I have a 2015 Audi S3, I ran a scan on the transmission and some codes popped up, the codes auto clear when the car is turned off and come back once started and go through the gears, car seems to run and drive fine, car has a DQ250 DSG Apr stage 3 TCU tune, engine has a big turbo with supporting mods and runs on e85, transmission malfunction does no come on, it has 2x once when i did a 1/4 pull it came on at the end of the run and once at the end of a 3rd,4th,5th gear pull, any information on possible causes would be much appreciated
Address 02: Auto Trans Labels: 0D9-927-770.CLB
Control Module Part Number: 0D9 300 012 HW: 02E 927 770 AQ
Component and/or Version: DQ250-6A MQB H53 4903
Software Coding: 0014
Work Shop Code: WSC 04742 780 00200
ASAM Dataset: EV_TCMDQ250021 001001 (AU37)
ROD: EV_TCMDQ250021.rod
VCID: 53A53B173A8271D774-8006
8 Faults Found:
21153 - Gear 1
P072C 00 [002] - Not Selectable
21154 - Gear 2
P072D 00 [002] - Not Selectable
21155 - Gear 3
P072E 00 [002] - Not Selectable
21156 - Gear 4
P072F 00 [002] - Not Selectable
21159 - Gear R
10732 - Valve 3 in Transmission Part 2
P174E 00 [002] - Electrical malfunction
10906 - Cooling Oil Valve
Sunday,18,August,2019,11:03:30:30521
VCDS Version: 19.6.1.0 (x64)
VIN: WAUFFGFFXF1077035 License Plate:
Address 02: Auto Trans Labels: 0D9-927-770.clb
9 Faults Found:
21153 - Gear 1
21154 - Gear 2
21155 - Gear 3
21156 - Gear 4
21157 - Gear 5
P073A 00 [002] - Not Selectable
21158 - Gear 6
P073B 00 [002] - Not Selectable
Address 02: DTCs cleared
Address 02: DTCs clearedSunday,18,August,2019,12:24:44:30521
12 Faults Found:
21153 - Gear 1
21154 - Gear 2
21155 - Gear 3
21156 - Gear 4
21157 - Gear 5
21158 - Gear 6
21159 - Gear R
10657 - RPM Signal from ECU
P0726 00 [002] - Implausible Signal
10909 - Cooling Oil Valve
Monday,19,August,2019,08:22:48:30521
Mileage: 66396km-41256mi Repair Order:
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 2B 3C 42 44 47 52 55
5F 6C A9 BB BC
VIN: WAUFFGFFXF1077035 Mileage: 66396km-41256miles
Address 01: Engine (J623-CYFB) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 259 K HW: 06K 907 425 E
Component: 2.0l R4 TFSI H13 0602
Revision: --H13---
Coding: 0A1D00322426000E3000
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM20TFS0208V0906259K 001003
ROD: EV_ECM20TFS0208V0906259K.rod
VCID: 489F1C7BF3C4C20F11-801C
Readiness: 1010 0100
Part No SW: 0D9 300 012 HW: 02E 927 770 AQ
Component: DQ250-6A MQB H53 4903
Revision: 03253104 Serial number: TFK01409241359
Shop #: WSC 04742 780 00200
Part No SW: 3Q0 907 379 Q HW: 3Q0 907 379 F
Component: ESC H42 0610
Revision: 00000000 Serial number: 62734000003093
Coding: 31FF6B9254270A730177030341C8698CD62A5080C08296B6024100D88207
Revision: 00021000 Serial number: 0349814246
Coding: 030C0C
VCID: 3A7B76B3BD28A09F97-806E
Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
Component: AC Automat H13 0052
Revision: 20026000 Serial number: 00000000470162
VCID: 33655B979A4251D754-8066
Serial number: FA988357000000000001
Part No SW: 5Q0 937 085 AC HW: 5Q0 937 085 AC
Component: BCM MQBAB HNA H18 0137
Serial number: 01011428800483
Coding: 04151C46C04106FD41C04004511807A00800000000000000000000000000
ROD: EV_BCMBOSCH_013.rod
VCID: 7AFBB6B3FDA8609FD7-802E
Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 141004 042 0585
Serial number: 141021125002
Coding: 0A47F7
Component: G397_RLFS H06 0002
Serial number: 23336452
Coding: 00006C
Subsystem 3 - Part No SW: 8V0 941 531 AA HW: 8V0 941 531 AA
Serial number: 08 08 2014 00001063
Serial number: 00000000000060812115
Sun Roof:
Component: J245 PS73.404 H02 0003
Serial number: 0000FST0000754G00000
Coding: 101F00
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 J HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0051
Revision: -------- Serial number: 39331428205581
Coding: 0030150011
VCID: 428B0E53D5F8E85FCF-8016
Address 14: Susp. Elect. (J250) Labels: 8V0-907-376.clb
Part No SW: 8V0 907 376 C HW: 8V0 907 376 C
Component: DAEMPFUNGS-SG H08 0066
Serial number: 220914038
ROD: EV_AudiMagneRide.rod
VCID: 4189015FD0FEF347D6-8014
Component: AirbagVW20 009 0825
Serial number: 003GCR00VDBR
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 479D1F47FEDACD7718-8012
Belt Pretensioner left:
Component: BeltPretRevFL H36 0350
Serial number: 34178311B22101440278
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H36 0350
Serial number: 34178312B22101470632
Coding: 333135
Occupant Detection:
Serial number: 6940000Y1400018PTT0L
Coding: 303230
Subsystem 4 - Part No SW: ----------- HW: 480 002 310 14
Serial number: 357000000005C289611G
Subsystem 5 - Part No SW: ----------- HW: 480 002 310 14
Serial number: 35800000000613896118
Subsystem 6 - Part No SW: ----------- HW: 480 401 610 14
Serial number: 3510002C918166B572C5
Subsystem 7 - Part No SW: ----------- HW: 480 401 610 14
Serial number: 3520002C718166B2B12.
