Results 1 to 5 of 5
Thread: LONG CODE HELPER - Cent. Elect, ABS Brakes, Engine,CAN Gateway,Central Conv.
Hybrid View
    Jun 2019
    California, USA
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 65 72
    VIN: 3VWRZ71K99M0XXXXX   Mileage:126384 miles
    Address 01: Engine (CBU)       Labels: 07K-906-055-CBT.clb
       Part No SW: 07K 906 055 M    HW: 07K 906 055 M
       Component: 2,5l R5/4V      G   9203
       Revision: G6H02---    Serial number: VWX7Z0HN2431AD
       Coding: 0000075
       Shop #: WSC 00066 000 00000
       VCID: 38292B354E583907329-806C
    000819 - Knock Sensor 2 (G66)
                   P0333 - 000 - Signal too High - Intermittent
                        Mileage: 200677 km
                        Time: 19:24:25
                        RPM: 1902 /min
                        Load: 67.8 %
                        Speed: 90.0 km/h
                        Temperature: 87.0C
                        Temperature: 36.0C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 14.097 V
       Part No SW: 09G 927 750 JE    HW: 09G 927 750 JE
       Component: AQ 250 6F           1377
       Revision: 00H76000    Serial number:
       Coding: 0000072
       VCID: 7DA7FA2121FADC2FA1F-8028
       Part No SW: 1K0 907 379 AN    HW: 1K0 907 379 AN
       Component: ESP MK60EC1   H45 0107
       Revision: 00H45001
       Coding: 113B400D492A0000880E02E6921E00413000
       Shop #: WSC 36555 002 104857
       VCID: 7EA5FD2D20FCC737B85-802A
       Part No SW: 1K0 820 047 JM    HW: 1K0 820 047 JM
       Component: Climatic PQ35   142 1212
       Revision: 00142032    Serial number: 00000000000000
       VCID: 78A9EB350ED8F907F29-802C
    Address 09: Cent. Elect.        Labels:. 3C0-937-049-30-M.lbl
       Part No SW: 3C8 937 049 D    HW: 3C8 937 049 D
       Revision: 00H54000    Serial number: 00000001126957
       Coding: 14058E234004100007140000001400000008730B5C000120000000000000
       Shop #: WSC 00066 123 12345
       VCID: 323D191DA824D3570CD-8066
       Component: Wischer 111108 021  0501
       Coding: 00038805
       Shop #: WSC 00066
       Part No SW: 8E0 035 593 M    HW: 8E0 035 593 M
       Component: SDAR SIRIUS     H07 0150
       Revision: 00000000    Serial number: AUZ4Z7H0474413
       Coding: 0000100
       VCID: 33331C19573EDA5F07B-8066
                        Fault Frequency: 9
                        Reset counter: 57
                        Mileage: 200012 km
                        Time: 23:05:21
       Component: 6A AIRBAG VW8R  034 8000
       Revision: 05034000    Serial number: 003B6M07MLDJ
       Coding: 0013889
       VCID: 6C81C7654A8045A7061-8038
       Subsystem 1 - Part No: 1K0 959 339 H
       Component: BF-Gewichtsens. 007 0006
       Subsystem 2 - Serial number: 6332MSME41145001U
       Subsystem 3 - Serial number: 6342MSME3F645540E
       Subsystem 4 - Serial number: 6351HSME184928504
       Subsystem 5 - Serial number: 6361HSME184970478
       Subsystem 6 - Serial number: 63727SME19085068/
       Subsystem 7 - Serial number: 63827SME19084108Z
       Part No SW: 1K0 953 549 BR    HW: 1K0 953 549 BR
       Component: J0527           051 0101
       Coding: 0010021
       VCID: 03538CD9471EAADFD7B-8056
    00576 - Terminal 15
    00885 - Ignition Switch (D) Terminal 50
       Part No SW: 1K0 920 954 S    HW: 1K0 920 954 S
       Component: KOMBIINSTRUMENT 3HL 1222
       Revision: V0003000    Serial number: VWX7Z0HN2431AD
       Coding: 0023203
       VCID: 3C2137257A601527D61-8068
       Component: J533  Gateway   H07 5063
       Revision:   H07 01    Serial number: 220908F2000138
       Coding: ED807F070003021002
       Shop #: WSC 11111 123 12345
       VCID: 35372201594AC46F29F-8060
       Component: IMMO            3HL 1222
       Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
       Component: J386  TUER-SG FT    1519
       Revision: 72009005    Serial number: 00000766589028
       Coding: 0001205
       VCID: 6FBBD0697B96BEBF233-803A
                008 - Implausible Signal
                        Fault Status: 01101000
                        Reset counter: 110
                        Mileage: 190135 km
                        Reset counter: 150
                        Mileage: 190135 km
       Part No: 1K0 909 144 C
       Component: EPS_ZFLS Kl. 70     2301
       Revision: 00H15000
       Shop #: WSC 02069 000 90108
       VCID: 2A0D017D80F49B97B4D-807E
                        Reset counter: 116
                        Mileage: 200179 km
                        Time: 12:16:37
                        Voltage: 11.75 V
