: 19.6.1.0 (x64)
    VIN: WVWZZZ3CZCP038881   License Plate:
    Mileage: 195010km-121173mi   Repair Order:
    Chassis Type: 3C-VW46 (7N0)
    Scan: 01 03 08 09 15 16 17 19 25 2E 37 42 44 46 4F 52 53 56 61 62
              65 72
    VIN: WVWZZZ3CZCP038881   Mileage: 195010km-121173miles
    Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 FS    HW: 03L 907 425 C
       Component: 1,6l R4 CR td H43 9196
       Revision: --H43---    Serial number: VWZCZ000000000
       Coding: 00194014030501080000
       Shop #: WSC 00028 028 00209
       ASAM Dataset: EV_ECM16TDI02103L906023FS 003006
       ROD: EV_ECM16TDI02103L906023FS_003.rod
       VCID: 7CF1B22FF788B1AFC5-8028
    7196 - Function Restriction due to Faults in Other Modules
              U1113 00 [100] - -
                        Mileage: 196510 km
                        Date: 2019.08.24
                        Time: 17:57:06
                        Coolant temperature: 58 C
                        Intake air temperature: 36 C
                        Voltage terminal 30: 11.972 V
                        Engine speed: 0 /min
                        Accelerator position: normalized-Accelerator position: 0.00 %
                        Battery voltage: 12.3 V
    Readiness: 0110 1000
       Part No SW: 3AA 614 109 BM    HW: 3AA 614 109 BM
       Component: J104   C2 450M VDD0 0040
       Revision: --H07---    Serial number: 00000008333363
       Coding: 0002983
       Shop #: WSC 00028 028 00001
       VCID: 79FFAB3B30BA8487DE-802C
                        Reset counter: 208
                        Mileage: 195012 km
                        Date: 2014.01.14
                        Time: 18:51:37
                        Speed: 14.0 km/h
                        Hex Value: 0x0001
                        Bin. Bits: 00000000 00000000
                        Voltage: 14.25 V
                        Bin. Bits: 00011111
                        Count: 19
                        Hex Value: 0x0000
       Part No SW: 5K0 907 044 ER    HW: 5K0 907 044 ER
       Revision: 00001003
       Coding: 0004001803
       Shop #: WSC 00028 028 00020
       VCID: 7F0B4523E69EAAB7E0-802A
       Part No SW: 3AA 937 087     HW: 3AA 937 087
       Component: BCM PQ47 M    413 0452
       Revision: BA413001
       Coding: 000000000000000000180080100000E443016488404C81606480C7200041
       VCID: 77FBAD03C6AE92F7A8-8022
       Subsystem 1 - Part No: 3AC 955 119   Labels: 1KX-955-119.CLB
       Component: Wischer 17061  26  0612
       Coding: 00B795
       Component: RLS 290611 05  54  0403
       Coding: 0230ED
       Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
       Component: J234__102 VW10 HI   1918
       Revision: 22014000    Serial number: 003K0PCQSW3K
       Coding: 0012338
       VCID: 4C9122EF2FA8C12F35-8018
       Subsystem 1 - Serial number: 6332MTS663001611
       Subsystem 2 - Serial number: 6342MTS682941611
       Subsystem 3 - Serial number: 6351HTS66IKH6AKR
       Subsystem 4 - Serial number: 6361HTS6E8DI6AKJ
       Part No SW: 3C5 953 501 BN    HW: 5K0 953 569 AB
       Revision: FF010040    Serial number: 20110624301095
       Coding: 0182250000
       VCID: 72ED9C17A5CCF7DF9F-8026
       Coding: E20000
       Part No SW: 3AA 920 970 E    HW: 3AA 920 970 E
       Coding: 460F00
       Shop #: WSC 00028 028 00022
       VCID: 3567670B9422A0E77A-8060
       Part No SW: 7N0 907 530 L    HW: 1K0 907 951
       Component: J533  Gateway H41 1620
       Revision:   H41       Serial number: 210611F1002563
       Coding: 461007
       VCID: 397F6B3BB03A44879E-806C
       Part No SW: 3AA 959 433     HW: 3AA 959 433
       Component:    IMMO         043 0400
       VCID: 76E5A00701A4EBFFB3-8022
       Revision: A1001003    Serial number: 7660297167
       Coding: 020000
       VCID: 295FBB7B409AF407EE-807C
       Part No SW: 3C0 035 279 B    HW: 3C0 035 279 B
       Component: RNS315-EU   H32 0263
       Serial number: VWZAZ2L3373225
       Coding: 040004010400100000019002
       ASAM Dataset: EV_RNS315EUV2UDS A01004
       ROD: EV_RNS315EUV2UDS.rod
       VCID: 224DAC5735AC275FAF-8076
       Component: EUR_W_0031  0031
    1048642 - Internal Control Module Memory Check Sum Error
              B2000 42 [009] - General memory failure
                        Mileage: 173022 km
                        Date: 2018.12.01
                        Time: 11:49:40
       Component: TUER-SG FT    002 0534
       Revision: 12110009    Serial number: 0003084929
       Coding: 0202B7
       Slave Driver:
