Results 1 to 10 of 10
Thread: Steering inoperative - Red steering wheel
    Aug 2019
    Greetings
    I have a 2007 Rabbit (golf) with a power steering rack issue. The dash shows the “Red steering wheel” indicator. Actually turning of the steering is next to impossible. My initial VCDS scan is enclosed below.
    I replaced the rack with a junkyard part, however now the dash light is a “Yellow steering wheel” indicator.
    Scan results from OEM Part and Junkyard part below. It appears they are not similar HW and SW versions… I am wondering if I might be able to replace the electronic components off the OEM rack onto the junkyard rack. Is it possible that doing so would allow for normal operation? I am grateful to the forum users to help me resolve this issue.
    https://i.imgur.com/jJEsc2m.jpg
    https://i.imgur.com/SVtu2NZ.jpg
    --OEM Part--
          Part No: 1K1 909 144 L
          Component: EPS_ZFLS Kl.069 H07 1806
          Shop #: WSC 00000 028 00001
          VCID: 34311CC4123A43D71E1-8060
       00003 - Control Module
                   007 - Short to Ground - MIL ON
    --Junkyard part--
          Part No: 1K1 909 144 M
          Component: EPS_ZFLS Kl.074 H08 1901
          VCID: 353721C019405ADF29F-8060
       02546 - Steering Limit Stop
                        Mileage: 208640 km
                        Temperature: 32.0°C
                        Voltage: 11.90 V
                        Voltage: 11.70 V
    Initial full scan
    Wednesday,07,August,2019,15:46:42:04807
    VIN: WVWAS71K27W238334   License Plate:
    Chassis Type: 1K (1K0)
    VIN: WVWAS71K27W238334   Mileage: 208640km-129642miles
    Address 01: Engine        Labels: 06A-906-032-BGP.lbl
       Part No SW: 07K 906 032 R    HW: 07K 906 032 Q
       Component: 2.5l R5/4V      G   9651
       Revision: --H01---    Serial number: VWZ7Z0G7062252
       Shop #: WSC 01279 785 00200
       VCID: 382928F40E52A7B7329-806C
    Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
       Part No: 1K0 907 379 P
       Component: ASR FRONT MK70      0105
       Coding: 0017025
       VCID: 3FDB43E82B7C908FF33-806A
       Part No SW: 1K0 820 047 GF    HW: 1K0 820 047 GF
       Component: Climatic PQ35   141 0909
       Revision: 00141027    Serial number: 00000000000000
       VCID: 6E85CEAC3C962907285-803A
    Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-M.lbl
       Part No SW: 3C0 937 049 AD    HW: 3C0 937 049 AD
       Component: Bordnetz-SG     H52 2002
       Revision: 00H52000    Serial number: 00000006871937
       Coding: 108D0F214004150047140000001400000008730B5C0001
       Shop #: WSC 08112 444 54565
       VCID: 6B83C7B80F84DC2F0FB-803E
       Component: Wischer 160307 020  0501
       Coding: 00038805
       Shop #: WSC 08112
       Component: 5L AIRBAG VW8R  034 8000
       Revision: 05034000    Serial number: 003B6D08AGAY
       Coding: 0013644
       Shop #: WSC 01269 785 00200
       VCID: 6C81C4A40A8ADB17061-8038
       Subsystem 1 - Part No: 1K0 959 339 G
       Component: BF-Gewichtsens. 007 0007
       Subsystem 2 - Serial number: 6332MSME1720211C/
       Subsystem 3 - Serial number: 6342MSME17326D004
       Subsystem 4 - Serial number: 6352QSME21304C5FJ
       Subsystem 5 - Serial number: 6362QSME236C2063C
       Subsystem 6 - Serial number: 63727SME0C451430W
       Subsystem 7 - Serial number: 63827SME0C450F4DE
       Part No SW: 1K0 953 549 AF    HW: 1K0 953 549 AF
       Component: Lenksäulenmodul 636 0070
       Coding: 0000022
       VCID: 76B5E6CC44C611C7E05-8022
       Part No SW: 1K0 920 953 P    HW: 1K0 920 953 P
       Component: KOMBIINSTRUMENT VDD 1610
       Revision: V0003000    Serial number: VWZ7Z0G7062252
       Coding: 0007207
       Shop #: WSC 08207 444 53375
       Part No SW: 1K0 907 530 K    HW: 1K0 907 951
       Component: J533__Gateway   H04 0021
