Results 1 to 10 of 10
Thread: Passat b6 folding mirror retrofit
Hybrid View
    Nov 2016
    Modules wont accept coding, getting -31 out of range
    Modules are gen3 max so should work, but i've never done folding mirrors before
    Scan as below
    Monday,19,August,2019,22:14:54:34436
    VCDS Version: 19.6.1.0
    Workshop Code: 755 54764 070000
    VIN: WVWZZZ3CZ7P046711   License Plate:
    Chassis Type: 3C-VW46 (3C0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72 7D
    VIN: WVWZZZ3CZ7P046711   Mileage: 281910km-175170miles
    Address 01: Engine        Labels: 03G-906-018-BKP.clb
       Part No SW: 03G 906 018 CE    HW: 03G 906 018 CE
       Component: R4 2.0l PPD1.5 G    9384
       Revision: --H25---    Serial number: VWZCZ000000000
       Coding: 0000072
       Shop #: WSC 66565 257 00032
       VCID: 6ADC7C0D45F96D1F27-803E
    005187 - Potentiometer for EGR (G212)
                   P1443 - 007 - Signal too Low
                        Fault Status: 01010010
                        Reset counter: 40
                        Mileage: 281919 km
                        Date: 2014.01.09
                        Time: 22:11:13
                        Torque: 128.0 Nm
                            0.00 %
                        Battery Volts: 1.0 V
                        Mass Air / Rev.: 0.0 mg/str
    Readiness: N/A
    Address 03: ABS Brakes        Labels:. 3C0-614-095-C2.clb
       Part No SW: 3C0 614 095 P    HW: 3C0 614 095 P
       Component: ESP 440 C2     H015 0004
       Revision:  H015       Serial number: 0667854032
       Coding: 0013602
       Shop #: WSC 00191 210 89371
       VCID: 2F6AAD19BE9BC83730-807A
       Part No SW: 7N0 907 426 AM    HW: 7N0 907 426 AM
       Component: AC Manuell    H19 0304
       Revision: 00001016
       Coding: 0000004002
       Shop #: WSC 70885 001 00001
       ROD: EV_ACManueBHBVW36X_VW46.rod
       VCID: 7F0ABD59E67BF8B7E0-802A
       Part No SW: 3C0 937 049 H    HW: 3C0 937 049 H
       Component: Bordnetz-SG     H37 1301
       Revision: 00H37000    Serial number: 00000004320760
       Coding: A0800F0700041A00000A00000F000000000859435C0000
       Shop #: WSC 54764 755 70000
       VCID: 2E54B01DB991C13F3B-807A
       Subsystem 1 - Part No: 3C2 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer 290607 022  0601
       Coding: 00046997
       Shop #: WSC 54764
       Part No SW: 3C0 909 605 F    HW: 3C0 909 605 F
       Component: 02 AIRBAG VW8   029 2421
       Revision: 08029000    Serial number: 0039USD4JJLH
       Coding: 0012338
       Shop #: WSC 05311 000 00000
       VCID: 295E4301807FA607EE-807C
       Subsystem 1 - Serial number: 6332MSME110F1075
       Subsystem 2 - Serial number: 6342MSME117A722E
       Subsystem 3 - Serial number: 6351HTS6K5Q6U873
       Subsystem 4 - Serial number: 6361HTS6VARQ03B2
    01738 - Crash Sensor for Front Airbag; Drivers Side (G283)
    Address 16: Steering wheel (J527)       Labels:| User\3C0-953-569.lbl
       Part No SW: 3C5 953 501 BN    HW: 5K0 953 569 AB
       Revision: FF010040    Serial number: 20110927100793
       Coding: 0182250000
       Shop #: WSC 00028 028 00020
       VCID: 72EC646DA529A5DF9F-8026
       Subsystem 1 - Part No SW: 3C8 959 537 B    HW: 3C8 959 537 B  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAP  H4  0021
       Coding: E20000
       Part No SW: 3C0 920 971 R    HW: 3C0 920 971 R
       Component: KOMBI         H05 0110
       Coding: 160F00
       VCID: 3460A2759FBDEBEF4D-8060
    Address 19: CAN Gateway        Labels:. 3C0-907-530-V2.clb
       Part No SW: 3C0 907 530 E    HW: 3C0 907 951
       Component: J533__Gateway   H10 0080
       Revision:   H10       Serial number: 1200P07C110958
       Coding: F9807F160002021003
       VCID: 23425129E2537C57A4-8076
                        Reset counter: 208
                        Mileage: 281919 km
                        Date: 2014.01.09
                        Time: 22:11:14
       Part No SW: 3C0 959 433 AR    HW: 3C0 959 433 AR
       Component:    IMMO         043 0383
       Revision: 00043000    Serial number: VWZCZ000000000
       Shop #: WSC 00545 210 88561
       VCID: 7AFC4C4D3559DD9FD7-802E
       Component:    ELV          027 0380
       3C0905861G     ELV          027 0380
    02823 - Requirements for Locking the Steering Column Lock not met
                        Reset counter: 208
                        Mileage: 281919 km
                        Date: 2014.01.09
                        Time: 22:12:26
       Part No SW: 1K0 959 701 Q    HW: 1K0 959 793 M
       Component: J386  TUER-SG FT    1132
       Revision: 31008001    Serial number: 00000126369120
       Coding: 0000695
       VCID: 3C708A557FED23AF85-8068
       Part No: 1K2 909 144 L