                            DU
                        Temperature: 46.0C
                        RPM: 1498 /min
    00750 - Warning Lamp
                        Fault Status: 00101101
                        Reset counter: 50
                        Mileage: 200179 km
                        Time: 12:16:44
                        Voltage: 11.63 V
                            DU
                        Temperature: 46.0C
       Component:    KSG PQ35 RDK 052 0221
       Coding: 13900F880186281B0904058FB0880F0488DCA0
       VCID: 04518FC54210ADE7EE1-8050
       Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
       Component: J387  TUER-SG BT    1519
       Revision: 72009005    Serial number: 08100814090904
       Coding: 0001204
       VCID: 70B9D31566A8A1473A9-8024
       Part No SW: 6RD 035 187 B    HW: 6RD 035 187 B
       Component: MIB2-S-R-CN   036 0317
       Revision: -----001    Serial number: VWZ6Z2R7301947
       Coding: 1600040004000A
       Shop #: WSC 00081 790 00120
       VCID: 46D555CD38AC5FF7B05-8012
    7 Faults Found:
    00856 - Radio Antenna
                        Fault Status: 00100111
                        Reset counter: 57
                        Mileage: 191377 km
                        Time: 07:30:31
    00532 - Supply Voltage B+
                        Reset counter: 45
                        Mileage: 15 km
                        Date: 2003.14.26
                        Time: 05:20:26
                        Reset counter: 45
                        Mileage: 14 km
                        Date: 2003.14.26
                        Time: 08:20:45
    00877 - Treble Speaker Rear Right (R16)
                        Fault Status: 00101011
                        Reset counter: 35
                        Mileage: 2 km
                        Date: 2000.14.00
                        Time: 02:16:09
    00876 - Treble Speaker Rear Left (R14)
                        Reset counter: 35
                        Mileage: 2 km
                        Date: 2000.14.00
                        Time: 02:16:09
    00875 - Treble Speaker Front Right (R22)
                        Reset counter: 35
                        Mileage: 2 km
                        Date: 2000.14.00
                        Time: 02:16:09
    00874 - Treble Speaker Front Left (R20)
                        Reset counter: 35
                        Mileage: 2 km
                        Date: 2000.14.00
                        Time: 02:16:09
       Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T
       Component: J388   TUER-SG HL   1401
       Revision: 12006001    Serial number: 00000003626568
       Coding: 0001168
       VCID: 76B5E50D04CC8F77E05-8022
       Component:    RDK              0450
       Coding: 0100101
                        Fault Status: 00110100
                        Reset counter: 150
                        Mileage: 200953 km
                        Time: 15:11:53
    01487 - System Function Test
                        Fault Status: 01110101
                        Mileage: 200953 km
                        Time: 15:12:21
       Part No SW: 1K0 959 704 AH    HW: 1K0 959 794 T
       Component: J389   TUER-SG HR   1401
       Revision: 12006001    Serial number: 00000003588487
       Coding: 0001168
       VCID: 77ABE80903C6F67FFB3-8022
    End----------(Elapsed Time: 01:45, VBatt start/end: 12.4V/12.4V)-----------
    Hello All,
    By any chance does anyone know the long code for the following modules (2009 VW JETTA SE/SEL PZEV):
    Cent. Elect [09]
    ABS Brakes [03]
    Engine [01]
    CAN Gateway [19]
    Central Conv. [46]
    I forgot to save my default codes before adjusting various modules.
    - SoCalJR
    Hello All,
    Cent. Elect [09]
    ABS Brakes [03]
    Engine [01]
    CAN Gateway [19]
    Central Conv. [46]
    JPPSG NO SOUP!
    Go search scans of the net and compare attributes, additionally, without VIN number & in some cases, codes can't be generated unless in EOLE 83 mode to find the short string as displayed of existing attributes as set.
    God loves backups........
    SVM
    Sounds like you should be in tweaks or retrofits huh?
    You are FOD & INDUCED FOD!
    "Give before it hurts!"
    Jun 2019
    California, USA
    JPPSG NO SOUP!
    SVM
    So you need the full VIN Number to get this information?
    - SoCalJR
    Go to dealer............SVM
    Quote Originally Posted by jdreid View Post
    See: CodingLog and AdpLog, little safety nets for you.
  6. Likes Jack@European_Parts, jdreid liked this post
