Results 1 to 9 of 9
Thread: No start help please
    Aug 2019
    Hello. Please help diagnosing a no start.
    2011 A4 Quatro 2.0L FL chassis
    Did a major engine repair after a chain tensioner failed.
    If I spray starting fluid it starts.
    using VCDS i was able to turn on HPFP valve, LPFP and all 4 injectors.
    Did some scanning on fuel, here's what I have while cranking
    Address 01: Engine (8K2 907 115 AD)
    14:58:24
    IDE00201 High fuel pressure: specified value 5.3250 MPa
    IDE00357 Fuel temperature -48.0 °C
    IDE00371 Fuel consumption 0.00 l/h
    IDE00589 Fuel pressure 80 kPa rel
    IDE01893 Fuel pump: specified value 10.001 %
    Please help me understand these numbers. I though I understand English untill i ran into this.
    Dec 2016
    Amsterdam
    Full autoscan please
    And a blockmap of the engine controller also wouldnt hurt.
    Current:
  3. Likes Jack@European_Parts, Uwe liked this post
    Hello and RT may or may not welcome the online police to the VCDS forum........
    Nein auto-scan?..........please post one!
    You have been fined 1 credit for a civil violation of the VCDS Church morality rules.
    JPPSG
    https://www.youtube.com/watch?v=BffgC5DKQG0
    Retrace your work steps for induced FOD!
  5. Likes Uwe liked this post
  6. #4
    Aug 2019
    Saturday,17,August,2019,12:16:54:35464
    VCDS Version: 19.6.1.0 (x64)
    VIN: WAUHFAFL8BN042640   License Plate:
    Mileage: 195070km-121210mi   Repair Order:
    Chassis Type: FL-AU48 (8T0)
    Scan: 01 03 05 08 09 15 16 17 19 2E 42 46 47 52 53 55 56 62 72 77
    VIN: WAUHFAFL8BN042640   Mileage: 195070km-121210miles
    Address 01: Engine (DL0MA-CAEB)       Labels:| 06H-907-115-CAB.clb
       Part No SW: 8K2 907 115 AD    HW: 8K2 907 115 D
       Component: 2.0l R4/4V TF H19 0003
       Revision: E1H19---
       Coding: 0104010A180F0160
       Shop #: WSC 02145 785 00200
       ASAM Dataset: EV_ECM20TFS0118K2907115AD 001006
       ROD: EV_ECM20TFS0118K2907115AD.rod
       VCID: 71E99438A02392C766-8024
    4527 - Coolant Fan Control Circuit 1
              P0480 00 [039] - Electrical Malfunction
                        Mileage: 195074 km
                        Date: 2010.04.03
                        Time: 12:47:13
                        Coolant temperature: 25 C
                        Intake air temperature: 30 C
                        Voltage terminal 30: 12.957 V
    Readiness: 1110 0101
       Part No SW: 8K0 907 379 BJ    HW: 8K0 907 379 BJ
       Component: ESP8 quattro  H04 0060
       Coding: 070D18
       Shop #: WSC 02391 823 56573
       VCID: 020BCBF49D85995F8F-8056
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 81
                        Mileage: 195074 km
                        Date: 2010.04.03
                        Time: 12:50:01
                        Hex Value: 0x0000
                        Hex Value: 0x0280
                        Hex Value: 0x0032
                        Hex Value: 0x02A2
                        Hex Value: 0x00FF
       Part No SW: 8K0 907 064 CF    HW: 8K0 907 064 CF
       Component: BCM2 2.0      H05 0435
       Coding: 0B0100
       Shop #: WSC 02399 823 56573
       VCID: 76E3A724C14DB5FFB3-8022
       Subsystem 1 - Part No SW: 8T0 959 754 A    HW: 8T0 959 754 A
       Component: FBSAUDIB8 IDG  H60 0072
       Serial number: 0811000006715015
       Serial number: 2310000105926010
       Part No SW: 8T1 820 043 AQ    HW: 8T1 820 043 AQ
       Component: KLIMA 3 ZONEN H08 0180
       Revision: C1000000    Serial number: 01250120110483
       Coding: 64002000
       VCID: 000FC1FC93898B4F99-8054
                        Reset counter: 81
                        Mileage: 195074 km
                        Date: 2010.04.03
                        Time: 12:47:12
                        Temperature: 28.0C
                        Reset counter: 81
                        Mileage: 195074 km
                        Date: 2010.04.03
                        Time: 12:47:12
       Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
       Component: BCM1 1.0      H30 0392
       Revision: 10030001    Serial number: 00000000768899
       Coding: 26001091063CAF010000080300003D0D0F1C120802010161000000
       VCID: 3C77750CBFE12FAF85-8068
       Component: WWS 240111  H06 0070
       Serial number: SWF11010245905
       Coding: 00FD11
       Component: RLS  H04 0003
       Serial number: 11234911
       Coding: 025028
       Component: E1 - LDS  H03 0031
       Serial number: 00000000001001110134