       Component: EPS_ZFLS Kl.134 H07 1806
       Shop #: WSC 00028 028 00001
       VCID: 35669F715CC7F2E77A-8060
       Component:    KSG PQ46 ELV 043 0612
       Coding: 18910A0001860E7630041C1D70085FCE107C01
       Subsystem 2 - Part No: 3C0 951 171 A
       Component: Neigungssensor  002 0508
       Subsystem 3 - Part No: 3C0 951 171 A
       Component: Innenraumueberw.002 0508
       Part No SW: 1K0 959 702 Q    HW: 1K0 959 792 M
       Component: J387  TUER-SG BT    1132
       Revision: 31008001    Serial number: 00000027169123
       Coding: 0000694
       VCID: 3D76875164F72AA7B2-8068
       Revision:   013
       Coding: 0000012
       VCID: 214E5B21F84F6E47B6-8074
    Address 56: Radio        Labels: None
       Part No SW: 3TD 035 156     HW: 3TD 035 156
       Component: RadioSK46MID  006 0010
       Coding: 01000424041000
       Shop #: WSC 00078 790 00000
       VCID: 7F0ABD59EE7BF8B7E0-802A
       Part No SW: 1K0 959 703 P    HW: 1K0 959 795 G
       Component: J388   TUER-SG HL   1113
       Revision: 11005001    Serial number: 00000000426810
       Coding: 0000144
       Part No SW: 1K0 959 704 P    HW: 1K0 959 794 G
       Component: J389   TUER-SG HR   1113
       Revision: 11005001    Serial number: 00000000524634
       Coding: 0000144
       VCID: 3E74805D69F131BFAB-806A
       VCID: 2D56B711B497BA2702-8078
                014 - Defective
    End---------------------(Elapsed Time: -2:00, udsna)-----------------------
    Mar 2015
    Australia
    Gen3 door controllers in RHD as far as I've been able to tell there is no known eeprom data for folding.
    Need to upgrade to gen4s.
    2009 R36 wagon|Biscay Blue|RVC|Tailgate|ECU and DSG tune|LED DRL/Indicators|Full colour MFD|Quad LED tail rings| Climatronics upgrade| Dynaudio retrofit | B7 RLine Flat Steering Wheel|3AA CCM|B7 Adaptive Cruise with Front Assist|TPMS Direct|Discover Media retrofit|PLA 2.0|Lane Assist
  3. Likes Uwe liked this post
    Nov 2016
    So gen3 in rhd won’t accept the +4096 regardless?
    Oct 2014
    The factory fitted RHD gen3 max modules certainly can as I retrofitted folding mirrors to my Octavia.
       Part No SW: 1T0 959 701 AA    HW: 1T0 959 701 AA
       Component: Tuer-SG         009 2120
       Coding: 0004854
       Part No SW: 1T0 959 702 S    HW: 1T0 959 702 S
       Coding: 0005110
    They are very different SW/HW versions to your Passat which could explain it.
    I think Kamold is suggesting that some LHD versions need the EEPROM data updating to support folding but has never seen a dump for RHD versions.
    Mar 2015
    Australia
    Sorry I'm confusing things here....I'm actually talking about comfort folding from the keyfob...
    That's a known eeprom change for LHD but unknown for RHD.
    Regular folding from the mirror controls is fully supported with Gen3 modules.
    Nov 2016
    Quote Originally Posted by kamold View Post
    But that is the issue I am having. Two sets of gen 3 modules won’t accept the coding
    Oct 2014
    It's two different issues Rhinopower.
    - Kamold is talking about direct editing of the door controller EEPROM to add 'comfort folding' on a vehicle which already has working folding mirrors.
    - Your talking about the door controllers refusing a coding change to add folding mirror support when retrofitting.
    Just to confirm, you're trying 0004791 and 0004790?
    I'm not sure what else to suggest as I'm not super familiar with the B6 so others might be able to offer more help. I believe that MAX3 door controllers should be able to support folding mirrors, did you check the pins were present when you added the mirrors?
    Kamold, RHD comfort folding certainly can be done. As per this thread I was able to tweak the EEPROM using the information from this page.
  9. #8
    Nov 2016
    Quote Originally Posted by langers2k View Post
    Yes to confirm i have tried 4791 and 4790. I even tried coding just folding mirrors and nothing else, and still refused by the controllers
  10. #9
    Oct 2014
    Did a quick google and found a few scans with identical modules with faults that look to be folding mirror related:
    - https://vwforum.ro/topic/41312-oglin...omment=2323027
    - https://forums.ross-tech.com/showthr...ull=1#post7951
    - https://forums.vwvortex.com/showthre...1#post60036148
    None of them have +4096 in their code which makes me think the coding chart *might* be incorrect for your module.
  11. #10
    Nov 2016
    Coding: 0001463
    Coding: 0001462
    This coding worked for folding mirrors, so the label file is wrong
    I corrected the coding for the puddle lights etc after and mirrors still worked, but the label file saying add 4096 is incorrect
  12. Likes kamold liked this post
