Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: VW Passat 1.6 2011 RHD ABS, Traction Control, amber Parking light on
    Jun 2019
    I have a 2011 VW Passat 1.6 RHD Saloon (I think it's a B7). I purchased the car as a non-runner and was advised the ECU might be faulty. My mechanic confirmed this as there seemed to be significant water ingress inside the ECU. Instead of getting the original repaired I decided to purchase the full ECU kit from a breaking car.
    The ECU from the donor car was identical in the part numbers, I received the ECU, BCM, steering lock, Ignition barrel and the key.
    My mechanic replaced all of the above items and the car starts and runs with the exception of the ABS, Traction Control, amber Parking light being on. He has advised me that he is unable to code the ABS pump as it needs to be hooked up to an online system.
    I booked the car into VW and explained the above, at first they were reluctant to touch it for obvious reasons however they agreed to have a go at re-coding the ABS pump. They came back and said that the ABS pump on the car is not the original and doesn't marry up with the vehicle VIN. I asked for the part number that should be on the car however they refused to provide it, as it's against their policy.
    I've contacted the person from whom I purchased the ECU kit but he doesn't have the ABS pump. I've also managed to get hold of the part number for the pump that should be on the car (at least that is what I've been told)
    1) Can someone help me/guide me on how I can resolve the issue with the pump already on the car? or at least tell me if it's possible to fix based on the above info?
    2) Shall I invest in a 2nd hand pump based on the part number (current part number is 3AA 614 109 AB, I have been advised it should be 3AA 614 109 BM)?
    3) If I go with option 2 can I simply change the ECU chip from one to the other and will I need to re-code it?
    TIA
    Jun 2019
    Tuesday,20,August,2019,17:09:11:25558
    VCDS Version: 19.6.1.0 (x64)
    VIN: WVWZZZ3CZCP038881   License Plate:
    Chassis Type: 3C-VW46 (7N0)
    Scan: 01 03 08 09 15 16 17 19 25 2E 37 42 44 46 4F 52 53 56 61 62
              65 72
    VIN: WVWZZZ3CZCP038881   Mileage: 194930km-121123miles
    Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 FS    HW: 03L 907 425 C
       Component: 1,6l R4 CR td H43 9196
       Revision: --H43---    Serial number: VWZCZ000000000
       Coding: 00194014030501080000
       Shop #: WSC 00028 028 00209
       ASAM Dataset: EV_ECM16TDI02103L906023FS 003006
       ROD: EV_ECM16TDI02103L906023FS_003.rod
       VCID: 7CF1B22FF788B1AFC5-8028
    Readiness: 1110 1000
       Part No SW: 3AA 614 109 AB    HW: 3AA 614 109 AB
       Component: J104   C2 450M V4CE 0022
       Revision: --H07---    Serial number: 00000004408076
       Coding: 0002983
       Shop #: WSC 00028 028 00001
       VCID: 6DD78F6B74F2282742-8038
    03366 - Vacuum Sensor
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 206
                        Mileage: 194939 km
                        Date: 2014.01.10
                        Time: 07:18:18
                        Hex Value: 0x0000
                        Bin. Bits: 00000000 00000000
                        Voltage: 12.50 V
                        Bin. Bits: 00011111
                        Count: 137
                        Hex Value: 0x0000
    03194 - Incompatible Interface
                        Reset counter: 206
                        Mileage: 194939 km
                        Date: 2014.01.10
                        Time: 07:18:19
                        Hex Value: 0x0000
                        Voltage: 12.25 V
                        Bin. Bits: 00011111
                        Count: 284
                        Hex Value: 0x0000
       Part No SW: 5K0 907 044 ER    HW: 5K0 907 044 ER
       Revision: 00001003
       Coding: 0004001803
       Shop #: WSC 00028 028 00020
       VCID: 7F0B4523E69EAAB7E0-802A
