Results 1 to 10 of 10
Thread: Request out of range message 09 adaptations
    Nov 2018
    Hi, new here so apologies if I’ve posted this incorrectly! I have a 2016 MK7 GTi and Recently I’ve noticed that when in auto mode the headlights (when on) will occasionally flick off and back on once super quickly after exiting a dark area, such as overhanging trees, I made the assumption that maybe it was sensing a further dark area at the point were the lights would shut off, therefore turning back on, to combat this I changed the tunnel on/off delay - channel 09 adaptations eng122930-rls_tunel_gateway_recognize ,(I now believe it may just be the on delay anyway) from 5seconds to 10seconds, this didn’t alter the abnormality so I wanted to put it back to 5seconds as when not playing up the lights stay on too long after a tunnel , however the adaptation will not take this time and displays a box stating ‘request out of range’ or such like and goes back to 10seconds, I’m entering the 31347 security code which takes so I don’t think it’s that, between the two adaptation change attempts I was prompted to update the HEX V2 cable so thought that might be something to do with it maybe? Anyway does anyone have any idea where I should start with this? I’m using the phone at the moment to post this so will post and auto scan ASAP, or an ad map later if required, having not done either of those things before though I may or may not need a little guidance, thanks.
    Monday,19,August,2019,20:42:30:06823
    VIN: WVWZZZAUZGW133319   License Plate:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F A9
    VIN: WVWZZZAUZGW133319   Mileage: 64886km-40318miles
    Address 01: Engine (J623-CHHB)       Labels:. 06K-907-425-V1.clb
       Part No SW: 5G0 906 259 C    HW: 06K 907 425 B
       Component: 2.0l R4 TFSI  H13 0002
       Revision: --H13---
       Coding: 091D00122464050B3000
       ASAM Dataset: EV_ECM20TFS0205G0906259C 001005
       ROD: EV_ECM20TFS0205G0906259C.rod
       VCID: 2E04F8B3F096EF07685-807A
       Part No SW: 0D9 300 041 C    HW: 02E 927 770 AQ
       Component: DQ250-6F MQB  H53 4902
       Revision: 06253104    Serial number: TFK01508131614
       ROD: EV_TCMDQ250021.rod
       VCID: 18683E6B621201B7129-804C
       Revision: 00000000    Serial number: 62545000003255
       Coding: 01FA93A13423296F077A0601C1CCA980C92C94E0608395F718425078C209
       VCID: 7AAC04E37C5EF3A784D-802E
       Revision: 00021000    Serial number: 0381047832
       Coding: 030C0C
       VCID: 3A2CC4E33CDE33A7C4D-806E
       Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
       Revision: 00001K08
       Coding: 00120004200100011005004000101002
       VCID: 6A8C34A30CFE432774D-803E
       Air quality sensor:
       Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
       Component: BCM MQBAB H   H24 0175
       Serial number: 01061526601261
       Coding: 03051A46C20122FB0F244080B11C07281800000000000000000000000000
       Shop #: WSC 12345 102 209715
       ROD: EV_BCMBOSCH_015.rod
       VCID: 094E6B2F29B8E83F9D7-805C
       Subsystem 1 - Part No SW: 5G2 955 119 A    HW: 5G2 955 119 A  Labels: 5QX-955-119-V1.CLB
       Component: WWS    150723  042 0551
       Serial number:         150806065600
       Coding: 0E4DFD
       Component: RLHS  037 0059
       Serial number: S5Y15M09D29H13M37S47
       Coding: 90A8DD
       Component: Sensor, DWA  006 0326
       Serial number: 000000000ZY1521718CE
       Serial number: 00000000000033405858
       Revision: --------    Serial number: 39331526402744
       Coding: 0071051011
       VCID: 43D2B9074B14726F97B-8016
    Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V1.clb
       Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 F
       Component: ACC Bosch MQB H05 0400
       Serial number: 10081503271980
       Coding: 001C1300FE0739
       ASAM Dataset: EV_ACCMRRBoschVW372 001016
       Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
       Component: AirbagVW20    015 0388
       Serial number: 003MLR13DEGY
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 7F5AF5F7677CD68FB33-802A
       Belt Pretensioner left:
       Serial number: 34169661C15091540122
       Coding: 333135
       Belt Pretensioner right:
       Serial number: 34169662C14091541230
       Coding: 333135
       Subsystem 3 - Part No SW: -----------    HW: 480 001 709 15
       Serial number: 3576700000012955F61T
       Subsystem 4 - Part No SW: -----------    HW: 480 001 709 15
       Serial number: 35867000000C1545F61Z
       Subsystem 5 - Part No SW: -----------    HW: 480 401 509 15
       Serial number: 35165029B1D25F70E1AO
       Subsystem 6 - Part No SW: -----------    HW: 480 401 609 15
