Results 1 to 10 of 19
Thread: 2009 Jetta S ABS ESP lights on Brake light flashing
    Aug 2019
    2009 Jetta S MT daily driver with 150,000 miles. ABS, ESP dash lights are lit, brake light flashes with warning tones after startup. Only complaint prior to these warning lights was the rear two tires lose air in about 24hrs, sometimes the left rear, sometime the right, sometimes both. This is my first time using VCDS and I was hoping that it was a wheel sensor or something easy or more obvious causing it. So far I've checked fuses, visual inspection of ABS module and pulled all four wheels and inspected.
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 65 72
    VIN: 3VWHM71K89M073088   Mileage: 247090km-153534miles
    Address 01: Engine (CBT)       Labels: 07K-906-055-CBT.clb
       Part No SW: 07K 906 055 Q    HW: 07K 906 055 M
       Component: 2,5l R5/4V      G   9971
       Revision: G6H02---    Serial number: VWX7Z0H924K0V7
       Coding: 0000071
       Shop #: WSC 35064 000 1048576
       VCID: 3C2134803A6CD667D61-8068
       Part No SW: 1K0 907 379 CD    HW: 1K0 907 379 AD
       Component: ESP MK60EC1   H35 0120
       Revision: 00H35001
       Coding: 113B400D492900FD880B02EC922100413000
       Shop #: WSC 50897 001 1048576
       VCID: 76B5E6A848C04C37E05-8022
    01130 - ABS Operation
                        Reset counter: 12
                        Mileage: 246307 km
                        Count: 32768
                        Count: 4608
                        Count: 125
                        Count: 51241
                        Count: 65275
       Part No SW: 1K0 820 047 JM    HW: 1K0 820 047 JM
       Component: Climatic PQ35   142 1212
       Revision: 00142032    Serial number: 00000000000000
       VCID: 78A9E8904ED43A47F29-802C
       Revision: 00H54000    Serial number: 00000001114734
       Coding: 14058E234004150007140000001400000008730B5C000120000000000000
       VCID: 323D1AB8E82810170CD-8066
       Component: Wischer 100908 021  0501
       Coding: 00038805
       Shop #: WSC 00066
    01117 - Generator Terminal DF Load Signal
                        Reset counter: 75
                        Mileage: 247026 km
                        Voltage: 12.00 V
       Revision: 05034000    Serial number: 003B6M07ATBD
       Coding: 0013889
       VCID: 6C81C4C00A8C86E7061-8038
       Subsystem 2 - Serial number: 6332MSME3F447760H
       Subsystem 3 - Serial number: 6342MSME3F0506168
       Subsystem 4 - Serial number: 6351HSME18381F65E
       Subsystem 5 - Serial number: 6361HSME18381621+
       Subsystem 6 - Serial number: 63727SME18574B286
       Subsystem 7 - Serial number: 63827SME18580D2FD
       Part No SW: 1K0 953 549 BR    HW: 1K0 953 549 BR
       Coding: 0000021
       VCID: 03538F7C0712699FD7B-8056
    00576 - Terminal 15
    00884 - Ignition Switch (D) Terminal X
    01744 - Ignition Switch Terminal P (D)
    00885 - Ignition Switch (D) Terminal 50
       Part No SW: 1K0 920 954 S    HW: 1K0 920 954 S
       Component: KOMBIINSTRUMENT 3HL 1222
       Revision: V0003000    Serial number: VWX7Z0H924K0V7
       Coding: 0023203
       Shop #: WSC 23317 444 84045
       Component: J533  Gateway   H07 5063
       Revision:   H07 01    Serial number: 060908F1000925
       Coding: E9807F070002021002
       VCID: 353721A41946072F29F-8060
       Component: IMMO            3HL 1222
       Revision: 72009005    Serial number: 00000518388927
       Coding: 0001205
       VCID: 6FBBD3CC3B9A7DFF233-803A
                        Fault Status: 00101100
                        Reset counter: 75
                        Reset counter: 35
                        Mileage: 216212 km
    00105 - Signal Central Locking SAVE/LOCK Drivers Side
                        Reset counter: 75
                        Mileage: 236753 km
       Part No: 1K0 909 144 C
       Component: EPS_ZFLS Kl. 69     2301
       Revision: 00H15000
       VCID: 2A0D02D8C0F858D7B4D-807E
       Coding: 13900F880186281B0904058FB0880F0488DCA0
       VCID: 04518C60021C6EA7EE1-8050
       Revision: 72009005    Serial number: 08091912163601
       Coding: 0001204
       VCID: 70B9D0B026A462073A9-8024
    Address 56: Radio        Labels: 1K0-035-161.lbl
       Part No SW: 1K0 035 161 D    HW: 1K0 035 161 D
       Component: Radio DE2       018 0021
       Revision: 00018000    Serial number: VWZ4Z7H6385115
       Coding: 0040401
       VCID: 2019E0F0B6C49287EA9-8074
       Revision: 12006001    Serial number: 00000003519038
       Coding: 0001168
       VCID: 76B5E6A844C04C37E05-8022
                        Reset counter: 75
                        Mileage: 216182 km
                        Reset counter: 35
                        Mileage: 216182 km
       Coding: 0100101
       Revision: 12006001    Serial number: 00000003524961
       Coding: 0001168
       VCID: 77ABEBAC43CA353FFB3-8022
                        Reset counter: 75
                        Mileage: 216341 km
                        Fault Frequency: 62
                        Reset counter: 35
                        Mileage: 216341 km
    End----------(Elapsed Time: 01:25, VBatt start/end: 12.4V/12.4V)-----------
    I'll be happy when this is fixed so I can finally repair the random unlocked door(s). Thanks in advance.