       Subsystem 4 - Part No SW: 8K0 907 410 C    HW: 8K0 907 410 C
       Component: HOMELINK  H01 0010
    02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
                        Reset counter: 81
                        Mileage: 195074 km
                        Date: 2010.04.03
                        Time: 12:47:00
    02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
                        Reset counter: 81
                        Mileage: 195074 km
                        Date: 2010.04.03
                        Time: 12:47:00
                        Reset counter: 81
                        Mileage: 195074 km
                        Date: 2010.04.03
                        Time: 12:47:00
       Part No SW: 8K0 959 655 K    HW: 8K0 959 655 K
       Component: AirbagVW-AU10 H44 0610
       Serial number: 003GLD0N3Z2U
       Coding: 303837354230303030304A55304C384B3053
       Shop #: WSC 02135 785 00200
       VCID: 458110E8C42B6E67EA-8010
       Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
       Serial number: 5810000R1100003R69
       Serial number: 6334MSME5B314B67L
       Serial number: 6344MSME5B422B51F
       Serial number: 6352QSME707D01027
       Serial number: 6362QSME4700066EF
    9443859 - Driver's Front Airbag Crash Sensor
              B101A 15 [137] - Open or Short to Plus
                        Mileage: 195074 km
                        Date: 2010.04.03
                        Time: 12:47:12
    9444115 - Front Passenger's Front Airbag Crash Sensor
              B101B 15 [137] - Open or Short to Plus
                        Mileage: 195074 km
                        Date: 2010.04.03
                        Time: 12:47:12
       Component: Lenks.Modul   H17 0014
       Revision: --------    Serial number: 90372KAP00174
       Coding: 000016
       VCID: 3D717808A4FB26A7B2-8068
       Component: E221 - MFL  H02 0010
       Part No SW: 8K0 920 950 H    HW: 8K0 920 950 H
       Component: KOMBIINSTR.   H20 0258
       Revision: 00200000    Serial number: EIL369T1C
       Coding: 8B1409000300D705020000
       VCID: 34675D2C97B1E7EF4D-8060
    00771 - Fuel Level Sensor (G)
                        Fault Status: 00101010
                        Reset counter: 121
                        Mileage: 195074 km
                        Date: 2010.01.25
                        Time: 22:20:05
    00438 - Fuel Supply Sensor 2 (G169)
                        Fault Status: 01101010
                        Fault Frequency: 7
                        Reset counter: 81
                        Mileage: 195074 km
                        Date: 2010.01.25
                        Time: 22:20:05
       Part No SW: 8T0 907 468 AB    HW: 8T0 907 468 H
       Component: GW-BEM 5CAN   H06 0117
       Revision: GB800053    Serial number: 5300G111168082
       Coding: 00C303
       VCID: 0109C4F89883824796-8054
       Subsystem 1 - Part No SW: 8K0 915 181 E    HW: 8K0 915 181 E
       Component: J367-BDM  H07 0170
       Serial number: 11004371140111
    Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
       Part No SW: 8T0 035 785 A    HW: 8T0 035 785
       Component: SG ext.Player H08 0290
       Revision: 00000000
       Coding: 020302
       VCID: 39796C18B0D31A879E-806C
       Part No SW: 8T0 959 793 M    HW: 8T0 959 793 D
       Component: TSG FA        H08 1501
       Coding: 011C03204000410001
       VCID: 53A53EB0327FC0D774-FFFE
       Revision: 00002001    Serial number: 0141838300
       Coding: 0106023A00FA444480B0013200000000
       Component: GTO BF  H01 0070
       Serial number: 00000000000000354421
       Subsystem 3 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
       Component: J245 PS039  H07 0041
    Address 47: Sound System (J525)       Labels:. 8T0-035-223-BOC.clb
       Part No SW: 8T0 035 223 AR    HW: 8T0 035 223 AJ
       Component: DSP Prem      H19 0320
       Revision: 00019001    Serial number: 34803000708601
       Coding: 0203010302
       Shop #: WSC 09223 444 84432
       VCID: 7EF3BF04E97DFDBFEB-802A
       Part No SW: 8T0 959 792 M    HW: 8T0 959 792 D
       Component: TSG BF        H08 1501
       VCID: 52AB3BB40D65C9DF7F-8006
       Revision: 00000003    Serial number: 00000000842883
                        Fault Status: 11101101
                        Reset counter: 81
                        Mileage: 195074 km
                        Date: 2010.04.03
                        Time: 12:47:12
                        Voltage: 13.00 V