       Revision:   H04 02    Serial number: 180307F1001883
       Coding: 3D0F034007000000
       VCID: 2F3B13A8FB1C600F633-807A
                        Reset counter: 254
                        Mileage: 82090 km
                        Time: 04:27:11
       Component: IMMO            VDD 1610
       Shop #: WSC 06401 444 53999
    01176 - Key
       Component: Tuer-SG         005 0983
       Coding: 0001077
    00109 - Left Mirror Turn Signal Lamp (L131)
    Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 CM
       Coding: 93C803281B09058F880A048050CC
       Shop #: WSC 00000 785 00200
       VCID: 7DA7F9E061F0429FA1F-8028
       Coding: 0001076
       VCID: 392F2DF03558BEBFCD7-806C
    00936 - Electric Window Switch in Front Passenger Door (E107).
    Address 56: Radio
    End----(Elapsed Time: 00:52, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
    Since the original problem was electrical in nature, why would you want to swap electrical components now?
    Is 1K1-909-144-M a suitable replacement for 1K1-909-144-L?
    We need a FOD check in this aisle, please.
    Indeed checking.........
    Vehicle Identification No. WVWAS71K27W238334
    Model Rabbit 2.5
    GO
    Date of production 02.04.2007
    Model year 2007
    Sales type 1K15R1
    Engine Code BGQ
    Transmission Code JCT
    Better check the harness & fuses, no?
    I show M & AJ reused for of from legacy..............
    PART NUMBER DESCRIPTION REMARK MODEL
    1K1 423 055 M or MX steering gear Generation 3
    lhd
    1K1 971 111 AJ
    3
    GO
    Special editions E0A Without special action equipment
    Lockable wheel bolts 1PC Wheel bolts with anti-theft protection (unlockable)
    Vehicle class differentiation units/platform components 0HA Vehicle class differentiation -1K0-
    tail pipe 0P1 Rear side exhaust tailpipe
    drive-off assistance UG0 Without hill start assist/hill descent control/comfort driving assist
    Emission standard 0GT Emission standard SULEV
    Trailer hitch 1D0 without trailer towing
    airbag 4UM Driver's and front passenger air bag, NAR with front passenger air bag deactivation (2-stage) - SMART airbag with automatic deactivation
    Aktivkohlebehälter / Ottopartikelfilter 1E7 Activated carbon canister (ORVR), for intensified evaporation system, siphoning device for fueling
    Aerials 8ZM Antenna
    Exterior mirror setting 6XN Exterior mirrors, power-adjustable/ separately heated
    Left exterior mirror 5SH Left exterior mirror, flat (US)
    Right exterior mirror 5RR Right exterior mirror, convex (US)
    Drive type 1X0 Front-wheel drive
    "Multimedia"video/DVD/notebook connection 9WL Jack for external audio source
    Equipment levels A8X US comfort equipment
    Brake type in rear 1KE Disc brakes in rear
    batteries J1L Battery 280 A (60 Ah)
    Brake type, front 1ZP Disc brakes in front (Geomet D)
    Components with special surface 6FF Exterior mirror housing and various attachments colour coded to vehicle
    Battery/alternator capacity NY0 Standard battery/alternator capacity
    Component part sets with country-specific design requirements B0D Assembly kit, USA corresponding vehicle version (not California), various parts
    vehicle tools and jack 1S1 vehicle tools and jack
    Brake systems 1AC Anti-lock brake system (ABS)
    Owner's manuals 0VM Information kit in American English
    Operating voltage 9Z0 Operating voltage 12 V
    brake wear indicator 9U1 brake wear indicator
    Heated washer nozzles 9T0 Without heated washer nozzles
    CD ROM/DVD/SD card 7QA Without CD/DVD for navigation
    CD changer/CD player 7A0 Without CD changer/CD player
    Chrome package QJ0 Without aluminum/chrome work package
    General operating permit, alterations C18 Operating permit, alteration