       Serial number: 3526502B11D25F718089
       Subsystem 7 - Part No SW: -----------    HW: 480 401 609 15
       Serial number: 3556502B11D25F725114
       Part No SW: 5Q0 953 507 HN    HW: 5Q0 953 549 E
       Component: Lenks. Modul  003 0110
       Revision: --------    Serial number: 20091504220994
       Coding: 0C10
       ROD: EV_SMLSKLOMQB_010_VW37.rod
       Part No SW: 5G1 920 956 A    HW: 5G1 920 956 A
       Component: KOMBI         302 6420
       Coding: 27AD01182F80260001816A011400000000000000
       VCID: 2D06FFBFFD90941F51F-8078
       Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 F
       Component: GW MQB High   128 1224
       Revision: --------    Serial number: 0003976655
       Coding: 030100043F085900FB00027E1C0F00010001050000000000000000000000
       ROD: EV_GatewLear_013.rod
       VCID: 75B617DF55409CDFE9F-8020
       Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H10 0040
       Serial number: 29150001808390035377
       Coding: 2DFFFF
       Serial number: 9124577803
       Revision: 00000000    Serial number: 15000210812004
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 3430EADB1EBAC5D71E1-8060
       Serial number: 060915BI505597
       Coding: 003F1220D001048100001000
       Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
       Component: EPS_MQB_ZFLS  505 5063
       Coding: 8103
       VCID: 392EDBEF39D838BFCD7-806C
       Serial number: 170915BIG19192
       Coding: 003F1020DE01048100801000
       VCID: 42DCBC03540E7B679CD-8016
       Coding: 029E01001F000200
       VCID: 40D8B60B5A0269778A9-8014
       Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
       Component: LeiMo links  H01 0002
       Coding: 2E0000
       Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H01 0002
       Coding: 2E0000
       Part No SW: 3Q0 035 874 A    HW: 3Q0 035 874 A
       Component: MU-S-ND-ER    820 0629
       Coding: 02730001FF00000051111101008808001F0203C601200100CF
       Shop #: WSC 39782 001 104857
       ROD: EV_MUStd4CDELP_VW37.rod
       VCID: 3038E6CBEAA2F9F77A9-8064
       Component: ABT_High  H62 0031
       Serial number: VWZ8Z9RU304QHJ
       Subsystem 2 - Part No SW: 3G0 919 866 BJ    HW: -----------
       Component: ECE1 2018  --- 0915
    6691 - Local Data Bus
              U10BA 00 [008] - No Communication
              [Sub-Bus keine Kommunikation]
                        Reset counter: 17
                        Mileage: 63174 km
                        Date: 2019.07.13
                        Time: 08:38:17
                        Voltage terminal 30: 12.5 V
                        Network diagnosis-Status: not enabled
       Part No SW: 5G0 907 159     HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0014
       Serial number: 150902200753
       VCID: 6B8231A703045A2F0FB-803E
    End----------(Elapsed Time: 01:55, VBatt start/end: 12.3V/12.3V)-----------
    May 2014
    ^^^ hmm.......... here's a more "evocative" form of the code-string on the BCM from your auto-scan:
    Byte	Hex	Binary
    0	03	00000011
    1	05	00000101
    2	1A	00011010
    3	46	01000110
    4	C2	11000010
    5	01	00000001
    6	22	00100010
    7	FB	11111011
    8	0F	00001111
    9	24	00100100
    10	40	01000000
    11	80	10000000
    12	B1	10110001
    13	1C	00011100
    14	07	00000111
    15	28	00101000
    16	18	00011000
    17	00	00000000
    18	00	00000000
    19	00	00000000
    20	00	00000000
    21	00	00000000
    22	00	00000000
    23	00	00000000
    24	00	00000000
    25	00	00000000
    26	00	00000000
    27	00	00000000
    28	00	00000000
    29	00	00000000
    30		00000000
    As you can see - the Bit-structure of Byte 6 and Byte 7 (which is where the Light sensor and LDS is defined) is singularly unremarkable. So, in the words of the leader-of-the-free-world (a walking cliche and my role model - not), "nothing to see here""!!
    Just a hunch (actually, it's a complete guess), but jyoung8607 (a very astute forum colleague- particularly where American politics is concerned) mentioned on another post that sometimes VCDS requires modules on MQB platform vehicles to be reset when reverting back channel values.
    I wonder if this idiosyncrasy is implicated in your dilemma? Worth considering IMO, given that it's an easy try - perhaps?
    If not then perhaps posting a BCM admap (as you say) can shed further light onto the problem (pun intended)
    EDIT: Ooops - forgot to mention that the 'JYoung" method for resetting control modules is to remove and re-connect the battery lead - yes, it's a tad severe (why can't VCDS software mimic this process "virtually" - do UDS modules have an interrupt vector 0 facility?) but apparently it has worked in some instances.