       Part No SW: 3AA 937 087     HW: 3AA 937 087
       Component: BCM PQ47 M    413 0452
       Revision: BA413001
       Coding: 000000000000000000180080100000E443016488404C81606480C7200041
       VCID: 77FBAD03C6AE92F7A8-8022
       Subsystem 1 - Part No: 3AC 955 119   Labels: 1KX-955-119.CLB
       Component: Wischer 17061  26  0612
       Coding: 00B795
       Component: RLS 290611 05  54  0403
       Coding: 0230ED
       Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
       Component: J234__102 VW10 HI   1918
       Revision: 22014000    Serial number: 003K0PCQSW3K
       Coding: 0012338
       VCID: 4C9122EF2FA8C12F35-8018
       Subsystem 1 - Serial number: 6332MTS663001611
       Subsystem 2 - Serial number: 6342MTS682941611
       Subsystem 3 - Serial number: 6351HTS66IKH6AKR
       Subsystem 4 - Serial number: 6361HTS6E8DI6AKJ
       Part No SW: 3C5 953 501 BN    HW: 5K0 953 569 AB
       Revision: FF010040    Serial number: 20110624301095
       Coding: 0182250000
       VCID: 72ED9C17A5CCF7DF9F-8026
       Coding: E20000
       Part No SW: 3AA 920 970 E    HW: 3AA 920 970 E
       Coding: 460F00
       Shop #: WSC 00028 028 00022
       VCID: 3567670B9422A0E77A-8060
       Part No SW: 7N0 907 530 L    HW: 1K0 907 951
       Component: J533  Gateway H41 1620
       Revision:   H41       Serial number: 210611F1002563
       Coding: 461007
       VCID: 397F6B3BB03A44879E-806C
       Part No SW: 3AA 959 433     HW: 3AA 959 433
       Component:    IMMO         043 0400
       VCID: 76E5A00701A4EBFFB3-8022
       Revision: A1001003    Serial number: 7660297167
       Coding: 020000
       VCID: 295FBB7B409AF407EE-807C
       Part No SW: 3C0 035 279 B    HW: 3C0 035 279 B
       Component: RNS315-EU   H32 0263
       Serial number: VWZAZ2L3373225
       Coding: 040004010400100000019002
       ASAM Dataset: EV_RNS315EUV2UDS A01004
       ROD: EV_RNS315EUV2UDS.rod
       VCID: 224DAC5735AC275FAF-8076
       Component: EUR_W_0031  0031
    1048642 - Internal Control Module Memory Check Sum Error
              B2000 42 [009] - General memory failure
                        Mileage: 173022 km
                        Date: 2018.11.30
                        Time: 11:49:40
       Component: TUER-SG FT    002 0534
       Revision: 12110009    Serial number: 0003084929
       Coding: 0202B7
       Slave Driver:
       Subsystem 1 - Part No SW: 3C0 959 704     HW: 3C0 959 794   Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  004 0408
       Serial number: 00000002264464
       Coding: 000290
       Part No: 1K0 909 144 M
       Component: EPS_ZFLS Kl. 195    3201
       Revision: 00H20000
       VCID: 34615A0F5758B9EF4D-8060
                        Fault Status: 00101101
                        Reset counter: 246
                        Mileage: 194930 km
                        Date: 2014.01.09
                        Time: 05:19:32
                        Voltage: 12.88 V
                            DU
                        Temperature: 32.0C
                        RPM: 1312 /min
                        Speed: 12.0 km/h
                        Speed: 12.0 km/h
       Component:    KSG PQ47 ELV 043 0634
       Coding: 01910A0002860E76340494157C085FCE107C01
       Component: EZE_2         H41 1620
       Coding: 00000008
       VCID: 6FEB9563BEFEDA3770-803A
       Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
       Component: Analoguhr  004 0003
       Component: TUER-SG BT    002 0534
       Revision: 14110009    Serial number: 0003092436
       Coding: 0202B6
       VCID: 366560078924ABFF73-8062
       Slave Passenger:
       Subsystem 1 - Part No SW: 3C0 959 703     HW: 3C0 959 795   Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  004 0408
       Serial number: 00000002271017
       Coding: 000290
       Part No SW: 3AA 907 801 G    HW: 3AA 907 801 G
       Component: J540 EPB4  VW-64783 0009
       Revision:   H19       Serial number: 00000000071225