    Roof rails/roof load rack 3S0 Without roof rails/roof load rack
    Roof insert/convertible top 3FA roof without cut out
    Suspension system in rear 1JA Rear shock absorption, basic design 1
    Suspension system in front G07 Shock absorption in front
    Load-through hatch/ski bag 3X0 without load through system
    Insert for the filling up of unleaded fuel/fuel type 2G7 Filler neck module 1 with insert
    Installation differentiation for components 0EJ Installation differentiation for transmission MQ 250 -- vehicle components --
    Theft protection system 7AG Electronic immobilizer with anti-theft alarm system (for USA)
    Inserts 5MJ Decorative inserts
    Scuff plates 7M5 Without impact protection film for door sill
    Park distance control 7X0 Without park distance control
    Electric interface for external use UF0 Without electric interface
    Manufacturing sequence differentiation 0FA Standard manufacturing sequence
    window regulator 4R4 Power windows with comfort operation and circuit breaker
    fire extinguisher 6A0 without fire extinguisher
    Pedestrian protection VL0 Without extended pedestrian protection measures
    Pedal cluster VF0 Standard pedal cluster
    Headlight activation 8K4 Separate daytime running lights NAR
    Alternators 8GU Alternator 140 A
    Weight category rear axle 0YC Weight range 3 installation control only, no requirement forecast
    Weight category front axle L07 Suspension range 07 installation control only, no requirement forecast
    Base engine T8K 5-cylinder SI engine 2.5 l unit 07K.1
    Luggage netting/pocket on backrest(s) 4U0 Without luggage nets/pockets on backrests
    Luggage compartment cover 3U1 Folding trunk cover
    cruise control system 8T2 Electronic cruise control system (CCS)
    Garage door opener VC0 without Garage door opener
    Luggage compartment trim 5A7 Comfort luggage compartment trim with service lid/snap-on cover
    Transmission specifications G0C 5-speed manual transmission
    Brackets 3P0 Without bracket for first aid kit and warning triangle
    handle for hand brake lever 6PA Hand brake lever handle in plastic
    Rear spoiler 5J0 Without rear spoiler
    Rear window wiper and washer system 8M1 Rear window wiper washer system with intermittent wipe
    Rear seats 3NZ Rear bench seat, not split, split backrest, folding
    Heating and air-conditioning system 9AP Climatic air-conditioning system (semi-automatic)
    Headlamps 8ES Twin headlamps for driving on the right, with integrated high beam (US design)
    Customized installation FC0 Without individual installation
    Interior light in footwell 6T0 Without interior light in footwell
    Instrument clusters U5C Instrument cluster, mph speedometer - USA -
    Breakaway interior rearview mirror 4L2 Breakaway interior rearview mirror, dimming
    Sticker (customized or special edition) 0KA Without decals and emblems
    Body style K8G Hatchback
    Cassette and CD storage unit 4W0 without cassette / CD tray
    coolbox 1W2 Glove compartment cooling system
    Electronic map cooling system QS0 Without electronic map cooling system
    Child seats QA0 without child seat
    Climatic zones 0Y2 Tropical zones
    Compass/road sign display QR0 Without compass
    headrest for seat, rear 3T2 Three rear head restraints
    Head restraints 5ZF Front head restraints
    Fuel tank treatment 2LF Fuel tank with special material treatment (coextrusion) with changed protective layer
    Fuel quantity for initial filling 1Z2 Increase in initial standard fuel filling
    Fuel systems 1A1 Fuel system for fuel-injected SI engine, injection system without fuel return
    Body measures 5C1 Body measures for increased safety requirements
    Child seat anchors in front 3G0 Without child seat anchora in front (ISOFIX)
    Rear license plate bracket 6P2 License plate bracket, rear (NAR)