                        Count: 80
                        Hex Value: 0x0270
                        Hex Value: 0x0001
                        Hex Value: 0x0101
       Part No: 8K5 907 357 B
       Coding: 0000004
       VCID: 39796C1870D31A879E-806C
    01535 - Control Circuit for Right Headlight Range Adjusting Motor (V49)
                        Reset counter: 121
                        Mileage: 195074 km
                        Date: 2010.04.03
                        Time: 12:47:13
    01534 - Control Circuit for Left Headlight Range Adjusting Motor (V48)
                        Reset counter: 121
                        Mileage: 195074 km
                        Date: 2010.04.03
                        Time: 12:47:13
       Part No SW: 8T1 035 186 R    HW: 8T1 035 186 R
       Component: Con3 Sirius   H06 0351
       Revision: 00000008    Serial number: AUZ5Z6J1374836
       Coding: 04030002010185004359070800
       Shop #: WSC 54644 000 1048576
       VCID: 468317E4F12D657FE3-8012
       Subsystem 1 - Part No SW: 8T0 919 603 F    HW: 8T0 919 603 F
       Component: Display
                        Reset counter: 81
                        Mileage: 195074 km
                        Date: 2010.04.03
                        Time: 12:47:22
       Part No SW: 8T0 959 795 N    HW: 8T0 959 795 B
       Component: TSG HL        H06 1501
       Coding: 010C03204000210001
       VCID: 56A3C7A4218DD5FF93-8002
       Component: TSG HR        H06 1501
       Part No SW: 8T0 862 336 E    HW: 8T0 862 336 E
       Component: FSE_256x BT     H42 0650
       Revision: 00000000    Serial number: 00000005107768
       Coding: 0010370
       Shop #: WSC 02335 785 00200
       VCID: 3D71780864FB26A7B2-8068
    End-------------------------(Elapsed Time: 09:39)--------------------------
    12:34:37
      IDE00019   Voltage terminal 30 12.910 V
      IDE00021   Engine speed 0 /min
      IDE00190   Charge air pressure specified value 340 hPa
      IDE00201   High fuel pressure: specified value 5.0000 MPa
      IDE00407-ENG57549   Rail pressure regulation: status-Bits 0-7 0
      IDE01930   High pressure regulation: adaptation value -0.1630 MPa
      IDE01931   High pressure pump injection volume control deviation 4.8125 MPa
      IDE01932   High pressure pump injection volume 327.67 mm
    No mods to the engine. Stock except for 2 ignition coils.
    Just finished rebuilding the head due to bent valves.
    Replaced all spark plugs, timing chains, chain guides, and tensioners.
    The front of the car is still off so fans, temp sensors etc aren't connected. Hence the errors on the scan.
    Parts purchased at genuineaudiparts.com and ecstuning.com
    All fuses are checked and none were bad. Although, I dont know if I found all fuse boxes. One in the trunk, one on each side of the dash.
    Hmmm is there something you are failing to tell us here?
    Is this car modified?
    Can you explain to us why your car is failing a readiness monitor bit for EGR valve?
    Uhm, the car isn't fully back together yet. Are we really going to obsess over readiness bits on a car that won't start?
    Well sure because It's a serious anomaly to me.
    I would like the OP or law enforcement official of the net to default controller clear codes and see if the status of anything changes here.
    OP please do this by a mere recode and clearing codes in the engine 0x01 and also in OBD2 mode in 0x33 MODE 4.
    Please advise of new scan and if readiness bit changed for EGR and if a pulse wakes up to injectors or N276?
    Usually people set stuff to not ready when doing something nefarious, in this case it's just the opposite so to me it matters!
    Are we missing power on bus to injectors or N276?
    What are ground points status?
  10. #8
    Aug 2019
    I can assure you that the car isn't modified.
    Sorry, what do you mean by EGR? Where do I find it on the scan I provided?
    There was a whole bunch of codes right at initial scan. The scan I provided above is after I cleared the initial codes after looking over stuff and plugging the things that were not connected and then cranking the engine a few times. However, will clear it again when I get to it.
    Meanwhile, can someone please explain these fuel stats to me?
  11. #9
    Reset counter: 121
    Mileage: 195074 km
    Date: 2010.01.25
    Time: 22:20:05
    Fault Frequency: 7
    Reset counter: 81
    Mileage: 195074 km
    Date: 2010.01.25
    Time: 22:20:05
    What is this all about?
