Results 1 to 8 of 8
Thread: Caddy 2K 2018 engine coding calculate
    Verified VCDS User AurimasFr's Avatar
    Jan 2018
    Lithuania
    some one know, ho to calculate engine coding in caddy 2018 year? Ho to calculate abs i found, but information about engine no.
    I need recode from RHD to LHD.
    Magdeburg, Germany
    Start posting an Auto-Scan from the vehicle in question.
    Jan 2018
    Lithuania
    Monday,19,August,2019,17:13:25:06635
    VIN: WV2ZZZ2KZJX088724   License Plate: CADDY
    Mileage: 950km-590mi   Repair Order:
    Chassis Type: 2K-VN35 (7N0)
    Scan: 01 02 03 08 09 10 13 15 16 17 18 19 25 42 44 46 4C 52 61
    VIN: WV2ZZZ2KZJX088724   Mileage: 950km-590miles
    Address 01: Engine (J623-DFSD)       Labels: None
       Part No SW: 04L 906 016 MJ    HW: 04L 907 309 K
       Component: R4 2.0l TDI   H20 4092
       Revision: 8AH20---
       Coding: 011D0012042415090000
       Shop #: WSC 12345 123 61029
       ASAM Dataset: EV_ECM20TDI01104L906016MJ 001001
       ROD: EV_ECM20TDI01104L906016GR_004.rod
       VCID: 7DA7FB2CED70F05FA1F-8028
    17158 - Implausible Data Received from ESP Control Module
              U0416 00 [039] - -
                        Mileage: 959 km
                        Time: 00:00:00
                        Coolant temperature: 34 °C
                        Intake air temperature: 33 °C
                        Voltage terminal 30: 14.220 V
                        Drivetrain coordinator: brake fault status-Bits 0-7: 4
                        Drivetrain coordinator: brake function status-Bits 0-7: 32
                        Acceleration: 0.000 m/s²
       Part No SW: 02E 300 066 M    HW: 02E 927 770 AT
       Component: GSG DSG AG6     541 5201
       Revision: 06454104    Serial number: 00001712090499
       Shop #: WSC 35110 377 00147
       VCID: 2313ED5427D466AFF7B-8076
    Address 03: ABS Brakes (J104)       Labels: 7E0-907-37x-MK100ESC.clb
       Part No SW: 7E0 907 379 P    HW: 7E0 907 379 M
       Component: ESC           H06 0133
       Revision: 00000000    Serial number: 60048000001086
       Coding: 1079409B936AA486087C0278C986259378F100
       VCID: 3FDB4124A7FC224FF33-806A
    8252 - Databus
              U1122 00 [137] - Implausible Message
              [ACAN: SY1_Lenker signal coding missmatch]
                        Reset counter: 204
                        Mileage: 959 km
                        Date: 2019.08.19
                        Time: 02:07:43
       Part No SW: 1K8 907 044 AE    HW: 1K8 907 044 AE
       Component: Climatronic   H05 0304
       Revision: 00001K03
       Coding: 001000C003
       ROD: EV_ClimaAutoBasis_VW32.rod
       VCID: 72BDD810A42EBF27CCD-8026
    7 Faults Found:
    9471765 - Temperature Sensor for Left Vent
              B1087 15 [009] - Open or Short to Plus
                        Reset counter: 204
                        Mileage: 959 km
                        Date: 2019.08.19
                        Time: 02:07:34
    9472021 - Temperature Sensor for Right Vent
              B1088 15 [009] - Open or Short to Plus
                        Reset counter: 204
                        Mileage: 959 km
                        Date: 2019.08.19
                        Time: 02:07:34
    9481748 - High Pressure Sensor
              B10AE 14 [009] - Open or Short to Ground
                        Reset counter: 204
                        Mileage: 959 km
                        Date: 2019.08.19
                        Time: 02:07:34
    9480469 - Control Circuit for A/C Compressor