       Subsystem 1 - Part No SW: 3C0 959 704     HW: 3C0 959 794   Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  004 0408
       Serial number: 00000002264464
       Coding: 000290
       Part No: 1K0 909 144 M
       Component: EPS_ZFLS Kl. 195    3201
       Revision: 00H20000
       VCID: 34615A0F5758B9EF4D-8060
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 208
                        Mileage: 195012 km
                        Date: 2014.01.14
                        Time: 18:51:38
                        Voltage: 14.25 V
                            DU
                        Temperature: 44.0C
                        RPM: 1766 /min
                        Speed: 14.0 km/h
                        Speed: 14.0 km/h
       Component:    KSG PQ47 ELV 043 0634
       Coding: 01910A0002860E76340494157C085FCE107C01
       Component: EZE_2         H41 1620
       Coding: 00000008
       VCID: 6FEB9563BEFEDA3770-803A
       Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
       Component: Analoguhr  004 0003
       Component: TUER-SG BT    002 0534
       Revision: 14110009    Serial number: 0003092436
       Coding: 0202B6
       VCID: 366560078924ABFF73-8062
       Slave Passenger:
       Subsystem 1 - Part No SW: 3C0 959 703     HW: 3C0 959 795   Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  004 0408
       Serial number: 00000002271017
       Coding: 000290
       Part No SW: 3AA 907 801 G    HW: 3AA 907 801 G
       Component: J540 EPB4  VW-64783 0009
       Revision:   H19       Serial number: 00000000071225
       Coding: 0022167
       VCID: 3567670B5C22A0E77A-8060
                        Reset counter: 208
                        Mileage: 195012 km
                        Date: 2014.01.14
                        Time: 18:51:37
                        Voltage: 14.20 V
                        Count: 105
                        Speed: 12.0 km/h
                        Hex Value: 0x1260
                        Hex Value: 0x0004
                        Hex Value: 0x0101
       Component: Batt.regelung H41 1620
       Coding: 030B185A
       VCID: 71EF931BA8CACCC766-8024
       Component: J367-BDM  H07 0180
       Serial number: 00000000008900692453
       Part No SW: 3AA 907 273 B    HW: 3AA 907 273 B
       Component: RDKBERU30     H08 0008
       Serial number: 10000000045196
       ASAM Dataset: EV_RDKBERU30 003010
       ROD: EV_RDKBERU30_003.rod
       VCID: 336359139A56BED754-8066
    End-------------------------(Elapsed Time: 03:07)--------------------------
  2. Likes Jack@European_Parts liked this post
  3. #22
    Jun 2019
    Further update, Rear drivers side ABS sensor not picking up any speed value when driving, cleaned the sensor and examined the cables which look good, will be replacing the rear hub which includes the ABS ring....fingers crossed.
  5. #23
    Verify the wiring to the ABS sensor back to ABS module and the connection itself at hub, spin the hub and measure the reading on meter or scope and watch in VCDS logs.
    Looks like things are improving OP
    See what happens when you start to correct FOD?
  6. #24
    Nov 2016
    B7’s aren’t fussy about abs ecu. As long as it supports tpms and acc if the car had it, you can use any abs ecu, and the coding is simple, there is an unofficial label file to make coding it easy
  7. #25
    Jun 2019
    Update, I’ve changed the rear hub, cleared the faults but they came back, I ordered a sensor of eBay, cleared the faults and the faults come, only difference with new sensor is that the faults reappear as soon as I clear them, with the old sensor they would reappear after driving the car for about 10/15 meters.
    I haven’t checked the wiring, I see cable from the rear goes into the body, am I right to think that only the exposed parts of the cable need to be checked? Any other pointers will be hugely received.
    TIA
  8. #26
    Are you going to put factory parts in yet and rid the FOD?
  9. #27
    Jul 2014
    "I haven’t checked the wiring, I see cable from the rear goes into the body, am I right to think that only the exposed parts of the cable need to be checked?"
    NO!
    As Jack say's, fit genuine parts and move on.
    Regards HMC
  11. #28
    Jun 2019
    For completeness, I replaced the rear ABS sensor with correct part number and all lights have gone out. Thank you all for your input.
  12. Likes Uwe liked this post
  13. #29
    Another repair chalked up to induced FOD cheap unqualified parts making routine repairs a compounded cluster f#@!
  14. Likes PetrolDave, Golftwincharged liked this post
