2019 VW Polo, 1.5 TSI Evo DSG
mipe
New Member
I guess this 1.5 TSI is a bit uncommon on the Polo, so here's a scan.
If I recall correctly, when opening the engine module, VCDS said that the engine was unknown, so hopefully this helps someone.
Sunday,18,August,2019,19:16:32:45958
VIN: WVWZZZAWZKY15xxxx   License Plate:
Mileage: 7326km-4552mi   Repair Order:
Chassis Type: AW-VW27 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 44 55 5F D6 D7
VIN: WVWZZZAWZKY15xxxx   Mileage: 7326km-4552miles
Address 01: Engine (J623-DADA)       Labels: None
   Part No SW: 05E 906 018 AB    HW: 05E 907 309
   Component: R4 1.5l TFS   H22 6086
   Revision: 81H22000
   Coding: 0125003223241D0800000000000000000000000000000000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM15TFS01105E906018AB 003002
   ROD: EV_ECM15TFS01105E906018AB_VW27.rod
   VCID: 6597B18375EAFE4F59F-8030
Readiness: 1110 0001
   Part No SW: 0CW 300 043 D    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1605
   Revision: 00005008    Serial number: CU501902118647
   ROD: EV_TCMDQ200021_VW27.rod
   VCID: 382928F792D8B3A7329-806C
   Part No SW: 2Q0 614 517 AG    HW: 2Q0 614 517 N
   Component: ESC_base_vFGS H23 0242
   Serial number: 08505600190212
   Coding: 0A034C64354650AE3201AC1D34DD22A649124526336A245824542254452C44659248A264CC56241A242A442AA249D64B3D926BD2BC
   ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004036
   ROD: EV_Brake1BOSCHESPMQBA0.rod
   VCID: 73B3DFDBCB3E10FFC7B-8026
Address 08: Auto HVAC (J255)       Labels:* Redir Fail!
   Part No SW: 2G0 907 044 L    HW: 2G0 907 044 L
   Component: Climatronic   H03 0501
   Coding: 0120000008000100011008000244010D0000000000000000000000000000
   ASAM Dataset: EV_ACClimaBHBMQBA0 004017
   ROD: EV_ACClimaBHBMQBA0_VW27.rod
   VCID: 2D0709A36D9A060F51F-8078
   Part No SW: 2Q0 937 090 A    HW: 2Q0 937 090
   Component: BCM A0 Std+   H98 0926
   Serial number: 00001905801388
   ASAM Dataset: EV_BCMA0 204001
   ROD: EV_BCMA0_204.rod
   VCID: 303910D77AA86BE77A9-8064
   Subsystem 1 - Part No SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
   Component: RLHS  052 0107
   Serial number: SAY19M02D25H03M53S09
   Coding: 0038DD
   Drivers Door Control Module:
   Subsystem 2 - Part No SW: 2Q1 959 881 B    HW: 2Q1 959 881 B
   Component: FHSG_DRV  001 0001
   Serial number: 00000000000027903219
   Coding: 130037
   Subsystem 3 - Part No SW: 2Q1 959 882 D    HW: 2Q1 959 882 D
   Component: FHSG_PSG  001 0002
   Serial number: 00000000000027780323
   Coding: 098037
   Subsystem 4 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D
   Component: FOND_FHSG_DRV  006 0007
   Serial number: 00000000000027871438
   Coding: 030000
   Subsystem 5 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D
   Component: FOND_FHSG_PSG  006 0007
   Serial number: 00000000000027935636
   Coding: 1B0000
   Serial number: 000308418019038
   Coding: 0471051011
   ROD: EV_EPHVA18AU3700000_009_VW27.rod
   VCID: 4CC16427F6402F07661-8018
   Part No SW: 2Q0 907 572 Q    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 0342