    Front license plate bracket 6W3 License plate bracket front (small, NAR)
    Paint preservative/transit coating 5K0 Without surface protection, with additional transit coating
    Paint coating FB0 standard paint coating
    Rear cargo area 3GA Without luggage compartment floor
    Steering system arrangement L0L Left-hand drive
    Reading lamp 8S4 Two reading lights front, two rear
    steering 1N3 Speed-related variable steering assist (Servotronic)
    Backrest release 3H9 Backrest release for front seats with Easy Entry feature
    Air duct, front area VK1 Air duct, type 1
    Load edge protection 2P1 Plastic loading edge protection
    Lumbar support 7P0 Without lumbar support in seat backrests
    steering wheels 1ME Steering wheel
    Speaker installation 8RW 10 speakers (passive)
    Headlight range control 8Q0 without beam length regulator
    Center armrest 6E0 Without center armrest in front
    Multi-function display/trip computer 9Q0 Without multi-function display/ trip computer
    Engine cooling 8Z6 Hot country
    Engine specifications D4F 5-cylinder SI engine 2.5 l/110 kW (20V) (R-5) base engine is T8K/TQ7
    Left vanity mirror 4SH Left vanity mirror illuminated with cover and special mirror imprint (NAR), extractable
    Right vanity mirror 4TH Vanity mirror, right, illuminated, with cover and special mirror imprint (NAR), extractable
    Navigation device 7Q0 without navigation system
    rear fog lamp 8TA witout rear fog lamp
    Front fog lamp/additional headlamp 8WA Without fog lights
    Rear of platform module base 4P0 Rear floor panel module, type 1
    Platform group class 7PA Platform group class 1
    Hubcaps 1NL Trims for alloy wheels
    Wheels CM6 Alloy wheels 6.5J x 16
    Radios 8UF Radio with CD drive (double DIN)
    Smoker's/non-smoker's package 9JA Non smoker version
    Tire pressure monitoring system 7K0 Without tyre pressure monitor
    tire H4B All-season tires 205/55 R16 H (NAR)
    Tire suppliers V0A Tires without specification of tire brand
    Spare wheel/breakdown kit 1G2 Spare wheel with full tyre, steel
    Restraint systems, front 4QQ 3-point seat belts in front with pretensioner and height adjustment, US label
    P2S Golf 16-inch alloy wheel package
    PMC Emissions concept for California
    Side airbag 4X3 Side airbag in front, with curtain airbag
    Gearshift knob/handle 6Q1 Gearshift knob/handle in plastic
    Special labels/plates 0SS Labels in English and French
    Locking mechanism for boot lid/cover rear 4E2 Tailgate/trunk lid release from inside (electrically)
    Front seat, left 3TB Standard seat in front, left
    Front seat, right 3SB Standard seat in front, right
    Nameplates for sales name QD0 Without lettering for sales name
    Seat belt check 9P7 Visual and acoustic seat belt reminder, electric contact in buckle
    Outer rear seat belts 3ZD 3-point seat belts, outer rear with US label
    Center rear seat belts 3C8 3-point seat belt, center rear with US label
    seat covers N4C Seat trim covers in fabric
    Seat adjustment 3L1 Manual height adjustment for left front seat
    seat heater 4A0 without seat heater
    Safety head restraint system 3K0 w/o safety head restraint system
    Side lights 7R4 Side marker lamps and turn signal repeaters (turn signals with white lens)
    Horns 8Y1 Two-tone horn
    Side and rear windows 4KC Side and rear windows in heat-insulating glass
    Protective side molding 4B1 Protective side molding
    Sunroof roller blind for rear/side windows 3Y0 without roller blind
    Supertone system and tone sequence control 9J0 Without supertone system and tone sequence control
    power outlet 7B2 12 volt socket in luggage compartment
    Bumper 2JB Standard bumpers
    Rear stabilizer 0BD Rear stabilizer
    Front stabilizer bar 0AD Front stabilizer bar