       Coding: 0021057
       VCID: 3567670B5C22A0E77A-8060
                        Fault Frequency: 58
                        Reset counter: 206
                        Mileage: 290899 km
                        Date: 2014.01.04
                        Time: 03:29:05
                        Voltage: 12.60 V
                        Count: 95
                        Hex Value: 0x1260
                        Hex Value: 0x0001
                        Hex Value: 0x0101
    03200 - Switch for Electric Parking Brake (E538)
                        Fault Frequency: 45
                        Reset counter: 206
                        Mileage: 290899 km
                        Date: 2014.01.04
                        Time: 03:29:05
                        Voltage: 12.60 V
                        Count: 9
                        Hex Value: 0x1260
                        Hex Value: 0x0001
                        Hex Value: 0x0101
                        Fault Frequency: 14
                        Reset counter: 246
                        Mileage: 194930 km
                        Date: 2014.01.09
                        Time: 05:19:32
                        Voltage: 12.70 V
                        Count: 105
                        Speed: 10.0 km/h
                        Hex Value: 0x1270
                        Hex Value: 0x0004
                        Hex Value: 0x0101
       Component: Batt.regelung H41 1620
       Coding: 030B185A
       VCID: 71EF931BA8CACCC766-8024
       Component: J367-BDM  H07 0180
       Serial number: 00000000008900692453
       Part No SW: 3AA 907 273 B    HW: 3AA 907 273 B
       Component: RDKBERU30     H08 0008
       Serial number: 10000000045196
       ASAM Dataset: EV_RDKBERU30 003010
       ROD: EV_RDKBERU30_003.rod
       VCID: 336359139A56BED754-8066
    End-------------------------(Elapsed Time: 02:59)--------------------------
    Is this problem EPB related due to short?
    Jun 2019
    The ABS pump coding in the log is: 0002983, this code is from when the car had no work done it i.e. was a non-runner, I had taken a full log using VCDS. When I received the car from VW yesterday it had the code 0006585, I'm not sure if this from what VW did or from what my mechanic had updated.
    The car has Auto Hold and electronic hand break.
    Jun 2019
    Hi Jack, Thanks for the prompt response, sorry but I don't understand what you're trying to say.
    Fault Frequency: 58
    Reset counter: 206
    Mileage: 290899 km
    Date: 2014.01.04
    Time: 03:29:05
    Voltage: 12.60 V
    Count: 95
    Hex Value: 0x1260
    Hex Value: 0x0001
    Hex Value: 0x0101
    03200 - Switch for Electric Parking Brake (E538) <<<<<<<<<<<<<<<<<<<< THIS!
    Fault Frequency: 45
    Reset counter: 206
    Mileage: 290899 km
    Date: 2014.01.04
    Time: 03:29:05
    Voltage: 12.60 V
    Count: 9
    Hex Value: 0x1260
    Hex Value: 0x0001
    Hex Value: 0x0101
    Fault Frequency: 14
    Reset counter: 246
    Mileage: 194930 km
    Date: 2014.01.09
    Time: 05:19:32
    Voltage: 12.70 V
    Count: 105
    Speed: 10.0 km/h
    Hex Value: 0x1270
    Hex Value: 0x0004
    Hex Value: 0x0101
    Why is this in fault?
  7. #7
    Jun 2019
    I really don't know, I thought it may have been linked to the ABS pump issue.
  8. #8
    Not normally a parking brake fault...........fix it and make sure parts are all correct, is there any FOD?
  9. #9
    Jun 2019
    Hi Jack, Given I had a copy of the full scan when the car was a non runner, I have applied the original code for the break switch, it got accepted and now the break switch light has gone along with the traction control light. I now only have ABS light, the following 2 messages also appear, these were present earlier but I didn't include them in my post 'brake servo failure' and 'Error: Brakes. Workshop!'
  10. #10
    Did you try this?
    ABS
    Coding: 0004007 or 0002471 or 0002983
    EPB
    Coding: 0022167 or 0022067