   Coding: 3204600208FF8748949C810500408700000000000000000000
   ASAM Dataset: EV_ACCMRRCONTIVW376 003015
   ROD: EV_ACCMRRCONTIVW376_003_VW27.rod
   VCID: 42DD4A1FC404E9779CD-8016
   Part No SW: 2Q0 959 655 AG    HW: 2Q0 959 655 AG
   Component: VW22Airbag    010 0248
   Revision: --------
   Coding: 88CCC0C0000000005C5400CF000800000065
   ASAM Dataset: EV_AirbaVW22BPAVW27X 001010
   ROD: EV_AirbaVW22BPAVW27X.rod
   VCID: 025D8A1F84842977DCD-8056
   Subsystem 1 - Part No SW: -----------    HW: 442 062 002 19
   Serial number: 3577Y23C32B99280B2AB
   Subsystem 2 - Part No SW: -----------    HW: 442 062 002 19
   Serial number: 3587Y23BB2B992820121
   Subsystem 3 - Part No SW: -----------    HW: 442 0B0 802 19
   Serial number: 3517785C12F41A56D17R
   Subsystem 4 - Part No SW: -----------    HW: 442 0B0 802 19
   Serial number: 3527785AF2F41A56619Z
   Subsystem 5 - Part No SW: -----------    HW: 442 133 101 19
   Component: FrontSensor_D  290 118A
   Serial number: 355AG11C12F424E2E48.
   Part No SW: 2G0 920 790 A    HW: 2G0 920 790 A
   Component: KOMBI         508 1701
   Coding: 04AC010829800008018822011001000000000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001026
   ROD: EV_DashBoardVDDMQBA0_VW27.rod
   VCID: 2517F183356A3E4F99F-8070
   Part No SW: 3Q0 907 530 AA    HW: 3Q0 907 530 C
   Component: GW MQB High   442 4367
   Revision: --------    Serial number: 0009134205
   Coding: 030100046F085600FA0002481C0F00010001070000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: 6E85CEAFA01C3D17285-803A
   Component: 0-00-00-00-00
   Subsystem 2 - Part No SW: 2G0 959 442 J    HW: 2G0 959 442 J
   Component: E221__MFL-DC1  H02 0052
   Serial number: 39190000099890089055
   Coding: 29FFFF
   Subsystem 3 - Part No SW: 2Q0 915 181     HW: 2Q0 915 181
   Component: J367-BDMBOSCH  H02 2011
   Serial number: 100E7AC2
Address 44: Steering Assist (J792)       Labels:* None
   Part No SW: 2Q1 909 144 M    HW: 2Q1 909 144 F
   Component: TRW_G4L_MQBA0 611 6041
   Serial number: 01071530CP3K064
   Coding: 010000000000000001010201010001000000010101
   ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 011016
   ROD: EV_SteerAssisTRWG4LMQBA0.rod
   VCID: 3C2134E7A6E09F87D61-8068
   Part No SW: 7P6 907 357 E    HW: 7P6 907 357 A
   Coding: 178A000009200003
   ASAM Dataset: EV_HeadlRegulAFSMQBMAX 001001
   ROD: EV_HeadlRegulAFSMQBMAX_VW27.rod
   VCID: 41DF4513C102F26F857-8014
   Part No SW: 3Q0 035 840 C    HW: 3Q0 035 840 C
   Component: MU-S--ER      H41 0472
   Serial number: VWZAZ2W0751066
   Coding: 02720000BE0000004111000100080A001F0500E40120000003
   ROD: EV_MUStd4CTSAT_VW27.rod
   VCID: 2B0307BB538E083F4FB-807E
   Subsystem 1 - Part No SW: 5G6 919 605 A    HW: 5G6 919 605 A
   Component: ABT_Std-2  H52 8130
   Serial number: VWZ6ZJW0531707
   Part No SW: 7P5 941 591 AH    HW: 7P5 941 591 A
   Component: LED1L         H07 0009
   ROD: EV_LED_PLUS_L_KEBODAVW416_VW27.rod
   Component: LED1R         H07 0009
End----------(Elapsed Time: 01:00, VBatt start/end: 12.4V/12.4V)-----------