              B10A9 15 [009] - Open or Short to Plus
                        Reset counter: 204
                        Mileage: 959 km
                        Date: 2019.08.19
                        Time: 02:07:36
    9496597 - Sunlight Photo Sensor
              B10E8 15 [009] - Open or Short to Plus
                        Reset counter: 204
                        Mileage: 959 km
                        Date: 2019.08.19
                        Time: 02:07:34
    9496613 - Sunlight Photo Sensor
                        Reset counter: 204
                        Mileage: 959 km
                        Date: 2019.08.19
                        Time: 02:07:34
    9478421 - Diagnostic Line for Front Air Blower
              B10A1 15 [008] - Open or Short to Plus
                        Reset counter: 244
                        Mileage: 959 km
                        Date: 2019.08.19
                        Time: 02:07:38
       Part No SW: 5K0 937 086 AA    HW: 5K0 937 086 AA
       Component: BCM PQ35 M+   122 0186
       Revision: BD122001
       Coding: 491A0A3E8825E12D00080083940009CC03D5000842CD8320E48487040041
       VCID: 73B3DD14DBB4B62FC7B-8026
       Subsystem 1 - Part No: 7N0 951 172
       Component: Sensor, DWA 0  005 0502
       Subsystem 2 - Part No: 1K0 951 605 F
       Component: LIN BACKUP HO  H01 0008
       Part No SW: 1K8 919 465 A    HW: 5Q0 919 283
       Component: PARKHILFE 4K  H10 0480
       Revision: --------    Serial number: 39261805103033
       Coding: 0000050011
       Shop #: WSC 12345 123 12345
       ASAM Dataset: EV_EPHVA14VW364GP00 001007
       ROD: EV_EPHVA14VW364GP00_VW36.rod
       VCID: 372B29048FCC1A0F3B3-8062
       Part No SW: 7N0 907 572 C    HW: 7N0 907 572
       Component: ACC Bosch PQx H03 0211
       Serial number: 3012170438A191
       Coding: 00009000FE0339
       ASAM Dataset: EV_ACCBEGVW361 001006
       ROD: EV_ACCBEGVW361_VW32.rod
       VCID: 3635240088C6E307205-8062
    1058 - Databus
              [FAULT_CIS_ECD_NOTAVAILABLE]
                        Reset counter: 204
                        Mileage: 958 km
                        Date: 2019.08.19
                        Time: 13:43:28
                        Control Module temperature: 37 °C
                        Voltage terminal 15: 13.3 V
                        Vehicle speed: 0.00 m/s
                        Acceleration: 0.00 m/s²
    1059 - Databus
              [FAULT_CIS_ESP_FAIL]
                        Reset counter: 204
                        Mileage: 958 km
                        Date: 2019.08.19
                        Time: 13:43:28
    1037 - Databus
              [FAULT_CIS_QDCACC_FAIL]
                        Reset counter: 204
                        Mileage: 958 km
                        Date: 2019.08.19
                        Time: 13:43:28
       Part No SW: 2K5 959 655 C    HW: 2K5 959 655 C
       Component: VW10Airbag00K H08 0018
       Revision: --------    Serial number: 003V2004E86P
       Coding: 00000000000000000000000000000000304B
       Shop #: WSC 35110 790 50316
       VCID: 3C213628B6EA3957D61-8068
       Serial number: 3497ARB400A59AHCKJ8D
       Serial number: 3507ARB400259AHDABAP
       Serial number: 3517ARB4059535RI9PKM
       Serial number: 3527ARB405J535RIQ9IW
       Part No SW: 5K0 953 521 FG    HW: 5K0 953 569 BC
       Component: LENKS.MODUL   018 0230
       Revision: FF010042    Serial number: 20180104300417
       Coding: 1882460008
       ASAM Dataset: EV_SMLSNGVOLWSR8C 001001
       ROD: EV_SMLSNGVOLWSR8C.rod