    Drawers under front seats QN0 Without drawers under front seats
    Heavy-duty/sports version 2UA Standard design
    Headlamp washer system 8X0 Without headlamp washer system
    Windshield wiper intermittent control/ light/rain sensor 8N4 Windshield wiper intermittent control with potentiometer (four speeds)
    Nameplate set 0NV Nameplate set "2.5"
    Special alarm systems 9A0 Without taxi alarm system
    Door storage compartments in front 3YR Door pockets with insert mats
    Mass damper for steering wheels 1Q0 steering wheel without balance weight
    Door and lid locking system 4K0 Central locking w/ radio remote control and interior controls
    Type approval countries/countries with special requirements B38 Legal requirements California
    Carrier frequency for remote control 5D2 Carrier frequency 315 MHz
    Partition 3CA without partition
    Door and side trim panels 4AF Door and side trim panel in foam film and woven fabric
    doors 0A1 2 doors
    TV reception/digital radio reception QV0 without TV/digital radio reception
    Identification plates 1EB without identification plate
    Delivery equipment 2A8 Delivery equipment, water border
    First aid kit / warning triangle 1T0 Without first-aid material, without warning triangle
    Two-way radio installation preparation 9D0 without prepared for two way radio system
    Preparation for rotating beacon/siren combination 9F0 Without preparation for rotating beacon/siren combination
    Telephone / telematics 9W0 Without car phone preparation/ installation
    Additional warning lights 9TC Additional retro-reflectors (door area)
    LongLife Service Regime QG0 without service interval extension
    Heat accumulator system/auxiliary heater 7E0 W/o heat accumulator/auxiliary heating
    Windshield Glass 4GF Windshield in heat-insulating glass
    Washer fluid level indicator 8W1 Washer fluid level indicator
    Additional tires (snow tires) 2WA without spare tyre
    floor mats 0TA without floor mats
    Additional body panels, side 6EA Without additional side body covers (stone guard)
    Additional child seat anchors 3B7 Child seat anchors as per Canadian requirements a. ISOFIX child seat system
    Auxiliary heating system 9M0 Without auxiliary heater/parking heater
  4. Likes Uwe liked this post
    Jul 2014
    Tallinn, Estonia
    If the new rack is already in, why not carry out the well-known basic setting for it? It's likely the rack would work then. Ideally, also upload the correct characteristic curve to the rack beforehand.
    Aug 2019
    Thank you for replies and general wisdom.
    Does FOD mean foreign object damage?
    I replaced the harness when swapping out the rack. The fuses test good.
    What is the right direction. Do I find a re-builder who can repair my rack? Can the junkyard rack be flashed to work correctly?
    I was not completely certain that there is an electrical issue. the steering is surely bound up.
    Aug 2019
    Silc can you further explain the process.
    Different hardware & power class no?
    Installing the correct part is always advised no? ............. FOD
  9. #8
    Jul 2014
    Tallinn, Estonia
    Quote Originally Posted by Colleen DeMenna View Post
    http://wiki.ross-tech.com/wiki/index...teering_Assist
  10. Likes Uwe liked this post
  11. #9
    Aug 2019
    Just wanted to conclude this thread, that the junk yard rack, once installed, once the Steering Angle Sensor was reset, the dash lamp went out and performs properly.
    The only note I would add is the the Steering Angle Sensor reset has to be done on the ground. Whereas it would not calibrate up on the lift...
    Thank you all for sharing your wisdom and time.
  12. Likes Jack@European_Parts, Uwe liked this post
  13. #10
    Nice what great retrofit..........
