Results 1 to 5 of 5
Thread: 2015 Audi S3 Mechatronic problem? Possibly
    Sep 2018
    I have a 2015 Audi S3, I ran a scan on the transmission and some codes popped up, the codes auto clear when the car is turned off and come back once started and go through the gears, car seems to run and drive fine, car has a DQ250 DSG Apr stage 3 TCU tune, engine has a big turbo with supporting mods and runs on e85, transmission malfunction does no come on, it has 2x once when i did a 1/4 pull it came on at the end of the run and once at the end of a 3rd,4th,5th gear pull, any information on possible causes would be much appreciated
                   Address 02: Auto Trans       Labels: 0D9-927-770.CLB
    Control Module Part Number: 0D9 300 012     HW: 02E 927 770 AQ
      Component and/or Version: DQ250-6A MQB  H53 4903
               Software Coding: 0014
                Work Shop Code: WSC 04742 780 00200
                  ASAM Dataset: EV_TCMDQ250021 001001 (AU37)
                           ROD: EV_TCMDQ250021.rod
                          VCID: 53A53B173A8271D774-8006
    8 Faults Found:
    21153 - Gear 1
              P072C 00 [002] - Not Selectable
    21154 - Gear 2
              P072D 00 [002] - Not Selectable
    21155 - Gear 3
              P072E 00 [002] - Not Selectable
    21156 - Gear 4
              P072F 00 [002] - Not Selectable
    21159 - Gear R
    10732 - Valve 3 in Transmission Part 2
              P174E 00 [002] - Electrical malfunction
    10906 - Cooling Oil Valve
    Sunday,18,August,2019,11:03:30:30521
    VCDS Version: 19.6.1.0 (x64)
    VIN: WAUFFGFFXF1077035   License Plate:
                    Address 02: Auto Trans       Labels: 0D9-927-770.clb
    9 Faults Found:
    21153 - Gear 1
    21154 - Gear 2
    21155 - Gear 3
    21156 - Gear 4
    21157 - Gear 5
              P073A 00 [002] - Not Selectable
    21158 - Gear 6
              P073B 00 [002] - Not Selectable
    Address 02: DTCs cleared
    Address 02: DTCs clearedSunday,18,August,2019,12:24:44:30521
    12 Faults Found:
    21153 - Gear 1
    21154 - Gear 2
    21155 - Gear 3
    21156 - Gear 4
    21157 - Gear 5
    21158 - Gear 6
    21159 - Gear R
    10657 - RPM Signal from ECU
              P0726 00 [002] - Implausible Signal
    10909 - Cooling Oil Valve
    Monday,19,August,2019,08:22:48:30521
    Mileage: 66396km-41256mi   Repair Order:
    Chassis Type: FF-AU37 (5Q0)
    Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 2B 3C 42 44 47 52 55
              5F 6C A9 BB BC
    VIN: WAUFFGFFXF1077035   Mileage: 66396km-41256miles
    Address 01: Engine (J623-CYFB)       Labels:. 06K-907-425-V1.clb
       Part No SW: 8V0 906 259 K    HW: 06K 907 425 E
       Component: 2.0l R4 TFSI  H13 0602
       Revision: --H13---
       Coding: 0A1D00322426000E3000
       Shop #: WSC 06385 790 00016
       ASAM Dataset: EV_ECM20TFS0208V0906259K 001003
       ROD: EV_ECM20TFS0208V0906259K.rod
       VCID: 489F1C7BF3C4C20F11-801C
    Readiness: 1010 0100
       Part No SW: 0D9 300 012     HW: 02E 927 770 AQ
       Component: DQ250-6A MQB  H53 4903
       Revision: 03253104    Serial number: TFK01409241359
       Shop #: WSC 04742 780 00200
       Part No SW: 3Q0 907 379 Q    HW: 3Q0 907 379 F
       Component: ESC           H42 0610
       Revision: 00000000    Serial number: 62734000003093
       Coding: 31FF6B9254270A730177030341C8698CD62A5080C08296B6024100D88207
       Revision: 00021000    Serial number: 0349814246
       Coding: 030C0C
       VCID: 3A7B76B3BD28A09F97-806E
       Component: AC Automat    H13 0052
       Revision: 20026000    Serial number: 00000000470162
       VCID: 33655B979A4251D754-8066
       Serial number: FA988357000000000001
       Part No SW: 5Q0 937 085 AC    HW: 5Q0 937 085 AC
       Component: BCM MQBAB HNA H18 0137
       Serial number: 01011428800483
       Coding: 04151C46C04106FD41C04004511807A00800000000000000000000000000
       ROD: EV_BCMBOSCH_013.rod
       VCID: 7AFBB6B3FDA8609FD7-802E
       Component: WWS371 141004  042 0585
       Serial number:         141021125002
       Coding: 0A47F7
       Serial number: 23336452
       Coding: 00006C
       Subsystem 3 - Part No SW: 8V0 941 531 AA    HW: 8V0 941 531 AA
       Serial number: 08 08 2014  00001063
       Serial number: 00000000000060812115
       Sun Roof:
       Component: J245 PS73.404  H02 0003
       Serial number: 0000FST0000754G00000
       Coding: 101F00
       Part No SW: 5Q0 919 294 J    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0051
       Revision: --------    Serial number: 39331428205581
       Coding: 0030150011
       VCID: 428B0E53D5F8E85FCF-8016
    Address 14: Susp. Elect. (J250)       Labels: 8V0-907-376.clb
       Part No SW: 8V0 907 376 C    HW: 8V0 907 376 C
       Component: DAEMPFUNGS-SG H08 0066
       Serial number:       220914038
       ROD: EV_AudiMagneRide.rod
       VCID: 4189015FD0FEF347D6-8014
       Serial number: 003GCR00VDBR
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 479D1F47FEDACD7718-8012
       Belt Pretensioner left:
       Serial number: 34178311B22101440278
       Coding: 333135
       Belt Pretensioner right:
       Serial number: 34178312B22101470632
       Coding: 333135
       Occupant Detection:
       Serial number: 6940000Y1400018PTT0L
       Coding: 303230
       Subsystem 4 - Part No SW: -----------    HW: 480 002 310 14
       Serial number: 357000000005C289611G
       Subsystem 5 - Part No SW: -----------    HW: 480 002 310 14
       Serial number: 35800000000613896118
       Subsystem 6 - Part No SW: -----------    HW: 480 401 610 14
       Serial number: 3510002C918166B572C5
       Subsystem 7 - Part No SW: -----------    HW: 480 401 610 14
       Serial number: 3520002C718166B2B12.