Subsystem 8 - Part No SW: ----------- HW: 480 400 109 14
Serial number: 3550002B5175A8E081ED
Front Sensor Passenger:
Subsystem 9 - Part No SW: ----------- HW: 480 400 109 14
Serial number: 3560002B5175A8E2D1FM
Address 16: Steering wheel (J527) Labels:. 5Q0-953-549.clb
Part No SW: 8V0 953 521 CP HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 18101404400027
Coding: A018
VCID: 0A1BE673AD48701FC7-805E
Part No SW: 8V0 920 970 S HW: 8V0 920 970 S
Component: KOMBI H02 4291
Coding: 0BED181B3B8857050201EA001800000000000000
VCID: 4C97206BE7BC2E2F35-8018
Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 M
Component: GW MQB High 212 2203
Revision: -------- Serial number: 01101410802775
Coding: 0101000830085A005B00022C980B00000001010000000000000000000000
ROD: EV_GatewConti_011.rod
VCID: 72EB9E93A5D818DF9F-8026
Subsystem 2 - Part No SW: 8U0 951 528 C HW: 8U0 951 528 C
Serial number: 17 10 2014 C0047695
Part No SW: 0CQ 907 554 D HW: 0CQ 907 554 D
Serial number: HA1-00004.09.14
Coding: 0001
VCID: 46831243F9D0D47FE3-8012
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 14000292251003
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 3467588B9F4C56EF4D-8060
Part No SW: 5Q0 907 566 A HW: 8T0 907 566 B
Component: SWA Master H05 0071
Serial number: 0348367775
Coding: 030211
VCID: 387F6CBB8324B28F61-806C
Subsystem 1 - Part No SW: 5Q0 907 568 A HW: 8T0 907 568 B
Component: SWA Slave H05 0071
Serial number: 0348774456
Coding: 030211
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 14101402090927
Coding: 005D1F205C00048000000002
VCID: 408F045BDBF4FA4FD9-8014
Part No SW: 3Q0 909 144 H HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5061
Coding: 8102
VCID: 377D6F878E3ABDF768-8062
Part No SW: 8V0 035 465 C HW: 8V0 035 465
Component: MIBAMP1ALPINE H11 0410
Serial number: AUZ8ZAEN900SSR%
Coding: 01030300AAAA2AAA01
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 14101403111564
Coding: 005D17205E00048000000002
VCID: 3F8D07A7A60A85B7A0-806A
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0091
Coding: 012200003F200400
Coding: E00100
Coding: E00100
Subsystem 3 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Labels: 3D0-941-329.CLB
Component: LeiMo links H01 7050
Coding: E00100
Subsystem 4 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 7050
Coding: E00100
Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-HGH1.clb
Part No SW: 8V0 035 038 B HW: 8V0 035 038 B
Component: MU-H-LNS-US H43 0394
Serial number: A302J0EB005348
Coding: 017301020000000021220002041A00102F000225010001043E
ROD: EV_MUHig6C3HBAS_AU37.rod
Subsystem 1 - Part No SW: V03 959 800 SS HW: -----------
Component: NAR 2015 --- 0035
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0013
Serial number: AUZ8Z9EY201YBT
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 L HW: 8V0 919 614 L
Component: ControlUnit_H H81 0816
Serial number: C1000002091400030299
Component: Gracenote --- 3006
Part No SW: 5Q0 907 441 A HW: 5Q0 907 441 A
Component: MQB RVC Mid H07 0140
Coding: 027300010201000300
ROD: EV_2CamSysRearPASE.rod
VCID: 306F549B6B546ACF29-8064
Part No SW: 8V0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0012
Serial number: 140920201090
VCID: 7DF1BDAFEC8657A7F2-8028
Part No SW: 5Q0 959 395 B HW: 5Q0 959 395 B
Component: TSG HFS 020 0025
Serial number: 15101406071203
Coding: 004D17204000048000000002
Component: TSG HBFS 020 0025
Serial number: 15101406071201
End-------------------------(Elapsed Time: 05:40)--------------------------
