Results 1 to 8 of 8
Thread: Seat Arosa 1.0 2004
    May 2018
    Seat Arosa 1.0 2004
    Hi, my daughters car came up with engine management light today, she said the car seems to be running ok, no loss of power, no different sounds or anything else, she cant say if it is using more fuel (she is constantly out in the car) The codes seem to all be related to sensors, is it worth trying to replace maf etc or can anyone suggest any troubleshooting that i can do to rule out any other causes? only used code reader for basic checks before now. Hopefully posted correct info below. Thanks Louise
    Monday,19,August,2019,18:35:53:12359
    VIN: VSSZZZ6HZ4R016356   License Plate:
    Chassis Type: 6H (6H - Seat Arosa (1997 > 2004))
    Scan: 01 02 03 08 15 17 19 25 35 56
    VIN: VSSZZZ6HZ4R016356   Mileage: 167660km-104179miles
       Part No: 030 906 032 DJ
       Component: ME7.5.10            4693
       Coding: 00001
       Shop #: WSC 06441
       VCID: 55F77C9E9C1252DFC9F-51CE
       VSSZZZ6HZ4R016356     VWZ1Z0D2673740
    17573 - Long Term Fuel Trim Additive Air; Bank 1; Range 1
                P1165 - 35-00 - System too Rich
    17560 - Long Term Fuel Trim Additive Air; Bank 1; Range 2
                P1152 - 35-10 - System too Lean - Intermittent
       Part No: 1C0 909 601
       Component: 06 AIRBAG VW51      0008
       Coding: 12342
       Shop #: WSC 06441
       VCID: 5DE764BEE4228A9F81F-4B5C
                32-10 - Resistance Too High - Intermittent
    Address 17: Instruments        Labels: 6X0-920-xxx-17.lbl
       Part No: 6H0 920 900
       Component: KOMBIINSTRUMENT RB8 V02
       Coding: 00441
       Shop #: WSC 01005
       VCID: 629D5742DD5CB567BCD-5184
    Address 25: Immobilizer        Labels: 6X0-953-257.lbl
       Part No: 6X0 953 257
       Component: IMMO                0008
       Coding: 00001
       VCID: 7DA7043E44E26A9FA1F-4B1E
    Address 35: Centr. Locks        Labels: 1C0-962-258-III.lbl
       Part No: 1C0 962 258 AB
       Component: 2S Zentr.Verriegel. 0004
       Coding: 00017
       Shop #: WSC 06441
       VCID: 678B4656367ED04F6B3-4B3C
    End----(Elapsed Time: 02:00, VBatt start/end: 12.1V/13.7V. VIgn 0.0V)------
    What do you have in MVB 032?
    May 2018
    -3.4 first block then 16.4, although I will do this again after work today now I understand a little more.
    http://wiki.ross-tech.com/wiki/index...0/P1152/004434
    Hmmmm when both codes appear either MAF, fuel regulation or a loose damaged, ground cable, intake boot & maybe as a result of being unsecured broken/worn engine mount!
    May 2018
    Certainly gives me enough to look at...I will check 032 and 032 again when I get home later..many thank for your response.
    May 2018
    so i checked the readings again : 032 -4.0% 15.6% & 033 -1.6% 1.560v do these readings point in any one direction?
    Yeah ...........did you check the mechanical's?
  9. #8
    May 2018
    Will check as much as I can at the weekend...i have managed to get engine diagrams - sensor placements etc so will go through your suggestions..thanks again.