       Subsystem 8 - Part No SW: -----------    HW: 480 400 109 14
       Serial number: 3550002B5175A8E081ED
       Front Sensor Passenger:
       Subsystem 9 - Part No SW: -----------    HW: 480 400 109 14
       Serial number: 3560002B5175A8E2D1FM
       Part No SW: 8V0 953 521 CP    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 18101404400027
       Coding: A018
       VCID: 0A1BE673AD48701FC7-805E
       Part No SW: 8V0 920 970 S    HW: 8V0 920 970 S
       Coding: 0BED181B3B8857050201EA001800000000000000
       VCID: 4C97206BE7BC2E2F35-8018
       Revision: --------    Serial number: 01101410802775
       Coding: 0101000830085A005B00022C980B00000001010000000000000000000000
       ROD: EV_GatewConti_011.rod
       VCID: 72EB9E93A5D818DF9F-8026
       Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
       Serial number: 17 10 2014  C0047695
       Part No SW: 0CQ 907 554 D    HW: 0CQ 907 554 D
       Serial number: HA1-00004.09.14
       Coding: 0001
       VCID: 46831243F9D0D47FE3-8012
       Revision: 00000000    Serial number: 14000292251003
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 3467588B9F4C56EF4D-8060
       Part No SW: 5Q0 907 566 A    HW: 8T0 907 566 B
       Serial number: 0348367775
       Coding: 030211
       VCID: 387F6CBB8324B28F61-806C
       Subsystem 1 - Part No SW: 5Q0 907 568 A    HW: 8T0 907 568 B
       Component: SWA Slave  H05 0071
       Serial number: 0348774456
       Coding: 030211
       Serial number: 14101402090927
       Coding: 005D1F205C00048000000002
       VCID: 408F045BDBF4FA4FD9-8014
       Coding: 8102
       VCID: 377D6F878E3ABDF768-8062
       Part No SW: 8V0 035 465 C    HW: 8V0 035 465
       Component: MIBAMP1ALPINE H11 0410
       Serial number: AUZ8ZAEN900SSR%
       Coding: 01030300AAAA2AAA01
       Serial number: 14101403111564
       Coding: 005D17205E00048000000002
       VCID: 3F8D07A7A60A85B7A0-806A
       Component: AFS-ECU       H01 0091
       Coding: 012200003F200400
       Coding: E00100
       Coding: E00100
       Subsystem 3 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
       Coding: E00100
       Subsystem 4 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
       Coding: E00100
       Part No SW: 8V0 035 038 B    HW: 8V0 035 038 B
       Component: MU-H-LNS-US   H43 0394
       Serial number: A302J0EB005348
       Coding: 017301020000000021220002041A00102F000225010001043E
       ROD: EV_MUHig6C3HBAS_AU37.rod
       Subsystem 1 - Part No SW: V03 959 800 SS    HW: -----------
       Component: NAR 2015  --- 0035
       Component: DU High  H49 0013
       Serial number: AUZ8Z9EY201YBT
       Multimedia Operating Unit:
       Serial number: C1000002091400030299
       Component: Gracenote  --- 3006
       Coding: 027300010201000300
       ROD: EV_2CamSysRearPASE.rod
       VCID: 306F549B6B546ACF29-8064
       Part No SW: 8V0 907 159     HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0012
       Serial number: 140920201090
       VCID: 7DF1BDAFEC8657A7F2-8028
       Part No SW: 5Q0 959 395 B    HW: 5Q0 959 395 B
       Component: TSG HFS       020 0025
       Serial number: 15101406071203
       Coding: 004D17204000048000000002
       Component: TSG HBFS      020 0025
       Serial number: 15101406071201
    End-------------------------(Elapsed Time: 05:40)--------------------------
    Some of these TCUs have really wonky diagnostic stacks. Try un-checking "Use Aggressive Mode" in VCDS and see if those faults still show up. My guess is that they won't, and if so, I wouldn't worry about 'em.
  3. Likes Railroader liked this post
    Sep 2018
    ok ill try that, just to mention that when i perform the scan with my eurodyne cable which has capability to do the adaptations and some coding, no codes pop up. Thanks
    Sounds like a loose ground or problem cooler valve shorting the bus.
    Sep 2018
    What do you mean cooler valve shorting bus, I'm gonna be replacing the thermostat housing and pulling the injectors this weekend so I'll go over all the connections when I have everything torn apart