       VCID: 76B5E400C846A307E05-8022
       Subsystem 1 - Part No SW: 2K0 959 442     HW: 2K0 959 442   Labels: 3C8-959-537.CLB
       Serial number: 0021820173200980BA1B
       Coding: 280000
       Part No SW: 2K5 920 866 C    HW: 2K5 920 866 C
       Component: KOMBI         H04 1107
       Coding: 1102011200
       VCID: 34311E089EBAF1171E1-8060
    13654544 - Databus
              [Steuergerät für Telefon keine Kommunikation]
                        Reset counter: 204
                        Mileage: 958 km
                        Date: 2019.08.19
                        Time: 13:43:28
    Address 18: Aux. Heat        Labels: 1K0-815-007.clb
       Part No: 7N0 963 272 E
       Component: Standheizer     044 4941
       Revision: 00044000    Serial number: 09028239000000
       Coding: 0031032
       Shop #: WSC 35110 377 00182
       VCID: 372B2904834C1A0F3B3-8062
       Part No SW: 7N0 907 530 BL    HW: 7N0 907 530 AN
       Component: J533  Gateway H56 1682
       Revision:   H56       Serial number: 030118F1001674
       Coding: 357421
       VCID: 7BA3F534F3E4FE6F9FB-802E
       Component: IMMO          H04 1107
       VCID: 6A8DC0708CFE77E774D-803E
       Part No SW: 2K5 959 701     HW: 2K5 959 701
       Component: Tuer-SG         009 2144
       Coding: 0133168
       Shop #: WSC 11111 111 45799
       VCID: 71BFD71CADA8843F357-8024
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 140    3501
       Revision: 00H22000
       Shop #: WSC 00046 000 00000
       VCID: 392F2F3CB5580C7FCD7-806C
       Part No SW: 2K5 959 702     HW: 2K5 959 702
       Coding: 0132144
       VCID: 72BDD810A8AEBF27CCD-8026
       Part No SW: 7N0 907 534     HW: 7N0 907 530 AN
       Component: Batt.regelung H56 1682
       Coding: 030F7873
       VCID: 71BFD71CA1A8843F357-8024
       Subsystem 1 - Part No SW: 2K0 915 181     HW: 2K0 915 181
       Serial number: 75885800001801080C6D
    End----------(Elapsed Time: 01:07, VBatt start/end: 14.3V/14.3V)-----------
  4. Likes Uwe liked this post
    Nov 2014
    New Zealand
    I would get the 03 ABS operating correctly, before bothering with the engine coding.
    Allan
    The R32ran Thread
    How to post a full Auto-Scan
    Jan 2019
    Quote Originally Posted by AurimasFr View Post
    Your ABS Coding is right for LHD.
    Normly you need to change in Engine Coding Byte 6 Bit 0 from 1 to 0. for change RHD to LHD
    Byte 6 ==> 0x24 but in your Scan this is already the case
    No clue
    Magdeburg, Germany
    The coding table should display properly with the next VCDS data version/update, however as written by others, you should address the issues in #03 first. That said, feel free to enlighten us what exactly happened to this car in the first place. That may help you getting some directions as to an actual fix...
    Jun 2014
    Quote Originally Posted by Sebastian View Post
    code ABS at first might reject it as VIN is RHD , and steering rack too
    Anyway - in GW you also have RHD coding ,
  9. #8
    Jan 2018
    Lithuania
    Hi
    thank you for help. I have miss code gateway. Faults from 01 and 03 gone. 01 is 04L not 03L, vcds dont have soufflers for this engine. How to know or byte 6 bit 0 is for rhd coding? Becouse, before GW coding, I code 01 byte 5 bit 5 and fault disapear from 01. Maybe here is rhd coding. When I recode GW, I recode 01 back and dont have faults. But still, i need recode 01 from rhd to lhd. Question is or byte 6 bit 0 is for rhd coding or byte 5 bit 5.
    Thanks for your time