    Hello and welcome to the VCDS forum OP.
    http://wiki.ross-tech.com/wiki/index.php/01130
    Has your car had any recall campaigns done recently or work operations for this problem, because your car appears to have been altered with update programming of the ABS module?
    https://vinrcl.safercar.gov/vin/vinLookup
    Year: 2009 Make: VW Model: JETTA 2.5 S MANUAL
    Number of Open Recalls: 0
    Additional Safety Information
    Besides the VIN search tool you just used, NHTSA offers additional safety information based on a vehicle's make, model, and model year and not tied to any particular VIN. A search by vehicle make, model, and model year gives you access to information about technical service bulletins, NHTSA investigations, and owner complaints, as well as safety recalls on aftermarket equipment that is often not linked to a particular VIN or even to your vehicle's manufacturer.
    To search NHTSA's safety information based on your vehicle's make, model, and model year, please go to the Safety Issues section opens new window and follow the instructions there.
    Recall information for this manufacturer is only available going back to August 19, 2004. If your vehicle was manufactured before this date, please contact the manufacturer for possible additional recall information.
    You might enjoy this thread, no?
    https://forums.ross-tech.com/showthr...de-not-working
    Did you JPPSG?
    Ever consider if OEM fails to rectify this free or to your expectations, that reporting it helps everyone, since a widespread pattern seems to exist?
    https://www-odi.nhtsa.dot.gov/VehicleComplaint/
  3. Likes Uwe liked this post
    Aug 2019
    Great Questions
    Did you JPPSG?
    I took the car in a couple of years ago to the dealership for a recall if I remember right. Last work that was done was back in March/April replaced the original battery (very dead) and both cooling fans to solve an overheat-A/C problem. (I had taken the car in for service at a VW Dealership in Bavaria they could not replicate the overheating problem from the one hot day in Bavaria but figured it was probably a bad thermostat, once we got thru the language barrier that is. It wasn't a bad thermostat. And they didn't have VWoA code readers or were familiar with 2.5L engine problems. I will say I was super impressed with the service.)
    I saw the JPPSG and the other ABS threads before when I was shopping for VCDS. Found the wiki index and 01130 so I started there, but the Bentley manual glosses over the ABS system at least for me.
    Thanks for the reminder, Ill start JPPSG.
    Aug 2019
    I got a chance to dig back into the ABS but I could use some help deciphering what I'm reading. So I understand Fault code 01130, found the Wiki support and suggested fixes. I ran thru the ABS module test with the "press brake pedal' prompts as it goes thru the four wheels. That test was good, so I went back looking for wiring problems. The 01130 fault comes back after reset as soon as you drive away.
    Question for the Group: What is this freeze frame info trying to tell me?
    Reset counter: 93
    Mileage: 249836 km
    Count: 4608
    Count: 125
    Count: 48399
    Count: 62703
    Did you report this problem to NHTSA yet & ask if VAG would own it?
    Feb 2015
    Quote Originally Posted by SamV View Post
    Reset counter: 93
    Mileage: 249836 km
    Count: 4608
    Count: 125
    Count: 48399
    Count: 62703
    So you took this car in for the ABS control module software update.......... I take it they did not replace the ABS module at that time correct?? If so you now have one of the two DTC that VW looks for to then replace the module after the software update or at a later time if it comes up with the correct freeze frame data in line 4 which you now have.
    "NOTE
     Fault 01130 MUST have 125 shown in the 4th line
    of the Expanded ambient conditions to qualify for
    ABS module replacement and/or fault 16352
    MUST have 96 shown in the 4th line of the
    Expanded ambient conditions to qualify for ABS
    module replacement."
    Stop playing with it and go to dealer for free replacement.
  8. Likes Jack@European_Parts, Uwe liked this post
    About time someone asked questions with continuity huh?
  10. #8
    Aug 2019
    Problem has been reported to NHTSA. I really need to find where the wife put the last recall paperwork
  11. #9
    Aug 2019
    Quote Originally Posted by MVB View Post
    "NOTE
    That sounds correct, software update didn't replace the ABS. I'll check my paperwork.
    Best explanation I've heard. It's above my paygrade.
  12. Likes Jack@European_Parts liked this post
  13. #10
    Is it warrantied under campaign yet for free?