    EDIT 2 : Subsequent rush of blood to the brain-box - have you tried a softer form of module reset: the one in the MENU called "factory reset"?
    Last edited by DV52; 08-19-2019 at 09:04 PM. Reason: Explained the "JYoung" method - and -subsequent deluge of the red stuff to the membrane!
    Nov 2018
    Thanks DV52 for your reply, yes I don’t believe there is anything remarkable showing in the coding for the RLS but I felt it was a requirement to post the auto scan, incidentally just prior to trying again to change the setting back to 5 seconds the battery had been unhooked for just over 24 hours as I had removed the steering wheel for a re trim, this appears to have had no effect, on a side note though it seems to have smoothed out the DSG rather like performing basic settings! Is applying the factory reset via VCDS a simple process? Is it performed in individual modules or is it system wide? Other than making a copy of the coding in the RLS are there any other prerequisites before clicking factory reset? Could updating the HEX-V2 in between changes have altered anything? Thanks.
    Nov 2018
    Does anyone have any thoughts on why I’d be getting the ‘request out of range’ message please?
    Quote Originally Posted by Carlosfandango View Post
    That message indicates that the control module in the car is refusing the change. As to why a control module is refusing, one would have to know the module's internal logic, and that's something we're not privy to.
  6. Likes DV52 liked this post
    May 2014
    TIs applying the factory reset via VCDS a simple process? Is it performed in individual modules or is it system wide? Other than making a copy of the coding in the RLS are there any other prerequisites before clicking factory reset? Could updating the HEX-V2 in between changes have altered anything? Thanks.
    Sorry for the confusion -it must be my thick Aussie accent - or the fact that English is my 2nd language!! When I said "the one in the MENU called "factory reset"" - I meant the MENU in the MIB - not any reset in VCDS (whatever you do, DON'T use "reset all adaptation channels" in Basic Settings in VCDS- that's a definite no no)
    You have already made "a copy of the coding in the RLS". On a mk7 Golf, the light sensor is what VCDS calls a SLAVE of the BCM (the sensor uses a LIN wire to talk to the BCM - but yes, that's probably too much information) If you look in your autoscan in the section for the hex09 module, you will find the following:
       Coding: 90A8DD
    which is a convenient segue into my question - have you changed the coding on this module? I ask because Bits 3-5 of Byte 0 determine the "Light activation threshold". On my earlier model mk7 ( my unit is HW 5Q0 955 547 - not HW 5Q0 955 547 A as in your car), the factory setting for Byte 0 was hex00 - as you can see your value is hex90 (or binary 1001 0000), which suggests that light sensor on your car has +40% earlier threshold.
    As for your question about any possible impact from updating to the current Hex series cables - I don't believe that this is the cause of your problem.
    Finally, some later version BCMs have a channel called MAS08228-ENG133443-Light sensor-Tunnel_einschalt_verzoegerung. Mr Google-translate purports this to mean MAS08228-ENG133443-Light sensor-Tunnel switch-on delay and my A3 Audi (which shares the same MQB build platform as the mk7) has the setting 2 - this probably means 2 seconds, I guess. Might be prudent to check this value on your car
  8. Likes Uwe, PetrolDave liked this post
    Nov 2018
    Thanks Don, Yes MAS08228-ENG133443-Light sensor-Tunnel switch-on delay in my car is set to 2, I did change this to 1 and the lights do switch on quicker, it wasn’t what I was looking for so see it back to 2, and yes the car is set to 40% earlier threshold when I look in the long coding helper, however as you know this can be set via the infotainment so I thought that is why it displayed 40% (matching the early infotainment setting), I now see that the value doesn’t change in VCDS when mid or late is selected on the headunit, I’ll check the auto scan I took when I bought the car and see if I changed it at some point (just checked and the coding hasn’t changed from 90A8DD)! However I now believe the ‘tunnel_gateway_recognize’ adaptation I originally asked about is actually the switch off delay, I’d still like to change it back to 5seconds so will have to keep trying, as for the factory reset, I won’t be doing that as I was already under the impression it was a no no,
  10. #8
    Dec 2016
    DE
    Try changing the value in the Engineering Session. I had a very similar problem with a friends car a few weeks ago.
  11. #9
    May 2018
    Czech Republic
    I must confrim this issue too! Suddenly missing all RLS channels as non available, on my Passat b8 BCM! Before updating on version 19.6.1., these channels were normaly usuable. Already sent on ross-tech suport as debug. Some bug here??
  12. #10
    Nov 2018
    Ok, so I’ve been able to change it back to 5 seconds, I had to use the S12345 security access code, I’ve no idea why I didn’t try it previously!? Didn’t cross my mind as I’d used 31347 previously I guess, so there we go, it was simple in the end, thanks for your replies and thoughts guys ��.
  13. Likes Uwe liked this post
